Remote Install - Detroit DDDL, DDDE, Backdoor, DDEC, Manuals, EPC, Checksum Updater
Remote Install - Detroit Diesel Diagnostic Link DDDL, DDDE, Backdoor, DDEC, Manuals, EPC, Checksum Updater, Magic Tuner Flash Tool
Detroit Diesel Diagnostic Link DDDL 8.19 Full (Level 10 10 10) +Troubleshooting / Programming (with kg locked 1 PC) - $1379
Detroit Diesel Diagnostic Link DDDL 8.19 2024 (Level 10 10 10) + 06.2023 Troubleshooting / Programming - $135
Detroit Diesel Diagnostic Link DDDL 8.19 (only activation) - $99
DDDL 8.09 - $99
Detroit Diesel Diagnostic Link DDDL 8.13 SP3 (Level 10-10-10) MAX Edition + Backdoor - $135
This DDDL kit allow to increase the odometer value. This can only be done on those СPC software versions where it is possible to increase the odometer by regular way (i.e. ""Actions - Set Odometer"" menu is available)
Program for diagnostics and firmware Detroit Diesel engines
Magic Tuner Flash Tool 3.0 (for Detroit, Maxxforce, Paccar, Caterpillar) - $145
Magic Tuner Flash Tool 2.1 (for Detroit, Maxxforce, Paccar, Caterpillar) (with kg locked for 1 PC) - $465
Magic Tuner Flash Tool 2.1 (for Detroit, Maxxforce, Paccar, Caterpillar) - $115
This tool can flash the ECU through the diagnostic connector so as not to remove the ECU, not to open, but simply flash them with a binary (*.bin) using any adapter, for example, Nexiq.
Works for:
Detroit DD15 DPF, EGR, SCR Performance Tuning Files - $165
Files for delete parameters, manual transmission. There are 3 files for that work. These deletes are for units from 2010 to 2013.
Detroit DD13 DPF, EGR, SCR Performance Tuning Files - $165
Detroit DDEC IV - V Tuning files - $165
List of files.
Detroit DD15/S60 DPF EGR SCR Delete files - $165
Detroit Calibration Files - $99
Calibration Files Collection.
Detroit Diesel Calibration Tool DDCT 4.5 - $75
The DDC Cal Tool provides a programmable software interface to the Electronic Control Module (ECM) in an engine. Using the DDC Cal Tool, you can:
Detroit Diesel Reprogramming System DDRS 7.11 - 75
Detroit Diesel Reprogramming System DDRS is a diagnostic program that is designed to schedule Detroit Diesel engines. It contains all data diagnostics and programming operations for all Detroit Diesel diesel engines. The main feature of it is that the application is an electronic tool for servicing the engine family EPA07, EPA10, GHG14 equipped with engines (S-60, MBE4000, MBE900, DD13, DD15, DD16).
Detroit Diesel Drumroll Engineering DDDE - $39
Detroit Diesel Drumroll Engineering (DDDE) is a diagnostic software that includes:
Detroit Backdoor - $75
It is needed to unlock all the parameters.
Detroit DDEC Reports 9.03 - $115
Detroit DDEC Reports 9.01 - $35
DDEC Reports is a fleet management application that includes support for Detroit engine controllers: DDEC 3-5 ECU, VCU, CPC2, CPC02T, CPC04T, CPC302T, and CPC501T.
Detroit Diesel 60 Series Service Manual - $65
Detroit Diesel ECU Checksum Updater - $207
It's a tool that updates the checksum of the ECU's specification files when we modify them. When you modify the file, you just have to drag it to the application and that's it. Otherwise, the DDDL will give you an error.
Detroit Diesel MBE 4000 EPC Spare Parts catalog - $102
The MBE 900 with an electronic engine management system is offered in both four and six-cylinder models, the 904 and 906. It is ideal for use in many different medium-duty truck applications including food service, beverage, towing, recreational vehicle, refuse, general delivery, fire & emergency, utility, dump, transit bus, and school bus. The MBE 900 with an electronic engine management system is offered in both four and six-cylinder models, the 904 and 906. It is ideal for use in many different medium-duty truck applications including food service, beverage, towing, recreational vehicle, refuse, general delivery, fire & emergency, utility, dump, transit bus, and school bus.
Detroit Diesel Power Service Literature Off-Highway - $85
Detroit Diesel Wiring Diagrams - $117
Detroit Diesel All Series Service Manual - $185
Detroit Full Set Shop Manual - $225
Contains: Workshop Manual, Repair Manual, Wiring Schematic, Service Bulletins, Parts Catalog
Need it? Write to me for details.
DDDL 8.09 - $99
Works for:
- Detroit MCM (EPA7, EPA10, GHG14, GHG17), ACM (EPA7, EPA10, GHG14, GHG17)
- Maxxforce (EDC17, EDC7, EIM7, S3V8, S4I6, S4I6Special, NECM2, IDM2, S8V8)
- Paccar
- Caterpillar CAT AG
List of files.
- View and edit the control parameters in the ECM to optimize the control logic
- View instrumentation variables, such as rpm or fluid temperatures and pressures, while the engine is running.
- View information about connected computers
- Performing Standard DTC Operations
- Performing standard and advanced troubleshooting methods
- Reading the value of variables in real-time and their graphical display
- Configure and manage settings
- Performing service procedures.
- Diagnostic Softwares + Activations + Special Files
- Activation Launch x431 EasyDiag Golo + ThinkDiag + Autel AP200 + 1 time/1 year
- Volvo PTT v2.05.55 + DEVTOOL (APCI+) Ultimate + 2.05 KG
- Deutz-Fahr SDF e-parts and e-doc 2014
- Tech Tool 2.04.55 Development (APCI+) Developer Tool + MATRIS 2
- CNH EST 8.7 ( Engineering Level)+Activator+unexpire+Diagnostic Procedures + keymaker
- BMW ISTA-D Rheingold 4.24.30 - Torrent
- Piwis 3 ver 37.2 - 40.0 for Vas6154 clone and PT3G, Piwis 2, Porsche PET
- CNH EST 8.6 +activator+ keymaker Engineering ,Dealer
- MTU DiaSys 2.70 (Windows 7 supported) dont need usb dongle
- PF-Diagnose v3.5
- Perkins SPI and EST 2015 KG
- Detroit Diesel Backdoor Passwords Generator 2017
- Isuzu E-IDSS/G-IDSS KG
