Remote Install - Cummins Insite, Calterm, QuickServe, Incal, Inpower, PowerSpec
Remote Install - Cummins Insite, Calterm, QuickServe, Incal, Inpower, PowerSpec, Wiring Diagram
Cummins Insite 8.7 Pro level + Fleet calibration + Zapit Password (with kg) - $599
Cummins Insite 8.7 Pro level + Fleet calibration + Zapit Password - $125
Cummins Insite 8.6 Pro level + Fleet calibration + Zapit Password - $75
Cummins Insite 8.5.2 Basic - $49
Fix v3 for Cummins insite 8.7.086 Zapit for unlock ECM - $199
The functionality Cummins:
Cummins CalDL - $649
The tool for downloading incal files. it works independently of the Insite. If there is a problem in the mismatch between the date and the Insite program, you need to install Fix v2
Cummins Calterm 5.8 + MetaFiles (with kg) - $795
Cummins Calterm 5.11 + MetaFiles - $155
Cummins Calterm 5.2 + MetaFiles - $75
Cummins Calterm 4.7 + MetaFiles - $55
Cummins Calterm 3.6 + MetaFiles - $40
Cummins Calterm Deletes ECFG's base of metafiles - $199
List of files
Cummins Calterm 50Gb base of meta and delete files ECFG, E2M 2022 - $265
The program for the diagnosis of Cummins engines. Calterm is an engineering development tool used to monitor Electronic Control Modules for Cummins engine systems and to alter the calibration data contained therein. Calterm is designed to modify fueling calibration parameters and feature settings in engineering development and test environment.
List of files
Cummins Insite 8.8.1, Calterm 5.8, Etool Holset, Jammer, Nemesis (with updates for 1 year) - $650
Works like original activation.
Cummings ISX CM2250 15L DPF, EGR, SCR Delete - $185
Included bootloader/ECFG file for configuration, complete stock file, and complete performance DPF, EGR, SCR delete.
Cummings CM2250 12L DPF, EGR, SCR Delete - $185
Cummings ISLe 8.9 CM2150 Euro 4.5 Adblue Off - $45
Cummings ISX CM870 EGR Delete - $79
Cummings CM2250 CPL 3491 484hp Non Vgt - $59
Cummings CM2250 CPL 3491 600hp Non Vgt 25000TQ - $59
Cummings ECFG CM871 DPF Delete - $79
Cummings ECFG CM871 EGR Delete - $79
Cummings ISB CM850 EGR Delete EC2 - $79
Cummings ISX CM2350 DPF Delete - $79
Cummins QuickServe Online 1 Year Subscription - $1550
Cummins QuickServe Online 1 Month Subscription - $330
Cummins QuickServe Online 1 Week Subscription - $85
These subscriptions offers following:
Cummins QuickServe 2017 - $75
QuickServe DVD - Power Generation Edition - Cummins ONAN 2017 spare parts catalog, service manuals, installation manuals, operator manuals, owner manuals, standard repair times, PDF.
Cummins INCAL + configure it in Insite - $45
Calibration files for Cummins engines.
Cummins Incal to Cal converter - $25
Software for converting any Incal Calibration to Calterm format. Good for practicing using Calterm.
Cummins InCal iMod Manager - $45
Utility to modify calibration files for outdated INCAL! You can change the expiration date for every calibration file. iNCAL M0d will notify if there's a problem with your files, or the wrong password to edit. iNCAL M0d is Full compatible with Insite 8 INCAL Files.
Cummins Incal unpacker, repacker, date changer - $79
UnPack Incal files, WorkOrders files. RePack Incal. Change Incal date.
Cummins Full Manuals All Models - $165
Cummins Inpower Pro 14 - $165
Cummins Inpower Pro 11.5 - $55
InPower provides the following functions for monitored equipment:
Cummins InPower Pro 14 (with kg) - $1070
Cummins Incal Tool 7.0 - $175
Cummins Incal Tool 6.0 - $155
Fix v3 for Cummins Incal - $85
Cummins PowerSpec 9.1 - $315
Cummins PowerSpec 8 - $299
Cummins PowerSpec 6.1.1 2016 - $199
Cummins PowerSpec is an electronic tool that makes it possible to tailor the operation of Cummins engines in every on-highway engine application.
PowerSpec full functionality is available to support all Cummins 2013 On-Highway engine products (ISX15, ISX12, ISL9, and ISB6.7), 2010 engine products (ISX15, ISX12, ISL9, ISC8.3, and ISB6.7), 2007 products (ISX, ISM, ISL, ISC, ISB), some of the Natural Gas products (ISL G and ISX12 G) and earlier products. Features include a gearing calculator, complete descriptions of electronic features, instructions on how to optimize parameter settings, and access to trip information and fault code data. It also supports fault codes and trip information on Euro 3/4.5/5, ISBe, N14+, M11+ CELECT Plus engines. Another functionality is not available for the Euro 3/4.5/5, ISBe, Celect Plus engines.
Cummins Technician Training - $135
What inside
Cummins Wiring Diagram - $99
Cummins Comercial Marine Diesel Engine Wiring Diagram - $99
Video course Cummins QuickServe Online for beginners - $55
What inside:
How to create a FREE Cummins QuickServe Online account
What the difference between a free and a paid account is
Analysis of the different sections and the information they contain
How to read Cummins wiring diagrams for your selected engine
How to use the Operation and Maintenance manual
What inside
Cummins Heavy Duty Engines + Midrange Trainings - $199
What inside
Cummins CM2250 DPF NOX Delete + Video - $99
Need it? Write to me for details.[/b]
- Reading, decoding, and resetting DTC diagnostic trouble codes.
- Reading and displaying parameters on a PC screen from ECU sensors in real-time.
- Testing and activation of actuators.
- Adaptation functions.
- Programming electronic control units.
- Reset service intervals and more.
List of files
List of files
- Electronic Service Manuals
- Parts Catalogs
- Wiring Diagrams
- Serial Numbers - Unlimited
- Direct connection capability from a personal computer to PowerCommand genset controls, transfer controls, and system controls; For details on devices supported refer Technical Details tab.
- Connection to generator set or transfer switch controls via modem or to multiple controls.
- Allows the monitored equipment to send alarm information to a connected computer.
- Configurable for units of measurement, and level of user access (read-only, read/change values, administrator).
- Adjustment of nearly every adjustment parameter within the connected control system, including parameters such as voltage and frequency levels, gains, protection set-points, other values.
- others.
What inside
What inside:
What inside
What inside
- Activation Launch x431 EasyDiag Golo + ThinkDiag + Autel AP200 + 1 time/1 year
- CNH EST 8.7 ( Engineering Level) Diagnostic Procedures
- Piwis 3 ver 37.2 - 40.0 for Vas6154 clone and PT3G, Piwis 2, Porsche PET
- MTU DiaSys 2.70 (Windows 7 supported) dont need usb dongle
- Activation keys ODIS Service, Engineering
- Remote Install - Porsche Piwis II Piwis III, PET2, POSES, WDS
- Video step-by-step tutorials for delete EGR/DPF/DEF/UREA/SCR Cummins volvo cat detroit
- iDecoder 4.5 - for VIN/PIN, DPF/DTC/IMMO Off
- Remote install - Mercedes-Benz - Xentry DAS XUS SCN Vediamo Monaco WIS EPC
- Remote Install - Volvo Premium Tech Tool (PTT) + DevTool, EWD, Impact, Prosis, VIDA
- Cummins Insite 8 Activation - KG
- Remote Install VAG - ODIS-E, ODIS-S, VAS PC, ETKA, ELSA
- Remote install - GM Opel LAAM, GMIO, GMNA, GDS2, GlobalTis32, Tech2win, TIS 2000
- Cummins Insite 8 + Activation
- Remote install - PSA Peugeot Citroen - DiagBox, Service Box, LASER, Sedre
