7,392
Raymond Pallet Truck 111 to 114XD Maintenance Manual PDMM-0088
Brand: Raymond
Type of Machine: Pallet Truck
Type of Manual: Maintenance Manual, Electrical Schematic
Model: Raymond Models 111, 111XD, 112, 112XD, 113, 113XD, 114, 114XD Pallet Truck
Serial Number: 41000 and up
Part Number: PDMM-0088
Publication Date: 2002
Number of Pages: 307 Pages
Page Revision Record
How To Use This Manual
Map Of The Manual
Manual Design
Start Page
Safety
Definitions
General Safety
Battery Safety
Jacking Safety
Tie-Down For Transport
Towing
Welding Safety
Systems Overview
Truck Model Identification
Vehicle Specifications
Maximum Speeds
General System Data
Special Tools
Theory Of Operation
Scheduled Maintenance
Maintenance Guidelines
Daily
Every Two Months Or 250 Operating Hours
Annually Or Every 1500 Operating Hours
Grease Fittings
Troubleshooting
How To Use This Chapter
Electrical Troubleshooting Guidelines
Hydraulic Troubleshooting Guidelines
Definitions
Electrical Connector Locator Chart
Fault Codes
Programmable Maintenance Tool
List Of Troubleshooting Charts/Tables
Troubleshooting Flowcharts
Symptom Tables: Lift/Lower System
Symptom Tables: Travel (Forward/Reverse) System
Symptom Tables: Wiring System
Component Procedures
List Of Component Procedures
Component Locator Photos
Tractor Cover
Battery
Power Cables
Wiring Harness
Fuses
Switches (General)
Control Handle Switches
Key Switch
Brake (Deadman) Switch
Lift-Limit Switch
Lift Cutout Switch
Grab Rail Switches
Load Backrest Switches
Coast Module (Da1)
Hydraulic Solenoids
Coastpro™ Solenoid
Manual Coast
Manual Coast
Gauges
Control Handle
Horn
Motor Controller
Contactors
Brake
Motors, General
Drive Motor
Drive Unit
Drive Wheel
Casters (Torsion)
Casters (Spring-Loaded)
Load Wheels
Pallet Entry Sliders
Fork Height Adjustment
Hydraulic Components
Hydraulic Fluid
Adjusting Hydraulic Pump Relief Valve Pressure
Hydraulic Ram
Hydraulic Unit
Lift Motor
Cold Storage Conditioning
Appendix
Lubrication Equivalency Chart
Torque Chart - Standard (Ferrous)
Torque Chart - Standard (Brass)
Torque Chart - Metric
Decimal Equivalent Chart
Standard/Metric Conversions
Schematics
Index
Rsis
Updated Torque Check Procedures
Forged Pull Rod Ends
Updated Fork Linkage Parts
Key Switch Retention
Lift Limit Switch Actuator
Improved Relief Valve Spring
Converting Speed Limited Model 112 To Standard Speed
Tight Slewing Bearing
New Throttle Potentiometer Bracket
