118
6,911
Raymond Pallet Truck 111 112 113 114 Maintenance Instructions PDMM-0073
Brand: Raymond
Type of Machine: Pallet Truck
Type of Manual: Maintenance Instructions, Electrical Schematic
Model: Raymond 111, 112, 113, 114 Pallet Truck
Serial Number: 99-25000 and up
Part Number: PDMM-0073
Publication Date: 2000
Number of Pages: 342 Pages
Chapter 1. How to Use This Manual
Map of the Manual
Page Revision Record
Table of Contents
Start Page
Chapter 2. Safety
Definitions
General Safety
Battery Safety
Static Safety
Jacking Safety
Tie-down for Transport
Towing
Welding Safety
Chapter 3. Systems Overview
Truck Model Identification
Vehicle Specifications
Maximum Speeds
General System Data
Special Tools
Theory of Operation
Chapter 4. Scheduled Maintenance
Maintenance Guidelines
Daily
Every Two Months or 250 Operating Hours
Annually or Every 1500 Operating Hours
Grease Fittings
Chapter 5. Troubleshooting
How to Use This Chapter
Electrical Troubleshooting Guidelines
Hydraulic Troubleshooting Guidelines
Definitions
Electrical Connector Locator Chart
Fault Codes
Programmable Maintenance Tool
List of Troubleshooting Charts
Troubleshooting Flowcharts
Chapter 6. Component Procedures
List of Component Procedures
Component Locator Photos
Tractor Cover
Battery
Power Cables
Wiring Hamess
Diodes
Fuses
Switches (General)
Control Handle Switches
Key Switch
Brake (Deadman) Switch
Lift Limit Switch
Grab Rail Switches
Coast Module (DA1)
Hydraulic Solenoids
Auto Coast Solenoid
Manual Coast
Gauges
Control Handle
Hom
Motor Controller
Contactors
Brake
Motors, General
Drive Motor
Drive Unit
Drive Wheel
Casters
Load Wheels
Pallet Entry Wheels
Fork Height Adjustment
Hydraulic Components
Hydraulic Fluid
Adjusting Hydraulic Pump Relief Valve Pressure
Hydraulic Ram
Hydraulic Unit
Lift Motor
Cold Storage Conditioning
Chapter 7. Appendix
Lubrication Equivalency Chart
Torque Chart - Standard
Torque Chart - Metric
Decimal Equivalent Chart
Standard/Metric Conversions
Schematics
Index
RSIs
Converting Speed Limited Model 112 to Standard Speed
Tractor Frame Reinforcement
Plastic Insulating Washers
Lift Cylinder Pivot Pin
Poly Torsion Caster
New coast interlock Model
Noticeable Play in Drive Unit
Handle Pivot Shaft
Improved Ergonomics
Roll Pin in Front Fork Trail Pivot Shaft
Improvements to the drive motor for 6K/8K Millennium Series
Improvements to the motor controller for increased control
Cracking of the Coast Support Casting
Lift ram pivot pins too short
Failure of coil suppressor for the lowering solenoid
Auto Coast Improvements
Pallet Entry Rollers
