118
6,911
Raymond Pallet Truck 101T-F40L Maintenance Instructions PDMM-0034
Brand: Raymond
Type of Machine: Pallet Truck
Type of Manual: Maintenance Instructions
Model: Raymond 101T-F40L Pallet Truck
Serial Number: 101-93-03351 and up
Part Number: PDMM-0034
Publication Date: 1994
Number of Pages: 137 Pages
General Maintenance Instructions
Maintenance Practices
Specifications
Hydraulic
Component Identification
Standard Torque Data For Bolts
Conversion Table
Decimal Equivalent Chart
Planned Maintenance (PM)
lnspection Form
PM Schedule and Procedure
Daily lnspedion
Monthly PM Service (or 100 Hrs.)
Semi Annual Service (or 500 Hrs.)
Annual PM Service (or 1000 Hrs.)
Lubrication Points
Fill Points
Scheduled Maintenance
Batteries
Motors
Power Section
Special Tools
Control Head Unit
Load Wheel
Pull Rod Bushings Removal and Replacement
Carrier Frame Linkage and Bushings
Drive Wheel
Drive Unit
Drive Motor
Controller Assembly
Battery
Replacement
Wiring Hookup
Brake
Brake Adjustment
Brake Interlock Switch
Brake Linkage Removal
Brake Linkage Installation
Brake Shoe Removal and Installation
Lift/Lower
Description
Theory of Operation
Electrical
Lower
Equipment Recommended for Normal Servicing
Pump and Motor
Installing the Reservoir
Check Valve
Cylinder Assembly Removal/Installation
Lift Limit Switch
Troubleshooting
Traction System
Transistor Control (Motor Controller)
Traction System Adjustments
Adjustment Panel
Theory
Contactor Tip/Bar Replacement
Troubleshooting
Troubleshooting
Wiring Inspection Procedure
Battery Charger
Battery Charts
Overview
Description
Low Current
High Current
Adjustment Panel
Power Wiring
Control Wiring
0-5kΩ Throttle ("Type 3")
Initial Check
Programming and Adjustments
Programming
Manual Adjustments
Current Limit Setting
Plug Current Adjustment
Acceleration Adjustment
Maintenance
Safety
Cleaning
Diagnostic History
Diagnostics and Troubleshooting
LED Diagnostics
Programmer Diagnostics
Programmer Operation
Operating Modes
Peace-of-mind Programming
Programmer Self Test
Programmer Menus
Diagnostics and Special Diagnostics "Menu"
Hydraulic Schematic
Electrical Schematic
Specifications
Glossary
