Raymond Pallet Truck 101 Operation and Maintenance Instructions PDMM-0025
Brand: Raymond
Type of Machine: Pallet Truck
Type of Manual: Operation Instructions, Maintenance Instructions
Model: Raymond Walkie 101 Pallet Truck
Serial Number: 101-91-01302 and up
Part Number: PDMM-0025
Publication Date: 1992
Number of Pages: 82 Pages
Safety
Owner Safe Maintenance Practices
Safety Decals
Planned Maintenance (PM)
Inspection Form
PM Schedule and Procedure
Daily Inspection
Monthly PM Service (or 250 Hrs.)
Semi-Annual PM Service (or 1000 Hrs.)
Annual PM Service (or 2000 Hrs)
Planned Maintenance Schedule
Schematics
Hydraulic Schematic
Electrical Schematic
Electrical Symbols
Specifications
Brake
Lift Limit Switch
Transmission Pivot Bearing Adjustment
Load Wheel Shimming
Theory of Operation
Adjustment
Brake Interlock Switch
Special Tools
Flush Grease Fitting Adaptor
Battery-Pak Lifter
Bearing Installation Tool
Load Wheel
Repair and Replacement
Pull Rod Bushings Removal and Replacement
Carrier Frame
Linkage and Bushings
Drive Wheel
Removal
Installation
Control Handle
Removal and Installation
Head Unit Removal
Master Control Switch Removal
Head Unit Disassembly
Control Handle Removal
Brake
Linkage Removal
Brake Shoe Removal and Installation
Contactor Tip/Bar Replacement
Removal
Installation
Axle Seal Removal
Disassembly
Assembly
Pump and Motor
Pump Motor Brush Removal
Drive Motor
Removal
Installation
Brush Removal
General
Pump Assembly Operation
Equipment Recommended for Normal Servicing
Hydraulic Pump Repair
Relief Valve
Solenoid Operated Release Valve
Removing and Installing Reservoir and Pump
Installing the Pump
Installing the Reservoir
Check Valve
Hydraulic Cylinder
Assembly Removal Installation
Removal
Assembly Removal and Repair Assembly
Disassembly
Installation
Inspection
Theory of Operation
Lift Mode
Lowering Mode
Travel
First Speed Forward
Second Speed Forward
Third Speed Forward
First Speed Reverse
Second Speed Reverse
Third Speed Reverse
Reverser Switch
Third Speed Cut-Out
Troubleshooting
Hydraulic
Electrical
Battery Charger
Battery Chart
Battery Charging Procedure
Battery Replacement Procedure
Index
Brand: Raymond
Safety
Safety Decals
Inspection Form
Daily Inspection
Schematics
Hydraulic Schematic
Electrical Symbols
Specifications
Brake
Lift Limit Switch
Load Wheel Shimming
Theory of Operation
Adjustment
Special Tools
Battery-Pak Lifter
Load Wheel
Carrier Frame
Drive Wheel
Removal
Installation
Control Handle
Head Unit Removal
Brake
Linkage Removal
Removal
Installation
Axle Seal Removal
Disassembly
Assembly
Pump and Motor
Drive Motor
Removal
Installation
Brush Removal
General
Relief Valve
Installing the Pump
Check Valve
Hydraulic Cylinder
Removal
Disassembly
Installation
Inspection
Theory of Operation
Lift Mode
Lowering Mode
Travel
First Speed Forward
Third Speed Forward
First Speed Reverse
Third Speed Reverse
Reverser Switch
Third Speed Cut-Out
Troubleshooting
Hydraulic
Electrical
Battery Charger
Battery Chart
Index
- Raymond Pallet Truck 8210 Maintenance Parts Manual, Electrical Schematic
- Raymond Walkie RSS22-RSS30-RSS40 Maintenance Parts Manual, Electrical Schematic
- Raymond Pallet 8210 Parts Manual & Service Maintenance Manual
- Raymond Walkie 6210 Maintenance Parts Manual, Electrical Schematic
- Raymond EASi R30, R35, R40, R50 Lift Truck 1012609 Parts Catalog
- Raymond Walkie RAS20-25 Maintenance Parts Manual, Electrical Schematic
- Raymond EASi Reach-Forklift Truck ET-F.DT-F Schematics Manual
- Raymond Pallet Truck 8310 8410 8510 8610 Schematic, Maintenance & Parts Manual
- Raymond Reach Truck 20 SCR Maintenance Parts Manuals
- Raymond Reach Truck 7700-7720 Maintenance Parts Manual, Electrical Schematic
- Raymond 8300, 8400, 8500, 8600 Pallet Truck 59,749 & up Maintenance Manual
- Raymond Reach Truck 7200-7300-7310 Maintenance Parts Manual, Electrical Schematic
- Raymond Orderpicker 5200 Maintenance Parts Manual - Schematics
- Raymond EASi Reach-Forklift Truck EZ-D DC-D Schematics Manual
- Raymond 9600-9700 Swing-Reach Schematics Manual
