118
6,911
Raymond Pallet Truck 019 Parts Catalog PDPM-0158
Brand: Raymond
Type of Machine: Pallet Truck
Model: Raymond 019 Walkie Pallet Truck
Serial Number: 21278 & Up
Part Number: PDPM-0158
Publication Date: 1998
Number of Pages: 144 Pages
Section 1 General Information
Major Sections
Recommended Spare Parts Index
Hardware Parts List
Bulk Items Index
Section 2 Finish & Accessories
Tractor Assembly
Caster Installations
Caster Assembly - 6k Standard
Caster Assembly, 8k Heavy Duty (Modern Suspension)
Caster Assembly, 8k Heavy Duty (Darcor)
Caster Assembly, 6k Heavy Duty
Cover Kit
Load Backrest And Tray Installation
Battery Roller Installation
Finish Instructions
Section 3 Steering & Controls
Handle Installation
Handle Installation (Serial # 21295 & Up)
Controller Assembly (S/N 00001-21294)
Controller Assembly (Serial # 21295 & Up)
Control Handle Assembly
Steer Wheel Assembly
Steer Motor Assembly
Section 4 Drive & Brake
Drive And Brake Assembly
Drive Unit Assembly
Drive Wheel Assembly
Lower Drive Unit Assembly
Drive Motor Sub-Assembly
Brake Assembly
Brake Pedal Assembly
Section 5 Electrical Components & Systems
Forward/Reverse Contactor Assembly
Contactor Assembly - Field Weakening
Battery Connectors
Ignition Switch
Meter Installation
Maintenance Tool, Programmable
Horn Assembly
Drive Motor/Lift Pump Motor/Steer Motor
Section 6 Hydraulic Components
Hydraulic Power Unit
Lift Ram - Cessna
Lift Ram - Bruning
Pump And Motor Assembly
Reservoir Assembly
Hydraulic Motor
Orbitrol Valve Assembly
Shaft And Flange Assembly
Section 7 Mast
Fork Assembly - 6000 Lb
Definition Of Item 6b (See Figure 7-1)
Load Wheel Assembly - 6000 Lb Full Wheel
Load Wheel Assembly - 6000 Lb Split Wheel
Entry Roller - 6000 Lb Standard
Entry Roller - 8000 Lb Long John
Fork, 8000 Lb, 27 Inch Fork
Definition Of Item 6b (See Figure 7-7)
Load Wheel Assembly - 8000 Lb, Full Wheel
Alphabetical Parts Index
Numerical Parts Index
