118
6,911
Raymond Orderpicker 5400 5500 5600 Parts Manual 1062278001 2019
Brand: Raymond
Type of Machine: Orderpicker Lift Truck
Model: Raymond 5400, 5500, 5600 Orderpicker Lift Truck
Serial Number: 100 & up for 5400, 100 to 44000 for 5500 and 5600
Part Number: 1062278001
Publication Date: 2019
Number of Pages: 659 Pages
Section 1 General Information
Section 2 Finish & Accessories
Frame, Mechanical Components
Bumper Installation
Battery Roller Assembly
Battery Gate And Roller Assembly
Finish Instructions
Mast Guard Assembly
Floor Pad Installation
Tether, Mechanical Installation
Section 3 Steering & Controls
Electric Steer Motor Installation
Steer Motor And Gearbox Assembly
Electric Steering And Control Components
Electric Steering Wheel
Section 4 Drive & Brake
Drive Unit And Brake Assembly
Drive Unit Installation
Brake Installation
Brake Assembly
Deadman Installation
Deadman Pedal Assembly
Deadman Brake Pedal Assembly, Standard
Deadman Brake Pedal Assembly, Optional
Lower Drive Unit, Heavy Duty
Lower Drive Unit Assembly, Standard
Drive Wheel Assembly
Section 5 Electrical Comp & System
Electrical Components
Fan Installation, Pump Compartment, 36v
Carriage Electrical Components
Traction And Ac Lift Controller Installation
Contactor Panel Installation
Contactor Panel Assembly, Standard
Contactor Panel Assembly, Ee
Contactor Assembly
Horn Installation
Fuse Relay Installation
Battery Connector And Installation
Platform, Limit Switch Installation
Travel, Lift Limit And Decel Switch Installation
Travel Limit Switch Installation
Warning Light Installation, Tractor Mount (Standard)
Warning Light Installation, Mast Mount (Optional)
Warning Light Assembly (Strobe)
Warning Lamp (Flashing)
Heater Assembly, Carriage Card
Drive Motors
Drive Motor Assembly With Target Plate
Lift Motors
Lift Motors, Dc
Lift Motor (Single Stage Pump) (24v)
Lift Motor, Ee (24v)
Lift Motor
Lift Motor Assembly (E)
Control Handle Assembly
Section 6 Hydraulic Components
Lift/Lower Manifold Installation
Lift/Lower Manifold Installation, With Auxiliary Lift
Lift/Lower Manifold Assembly
Manifold Assembly, Lift Select
Manifold Assembly, Auxiliary Lift
Lift/Lower Manifold Sub-Assembly, Standard
Manifold, Lift Select, Auxiliary Lift
Lift/Lower Valve, Auxiliary Lift
Flow Sensor Assembly
Lift Pump And Motor Assembly, Ac Lift
Lift Pump And Motor Assembly (24v, Dc)
Cylinder Assembly, Main Lift, 175 In Diameter (Three Stage Only)
Cylinder Assembly, Free Lift, 25 In Diameter
Cylinder Assembly, Main Lift, 175 In (Two Stage)
Cylinder Assembly, Auxiliary Lift
Reservoir Installation
Reservoir Assembly
Section 7 Mast
Mast Mounting
Three Stage Mast, Electric Steer
Elevating Section, Two Stage
Load Wheels
Auxiliary Lift, Mast
Auxiliary Lift Mast
Over The Mast Hoses, Cables, And Pulleys (Three Stage)
System Mechanical, Elevating Section
Pulley Assembly, Cable, End Cap, Three Stage
Pulley Assembly, Hose
Pulley Assembly, Cable, Bottom
Bumper Assembly
Fork Assembly, Standard
Fork Assembly, Extended Lift, 175 In X 5 In, Heat Treated
Fork Assembly, Tubular
Fork Assembly, Auxiliary Lift
Section 8 Options & Kits
Pallet Clamp Assembly, 125 In To 225 In
Pallet Clamp Installation
Pallet Clamp, Jaws Assembly
Pallet Assembly, Clamp And Cable
Pallet Clamp, Pedal Assembly, 125 In To 500 In
Pallet Clamp, Weldment
Sidegate Installation
Sidegates, Heavy Duty (Optional)
Full Retractable Sidegate Installation
Mechanical Sidegates, Bar, Installation
Mechanical Sidegates, Fixed, Installation
Platform Extension
Platform Extension, Rear
Guide Roller Installation, 25 In Wheel
Carriage Alteration And Hardware
Guide Roller Assembly
Guide Roller Installation, 325 In Wheel
Roller Switch Assembly
Guide Roller Assembly, Heavy Duty
Guide Roller Assembly With 5700 In Base Legs
Guide Roller Assembly (Furniture Picker)
Guide Roller Installation, 6 In Guide Rollers
Cart Latch Assembly
Wire Guidance Installation
Guidance Control Assembly
Wire Guidance Sensor, Tractor End
Wire Guidance Sensor, Load End
Control Assembly, Antenna
End-Of-Aisle Slowdown
Operator Compartment, Lights And Fan
Light Assembly, Led, Overhead
Overhead Fluorescent Light Assembly
Lights And Fan, Operator Compartment (Cold Storage)
Bin Lights Installation
Bin Light Assembly
Working Light Installation, Led
Working Light Assembly, Led
Auxiliary Power Hookup
Auxiliary Power Hookup (6 Amp And 10 Amp)
Auxiliary Power (100 Amp)
Motion Alarm Installation
Cooling Fan Installation
Operator Cooling Fan Installation
Operator Cooling Fan Assembly
Fire Extinguisher
Battery Guide
Slack Switch Installation
Accessory Installation
Rf Terminal Mounting
Security Start Switch Installation
Iport And Iwarehouse Installation
Mechanical Guide Rollers, Installation
Outrigger Installation (With Wheels)
Battery Gate Interlocks, Installation
Cart Latch Installation
Auxiliary Light, Mast Mounted
Iw Essential (Iwarehouse Red)
Carriage, Catwalk, Installation
Catwalk, Chain Installation
Mechanical Stop, Installation
Overhead Guard, Plexiglass And Mesh
Sidegate Covers
Terminal Strip Install (On-Board Power Hookup)
Ic Converter, Inverter Installation
Plug Installation
Sb-175, Installation
Sb-350, Installation
Switch, Emergency Power Off, Installation
Switch Installation
Battery Spacer, Installation
Blue Light Installation
Encoder Installation, Main Lift
Encoder Installation, Free Lift
Zap Installation (Zoning And Positioning)
Appendix A Alphabetical Parts Index
Appendix B Numerical Parts Index
