Raymond Orderpicker 5300 5500 5600 Parts Manual 1301129001 2021
Brand: Raymond
Type of Machine: Orderpicker, Orderpicker Lift Truck
Model: Raymond 5300, 5500, 5600 Orderpicker Lift Truck
Serial Number: 1 & up for 5300, 44001 & up for 5500 and 5600
Part Number: 1301129001
Publication Date: 2021
Number of Pages: 447 Pages
Section 1 General Information
Section 2 Finish & Accessories
Battery Compartment
Bumper Installation
Battery Roller Assembly
Finish Instructions
Mast Guard Assembly
Floor Pad
Fall Protection
Section 3 Steering & Controls
Steer Motor Installation
Steer Motor And Gearbox Assembly
Electric Steering And Control Components
Electric Steering Wheel
Section 4 Drive & Brake
Transmission Installation
Drive Unit And Drive Motor Installation
Brake Installation
Brake Assembly
Drive Wheel Assembly
Lower Drive Unit Assembly (Standard)
Lower Drive Unit (Heavy Duty)
Deadman Pedal Installation
Deadman Pedal Assembly
Section 5 Electrical Comp. & System
Fan Installation, Pump Compartment, 36v
Electrical System, Carriage
Bezel Assembly
Contactor Panel Installation
Contactor Panel Assembly, Standard
Contactor Panel Assembly, Ee
Contactor Assembly
Horn Installation
Fuse Relay Installation
Battery Connector And Installation
Platform, Limit Switch Installation
Lower Limit Switch Installation (8-28 In.)
Travel, Lift Limit And Decel Switch Installation
Travel Limit Switch Installation
Traction And Ac Lift Controller Installation
Warning Light Installation, Tractor Mount (Standard)
Drive Motor, 24v And 36v, E
Drive Motor, 24v & 36v Ee
Motor Lift, (24v Dc) E And Ee
Lift Motor, 24v, Ac
Lift Motor, 36 Volt
Lift Motor, 24 Volt, Ee
Lift Motor, 36volt, Ee
Control Handle Assembly
Section 6 Hydraulic Components
Tractor Hydaulic Manifold Installation (Below 316 In. Eh)
Tractor Hydaulic Manifold Installation (Above 329 In. Eh)
Tractor Hydraulic Manifold Installation, With Auxiliary Lift
Lift Lower Manifold Assembly
Lift Lower Manifold Assembly (Aux Lift)
Flow Sensor Assembly
Lift Pump And Motor Installation (24v Dc)
Lift Pump And Motor Installation/Assembly (Ac)
Lift Pump Assembly
Main Lift Cylinder Assembly (3 Stage)
Main Lift Cylinder Assembly (2 Stage)
Free Lift Cylinder Assembly
Auxiliary Lift Cylinder Assembly
Reservoir Installation
Reservoir Assembly
Section 7 Mast
Mast Mounting
Three Stage Mast, Electric Steer
Elevating Section, Two Stage
Load Wheels
Bumper Assembly
System Mechanical Elevation Section (Three Stage)
System Mechanical, Elevating Section (Two Stage)
Pulley Assembly, Cable, End Cap, Three Stage
Pulley End Cap Assembly, Australia Only
Pulley Assembly, Hose
Pulley Assembly, Cable, Bottom
Pulley Assembly, Cable, Triple Pulley
Pulley Assembly, Cable, Right-Hand
Bumper Assembly
Fork Assembly, Standard
Fork Assembly, Tubular
Section 8 Options & Kits
Pallet Clamp Installation
Pallet Clamp, Jaws Assembly
Pallet Clamp Assembly
Pallet Assembly, Clamp And Cable
Pallet Clamp, Pedal Assembly
Sidegate Installation, Hinged
Full Retractable Sidegate Installation
Mechanical Sidegates, Fixed, Installation
Platform Extension
Guide Roller Installation, 2.5 In. Wheel
Switch Assembly, Guide Roller
Guide Roller Installation, 3.25 In. Wheel
Guide Roller Assembly
Wire Guidance Installation
Guidance Control Assembly
Wire Guidance Sensor, Tractor End
Wire Guidance Sensor, Load End
Control Assembly, Antenna
End-Of-Aisle Slowdown
Light Assembly, Led, Overhead
Working Light Installation, Led
Working Light Assembly, Led
Auxiliary Power Hookup, 2 Amp
Auxiliary Power Hookup 10 Amp
Motion Alarm Installation
Operator Cooling Fan Installation
Operator Cooling Fan Assembly
Fire Extinguisher
Slack Switch Installation
Rf Terminal Mounting
Security Start Switch Installation
Iport And Iwarehouse Installation
Battery Gate Interlocks, Installation
Iw Essential (Iwarehouse Red)
Iw Evolution/ Evo (Iwarehouse Blue)
Iw Evolution/Evo (Blue) Platform Installation
Mechanical Stop, Installation
Overhead Guard, Plexiglass And Mesh
Blue Light Installation
Encoder Installation, Main Lift
Encoder Installation, Free Lift
Navigation Solutions (Zoning And Positioning)
Control Assembly, Zpu
Object Sense
Laser Sensor Installation
Guide Roller Assembly (Furniture Picker)
Appendix A Alphabetical Parts Index
Appendix B Numerical Parts Index
Brand: Raymond
Battery Compartment
Bumper Installation
Finish Instructions
Mast Guard Assembly
Floor Pad
Fall Protection
Brake Installation
Brake Assembly
Bezel Assembly
Contactor Assembly
Horn Installation
Lift Motor, 24v, Ac
Lift Motor, 36 Volt
Lift Pump Assembly
Reservoir Assembly
Section 7 Mast
Mast Mounting
Load Wheels
Bumper Assembly
Bumper Assembly
Platform Extension
Fire Extinguisher
Object Sense
- Raymond Pallet Truck 8210 Maintenance Parts Manual, Electrical Schematic
- Raymond Walkie RSS22-RSS30-RSS40 Maintenance Parts Manual, Electrical Schematic
- Raymond Pallet 8210 Parts Manual & Service Maintenance Manual
- Raymond Walkie 6210 Maintenance Parts Manual, Electrical Schematic
- Raymond EASi R30, R35, R40, R50 Lift Truck 1012609 Parts Catalog
- Raymond Walkie RAS20-25 Maintenance Parts Manual, Electrical Schematic
- Raymond EASi Reach-Forklift Truck ET-F.DT-F Schematics Manual
- Raymond Pallet Truck 8310 8410 8510 8610 Schematic, Maintenance & Parts Manual
- Raymond Reach Truck 20 SCR Maintenance Parts Manuals
- Raymond Reach Truck 7700-7720 Maintenance Parts Manual, Electrical Schematic
- Raymond 8300, 8400, 8500, 8600 Pallet Truck 59,749 & up Maintenance Manual
- Raymond Reach Truck 7200-7300-7310 Maintenance Parts Manual, Electrical Schematic
- Raymond Orderpicker 5200 Maintenance Parts Manual - Schematics
- Raymond EASi Reach-Forklift Truck EZ-D DC-D Schematics Manual
- Raymond 9600-9700 Swing-Reach Schematics Manual
