7,392
Raymond Orderpicker 212 218 233 Gofer Maintenance Manual PDMM-0049
Brand: Raymond
Type of Machine: Orderpicker
Type of Manual: Maintenance Manual, Electrical Schematic
Model: Raymond 212, 218, 233 Gofer Orderpicker
Part Number: PDMM-0049
Number of Pages: 441 Pages
How To Use This Manual
Map of the Manual
Manual Design
Page Revision Record
Service Bulletins Included
Product Improvement Notices Included
Table of Contents
START Page
Safety
Definitions
General Safety
Battery Safety
Static Safety
Jacking Safety
Tie-Down for Transport
Towing a Disabled Unit
Welding Safety
Systems Overview
Vehicle Specification
Special Tools
Cold Storage
Scheduled Maintenance
Maintenance Guidelines
Operator’s Daily Checklist
Moderate Usage: Every 6 Months or 500 Hours; Severe Usage: Every 3 Months or 250 Hours
Moderate and Severe Usage: Every Year or 1500 Operating Hours
Lubrication Points
Troubleshooting
How to Use This Chapter
Electrical Troubleshooting Guidelines
Shorts to Frame Test
Hydraulic Troubleshooting Guidelines
Definitions
Electrical Connector Locator Chart
Programmable Maintenance Tool
Drive Unit Troubleshooting Guide
List of Troubleshooting Charts
Troubleshooting Flowcharts
Codes and Tests
Operator Display Messages
Maintenance Mode
Traction Power Amplifier Fault Codes
Operator Display Fault Codes
Component Procedures
List of Component Procedures
Component Locator Photos
Finger Guard
Operator Display
Steering Wheel
Steer Encoder
Control Handle
Throttle Potentiometer
Drive Wheel
Brake
Contactors
Contactor Tip Replacement
Fuses
Circuit Cards (General)
Horn
Power Cables
Wiring Harness
Switches (General)
Motors (General)
Electric Motor Tests
Drive Motor
Steer Motor
Lift Motor
Hydraulic Filter
Hydraulic Assembly
Hydraulic Manifold
Solenoid Valves
Lift Pump
Lift Pressure Adjustment
Bleeding the Hydraulic System
Lift Ram— Models 212 and 218
Lift Ram—Model 233
Auxiliary Lift
Operator Platform—233
Lift Chains—Model 233
Forks—Without Mini Mast
Forks—With Mini Mast
Load Wheels
Mast Cable— Models 212 and 218
Mast Cable—Model 233
Option Kits
Figure 8-1: Cross-tie Location
Auxiliary Power Hook-Up
Bin Lights
Bin Lights
Clipboard
Fan Assembly
Fan Assembly
Fire Extinguisher
Hour Meter
Lift Limit
Lift Limit With Bypass
Mast Guard
Mini-Lift
Overhead Guard—212
Pallet Clamp
Platform Extensions
Rail Guidance— Installing Guide Rollers
Sidegates Without Interlock
Sidegates With Interlock
Sidegate Power Interlock Kit
Storage Caddie
Warning Light
Theory of Operation
Battery Plugged In
Key Switch (S1) On
Closing Deadman Switches (S2 and S23)
Travel
Steering
Lift/Lower
Auxiliary Lift
Auxiliary Lower
Software Configuration
PC Loader Program
Appendix
Lubrication Equivalency Chart
Torque Chart - Standard (Ferrous)
Torque Chart - Metric
Torque Chart - Standard (Brass)
Decimal Equivalent Chart
Standard/Metric Conversions
Hydraulic Schematic
Index
RSIs
Scheduled Maintenance - Software Updates
New Pump Spline Lubricant
Updated Torque Check Procedures
