Raymond Forklift 4750 - C80 C100 C120 Maintenance Manual 1393839_001B 2024
Brand: Raymond
Type of Machine: Forklift
Type of Manual: Maintenance Manual, Wiring Diagrams
Model: Raymond 4750 - C80, C100, C120 Forklift
Serial Numbers: 00001 and Up
Part Number: 1393839/001B
Publication Date: 2024
Number of Pages: 597 Pages
GENERAL
Brand: Raymond
GENERAL
0.1 EXTERIOR VIEWS
0.2 LIFT TRUCK MODEL
0.3 FRAME NUMBER
0.4 HOW TO USE THIS MANUAL
0.5 OPERATIONAL TIPS
0.6 JACK-UP POINT
0.7 HOISTING THE LIFT TRUCK
0.8 CAUTION FOR TOWING
0.9 ATTENTIVE POINTS ON PSS
0.10 CIRCUIT TESTER
0.11 STANDARD BOLT & NUT TIGHTENING TORQUE
0.12 PRECOAT BOLTS
0.13 HIGH PRESSURE HOSE TIGHTENING TORQUE
0.14 WIRE ROPE SUSPENSION ANGLE LIST
0.15 SAFE LOAD FOR WIRE ROPE SUSPENSION ANGLE
0.16 COMPONENT WEIGHTS
0.17 RECOMMENDED LUBRICANT QUANTITY & TYPES
0.18 LUBRICATION CHART
0.19 PERIODIC MAINTENANCE
0.20 PERIODIC REPLACEMENT: PARTS / LUBRICANTS
BATTERY1.1 BATTERY COMPARTMENT AND REQUIRED WEIGHT
1.2 SERVICE STANDARD
1.3 DISPLAY
1.4 TROUBLESHOOTING
1.5 BATTERY ASSY
CONTROLLER2.1 GENERAL
2.2 ADDED FUNCTIONALITIES
2.3 SPECIFICATIONS
2.4 COMPONENTS
2.5 CONTROLLER
2.6 COMBINATION SWITCH
2.7 ACCELERATOR POTENTIOMETER ADJUSTMENT
2.8 BRAKE SWITCH ADJUSTMENT
2.9 MATERIAL HANDLING LEVER SWITCH ADJUSTMENT
2.10 FORWARD/REVERSE TRAVEL PEDAL (OPT)
MULTI-DISPLAY FUNCTIONS3.1 MULTIPLE DISPLAY
3.2 NORMAL FUNCTION SCREEN
3.3 MASK FUNCTIONS
3.4 DIAGNOSIS
TROUBLESHOOTING4.1 Before Troubleshooting
4.2 Troubleshooting Method
4.3 SST Setting MethodS
4.4 TROUBLESHOOTING
MOTOR5.1 DRIVE MOTOR
5.2 PUMP MOTOR
5.3 MOTOR BRUSH WEAR AND OVERHEAT WARNING
DRIVE UNIT6.1 GENERAL
6.2 SPECIFICATIONS
6.3 COMPONENTS
6.4 DRIVE UNIT ASSY
6.5 DIFFERENTIAL CASE ASSY
FRONT AXLE7.1 GENERAL
7.2 SPECIFICATIONS
7.3 COMPONENTS
7.4 FRONT AXLE SHAFT×AXLE HUB
7.5 DIFFERENTIAL HOUSING
REAR AXLE8.1 GENERAL
8.2 SPECIFICATIONS
8.3 COMPONENTS
8.4 REAR AXLE ASSY
8.5 STEERING KNUCKLE
8.6 REAR AXLE CYLINDER
STEERING9.1 GENERAL
9.2 SPECIFICATIONS
9.3 COMPONENTS
9.4 STEERING WHEEL×MAST JACKET
9.5 HYDROSTATIC STEERING VALVE ASSY
9.6 RELIEF PRESSURE INSPECTION×ADJUSTMENT
BRAKES10.1 GENERAL
10.2 SPECIFICATIONS
10.3 COMPONENTS
10.4 FRONT BRAKE
10.5 BRAKE AIR BLEEDING
10.6 BRAKING FORCE INSPECTION×ADJUSTMENT
10.7 BRAKE BOOSTER
10.8 PARKING BRAKE INSPECTION×ADJUSTMENT
10.9 BRAKE PEDAL INSPECTION×ADJUSTMENT)
BODY11.1 COMPONENTS
11.2 BATTERY HOOD ASSY
11.3 COUNTERWEIGHT
11.4 DRIVER’S SEAT
11.5 FUSE
MATERIAL HANDLING SYSTEM12.1 HYDRAULIC SYSTEM DIAGRAM
12.2 COMPONENTS
12.3 RETURN FILTER×SUCTION FILTER
12.4 NATURAL DROP TEST
12.5 NATURAL FORWARD TILT TEST
12.6 OIL LEAK TEST
MAST13.1 TN MAST ASSY
13.2 CHAIN
13.3 FORK
13.4 LOAD BACKREST INSPECTION
13.5 TF×TT MAST ASSY
13.6 LIFT CYLINDER ROD SHIM ADJUSTMENT (PREVENTION OF UNEVEN LIFTING)
CYLINDER14.1 LIFT CYLINDER (TN) · REAR LIFT CYLINDER (TF · TT)
14.1 FLOW REGULATOR VALVE
14.2 SAFETY DOWN VALVE
14.3 FRONT LIFT CYLINDER (TF×TT)
14.1 TILT CYLINDER
14.2 MAST FORWARD BACKWARD TILTING ANGLE ADJUSTMENT (PREVENTION OF UNEVEN TILTING)
OIL PUMP15.1 GENERAL
15.2 SPECIFICATIONS
15.3 COMPONENTS
15.4 OIL PUMP ASSY
15.5 TEST METHOD
OIL CONTROL VALVE16.1 GENERAL
16.2 SPECIFICATIONS
16.3 COMPONENTS
16.4 LIFT & TILT LOCK VALVE ASSY
16.5 TILT LOCK VALVE ASSY (for OPS)
16.6 RELIEF PRESSURE ADJUSTMENT
16.7 CONTROL VALVE LEVER ASSY
PSS FUNCTIONS17.1 GENERAL
17.2 COMPONENTS
17.3 BEFORE STARTING REPAIR WORK
17.4 YAW RATE SENSOR
17.5 SWING LOCK CYLINDER
17.6 TILT ANGLE SENSOR
17.7 LOAD SENSOR
17.8 SPEED SENSOR
17.9 MAST LIFTING HEIGHT SWITCH
17.10 MATCHING
17.11 CAUTIONS ON MODIFYING VEHICLES
17.12 RENEWAL OF PSS CAUTION LABEL
APPENDIXSST LIST - MECHANICAL TOOLS
SST LIST - ELECTRICAL TOOLS
SERVICE STANDARDS LIST - MECHANICAL SYSTEMS
SERVICE STANDARDS - ELECTRICAL SYSTEMS
CONNECTOR LISTING
COMPONENT/CONNECTOR DIAGRAMS
JOINT DIAGRAM
CONNECTING DIAGRAM
WIRING DIAGRAM
- Raymond Pallet Truck 8210 Maintenance Parts Manual, Electrical Schematic
- Raymond Walkie RSS22-RSS30-RSS40 Maintenance Parts Manual, Electrical Schematic
- Raymond Pallet 8210 Parts Manual & Service Maintenance Manual
- Raymond Walkie 6210 Maintenance Parts Manual, Electrical Schematic
- Raymond EASi R30, R35, R40, R50 Lift Truck 1012609 Parts Catalog
- Raymond Walkie RAS20-25 Maintenance Parts Manual, Electrical Schematic
- Raymond EASi Reach-Forklift Truck ET-F.DT-F Schematics Manual
- Raymond Pallet Truck 8310 8410 8510 8610 Schematic, Maintenance & Parts Manual
- Raymond Reach Truck 20 SCR Maintenance Parts Manuals
- Raymond Reach Truck 7700-7720 Maintenance Parts Manual, Electrical Schematic
- Raymond 8300, 8400, 8500, 8600 Pallet Truck 59,749 & up Maintenance Manual
- Raymond Reach Truck 7200-7300-7310 Maintenance Parts Manual, Electrical Schematic
- Raymond Orderpicker 5200 Maintenance Parts Manual - Schematics
- Raymond EASi Reach-Forklift Truck EZ-D DC-D Schematics Manual
- Raymond 9600-9700 Swing-Reach Schematics Manual
