7,392
Raymond Automation 3010 3020 Parts Manual 1134578 2021
Brand: Raymond
Type of Machine: Automation, Pallet Truck, Tow Tractor
Model: Raymond 3010, 3020 Pallet Truck and Tow Tractor
Serial Number: 301-14-00001 and Up, 302-14-00001 and Up
Part Number: 1134578
Issue Date: 2021
Number of Pages: 246 Pages
Section 1 General Information
Section 2 Finish & Accessories
Suspension Assembly Model 3020
Caster Installation
Caster Assembly
Finish Instructions
Front Cover Installation
Console Cover Installation
Mat Installation
Battery Roller And Gate Installation
Battery Roller Installation
Battery Shim-Spacer, Installation
Bumper Installation
Cushion Installation
Handle Mounting Cover Installation
Platform Installation
Section 3 Steering & Controls
Handle Installation
Handle Assembly
Control Handle Installation
Control Handle Assembly
Control Head Assembly
Handle Return
Brake Actuator Assembly
Power Steering Installation
Gear Motor Assembly, Power Steering
Section 4 Drive & Brake
Drive Unit And Brake Installation
Brake Assembly
Drive Unit And Motor Assembly
Drive Unit Assembly
Drive Wheel Assembly
Section 5 Electrical Comp & System
Contactor Assembly
Keyswitch Installation
Battery Connector Assembly
Arch Installation
Short Arch Installation
Sensor Assembly
Control Installation
Control Assembly
Front Laser Assembly
Front Sensor Installation
Drive Motor
Section 6 Hydraulic Components
Lift Cylinder Assembly
Section 7 Mast
Fork Attachment Assembly
Fork Linkage, Model 3010
Pull Rod
Load Wheel Assembly, Single
Load Wheel Assembly, Dual Single
Load Wheel Assembly, Triple Single
Load Wheel Assembly, 8k, Split Wheel, Tandem
Load Wheel Assembly, 8k, Single Wheel, Tandem
Roller Entry Installation
Slider Entry Installation
Section 8 Options & Kits
Battery Gate Interlock
Tow Coupler Installation
Auto Hitch Installation
Connector-Mech, Hitch
Coupler, Hitch Assembly
Travel Alarm Installation
Auxiliary Power Hook-Up
Iwarehouse Blue
Fork Tip Sensor
Reverse Scanner
Appendix A Alphabetical Parts Index
Appendix B Numerical Parts Index
