Powerscreen Impact Crusher Trakpactor 550 Parts Manual
Brand: Powerscreen
Type of Machine: Impact Crusher
Model: Powerscreen Trakpactor 550 Impact Crusher
From Serial No: PIDTP550COMH13309
Publication Date: 2017
Number of Pages: 701 Pages
TRAKPACTOR 550
Brand: Powerscreen
TRAKPACTOR 550
Table of Content
02-01 CHASSIS ASM OVERVIEW (PRESCREEN)
02-02 CHASSIS ASM 1
02-03 CHASSIS ASM 2
02-04 TUNNEL ASM (PRESCREEN AND VGF)
02-05 TENSIONER PIVOT PHANTOM ASM (PRESCREEN AND VGF)
02-06 SPRAYBAR ASM (PRESCREEN AND VGF)
02-10 CHASSIS ASM OVERVIEW (VGF)
02-11 CHASSIS ASM 1
02-12 CHASSIS ASM 2
03-01 TRACK ASM 1
03-02 TRACK ASM 2
03-03 TRACKS BREAKDOWN FROM SERIAL NO. PIDTP550COMGB3309
04-1 PRESCREEN
04-01 HOPPER, FEEDER BED AND PRESCREEN ASM OVERVIEW
04-02 HOPPER ASM OVERVIEW (PRESCREEN)
04-03 HOPPER SIDE ASM BREAKDOWN
04-04 HOPPER SIDE ASM 2
04-05 HOPPER REAR FRAME, FRONT LEG ASM
04-06 FEEDER BED AND VIBRATING UNIT OVERVIEW (PRESCREEN)
04-07 FEEDER BED AND LINERS ASM
04-08 VIBRATORY UNIT OVERVIEW
04-09 FEEDER VIBRATORY UNIT HOUSING AND DRIVE COVERS
04-10 VIBRATORY UNIT BEARING HOUSING ASM (PRESCREEN AND VGF)
04-11 VIBRATOR DRIVE SIDE SHAFT ASM
04-12 VIBRATOR NON DRIVE SIDE SHAFT ASM
04-13 MOTOR AND COUPLING ASM (PRESCREEN AND VGF)
04-20 PRESCREEN ASM OVERVIEW
04-21 PRESCREEN ASM 1
04-22 PRESCREEN ASM 2
04-23 PRESCREEN LINERS ASM
04-24 PRESCREEN HUCK-BOLTED ASM
04-25 PRESCREEN SHAFT ASM
04-26 PRESCREEN SHAFT BEARING ASM (FIXED DRIVE SIDE)
04-27 PRESCREEN SHAFT BEARING ASM (FLOATING NON-DRIVE SIDE)
04-28 PRESCREEN FLYWHEEL ASM
04-2 VGF
04-40 HOPPER AND VGF ASM - OVERVIEW
04-41 HOPPER ASM OVERVIEW (VGF)
04-42 HOPPER SIDE ASM BREAKDOWN
04-43 HOPPER SIDE ASM
04-44 HOPPER REAR FRAME ASM
04-45 VGF AND VIBRATOR UNIT OVERVIEW
04-46 VGF ASM 1
04-47 VGF ASM 2
04-48 VIBRATORY UNIT OVERVIEW (VGF)
04-49 FEEDER VIBRATORY UNIT HOUSING AND DRIVE COVERS
04-50 VIBRATOR DRIVE SIDE SHAFT ASM
04-51 VIBRATOR NON DRIVE SIDE SHAFT ASM
05-1 TIER 4 FINAL SCANIA DC13 POWERUNIT
05-01 TIER 4 FINAL SCANIA DC13 POWERUNIT OVERVIEW 1
05-02 TIER 4 FINAL SCANIA DC13 POWERUNIT OVERVIEW 2
05-03 TIER 4 FINAL SCANIA DC13 ENGINE COMPARTMENT OVERVIEW
05-04 ENGINE COMPARTMENT ROOF ASM
05-05 ENGINE COMPARTMENT LHS ASM
05-06 TIER 4 FINAL SCANIA DC13 ENGINE COMPARTMENT FRONT ASM
05-07 ENGINE COMPARTMENT RHS ASM
05-08 ENGINE COMPARTMENT BACK ASM
05-09 ENGINE RADIATOR ROOF SUPPORT ASM
05-10 TIER 4 FINAL SCANIA DC13 ENGINE BREAKDOWN
05-11 TIER 4 FINAL SCANIA DC13 ENGINE ASM
05-12 TIER 4 FINAL SCANIA DC13 AIR FILTER, HOSES AND FITTINGS
05-13 TIER 4 FINAL SCANIA DC13 ENGINE RADIATOR, HOSES AND FITTINGS
05-14 TIER 4 FINAL SCANIA DC13 ENGINE RADIATOR FAN, HOSES AND FITTINGS
05-15 TIER 4 FINAL SCANIA DC13 LOW TURBO EXHAUST ASM MOUNTINGS
05-16 TIER 4 FINAL SCANIA DC13 LOW TURBO EXHAUST ASM
05-17 ENGINE CLUTCH ASM
05-18 TIER 4 FINAL SCANIA DC13 ENGINE ALTERNATOR BELT COVERS ASM
05-19 CLUTCH PULLEY COVER ASM
05-20 TIER 4 FINAL SCANIA DC13 POWER UNIT SUBFRAME ASM
05-2 TIER 3 CAT C13 POWERUNIT
05-30 TIER 3 CAT C13 POWERUNIT OVERVIEW 1
05-31 TIER 3 CAT C13 POWERUNIT OVERVIEW 2
05-32 TIER 3 CAT C13 ENGINE COMPARTMENT OVERVIEW
05-33 TIER 3 CAT C13 ENGINE COMPARTMENT FRONT ASM
05-34 TIER 3 CAT C13 ENGINE BREAKDOWN
05-35 TIER 3 CAT C13 ENGINE ASM
05-36 TIER 3 CAT C13 ENGINE AIR FILTER,EXHAUST ARRANGEMENT ASM
05-37 TIER 3 CAT C13 ENGINE RADIATOR, HOSES AND FITTINGS
05-38 TIER 3 CAT C13 ENGINE RADIATOR FAN, HOSES AND FITTINGS
05-39 TIER 3 CAT C13 ENGINE ALTERNATOR BELT COVERS ASM
05-3 SCANIA DC13 CONSTANT SPEED POWERUNIT
05-50 SCANIA DC13 CONSTANT SPEED POWERUNIT OVERVIEW 1
05-51 SCANIA DC13 CONSTANT SPEED POWERUNIT OVERVIEW 2
05-52 SCANIA DC13 CONSTANT SPEED ENGINE COMPARTMENT OVERVIEW
05-53 SCANIA DC13 CONSTANT SPEED ENGINE COMPARTMENT FRONT ASM
05-54 SCANIA DC13 CONSTANT SPEED ENGINE BREAKDOWN
05-55 SCANIA DC13 CONSTANT SPEED ENGINE ASM
05-56 SCANIA DC13 CONSTANT SPEED ENGINE AIR FILTER, HOSES AND FITTINGS
05-57 SCANIA DC13 CONSTANT SPEED ENGINE RADIATOR, HOSES AND FITTINGS
05-58 SCANIA DC13 CONSTANT SPEED ENGINE RADIATOR FAN, HOSES AND FITTINGS
05-59 SCANIA DC13 CONSTANT SPEED ENGIN ALTERNATOR BELT COVERS ASM
06-01 HYDRAULIC TANK ASM 1
06-02 HYDRAULIC TANK ASM 2
06-03 HYDRAULIC TANK ASM 3
06-04 HYDRAULIC TANK ASM 4
07-01 FUEL TANK ASM 1
07-02 FUEL TANK ASM 2
08-1 TEREX CHAMBER COMPONENTS
08-01 IMPACTOR CHAMBER OVERVIEW
08-02 IMPACTOR EXTERNAL COMPONENTS 1
08-03 IMPACTOR EXTERNAL COMPONENTS 2
08-04 IMPACTOR INTERNAL COMPONENTS
08-05 IMPACTOR MOVING BODY FABRICATION AND ACCESS PANELS
08-06 TOP APRON AND BOTTOM APRON ASM
08-07 IMPACTOR LINERS AND FITTINGS ASM
08-08 LIFTING CRADLE ASM
08-09 IMPACTOR ROTOR ASM
08-10 BEARING ASM - DRIVE SIDE
08-11 BEARING ASM - NON DRIVE SIDE
08-12 INLET LID ASM
08-13 TOP CYLINDER ASM
08-14 BOTTOM CYLINDER ASM
08-2 HAZEMAG CHAMBER COMPONENTS
08-20 IMPACT CHAMBER OVERVIEW
08-21 IMPACT CHAMBER COMPONENTS 1
08-22 IMPACT CHAMBER COMPONENTS 2
08-23 IMPACT CHAMBER BEARINGS
08-24 IMPACT CHAMBER BEARING SEALING SYSTEM
08-25 IMPACT CHAMBER BEARING LABYRINTH SEAL
08-26 HAZEMAG CHAMBER LIFTING TOOL
10-1 MAIN CONVEYOR (3.8M UNDERPAN )
10-40 MAIN CONVEYOR ASM - OVERVIEW (3.8M UNDERPAN )
10-41 MAIN CONVEYOR MID SECTION ASM 1 (3.8M UNDERPAN AND 3.8M UNDERBELT)
10-42 MAIN CONVEYOR MID SECTION ASM 2 (3.8M UNDERPAN AND 3.8M UNDERBELT)
10-43 MAIN CONVEYOR MID SECTION ASM 3 (3.8M UNDERPAN AND 3.8M UNDERBELT)
10-44 MAIN CONVEYOR HEAD SECTION ASM 1 (3.8M UNDERPAN AND 3.8M UNDERBELT)
10-45 MAIN CONVEYOR HEAD SECTION ASM 2 (3.8M UNDERPAN AND 3.8M UNDERBELT)
10-46 MAIN CONVEYOR HEAD DRUM CHUTE ASM (3.8M UNDERPAN AND 3.8M UNDERBELT)
10-47 MAIN CONVEYOR DUST COVER ASM (3.8M UNDERPAN AND 3.8M UNDERBELT)
10-02 MAIN CONVEYOR TAIL SECTION ASM 1 (3.8M UNDERPAN AND 4.2M FOLDING HEAD SECTION UNDERPAN )
10-03 MAIN CONVEYOR TAIL SECTION ASM 2 (3.8M UNDERPAN AND 4.2M FOLDING HEAD SECTION UNDERPAN )
10-2 MAIN CONVEYOR (3.8M UNDERBELT )
10-50 MAIN CONVEYOR ASM - OVERVIEW (3.8M UNDERBELT )
10-51 MAIN CONVEYOR TAIL SECTION IMPACT BAR AND IMPACT ROLLERS ASM (3.8M UNDERBELT AND 4.2M FOLDING HEAD SECTION UNDERBELT )
10-52 MAIN CONVEYOR TAIL DRUM AND ROLLER ASM (3.8M UNDERBELT AND 4.2M FOLDING HEAD SECTION UNDERBELT )
10-53 MAIN CONVEYOR TAIL DRUM GUARD ASM (3.8M UNDERBELT AND 4.2M FOLDING HEAD SECTION UNDERBELT )
10-54 MAIN CONVEYOR IMPACT ROLLER ASM (3.8M UNDERBELT AND 4.2M FOLDING HEAD SECTION UNDERBELT )
10-3 MAIN CONVEYOR (4.2M FOLDING HEAD SECTION UNDERPAN) (OPTION TP550 ONLY)
10-01 MAIN CONVEYOR ASM - OVERVIEW
10-04 MAIN CONVEYOR MID SECTION ASM 1 (4.2M FOLDING HEAD SECTION UNDERPAN AND 4.2M FOLDING HEAD SECTION UNDERBELT)
10-05 MAIN CONVEYOR MID SECTION ASM 2 (4.2M FOLDING HEAD SECTION UNDERPAN AND 4.2M FOLDING HEAD SECTION UNDERBELT)
10-06 MAIN CONVEYOR MID SECTION ASM 3 (4.2M FOLDING HEAD SECTION UNDERPAN AND 4.2M FOLDING HEAD SECTION UNDERBELT)
10-07 MAIN CONVEYOR HEAD SECTION ASM 1 (4.2M FOLDING HEAD SECTION UNDERPAN AND 4.2M FOLDING HEAD SECTION UNDERBELT)
10-08 MAIN CONVEYOR HEAD SECTION ASM 2 (4.2M FOLDING HEAD SECTION UNDERPAN AND 4.2M FOLDING HEAD SECTION UNDERBELT)
10-09 MAIN CONVEYOR WING ROLLER ASM (4.2M FOLDING HEAD SECTION UNDERPAN AND 4.2M FOLDING HEAD SECTION UNDERBELT)
10-10 SPIRAL ROLLER WITH GUARD AND SCRAPER ASM (4.2M FOLDING HEAD SECTION UNDERPAN AND 4.2M FOLDING HEAD SECTION UNDERBELT)
10-11 SCRAPER AND TORQUE ARM ASM (4.2M FOLDING HEAD SECTION UNDERPAN AND 4.2M FOLDING HEAD SECTION UNDERBELT)
10-12 MAIN CONVEYOR DUST COVER ASM (4.2M FOLDING HEAD SECTION UNDERPAN AND 4.2M FOLDING HEAD SECTION UNDERBELT)
10-4 MAIN CONVEYOR (4.2M FOLDING HEAD SECTION UNDERBELT) (OPTION TP550 ONLY)
10-60 MAIN CONVEYOR ASM - OVERVIEW(4.2M FOLDING HEAD SECTION UNDERBELT) (OPTION I-140 ONLY)
10-5 DIRT CONVEYOR (LHS)
10-20 DIRT CONVEYOR OVERVIEW (LHS)
10-21 DIRT CONVEYOR TAIL SECTION ASM 1
10-22 DIRT CONVEYOR TAIL SECTION ASM 2
10-23 DIRT CONVEYOR TAIL SECTION ASM 3
10-24 DIRT CONVEYOR FEEDBOOT ASM (LHS AND RHS)
10-25 DIRT CONVEYOR SUPPORT STRUT ASM
10-26 DIRT CONVEYOR HEAD SECTION ASM 1
10-27 DIRT CONVEYOR HEAD SECTION ASM 2
10-28 DIRT CONVEYOR CHUTE SLIDER PAD ASM (LHS AND RHS)
10-29 DIRT CONVEYOR SCRAPER ASM (LHS AND RHS)
10-30 DIRT CONVEYOR WING ROLLER ASM (LHS AND RHS)
10-6 DIRT CONVEYOR (LHS)
10-70 DIRT CONVEYOR OVERVIEW (RHS)
10-71 DIRT CONVEYOR TAIL SECTION ASM 1
10-72 DIRT CONVEYOR TAIL SECTION ASM 2
10-73 DIRT CONVEYOR TAIL SECTION ASM 3
10-74 DIRT CONVEYOR SUPPORT STRUT ASM
10-75 DIRT CONVEYOR HEAD SECTION ASM 1
10-76 DIRT CONVEYOR HEAD SECTION ASM 2
11-01 CATWALK OVERVIEW
11-02 POWERUNIT CATWALK ASM
11-03 RHS CATWALK ASM
11-04 RHS CATWALK STEP ASM
11-05 CATWALK ACCESS PANEL ASM
11-06 LHS CATWALK ASM
11-07 LHS CATWALK STEP ASM
11-08 REAR HANDRAIL ASM
12-01 ELECTRICAL COMPONENTS
12-02 CONTROL PANEL DOOR
12-03 CONTROL PANEL INTERNAL COMPONENTS OVERVIEW
12-04 CONTROL PANEL CIRCUIT
12-05 CONTROL PANEL RELAYS
12-06 TIER 3 ENGINE HARNESS
12-07 TIER 3 STARTER MOTOR CABLE KIT
12-08 TIER 4 ENGINE HARNESS
12-09 TIER 4 STARTER MOTOR CABLE KIT
12-10 TIER 4 SCANIA CS ENGINE HARNESS
12-11 HYDRAULIC CABINET HARNESS
12-12 CHAMBER NODE 2 KIT
12-13 NODE CABLES
12-14 BATTERY CABLE KIT
12-15 FRONT HARNESS
12-16 VGF & PRE-SCREEN ELECTRICAL CHASSIS KIT
12-17 ELECTRICAL CHASSIS KIT 1
12-18 ELECTRICAL CHASSIS KIT 2
12-19 LED LIGHT TOWER ELECTRICAL KIT (OPTIONAL)
12-20 FLEXXAIRE FAN HARNESS (OPTIONAL)
12-23 PANEL, PLC, NODE & MISC
12-24 TIER 4 FUSE BOX SPARE PARTS
13-1 CHASSIS HYDRAULICS
13-01-01 BANK 4 CONTROL VALVE 1 ASM (PRESCREEN)
13-01-02 BANK 4 CONTROL VALVE 2 ASM (PRESCREEN)
13-3 HOPPER/FEEDER/PRESCREEN HYDRAULICS
13-03-01 HOPPER LOCKING PIN HYDRAULIC CYLINDER ASM
13-03-02 HOPPER RAM, HOSES AND FITTINGS
13-03-03 HOPPER CYLINDER, HOSES AND FITTINGS
13-03-04 REAR HOPPER CYLINDER, HOSES AND FITTINGS
13-03-05 VIBRATING UNIT MOTOR, HOSES AND FITTINGS
13-03-06 PRESCREEN HYDRAULIC MOTOR, HOSES AND FITTINGS
13-4 POWERUNIT HYDRAULICS
13-04-01 PUMP, HOSES AND FITTINGS
13-04-02 START UP MOTOR, HOSES AND FITTINGS
13-04-03 SCANIA DIESEL WATERTRAP BREAKDOWN, FITTINGS AND HOSES
13-04-04 BALANCE VALVE, HOSES AND FITTINGS
13-04-05 TWIN FILTER ASM AND DIESEL REFUELLING PUMP ASM
13-04-06 CHECK VALVE, PRESSURE RELIEF VALVE, HOSES AND FITTINGS
13-04-07 SPRAYBAR MANIFOLD, HOSES AND FITTINGS
13-04-08 FAN CONTROL BLOCK, HOSES AND FITTINGS
13-04-09 RETURN MANIFOLD ASM
13-04-10 PRESSURE REDUCING VALVE ASM
13-04-11 CLUTCH SOLENOID VALVE ASM
13-04-12 LH, RH PRESSURE FILTER ASM
13-04-13 PRESSURE REDUCING CYLINDER CONTROL VALVE, HOSES AND FITTINGS
13-04-14 RH PVG VALVE (6-BANK), HOSES AND FITTINGS 1
13-04-15 RH PVG VALVE (6-BANK), HOSES AND FITTINGS 2
13-04-16 LH PVG VALVE (5-BANK), HOSES AND FITTINGS 1
13-04-17 LH PVG VALVE (5-BANK), HOSES AND FITTINGS 2
13-04-18 RH PVG VALVE BREAKDOWN
13-04-19 LH PVG VALVE BREAKDOWN
13-04-20 HYDRAULIC RELIEF VALVE ASM
13-04-21 DC MOTOR BREAKDOWN, HOSES AND FITTINGS
13-04-22 OIL COOLER,HOSES AND FITTINGS
13-04-23 CHASSIS OIL COOLER, HOSES AND FITTINGS
13-04-24 CHAMBER CONTROL BLOCK, HOSES AND FITTINGS
13-04-25 TIER 3 CAT C13 ENGINE WATERTRAP BREAKDOWN, FITTINGS AND HOSES
13-7 IMPACTOR HYDRAULICS
13-07-01 IMPACTOR HYDRAULIC CYLINDER, HOSES AND FITTINGS
13-07-02 INLET LID HYDRAULIC CYLINDER, HOSES AND FITTINGS (OPTION)
13-07-03 APRONS HYDRAULIC CYLINDER, HOSES AND FITTINGS
13-07-04 HAZEMAG IMPACTOR HYDRAULIC CYLINDER, HOSES AND FITTINGS
13-9 CONVEYOR HYDRAULICS
13-09-01 MAIN CONVEYOR HYDRAULIC CYLINDER, HOSES AND FITTINGS 1
13-09-02 MAIN CONVEYOR HYDRAULIC CYLINDER, HOSES AND FITTINGS 2
13-09-03 MAIN CONVEYOR MOTOR, HOSES AND FITTINGS
13-09-04 MAIN CONVEYOR NON-RETURN VALVE, HOSES AND FITTINGS
13-09-05 SIDE CONVEYOR HYDRAULIC RAM, HOSES AND FITTINGS
13-09-06 SIDE CONVEYOR HYDRAULIC MOTOR, HOSES AND FITTINGS
14-01 PRESCREEN DIRT CHUTE ASM 1
14-02 PRESCREEN DIRT CHUTE ASM 2
14-03 UNDERPAN ASM OVERVIEW
14-04 UNDERPAN ASM
14-05 UNDERPAN WEAR PLATES
14-06 UNDERPAN GEAR BOX ASM
14-07 UNDERPAN FEED CHUTE ASM
14-08 UNDERPAN FEED CHUTE WEAR PLATES
14-09 CONTROL CABINET ASM
14-10 HYDRAULIC CABINET ASM
14-11 BATTERY CABINET ASM
14-12 DRIVE GUARDS AND GRP PANEL OVERVIEW
14-13 MAIN GRP DRIVE GUARD ASM
14-14 GRP MIDDLE DRIVE GUARD
14-15 UPPER DRIVESIDE GRP PANEL AND GRP SUPPORT FRAME ASM
14-16 LOWER DRIVESIDE GRP PANEL AND GRP SUPPORT FRAME ASM
14-17 OIL COOLER PANEL ASM
14-18 HYDRAULIC TANK RH FIXED FRAME AND UREA SIDE DOOR ASM
14-19 TOOL BOX ASM
14-20 TIER 4 FINAL SCANIA DC13 UREA TANK ASM
14-21 GEAR BOX MOTOR, HOSES AND FITTINGS
14-22 WORKING LIGHTS ASM (OPTION)
14-23 VGF DIRT CHUTE ASM 1
14-24 VGF DIRT CHUTE ASM 2
14-25 UNDERBELT CHUTE ASM 1
14-26 UNDERBELT CHUTE WEAR PLATES
14-27 UNDERBELT CHUTE CURTAIN ASM
15-01 MAGNET ASM, HOSES AND FITTINGS (OPTION)
15-02 MAGNET SINGLE POLE (OPTION)
15-03 HYDRAULIC WATER PUMP OVERVIEW (OPTION)
15-04 HYDRAULIC PUMP COMPONENTS 1 (OPTION)
15-05 HYDRAULIC PUMP COMPONENTS 2 (OPTION)
SBOM_5_000_332-MANUAL-TRAKPACTOR-550_13102017134526.pdfTRAKPACTOR 550
Table of Content
02-02 CHASSIS ASM 1
02-03 CHASSIS ASM 2
02-11 CHASSIS ASM 1
02-12 CHASSIS ASM 2
03-01 TRACK ASM 1
03-02 TRACK ASM 2
04-1 PRESCREEN
04-2 VGF
04-46 VGF ASM 1
04-47 VGF ASM 2
08-12 INLET LID ASM
12-13 NODE CABLES
12-15 FRONT HARNESS
14-04 UNDERPAN ASM
14-19 TOOL BOX ASM
- Powerscreen Crushing Warrior 1400 Parts Manual
- Powerscreen COMMANDER 1400 User Manual
- Powerscreen Trommel 615 Parts Manual
- Powerscreen Chieftain 2100
- Powerscreen Chieftain 1800 Spare Parts Listings
- Powerscreen Trommel 511 Spare Parts Listings
- Powerscreen Titan 1800 Spare Parts Listings
- Terex PowerScreen Horizon 6203 Parts Manual
- Powerscreen Powertrack 1400 Spare Parts Listings
- Powerscreen Phoenix 1200-1600 Spare Parts Listings
- PowerScreen Chieftain 2100X Parts Manual
- Powerscreen Chieftain 1400 Operator Manual
- Powerscreen Chieftain 2400
- Powerscreen 1300 Maxtrak Cone Crusher Service Manual 01-01-2013
- Powerscreen Warrior 2100 Operations Manual
