Hyundai
86
176,834
Perkins Engine 2506F-E15TA to 2806J-E18TTA Disassembly and Assembly Manual M0070446-04
Brand: Perkins
Type of Manual: Disassembly and Assembly Manual
Model: Perkins 2506F-E15TA, 2506J-E15TA, 2806FE18TA, 2806J-E18TA, 2806J-2806JE18TTA
Part Number: M0070446-04
Publication Date: 2019
Number of Pages: 334 Pages
Fuel Priming Pump - Remove and Install
Fuel Filter Base - Remove
Fuel Filter Base - Disassemble
Fuel Filter Base - Assemble
Fuel Filter Base - Install
Fuel Transfer Pump - Remove
Fuel Transfer Pump - Install
Fuel Pressure Regulator - Remove and Install
Fuel Manifold (ARD) - Remove and Install
Exhaust Cooler (NRS) - Remove and Install (For Series Turbocharger Applications)
Electronic Unit Injector - Remove
Electronic Unit Injector - Install
Electronic Unit Injector Sleeve - Remove
Electronic Unit Injector Sleeve - Install
Air Cleaner - Remove and Install
Turbocharger - Remove and Install (High Pressure Turbocharger - For Series Turbocharger Applications)
Turbocharger - Remove and Install (Low-Pressure Turbocharger - For Series Turbocharger Applications)
Turbocharger - Install
Solenoid Valve (Exhaust Balance) - Remove and Install
Air Control Valve - Remove and Install
Exhaust Gas Valve (NRS) - Remove and Install
Exhaust Gas Valve (NRS) - Disassemble
Exhaust Gas Valve (NRS) - Assemble
Nozzle Heater Harness - Remove and Install (Clean Emissions Module)
ARD Spark Plug - Remove and Install
Ignition Coil - Remove and Install
Diesel Exhaust Fluid Module - Disassemble
Diesel Exhaust Fluid Module - Assemble
Diesel Exhaust Fluid Lines - Remove and Install
Diesel Exhaust Fluid Pump - Remove and Install
DEF Injector and Mounting - Remove and Install
Electronic Control (Diesel Exhaust Fluid) - Remove and Install
Manifold (DEF Heater) - Remove and Install
Solenoid Valve (DEF Heater Coolant) - Remove and Install
Combustion Head - Remove and Install
Relay (ARD Nozzle Heater) - Remove and Install (Clean Emissions Module)
Flexible Exhaust Pipe - Remove and Install
Exhaust Manifold - Remove and Install
Exhaust Elbow - Remove and Install
Catalyst (SCR) - Remove and Install
Diesel Particulate Filter - Remove and Install
Catalyst - Remove and Install (Diesel Oxidation Catalyst (DOC) - Clean Emissions Module)
Inlet Module (Catalyst) - Remove and Install (Diesel Oxidation Catalyst (DOC))
Air Inlet Elbow - Remove and Install
Inlet and Exhaust Valve Springs - Remove and Install
Inlet and Exhaust Valves - Remove and Install
Inlet and Exhaust Valve Guides - Remove and Install
Engine Oil Filter Base - Remove (Remote Oil Filter Adapter)
Engine Oil Filter Base - Remove (Remote Engine Oil Filter Base)
Engine Oil Filter Base - Remove (2806F-E18TA and 2806J-E18TA Engine Oil Filter Base)
Engine Oil Filter Base - Remove (2506F-E15TA and 2506J-E15TA Engine Oil Filter Base)
Engine Oil Filter Base - Disassemble (Remote Oil Filter Adapter)
Engine Oil Filter Base - Disassemble (Remote Engine Oil Filter Base)
Engine Oil Filter Base - Disassemble (2806F-E18TA and 2806J-E18TA Engine Oil Filter Base)
Engine Oil Filter Base - Disassemble (2506F-E15TA and 2506J-E15TA Engine Oil Filter Base)
Engine Oil Filter Base - Assemble (Remote Oil Filter Adapter)
Engine Oil Filter Base - Assemble (Remote Engine Oil Filter Base)
Engine Oil Filter Base - Assemble (2806F-E18TA and 2806J-E18TA Engine Oil Filter Base)
Engine Oil Filter Base - Assemble (2506F-E15TA and 2506J-E15TA Engine Oil Filter Base)
Engine Oil Filter Base - Install (Remote Oil Filter Adapter)
Engine Oil Filter Base - Install (Remote Engine Oil Filter Base)
Engine Oil Filter Base - Install (2806F-E18TA and 2806J-E18TA Engine Oil Filter Base)
Engine Oil Filter Base - Install (2506F-E15TA and 2506J-E15TA Engine Oil Filter Base)
Engine Oil Cooler - Remove (2806F-E18TA and 2806J-E18TA Engine Oil Cooler)
Engine Oil Cooler - Remove (2506F-E15TA and 2506J-E15TA Engine Oil Cooler)
Engine Oil Cooler - Install (2806F-E18TA and 2806JE18TA Engine Oil Cooler)
Engine Oil Cooler - Install (2506F-E15TA and 2506JE15TA Engine Oil Cooler)
Engine Oil Pump - Remove
Engine Oil Pump - Disassemble
Engine Oil Pump - Assemble
Engine Oil Pump - Install
Variable Valve Actuator Oil Pressure Sensor - Remove and Install (For Series Turbocharger Applications)
Variable Valve Actuator Oil Pressure Solenoid - Remove and Install (For Series Turbocharger Applications)
Water Pump - Remove
Water Pump - Disassemble
Water Pump - Assemble
Water Pump - Install
Water Temperature Regulator Housing - Remove and Install
Precooler - Remove and Install (For Series Turbocharger Applications)
Engine Support (Front) - Remove and Install
Flywheel - Remove
Flywheel - Install
Crankshaft Rear Seal - Remove
Crankshaft Rear Seal - Install
Flywheel Housing - Remove and Install
Vibration Damper and Pulley - Remove and Install
Crankshaft Front Seal - Remove
Crankshaft Front Seal - Install
Front Cover - Remove
Front Cover - Install
Gear Group (Front) - Remove
Gear Group (Front) - Install
Housing (Front) - Remove
Housing (Front) - Install
Crankcase Breather - Remove and Install (Open Crankcase Breather)
Valve Mechanism Cover - Remove and Install
Valve Mechanism Cover Base - Remove and Install
Valve Actuator (Variable) - Remove
Valve Actuator (Variable) - Install
Rocker Arm and Shaft - Remove
Rocker Arm - Disassemble
Rocker Arm - Assemble
Rocker Arm and Shaft - Install
Cylinder Head - Remove
Cylinder Head - Install
Camshaft - Remove
Camshaft - Install
Camshaft Gear - Remove and Install
Camshaft Bearings - Remove
Camshaft Bearings - Install
Engine Oil Pan - Remove and Install
Cylinder Liner - Remove
Cylinder Liner - Install
Piston Cooling Jets - Remove and Install
Pistons and Connecting Rods - Remove
Pistons and Connecting Rods - Disassemble
Pistons and Connecting Rods - Assemble
Pistons and Connecting Rods - Install
Connecting Rod Bearings - Remove (Connecting Rods in Position)
Connecting Rod Bearings - Install (Connecting Rods in Position)
Crankshaft Main Bearings - Remove
Crankshaft Main Bearings - Install
Crankshaft - Remove
Crankshaft - Install
Bearing Clearance - Check
Refrigerant Compressor - Remove and Install
Nitrogen Oxide Sensor - Remove and Install
Atmospheric Pressure Sensor - Remove and Install
Camshaft Position Sensor - Remove and Install
Crankshaft Position Sensor - Remove and Install. 255
Coolant Temperature Sensor - Remove and Install
Engine Oil Pressure Sensor - Remove and Install
Crankcase Pressure Sensor - Remove and Install260
Fuel Pressure Sensor - Remove and Install
Fuel Temperature Sensor - Remove and Install
Pressure Sensor (ARD Combustion Air) - Remove and Install
Temperature Sensor (Catalyst Inlet) - Remove and Install
Temperature Sensor (DPF Inlet, Flame Detect) - Remove and Install
Pressure Sensor (DPF) - Remove and Install (Inlet Pressure Sensor (DPF))
Pressure Sensor (DPF) - Remove and Install (Differential Pressure Sensor)
Temperature Sensor (Cooled Exhaust Gas) - Remove and Install
Pressure Sensor (Cooled Exhaust Gas) - Remove and Install (Differential Pressure)
Pressure Sensor (Cooled Exhaust Gas) - Remove and Install (Outlet Pressure)
Boost Pressure Sensor - Remove and Install
Inlet Air Temperature Sensor - Remove and Install
Inlet Manifold Pressure Sensor - Remove and Install
Temperature Sensor - Remove and Install (Selective Catalytic Reduction (SCR) Inlet Temperature Sensor)
Venturi Tube - Remove and Install
Jacket Water Heater - Remove and Install
Alternator Belt - Remove and Install
Idler Pulley - Remove and Install (Grooved Idler Pulley)
Idler Pulley - Remove and Install (Flat Idler Pulley)
Belt Tensioner - Remove and Install
Belt Tightener - Remove
Belt Tightener - Disassemble
Belt Tightener - Assemble
Belt Tightener - Install
Fan Drive - Remove
Fan Drive - Disassemble
Fan Drive - Assemble
Fan Drive - Install
Pump Drive - Remove (Transfer Pump)
Pump Drive - Disassemble (Transfer pump)
Pump Drive - Assemble (Transfer pump)
Pump Drive - Install (Transfer Pump)
Electronic Control Module - Remove and Install
Electronic Control (Aftertreatment) - Remove and Install (2806F-E18TA and 2806J-E18TA Electronic Control (Aftertreatment) (Engine Mounted)
Electronic Control (Aftertreatment) - Remove and Install (2506F-E15TA and 2506J-E15TA Electronic Control (Aftertreatment) (Off Engine Mounted)... 311
Voltage Load Protection Module - Remove and Install
Alternator - Remove and Install
Alternator - Remove
Alternator - Install
Electric Starting Motor - Remove and Install
Air Compressor - Remove and Install (Twin Cylinder Compressor)
Air Compressor - Remove and Install (Single Cylinder)
