NIFTYLIFT Towable Boom Lifts TM50 48378 Operating Service Parts Manual And Diagram 2022
Brand: NIFTYLIFT
Type of Machine: Towable Boom Lifts
Type of Manual: Service Manual, Operating Manual, Parts Manual, Electrical Schematic, Hydraulic Schematic, Hose Diagram
Model: NIFTYLIFT TM50 Towable Boom Lifts
Serial Number: 48378
Publication Date: 2022
List of Files:
01_ELECTRICAL SCHEMATIC D80473 (issue 018) 48378.pdf (4 Pages)
02_HYDRAULIC DIAGRAM 170H INST D80483 (issue 014) 48378.pdf (1 Pages)
03_HOSE DIAGRAM 170H INSTINCTIVE D80571 (issue 006) 48378.pdf (1 Pages)
04_LIFTING POINTS, 170H D80906 (issue 004) 48378.pdf (2 Pages)
05_170 TM50 PARTS MANUAL M50150 (issue 018) 48378.pdf (130 Pages)
Front cover
Parts Order Form
chassis assembly
1.1 Base assembly
1.2 Traction drive assembly
1.3 Bike bar assemblies
1.4 Stabiliser assembly
1.5 Tow coupling assembly
1.6 Heavy duty jockey wheel
1.7 Lighting assemblies
1.8 Wheel hub assembly
1.9 Wheel hub assembly (Axle P15305)
1.10 Valve block (Traction drive)
1.11 auto power inlet unit (UK)
superstructure
2.1 Power tray (Petrol/Diesel/Bi-energy)
2.2 Power tray (AC/Mains)
2.3 Power tray (DC - Lithium)
2.4 Slew assembly
2.5 Control valve assembly (3 spool)
2.6 Control valve assembly (4 spool)
2.7 Button box assemblies
2.8 Control box
2.9 Diesel box
2.10 AC transformer box
2.11 DC Power pack
2.12 AC Power pack
2.13 Diesel engine (Kubota OC60)
2.14 Anderson connector
boom assemblies
3.1 Upper boom assembly
3.2 Lower boom assembly
3.3 Lift cylinder
3.4 Levelling cylinder
3.5 Telescope cylinder
3.6 Levelling valve
cage assembly
4.1 Non-swivel cage assembly
4.2 Swivel cage assembly (Option)
4.3 Cage assembly (Fibreglass)
4.4 Non- swivel cage weigh assembly
4.5 Swivel cage weigh assembly
4.6 Control valve assembly
4.7 Button box assembly
labelling
5.1 Label locations 170
5.2 Label locations TM50 (USA)
Labels 1 to 31
Labels 30 to 52
hydraulic hoses
6.1 Hose kit 170H (TM50)
06_Honda GX160 Operators Manual M50294 (issue 001) 48378.pdf (60 Pages)
INTRODUCTION
SAFETY MESSAGES
CONTENTS
SAFETY INFORMATION
SAFETY LABEL LOCATION
COMPONENT & CONTROL LOCATION
FEATURES
OIL ALERT® SYSTEM (APPLICABLE TYPES)
CIRCUIT PROTECTOR (APPLICABLE TYPES)
BEFORE OPERATION CHECKS
IS YOUR ENGINE READY TO GO?
OPERATION
SAFE OPERATING PRECAUTIONS
STARTING THE ENGINE
STOPPING THE ENGINE
SETTING ENGINE SPEED
SERVICING YOUR ENGINE
THE IMPORTANCE OF MAINTENANCE
MAINTENANCE SAFETY
SAFETY PRECAUTIONS
MAINTENANCE SCHEDULE
REFUELING
RECOMMENDED FUEL
ENGINE OIL
RECOMMENDED OIL
OIL LEVEL CHECK
OIL CHANGE
REDUCTION CASE OIL (APPLICABLE TYPES)
RECOMMENDED OIL
OIL LEVEL CHECK
OIL CHANGE
AIR CLEANER
INSPECTION
CLEANING
SEDIMENT CUP
CLEANING
SPARK PLUG
RECOMMENDED SPARK PLUGS
SPARK ARRESTER (APPLICABLE TYPES)
REMOVAL
CLEANING & INSPECTION
IDLE SPEED
ADJUSTMENT
HELPFUL TIPS & SUGGESTIONS
STORING YOUR ENGINE
STORAGE PREPARATION
CLEANING
FUEL
DRAINING THE FUEL TANK AND CARBURETOR
ENGINE OIL
STORAGE PRECAUTIONS
REMOVAL FROM STORAGE
TRANSPORTING
TAKING CARE OF UNEXPECTED PROBLEMS
FUSE REPLACEMENT (APPLICABLE TYPES)
TECHNICAL & CONSUMER INFORMATION
TECHNICAL INFORMATION
SERIAL NUMBER LOCATION
BATTERY CONNECTIONS FOR ELECTRIC STARTER (APPLICABLE TYPES)
REMOTE CONTROL LINKAGE
CARBURETOR MODIFICATIONS FOR HIGH ALTITUDE OPERATION
OXYGENATED FUELS
EMISSION CONTROL SYSTEM INFORMATION
AIR INDEX
SPECIFICATIONS
QUICK REFERENCE INFORMATION
WIRING DIAGRAMS
DISTRIBUTOR/DEALER LOCATOR INFORMATION
CUSTOMER SERVICE INFORMATION
FRANÇAIS
ESPAÑOL
07_TM50 SERVICE MANUAL M50593 (issue 001) 48378.pdf (69 Pages)
1.1 Foreword
1.2 Warranty
1.3 Scope
1.4.1 Pre-maintenance checks
1.4.2 Maintenance information
1.4.3 Frequent inspection
1.4.4 Annual inspection
1.5.3 Diesel system safety
1.5.4 Electrical safety
1.5.5 Hydraulic safety
1.5.6 Environmental awareness
2 Specifications
2.1 Engine specifications
2.2 Fluid properties
2.2.1 Fluid volumes
2.2.2 Engine oil specifications
2.2.3 Hydraulic oil specifications
2.3 Hydraulic pressure settings
2.4 Tire specifications
2.5 Torque settings
2.5.1 Torque Settings - Kubota OC60 engine
2.6 Hydraulic hose and fitting torque specifications
3 Preventative maintenance
3.1 Maintenance schedules
3.1.1 Engine maintenance
3.1.2 Machine maintenance
3.2 Consumables
3.2.2 Engine oil level check
3.2.3 Engine oil replace
3.2.4 Engine oil strainer
3.2.5 Air filter element maintenance
3.2.6 Fuel filter clean / replace
3.2.7 Fuel pipe check
3.2.8 Fuel tank maintenance
3.2.9 Fuel injector nozzle
3.2.10 Fuel injection pump
3.2.11 Exhaust system inspect
3.2.12 Valve clearance
3.3 Wheels and tires
3.3.1 Tire condition check
3.3.2 Tire pressure check
3.3.3 Wheel nut torque (Monthly)
3.4 Axle suspension
3.4.1 Axle inspection
3.5 Traction drive
3.6 Tow coupler
3.7 Braking system
3.7.1 Brake adjustment
3.8 Fenders
3.9 Stabilizers
3.9.1 Stabilizer foot plate check and lubricate (monthly)
3.9.2 Stabilizer pivot pins
3.10 Hub bearings
3.10.1 Hub bearing check
3.10.2 Hub bearing adjustment
3.10.3 Hub bearing inspection and lubrication
3.11 Lighting
3.11.1 Bulb replacement
3.12 Batteries
3.12.1 Condition check (daily)
3.12.2 Condition check (weekly) - excludes Li-ion batteries
3.12.3 Storage
3.13 Hydraulic oil
3.13.1 Level check (weekly)
3.13.2 Pressure filter check (weekly)
3.13.3 Hydraulic oil and filters replace
3.14 Telescopic boom
3.14.1 Wear pad check & lubricate (monthly)
3.14.2 Hose trunking and energy chain check (weekly)
3.14.3 Boom pivot pin check (daily)
3.14.4 Lubricate boom pivot bushes (annually)
3.15 Boom rotation gear
3.15.1 Rotation gear engagement check (monthly)
3.15.2 Lubricate rotation gear worm (monthly)
3.15.3 Lubricate rotation ring (monthly)
3.15.4 Rotation ring bolts check (annually)
4 Repair procedures
4.1 General
4.1.1 Fuses
4.1.2 Li-ion battery fuse
4.2 Platform/Basket
4.3 Booms
4.3.1 Energy chain link
4.4 Base assembly
4.4.1 Engine Exhaust
4.4.2 Exhaust Assembly - Gasoline
4.4.3 Stabilizer microswitch
4.5 Axle
4.5.1 Hub bearing replacement
4.5.2 Brake shoe replacement
5 System overview
5.1 Introduction
5.1.1 Diesel / gasoline system
5.1.2 DC electric system
5.1.3 Charging and batteries
5.1.4 Battery charging - extension cords
5.1.5 AC power system
5.2 Bi-Energy system
5.2.1 Duty selector
5.3 Boom system
5.3.1 Boom switch
5.4 Hydraulic system overview
5.5 Hydraulic pump
5.6 Control logic
6 Troubleshooting guide
6.1 Trouble shooting information
6.3 Engine fault finding
6.3.1 Diesel engine
6.3.2 Gasoline engine
6.4 Braking system
6.5 Li-ion battery system
08_TM50 OPERATING MANUAL (USA) M50903 (issue 002) 48378.pdf (40 Pages)
Brand: NIFTYLIFT
List of Files:
Front cover
Parts Order Form
chassis assembly
1.1 Base assembly
superstructure
2.4 Slew assembly
2.8 Control box
2.9 Diesel box
2.11 DC Power pack
2.12 AC Power pack
boom assemblies
3.3 Lift cylinder
3.6 Levelling valve
cage assembly
labelling
Labels 1 to 31
Labels 30 to 52
hydraulic hoses
INTRODUCTION
SAFETY MESSAGES
CONTENTS
SAFETY INFORMATION
FEATURES
OPERATION
STARTING THE ENGINE
STOPPING THE ENGINE
MAINTENANCE SAFETY
SAFETY PRECAUTIONS
REFUELING
RECOMMENDED FUEL
ENGINE OIL
RECOMMENDED OIL
OIL LEVEL CHECK
OIL CHANGE
RECOMMENDED OIL
OIL LEVEL CHECK
OIL CHANGE
AIR CLEANER
INSPECTION
CLEANING
SEDIMENT CUP
CLEANING
SPARK PLUG
REMOVAL
IDLE SPEED
ADJUSTMENT
STORING YOUR ENGINE
STORAGE PREPARATION
CLEANING
FUEL
ENGINE OIL
STORAGE PRECAUTIONS
TRANSPORTING
OXYGENATED FUELS
AIR INDEX
SPECIFICATIONS
WIRING DIAGRAMS
FRANÇAIS
ESPAÑOL
1.1 Foreword
1.2 Warranty
1.3 Scope
2 Specifications
2.2.1 Fluid volumes
2.5 Torque settings
3.2 Consumables
3.4 Axle suspension
3.5 Traction drive
3.6 Tow coupler
3.7 Braking system
3.8 Fenders
3.9 Stabilizers
3.10 Hub bearings
3.11 Lighting
3.12 Batteries
3.12.3 Storage
3.13 Hydraulic oil
4 Repair procedures
4.1 General
4.1.1 Fuses
4.2 Platform/Basket
4.3 Booms
4.4 Base assembly
4.5 Axle
5 System overview
5.1 Introduction
5.2.1 Duty selector
5.3 Boom system
5.3.1 Boom switch
5.5 Hydraulic pump
5.6 Control logic
6.3.1 Diesel engine
6.4 Braking system
