NIFTYLIFT Towable Boom Lifts TM34 62741 Operating Service Parts Manual And Diagram 2025 EN FR
Language: English, French
Brand: NIFTYLIFT
Type of Machine: Towable Boom Lifts
Type of Manual: Service Manual, Operating Manual, Parts Manual, Electrical Schematic, Hydraulic Schematic,
Model: NIFTYLIFT TM34 Towable Boom Lifts
Serial Number: 62741
Publication Date: 2025
List of Files:
01_WORKING ENVELOPE, 120M D80016 (issue 003) 62741.pdf (2 Pages)
Sheets and Views
D80016_003-Metric
D80016_003-Imperial
02_SCHEMATIC - ELECTRICAL D80169 (issue 020) 62741.pdf (3 Pages)
Sheets and Views
8 - D80169_020-Model
03_LIFTING POINTS, 120M D81193 (issue 004) 62741.pdf (2 Pages)
Sheets and Views
D81193_004-English
D81193_004-French
04_120M TM34M ECO Hydraulic Schematic D82193 (issue 001) 62741.pdf (1 Pages)
Sheets and Views
Model
05_STOWED DIMENSIONS, 120M D82249 (issue 001) 62741.pdf (1 Pages)
Sheets and Views
D82249_001-Sheet 1
06_120M TM34M PARTS MANUAL M50111 (issue 019) 62741.pdf (94 Pages)
Front Cover
Parts Order Form
chassis assembly
1.1 Base assembly
1.2 Manual jack assembly
1.3 Tow coupling assembly
1.4 Jockey wheel assembly
1.5 Heavy duty jockey wheel
1.6 Lighting assemblies
1.7 Metal Light Support (Options)
1.8 Wheel hub assembly
superstructure
2.1 Power tray (Petrol/Diesel/Bi-energy)
2.2 Power tray (AC/Mains)
2.3 Slew assembly
2.4 Control valve assembly (3 spool)
2.5 Button box assemblies
2.6 Control box
2.7 AC transformer box
2.8 DC Power pack
2.9 AC Power pack
2.10 Diesel engine (Kubota OC60)
2.11 Battery charger
boom assemblies
3.1 Booms assembly
3.2 Lift cylinder
cage assembly
4.1 Cage assembly
4.2 Cage assembly (Fibreglass)
4.3 Cage weigh assembly
4.4 Control valve assembly (3 spool)
4.5 Button box assemblies
labelling
5.1 Label locations 120M
5.2 Label locations TM34M (USA)
Labels 1 - 33
Labels 34 - 47
07_Honda GX160 Operators Manual M50294 (issue 001) 62741.pdf (60 Pages)
INTRODUCTION
SAFETY MESSAGES
CONTENTS
SAFETY INFORMATION
SAFETY LABEL LOCATION
COMPONENT & CONTROL LOCATION
FEATURES
OIL ALERT® SYSTEM (APPLICABLE TYPES)
CIRCUIT PROTECTOR (APPLICABLE TYPES)
BEFORE OPERATION CHECKS
IS YOUR ENGINE READY TO GO?
OPERATION
SAFE OPERATING PRECAUTIONS
STARTING THE ENGINE
STOPPING THE ENGINE
SETTING ENGINE SPEED
SERVICING YOUR ENGINE
THE IMPORTANCE OF MAINTENANCE
MAINTENANCE SAFETY
SAFETY PRECAUTIONS
MAINTENANCE SCHEDULE
REFUELING
RECOMMENDED FUEL
ENGINE OIL
RECOMMENDED OIL
OIL LEVEL CHECK
OIL CHANGE
REDUCTION CASE OIL (APPLICABLE TYPES)
RECOMMENDED OIL
OIL LEVEL CHECK
OIL CHANGE
AIR CLEANER
INSPECTION
CLEANING
SEDIMENT CUP
CLEANING
SPARK PLUG
RECOMMENDED SPARK PLUGS
SPARK ARRESTER (APPLICABLE TYPES)
REMOVAL
CLEANING & INSPECTION
IDLE SPEED
ADJUSTMENT
HELPFUL TIPS & SUGGESTIONS
STORING YOUR ENGINE
STORAGE PREPARATION
CLEANING
FUEL
DRAINING THE FUEL TANK AND CARBURETOR
ENGINE OIL
STORAGE PRECAUTIONS
REMOVAL FROM STORAGE
TRANSPORTING
TAKING CARE OF UNEXPECTED PROBLEMS
FUSE REPLACEMENT (APPLICABLE TYPES)
TECHNICAL & CONSUMER INFORMATION
TECHNICAL INFORMATION
SERIAL NUMBER LOCATION
BATTERY CONNECTIONS FOR ELECTRIC STARTER (APPLICABLE TYPES)
REMOTE CONTROL LINKAGE
CARBURETOR MODIFICATIONS FOR HIGH ALTITUDE OPERATION
OXYGENATED FUELS
EMISSION CONTROL SYSTEM INFORMATION
AIR INDEX
SPECIFICATIONS
QUICK REFERENCE INFORMATION
WIRING DIAGRAMS
DISTRIBUTOR/DEALER LOCATOR INFORMATION
CUSTOMER SERVICE INFORMATION
FRANÇAIS
ESPAÑOL
08_TM34M SERVICE MANUAL - USA M50796 (issue 001) 62741.pdf (61 Pages)
1.1 Foreword
1.2 Warranty
1.3 Scope
1.4.1 Pre-maintenance checks
1.4.2 Maintenance information
1.4.3 Frequent inspection
1.4.4 Annual inspection
1.5.3 Diesel system safety
1.5.4 Electrical safety
1.5.5 Hydraulic safety
1.5.6 Environmental awareness
2 Specifications
2.1 Engine specifications
2.2 Fluid properties
2.2.1 Fluid volumes
2.2.2 Engine oil specifications
2.2.3 Hydraulic oil specifications
2.2.4 Hydraulic pressure settings
2.3 Tire specifications
2.4 Torque settings
2.4.1 Torque Settings - Kubota OC60 engine
2.5 Hydraulic hose and fitting torque specifications
3 Preventative maintenance
3.1 Maintenance schedules
3.1.1 Engine maintenance
3.1.2 Machine maintenance
3.2 Consumables
3.3 Engine maintenance procedures
3.3.1 Engine oil level check
3.3.2 Engine oil replace
3.3.3 Engine oil strainer - clean
3.3.4 Air filter element maintenance
3.3.5 Fuel tank maintenance
3.3.6 Fuel filter
3.3.7 Fuel injector nozzle
3.3.8 Fuel injection pump
3.3.9 Sediment cup
3.3.10 Fuel hoses
3.3.11 Exhaust system inspect
3.3.12 Valve clearance
3.3.13 Combustion chamber
3.3.14 Spark plug
3.3.15 Spark arrester
3.4 Wheels and tires
3.4.1 Tire condition check
3.4.2 Tire pressure check
3.4.3 Wheel nut torque
3.5 Axle
3.5.1 Axle locating pin inspection and lubricate (monthly)
3.5.2 Axle slides inspection and lubricate (monthly)
3.5.3 Axle inspection (annually)
3.6 Tow coupler
3.7 Braking system
3.7.1 Brake adjustment
3.8 Fenders
3.9 Outriggers
3.9.1 Outrigger inspection and lubricate (monthly)
3.9.2 Manual jack foot plate inspection and lubricate (monthly)
3.10 Hub bearings
3.10.1 Hub bearing check
3.10.2 Hub bearing adjustment
3.10.3 Hub bearing inspection and lubrication
3.11 Lighting
3.11.1 Bulb replacement
3.12 Batteries
3.12.1 Condition check (daily)
3.12.2 Condition check (weekly) - excludes AGM and start battery
3.12.3 Storage
3.13 Hydraulic oil
3.13.1 Level check (weekly)
3.13.2 Pressure filter check (weekly)
3.13.3 Hydraulic oil and filters replace
3.14 Booms
3.14.1 Boom pivot pin check (daily)
3.14.2 Lubricate boom pivot bushes (annually)
3.15 Boom rotation gear
3.15.1 Rotation gear engagement check (monthly)
3.15.2 Rotation gear and worm lubricate (monthly)
3.15.3 Center post lubricate (monthly)
3.15.4 Rotation ring bolts check (annually)
4 Repair procedures
4.1 General
4.1.1 Fuses
4.2 Platform/Basket
4.3 Axle
4.3.1 Brake shoe replacement
5 System overview
5.1 Introduction
5.1.1 Diesel / gasoline system
5.1.2 DC electric system
5.1.3 AC power system
5.1.4 AC/DC power system
5.2 Charging and batteries
5.2.1 Battery charging - extension cords
5.3 Bi-Energy system
5.3.1 Power source selection
5.4 Hydraulic system overview
5.5 Hydraulic pump
5.6 Control logic
6 Troubleshooting guide
6.1 Trouble shooting information
6.3 Engine fault finding
6.3.1 Diesel engine
6.3.2 Gasoline engine
6.4 Braking system
09_TM34 OPERATING MANUAL (USA) M50900 (issue 004) 62741.pdf (45 Pages)
Blank Page
Brand: NIFTYLIFT
List of Files:
Sheets and Views
D80016_003-Metric
D80016_003-Imperial
Sheets and Views
Sheets and Views
D81193_004-English
D81193_004-French
Sheets and Views
Model
Sheets and Views
D82249_001-Sheet 1
Front Cover
Parts Order Form
chassis assembly
1.1 Base assembly
superstructure
2.3 Slew assembly
2.6 Control box
2.8 DC Power pack
2.9 AC Power pack
boom assemblies
3.1 Booms assembly
3.2 Lift cylinder
cage assembly
4.1 Cage assembly
labelling
Labels 1 - 33
Labels 34 - 47
INTRODUCTION
SAFETY MESSAGES
CONTENTS
SAFETY INFORMATION
FEATURES
OPERATION
STARTING THE ENGINE
STOPPING THE ENGINE
MAINTENANCE SAFETY
SAFETY PRECAUTIONS
REFUELING
RECOMMENDED FUEL
ENGINE OIL
RECOMMENDED OIL
OIL LEVEL CHECK
OIL CHANGE
RECOMMENDED OIL
OIL LEVEL CHECK
OIL CHANGE
AIR CLEANER
INSPECTION
CLEANING
SEDIMENT CUP
CLEANING
SPARK PLUG
REMOVAL
IDLE SPEED
ADJUSTMENT
STORING YOUR ENGINE
STORAGE PREPARATION
CLEANING
FUEL
ENGINE OIL
STORAGE PRECAUTIONS
TRANSPORTING
OXYGENATED FUELS
AIR INDEX
SPECIFICATIONS
WIRING DIAGRAMS
FRANÇAIS
ESPAÑOL
1.1 Foreword
1.2 Warranty
1.3 Scope
2 Specifications
2.2.1 Fluid volumes
2.4 Torque settings
3.2 Consumables
3.3.6 Fuel filter
3.3.9 Sediment cup
3.3.10 Fuel hoses
3.3.14 Spark plug
3.5 Axle
3.6 Tow coupler
3.7 Braking system
3.8 Fenders
3.9 Outriggers
3.10 Hub bearings
3.11 Lighting
3.12 Batteries
3.12.3 Storage
3.13 Hydraulic oil
3.14 Booms
4 Repair procedures
4.1 General
4.1.1 Fuses
4.2 Platform/Basket
4.3 Axle
5 System overview
5.1 Introduction
5.5 Hydraulic pump
5.6 Control logic
6.3.1 Diesel engine
6.4 Braking system
Blank Page
