NIFTYLIFT Towable Boom Lifts 120TAC 43631 Operating Service Parts Manual And Diagram 2019
Brand: NIFTYLIFT
Type of Machine: Towable Boom Lifts
Type of Manual: Service Manual, Operating Manual, Parts Manual, Electrical Schematic, Hydraulic Schematic, Hose Diagram
Model: NIFTYLIFT 120TAC Towable Boom Lifts
Serial Number: 43631
Publication Date: 2019
List of Files:
01_HOSE DIAGRAM 120T INSTINCTIVE D80280 (issue 005) 43631.pdf (1 Pages)
02_HYD CIRCUIT 120T DRIVEN INSTINCTIVE D80532 (issue 011) 43631.pdf (1 Pages)
03_LIFTING POINTS, 120T D80541 (issue 005) 43631.pdf (2 Pages)
04_WIRING DIAGRAM 120TAC- UK EN280 C. WEIGH D80612 (issue 020) 43631.pdf (5 Pages)
05_120T TM34T PARTS MANUAL M50120 (issue 018) 43631.pdf (128 Pages)
chassis assembly
1.1 Base assembly - Sliding axle
1.2 Base assembly - Fixed axle
1.3 Traction drive assembly
1.4 Stabiliser assembly
1.5 Tow coupling assembly
1.6 Jockey wheel assembly
1.7 Heavy duty jockey wheel
1.8 Lighting assemblies
1.9 Wheel hub assembly
1.10 Valve block (Traction drive)
superstructure
2.1 Power tray (P/D/E/PE)
2.2 Power tray (AC/DC)
2.3 Power tray (AC)
2.4 Power tray (DC - Lithium)
2.5 Slew assembly
2.6 Control valve assembly (3 spool)
2.7 Control valve assembly (4 spool)
2.8 Button box assemblies
2.9 PCB Control box
2.10 AC transformer box
2.11 AC/DC transformer box
2.12 DC Power pack
2.13 AC Power pack
2.14 DC Power pack (AC/DC machine)
2.15 Battery charger (UK)
2.16 Battery charger (Euro/Australia & USA)
boom assemblies
3.1 Booms assembly
3.2 Lift cylinder
3.3 Levelling cylinder
3.4 Telescope cylinder
3.5 Energy chain
cage assembly
4.1 Cage assembly
4.2 Cage assembly (Fibreglass)
4.3 Cage weigh assembly
4.4 Control valve assembly (Cage)
4.5 Button box assemblies
labelling
5.1 Label locations 120T
5.2 Label locations TM34T
Labels 1-31
Labels 32-52
hydraulic hoses
6.1 Hose kit 120T (TM34T)
6.2 Traction Drive Kit (P14205)
06_120T TM34T OPERATING MANUAL UK USA M50121 (issue 009) 43631.pdf (55 Pages)
07_120T SERVICE MANUAL M50570 (issue 001) 43631.pdf (65 Pages)
1.1 Foreword
1.2 Warranty
1.3 Scope
1.4.1 Pre-maintenance checks
1.4.2 Maintenance information
1.4.3 Frequent inspection
1.4.4 Annual inspection
1.5.3 Diesel system safety
1.5.4 Electrical safety
1.5.5 Hydraulic safety
1.5.6 Environmental awareness
2 Specifications
2.1 Engine specifications
2.2 Fluid properties
2.2.1 Fluid volumes
2.2.2 Engine oil specifications
2.2.3 Hydraulic oil specifications
2.2.4 Hydraulic pressure settings
2.3 Tyre specifications
2.4 Torque settings
2.5 Hydraulic hose and fitting torque specifications
3 Preventative maintenance
3.1 Maintenance schedules
3.1.1 Engine maintenance
3.1.2 Machine maintenance
3.2 Consumables
3.3 Engine maintenance procedures
3.3.1 Engine oil level check
3.3.2 Engine oil replace
3.3.3 Engine oil filter replace
3.3.4 Air filter element maintenance
3.3.5 Fuel filter and fuel tank maintenance
3.3.6 Fuel injector nozzle
3.3.7 Sediment cup
3.3.8 Cylinder compression
3.3.9 Fuel hoses
3.3.10 Exhaust system inspect
3.3.11 Valve clearance
3.3.12 Combustion chamber
3.3.13 Spark plug
3.3.14 Spark arrester
3.4 Wheels and tyres
3.4.1 Tyre condition check
3.4.2 Tyre pressure check
3.4.3 Wheel nut / bolt torque
3.5 Axle suspension
3.5.1 Axle inspection
3.6 Traction drive
3.7 Tow hitch
3.8 Braking system
3.8.1 Brake adjustment
3.9 Mudguards
3.10 Stabilisers
3.10.1 Stabiliser foot plate inspection and lubricate (monthly)
3.10.2 Stabiliser pivot pins
3.11 Hub bearings
3.11.1 Hub bearing check
3.11.2 Hub bearing adjustment
3.11.3 Hub bearing inspection and lubrication
3.12 Lighting
3.12.1 Bulb replacement
3.13 Batteries
3.13.1 Condition check (daily)
3.13.2 Condition check (weekly) - excludes AGM & Li-ion batteries
3.13.3 Storage
3.14 Hydraulic oil
3.14.1 Level check (weekly)
3.14.2 Pressure filter check (weekly)
3.14.3 Hydraulic oil and filters replace
3.15 Telescopic boom
3.15.1 Wear pad check & lubricate (monthly)
3.15.2 Hose trunking and energy chain check (weekly)
3.15.3 Boom pivot pin check (daily)
3.15.4 Lubricate boom pivot bushes (annually)
3.16 Boom rotation gear
3.16.1 Slew gear engagement check (monthly)
3.16.2 Lubricate slew ring (monthly)
3.16.3 Slew ring bolts check (annually)
4 Repair procedures
4.1 General
4.1.1 Fuses
4.2 Platform/Cage
4.3 Booms
4.3.1 Energy chain link
4.4 Base assembly
4.4.1 Stabiliser microswitch
4.5 Axle
4.5.1 Brake shoe replacement
5 System overview
5.1 Introduction
5.1.1 Diesel / petrol system
5.1.2 DC electric system
5.1.3 AC power system
5.1.4 AC/DC power system
5.2 Charging and batteries
5.2.1 Battery charging - extension leads
5.3 Bi-Energy system
5.3.1 Duty selector
5.4 Boom system
5.4.1 Boom switch
5.5 Hydraulic system overview
5.6 Hydraulic pump
5.7 Control logic
6 Troubleshooting guide
6.1 Trouble shooting information
6.3 Engine fault finding
6.3.1 Diesel engine
6.3.2 Petrol engine
6.4 Li-ion battery system
6.5 Braking system
Brand: NIFTYLIFT
List of Files:
chassis assembly
superstructure
2.3 Power tray (AC)
2.5 Slew assembly
2.9 PCB Control box
2.12 DC Power pack
2.13 AC Power pack
boom assemblies
3.1 Booms assembly
3.2 Lift cylinder
3.5 Energy chain
cage assembly
4.1 Cage assembly
labelling
Labels 1-31
Labels 32-52
hydraulic hoses
1.1 Foreword
1.2 Warranty
1.3 Scope
2 Specifications
2.2.1 Fluid volumes
2.4 Torque settings
3.2 Consumables
3.3.7 Sediment cup
3.3.9 Fuel hoses
3.3.13 Spark plug
3.5 Axle suspension
3.6 Traction drive
3.7 Tow hitch
3.8 Braking system
3.9 Mudguards
3.10 Stabilisers
3.11 Hub bearings
3.12 Lighting
3.13 Batteries
3.13.3 Storage
3.14 Hydraulic oil
4 Repair procedures
4.1 General
4.1.1 Fuses
4.2 Platform/Cage
4.3 Booms
4.4 Base assembly
4.5 Axle
5 System overview
5.1 Introduction
5.3.1 Duty selector
5.4 Boom system
5.4.1 Boom switch
5.6 Hydraulic pump
5.7 Control logic
6.3.1 Diesel engine
6.3.2 Petrol engine
6.5 Braking system
