NIFTYLIFT Articulating Boom Lifts SP34 37853 Operating Parts Manual And Diagram 2018
Brand: NIFTYLIFT
Type of Manual: Operating Manual, Parts Manual, Electrical Schematic, Hydraulic Schematic, Hose Diagram
Model: NIFTYLIFT SP34 Articulating Boom Lifts
Serial Number: 37853
Publication Date: 2018
List of Files:
01_DIAGRAM LIFTING POINTS HR10 & 12 D80461 (issue 004) 37853.pdf (2 Pages)
02_HOSE DIAGRAM HR12DE 4WD D80849 (issue 001) 37853.pdf (1 Pages)
03_HYDRAULIC DIAGRAM HR12DE 4WD D80850 (issue 016) 37853.pdf (3 Pages)
04_DIAGRAM ELECTRIC HR12D-4WD UK STD CAGE D81242 (issue 004) 37853.pdf (1 Pages)
05_HR12 (SP34) 4x4 PARTS MANUAL M50191 (issue 009) 37853.pdf (92 Pages)
chassis assembly
1.1 Base assembly
1.2 Bonnets/Covers/Guards
1.3 Front axle assembly
1.4 Power pack
1.5 Drive control valve
1.6 Diesel engine (Part 1)
1.7 Diesel engine (Part 2)
1.8 Diesel box
1.9 Anderson connector
superstructure
2.1 Control station - Base
2.2 Slew assembly
2.3 Control valve assembly (3 spool)
2.4 Button box assembly
2.5 Control box
2.6 Dual voltage charger box
2.7 Battery charger
boom assemblies
3.1 Booms assembly
3.2 Lift cylinder
3.3 Levelling cylinder
3.4 Telescope cylinder
3.5 Energy chain
cage assembly
4.1 Cage assembly
4.2 SiOPS assembly
4.3 Cage weigh assembly - Load Cell
4.4 Control box - Cage
4.5 Control valve - Cage
labelling
5.1 Label locations
5.2 Label locations SP34 (USA)
Labels 1 to 34
Labels 35 to 43
06_Kubota D722 Z482 Operators Manual And Wiring Diagram M50291 (issue 002) 37853 1J090-8916-1.pdf (39 Pages)
E.pdf
SAFE OPERATION
SERVICING OF THE ENGINE
NAMES OF PARTS
PRE-OPERATION CHECK
BREAK-IN
DAILY CHECK
To prevent trouble from occurring, it is important to know the conditions of the engine well. Che...
OPERATING THE ENGINE
STARTING THE ENGINE(NORMAL)
COLD WEATHER STARTING
STOPPING THE ENGINE
CHECKS DURING OPERATION
REVERSED ENGINE REVOLUTION AND REMEDIES
MAINTENANCE
SERVICE INTERVALS
PERIODIC SERVICE
FUEL
ENGINE OIL
RADIATOR
AIR CLEANER
ELECTRIC WIRING
FAN BELT
CARRIAGE AND STORAGE
CARRIAGE
STORAGE
TROUBLESHOOTING
If the engine does not function properly, use the following chart to identify and correct the cause.
SPECIFICATIONS
WIRING DIAGRAMS
07_SP26 34 OPERATING MANUAL (USA) M50416 (issue 004) 37853.pdf (41 Pages)
Brand: NIFTYLIFT
List of Files:
chassis assembly
1.1 Base assembly
1.4 Power pack
1.8 Diesel box
superstructure
2.2 Slew assembly
2.5 Control box
2.7 Battery charger
boom assemblies
3.1 Booms assembly
3.2 Lift cylinder
3.5 Energy chain
cage assembly
4.1 Cage assembly
4.2 SiOPS assembly
labelling
5.1 Label locations
Labels 1 to 34
Labels 35 to 43
E.pdf
SAFE OPERATION
NAMES OF PARTS
PRE-OPERATION CHECK
BREAK-IN
DAILY CHECK
STOPPING THE ENGINE
MAINTENANCE
SERVICE INTERVALS
PERIODIC SERVICE
FUEL
ENGINE OIL
RADIATOR
AIR CLEANER
ELECTRIC WIRING
FAN BELT
CARRIAGE
STORAGE
TROUBLESHOOTING
SPECIFICATIONS
WIRING DIAGRAMS
