118
6,911
NIFTYLIFT Articulating Boom Lifts HR17N 43920 Operating Service Parts Manual And Diagram 2019 EN HU
Language: English, Hungarian
Brand: NIFTYLIFT
Type of Manual: Service Manual, Operating Manual, Parts Manual, Electrical Schematic, Hydraulic Schematic,
Model: NIFTYLIFT HR17N Articulating Boom Lifts
Serial Number: 43920
Publication Date: 2019
List of Files:
01_HR15 17NE M4 & E Mk3 Hydraulic Schematic D82093 (issue 005) 43920.pdf (4 Pages)
D82093_005
Schematics
D82093_Sht1
D82093_Sht2
BOMS
D82093_Sht3
D82093_Sht4
02_Electrical Schematic HR15 17 MK4 E D82115 (issue 003) 43920.pdf (11 Pages)
03_LIFTINGS POINTS, HR15 17N MK4 D82117 (issue 004) 43920.pdf (2 Pages)
04_STOWED DIMENSIONS, HR17N MK4 D82118 (issue 002) 43920.pdf (1 Pages)
05_WORKING ENVELOPE, HR17N MK4 D82120 (issue 003) 43920.pdf (2 Pages)
06_TURNING CIRCLE, HR15 17N MK4 D82124 (issue 002) 43920.pdf (1 Pages)
07_HR15N 17N Mk4 SERVICE MANUAL M50665 (issue 001) 43920.pdf (71 Pages)
1.1 Foreword
1.2 Warranty
1.3 Scope
1.4.1 Pre-maintenance checks
1.4.2 Maintenance information
1.4.3 Frequent inspection
1.4.4 Annual inspection
1.5.3 Electrical safety
1.5.4 Hydraulic safety
1.5.5 Environmental awareness
2 Specifications
2.1 Gearbox specification
2.2 Function times
2.3 Fluid properties
2.3.1 Fluid volumes
2.3.2 Gearbox oil specifications
2.3.3 Hydraulic oil specifications
2.3.4 Hydraulic pressure settings
2.4 Tyre specifications
2.5 Torque settings
2.6 Hydraulic hose and fitting torque specifications
3 Preventative maintenance
3.1 Maintenance schedules
3.2 Consumables
3.3 Drive hub gearbox
3.3.1 Gearbox disengagement
3.3.2 Gearbox oil replace
3.4 Batteries
3.4.1 Condition check (daily)
3.4.2 Storage
3.5 Inverter / generator and power to cage options
3.5.1 Condition check (daily)
3.6 Hydraulic oil
3.6.1 Level check (weekly)
3.6.2 Return filter check (monthly)
3.6.3 Pressure filter check (weekly)
3.6.4 Hydraulic oil and filters replace
3.7 Telescopic boom
3.7.1 Wear pad check (monthly)
3.7.2 Hose trunking and energy chain check (weekly)
3.7.3 Lubricate boom pivot bushes (annually)
3.7.4 Boom pivot pin check (daily)
3.8 Boom rotation gear
3.8.1 Slew gear engagement check (monthly)
3.8.2 Lubricate Slew ring (monthly)
3.8.3 Slew ring bolts check (annually)
3.9 Front axle
3.9.1 Lubricate steer pin (daily)
3.9.2 Steer hub (annually)
3.10 Chassis
3.10.1 Earth strap check (daily)
4 Repair Procedures
4.1 General
4.1.1 Fuses
4.2 Platform/Cage
4.2.1 Footswitch - Contact Switch replace
4.3 Booms
4.3.1 Energy Chain Link
4.4 Base Assembly
4.4.1 Steer Cylinder
4.4.2 Steering calibration
4.5 Superstructure
4.5.1 Tilt sensor
4.5.2 Sensor calibration
5 System Overview
5.1 Introduction
5.1.1 DC electric system
5.2 Charging system and batteries
5.2.1 Absorbent Glass Mat (AGM) batteries
5.2.2 Lithium (Li-ion) batteries
5.2.3 Battery charging - extension leads
5.3 Boom System
5.3.1 Boom switch
5.3.2 Telescopic boom switch
5.3.3 Pump control valve
5.4 Drive System
5.4.1 Drive speeds
5.5 Hydraulic System Overview
5.6 Hydraulic gear pump
5.7 Boom control valve
5.8 Steering
5.9 Electrical Control System Overview
5.10 Control Logic
5.11 Controller
5.11.1 Motor Control
5.12 Niftylift diagnostics
6 Troubleshooting guide
6.3 Gearbox fault finding
6.4 Error codes
6.4.1 Error cause (1st byte)
6.4.2 Error source (2nd byte)
6.4.3 Safety controller
6.4.4 Application specific error code (3rd byte)
6.4.5 Error class (4th byte)
6.4.6 Inverter error codes
6.5 Motor controller fault codes
6.5.1 Drive system error codes
6.5.2 Boom system error codes
08_HR15N 17N SP45N 50N MK4 PARTS MANUAL M50740 (issue 001) 43920.pdf (92 Pages)
Parts Order Form
Contents
chassis assembly
1.1 Base assembly
1.2 Axle assembly (Front)
1.3 Wheel hub assembly
1.4 Drive control assembly
1.5 Charger/Auxiliary power assembly
1.6 Covers and guards
1.7 Battery pod assembly - Lithium
superstructure
2.1 Superstructure
2.2 Slew assembly
2.3 Base control assembly
2.4 Recovery switch assembly
2.5 Track unit (Niftylink)
boom assemblies
3.1 Telescope assembly (Part 1)
3.2 Telescope assembly (Part 2)
3.3 Links assembly (HR15N/SP45N)
3.4 Links assembly (HR17N/SP50N)
3.5 Lift & luffing cylinders
3.6 Levelling cylinder
3.7 Energy chain
3.8 Levelling valve block
cage and flyboom
4.1 toughcage assembly
4.2 cage console assembly
4.3 SiOPS assembly
4.4 cage rotate assembly
4.5 flyboom assembly
4.6 flyboom cylinder
4.7 control panel assembly
labelling
5.1 Label locations
Figure 5.1
Labels (1 to 33)
Labels (34 to 43)
09_HR15N 17N MK4 OPERATING MANUAL HUNGARIAN M50761 (issue 001) 43920.pdf (78 Pages)
1 Bevezetés és általános tudnivalók
1.1 ELŐSZÓ
1.2 A DOKUMENTUM HATÓKÖRE
1.3 A HEIGHT RIDER ÖNJÁRÓ (SP) SOROZATÁNAK BEMUTATÁSA
1.4 ÁLTALÁNOS MŰSZAKI ADATOK
1.5 AZONOSÍTÁS (EGYESÜLT KIRÁLYSÁGI TÁBLA)
1.6 EK MEGFELELŐSÉGI NYILATKOZAT (általános)
2 Biztonság
2.1 KÖTELEZŐ ÓVINTÉZKEDÉSEK
2.2 KÖRNYEZETVÉDELMI KORLÁTOZÁSOK
2.3 ZAJ ÉS REZGÉSEK
2.4 TESZTJELENTÉS
3 Előkészítés és átvizsgálás
3.1 KICSOMAGOLÁS
3.2 A HASZNÁLATRA VALÓ ELŐKÉSZÍTÉS
3.3 ÜZEMELTETÉS ELŐTTI BIZTONSÁGI ELLENŐRZÉSI ÜTEMTERV
3.3.1 NAPI BIZTONSÁGI ELLENŐRZÉSEK
3.3.2 HETI BIZTONSÁGI ELLENŐRZÉSEK
3.3.3 HAVI BIZTONSÁGI ELLENŐRZÉSEK
3.3.4 ÉVES BIZTONSÁGI ELLENŐRZÉSEK
Kosármerevítő padlózat
3.4 TÍPUSTÁBLA, MATRICÁK ÉS ELHELYEZKEDÉSÜK (UK)
3.5 NYOMATÉKKÖVETELMÉNYEK
4 Üzemeltetés
4.1 A VEZÉRLŐÁRAMKÖR ELEMEI
4.1.1 FÖLDI KEZELŐSZERVEK
4.1.2 EMELŐKOSÁR
4.1.3 BIZTOSÍTÉKOK
4.2 VEZÉRLÉS A FÖLDRŐL
4.2.1 VEZÉRLÉS A FÖLDRŐL
4.2.2 ÜZEMELTETÉS
4.3 VEZÉRLÉS AZ EMELŐKOSÁRBÓL
4.3.1 EMELŐKOSÁRBÓL VEZÉRELHETŐ FUNKCIÓK
4.3.2 KIJELZŐ KÉPERNYŐ
4.3.3 TÁJÉKOZTATÓ IKONOK
4.3.4 MENÜKÉPERNYŐK
4.3.5 ÜZEMELTETÉS
4.3.6 SiOPSTM – TERHELÉSÉRZÉKELŐ KONZOL
4.4 KEZELŐSZERVEK
4.5 A KOSÁR SÚLYMÉRŐ RENDSZERE
4.5.1 MÉRŐCELLÁS KIVITEL
4.5.2 KALIBRÁLÁS, VIZSGÁLAT ÉS KARBANTARTÁS
4.6 AKKUMULÁTOROK ÉS TÖLTÉS
4.7 SZÁLLÍTÁS, VONTATÁS, DARUZÁS, TÁROLÁS ÉS A MUNKAVÉGZÉS ELŐKÉSZÍTÉSE
4.7.1 SZÁLLÍTÁS
4.7.2 VONTATÁS
4.7.3 DARUZÁS
4.7.4 TÁROLÁS
4.7.5 A MUNKAVÉGZÉS ELŐKÉSZÍTÉSE
5 Vészhelyzeti kezelőszervek
5.1 ÁLTALÁNOS TUDNIVALÓK
5.2 AKADÁLYOZTATOTT KEZELŐ ESETÉN
5.3 GÉPHIBA ESETÉN
5.4 ÉRTESÍTÉS BALESET ESETÉN
6 Felelősségek
6.1 TULAJDONOSVÁLTÁS
6.2 A VILLANYMOTOR KÉZIKÖNYVE (csak USA)
6.3 VIZSGÁLATI/SZERVIZELÉSI/BÉRLÉS ELŐTTI ELLENŐRZŐLISTA
„A” függelék
„B” függelék
