NIFTYLIFT Articulating Boom Lifts HR12N 38351 Operating Service Parts Manual And Diagram 2018
Brand: NIFTYLIFT
Type of Manual: Service Manual, Operating Manual, Parts Manual, Electrical Schematic, Hydraulic Schematic, Hose Diagram
Model: NIFTYLIFT HR12N Articulating Boom Lifts
Serial Number: 38351
Publication Date: 2018
List of Files:
01_DIAGRAM LIFTING POINTS HR10 & 12 D80461 (issue 004) 38351.pdf (2 Pages)
02_HOSE DIAGRAM HR12 ECO SOM D80525 (issue 005) 38351.pdf (1 Pages)
03_HYDRAULIC DRG HR12 D80526 (issue 010) 38351.pdf (2 Pages)
04_HR12NDE CW LC UK Elec Schematic. D81632 (issue 017) 38351.pdf (7 Pages)
05_HR10 12 SP26 34 OPERATING MANUAL UK USA M50192 (issue 017) 38351.pdf (58 Pages)
06_Kubota OC60 95 Operators Manual M50290 (issue 002) 38351 11551-8915-6.pdf (2 Pages)
OPS BROCHURE - KUBOTA DIESEL AC60 OC60 / 80 / 95 (11551-8915-6)
Foreword
Safety First
Safe Operation
Requesting Servicing
Specifications
Periodic Service
Battery
Pulley
Wiring Diagram
Genuine Regulator Installation Example
How To Hoist Up The Engine
Pre-Start Checks
Capacity
Fuel
Crankcase Oil
Starting And Operation
Starting - Electric Starting Model
Starting - Recoil Starting Model
Starting Low Temperatures - Recoil Starting Model
Operation
Maintenance - Refer To Periodic Service
The Fuel Filter
The Crankcase Oil
The Air Cleaner
The Oil Cooler
The Rubber Hose
Precautions At Recoil Starting
Stopping
Storage
Kubota Contact Details
07_HR12 2x4 PARTS MANUAL M50510 (issue 006) 38351.pdf (102 Pages)
Front Cover
Contents
chassis assembly
1.1 Base assembly - P/D/PE/DE
1.2 Base assembly - Electric
1.3 Bonnets/Covers/Guards
1.4 Steering assembly
1.5 Front hub assembly
1.6 Power pack
1.7 Drive control valve
1.8 Diesel engine (Part 1)
1.9 Diesel engine (Part 2)
1.10 Diesel box
1.11 Anderson connector
1.12 Generator assembly (Option)
superstructure
2.1 Control station - Base
2.2 Slew assembly
2.3 Control valve assembly (3 spool)
2.4 Control valve assembly (4 spool)
2.5 Button box assembly
2.6 Control box
2.7 Dual voltage charger box
2.8 Battery charger
boom assemblies
3.1 Booms assembly
3.2 Lift cylinder
3.3 Levelling cylinder
3.4 Telescope cylinder
3.5 Energy chain
cage assembly
4.1 Cage assembly
4.2 SiOPS assembly
4.3 Cage weigh assembly - Load Cell
4.4 Control box - Cage
4.5 Control valve - Cage
labelling
5.1 Label locations
5.2 Label locations SP34 (USA)
Labels 1 to 31
Labels 32 to 46
08_HR12 N SERVICE MANUAL M50606 (issue 001) 38351.pdf (64 Pages)
1.1 Foreword
1.2 Warranty
1.3 Scope
1.4.1 Pre-maintenance checks
1.4.2 Maintenance information
1.4.3 Frequent inspection
1.4.4 Annual inspection
1.5.3 Diesel system safety
1.5.4 Electrical safety
1.5.5 Hydraulic safety
1.5.6 Environmental awareness
2 Specifications
2.1 Engine specifications
2.2 Gearbox specifications
2.3 Function times
2.4 Fluid properties
2.4.1 Fluid volumes
2.4.2 Engine oil specifications
2.4.3 Gearbox oil specifications
2.4.4 Hydraulic oil specifications
2.4.5 Hydraulic pressure settings
2.5 Tyre specifications
2.6 Torque settings
2.6.1 Torque settings - Kubota OC60 and OC95 engines
2.7 Hydraulic hose and fitting torque specifications
3 Preventative maintenance
3.1 Maintenance schedules
3.1.1 Engine maintenance
3.1.2 Machine maintenance
3.1.3 Engine oil level check
3.1.4 Engine oil replace
3.1.5 Engine oil strainer clean - Diesel
3.1.6 Air filter element maintenance
3.1.7 Fuel pipes check
3.1.8 Fuel filter clean / replace
3.1.9 Spark plug check
3.1.10 Exhaust system inspect
3.2 Drive hub gearbox
3.2.1 Oil replace
3.2.2 Bleeding air from the braking circuit
3.3 Batteries
3.3.1 Condition check (daily)
3.3.2 Condition check (weekly) - excludes AGM batteries
3.3.3 Storage
3.4 Inverter / generator and power to cage options
3.4.1 Condition check (daily)
3.5 Hydraulic oil
3.5.1 Level check (weekly)
3.5.2 Pressure filter check (weekly)
3.5.3 Hydraulic oil and filters replace
3.6 Telescopic boom
3.6.1 Wear pad check (monthly)
3.6.2 Hose trunking and energy chain check (weekly)
3.6.3 Boom pivot bushes lubricate (annually)
3.6.4 Boom pivot pin check (daily)
3.7 Boom rotation gear
3.7.1 Slew gear engagement check (monthly)
3.7.2 Slew ring lubrication (monthly)
3.7.3 Slew ring bolts check (yearly)
3.8 Front axle
3.8.1 Front wheel hub bushes (yearly)
3.9 Chassis
3.9.1 Earth strap check (daily)
3.10 Wheels and tyres
3.10.1 Wheel bolt torque (monthly)
4 Repair procedures
4.1 General
4.1.1 Fuses
4.2 Platform/Cage
4.3 Booms
4.3.1 Energy chain link
4.4 Base Assembly
4.4.1 Engine exhaust
4.4.2 Steer cylinder
5 System overview
5.1 Introduction
5.1.1 Power system
5.1.2 DC electric system
5.2 Battery charging
5.2.1 Battery charging - extension leads
5.3 Bi-energy system
5.3.1 Duty selector
5.4 Boom system
5.4.1 Boom switch
5.5 Drive system
5.5.1 Drive Control Valve (DCV)
5.5.2 Brake Release Valve
5.6 Hydraulic system overview
5.7 Steering
5.8 Electrical control system overview
5.9 Control logic
6 Troubleshooting guide
6.1 Trouble shooting information
6.3 Engine fault finding
6.3.1 Diesel engine
6.3.2 Petrol engine
6.4 Gearbox fault finding
Brand: NIFTYLIFT
List of Files:
Foreword
Safety First
Safe Operation
Specifications
Periodic Service
Battery
Pulley
Wiring Diagram
Pre-Start Checks
Capacity
Fuel
Crankcase Oil
Operation
The Fuel Filter
The Crankcase Oil
The Air Cleaner
The Oil Cooler
The Rubber Hose
Stopping
Storage
Front Cover
Contents
chassis assembly
1.6 Power pack
1.10 Diesel box
superstructure
2.2 Slew assembly
2.6 Control box
2.8 Battery charger
boom assemblies
3.1 Booms assembly
3.2 Lift cylinder
3.5 Energy chain
cage assembly
4.1 Cage assembly
4.2 SiOPS assembly
labelling
5.1 Label locations
Labels 1 to 31
Labels 32 to 46
1.1 Foreword
1.2 Warranty
1.3 Scope
2 Specifications
2.3 Function times
2.4.1 Fluid volumes
2.6 Torque settings
3.2.1 Oil replace
3.3 Batteries
3.3.3 Storage
3.5 Hydraulic oil
3.6 Telescopic boom
3.8 Front axle
3.9 Chassis
4 Repair procedures
4.1 General
4.1.1 Fuses
4.2 Platform/Cage
4.3 Booms
4.4 Base Assembly
5 System overview
5.1 Introduction
5.1.1 Power system
5.3.1 Duty selector
5.4 Boom system
5.4.1 Boom switch
5.5 Drive system
5.7 Steering
5.9 Control logic
6.3.1 Diesel engine
6.3.2 Petrol engine
