Auto
532
1,849,429
Nichiyu Forklift FBT13P FBT15P FBT18P FBT20PN Workshop Troubleshooting Manual 07W-2204
Brand: Nichiyu
Type of Machine: Forklift
Type of Manual: Workshop Manual, Troubleshooting Manual, Wiring Diagram
Model: Nichiyu 75 Series FBT13P FBT15P FBT18P FBT20PN Forklift
Part Number: 07W-2204
List of Files:
Nichiyu Forklift 75 Series FBT13P FBT15P FBT18P FBT20PN Troubleshooting Manual 07W-2204.pdf (105 pages)
1. Adjustment Of Sicos-Ac
1-1. Explanation Of The Monitor Display
1-1-1. Indicator Panel
1-1-2. Indication Of Display
1-1-3. Function Of Display
1-1-4. Various Kinds Of Mode Selection
1-2. Explanation Of Control Boards
1-2-1. Basic Control Board Construction
1-2-2. Travel/Hydraulic Board
1-2-3. Eps Controller Board
1-2-4. Rotary Switch On The Travel/Hydraulic Board
1-2-5. Rotary Switch On The Eps Conotroller Board
1-2-6. Adjustment Standards List For Fbt-75 Series
1-2-7. Other Settings
1-.3 Sicos-Ac Check And Adjustment
1-3-1. Chassis Insulation Check
1-3-2. Battery Voltage Calibration
1-3-3. Current Sensor Check
1-3-4. Model Setting
1-3-5. Hydraulic Function Setting And Adjustment
1-3-6. Switch Back(Plugging/Regenerative)
Braking Force Adjustment
1-3-7. Regenerative Braking Force
1-3-8. Display Monitor Symbol (Icon) Check And Setting
1-3-9. Display Language Check And Setting
1-3-10. Optional Function Check And Setting
1-3-11. Display Brightness Check And Adjustment
1-3-12. Hour Meter Working Check
1-3-13. Auto Power Off Function Working Check
1-3-14. Battery Electrolyte Level (Optional)
Working Check (For Gs Battery Only)
1-3-15. Turn Signal Lamp Working Check
1-3-16. Load Sensor (Optional) Working Check
And Calibration
1-3-17. Cooling Fan Working Check
1-3-18. Lift Interrupt (Optional) Working Check
1-3-19. Accelator Potentiometer Adjustment
1-3-20. Steering Angle Potentiometer Adjustment
1-3-21. Ois (Operation Interlock System)
Working Check
1-3-22. Hydraulic Oil Level Warning (Optional)
Working Check
1-3-23. Brake Oil Level Warning Working Check
1-3-24. Turning Speed Reduction (Optional)
Adjustment And Working Check
1-3-25. Laser Positioner (Optional) Working Check
1-3-26. Built-In Charger (Optional) Working Check
2. Troubleshooting
2-1. Self Diagnosis Function
2-1-1. Display
2-1-2. Error Messeages And Conditions To Appear
2-2. Error History Memory
2-2-1. Error History Memory 1
2-2-2. Error History Memory 2
2-2-3. Clearing The Error History Memory
(Memory Initialization)
2-3. I/O Check
2-3-1. Indication Of The I/O Check Mode
2-3-2. I/O Port Table
3. Wiring (Diagrams)
3-1. Wiring, System
3-1-1. [Body]
3-1-2. [Fingertip]
3-2. Wiring, Body
3-2-1. [Body]
3-2-2. [Fingertip]
3-2-3. [3 400v Built-In Charger]
3-3. Harness, Body
3-3-1. [Body]
3-3-2. [Lead Wire Chart]
3-3-3. [Fingertip]
3-4. Controller Wiring
3-5. Controller Harness
3-6. Main Controller Ass'y
3-7. Wiring, Bc
3-7-1. [3 200v]
3-7-2. [3 400v]
3-8. Harness, Bc
3-8-1. [3 200v]
3-8-2. [3 400v]
3-9. Wiring, Lamp
3-10.Forward & Backward Chime / Buzzer
3-10-1. [Wiring, Chime (Forward & Backward)]
3-10-2. [Wiring, Buzzer (Forward & Backward)]
3-10-3. [Wiring, Chime (Forward)]
3-10-4. [Wiring, Chime (Backward)]
3-11.Wiring, Lift Limit
4. Reference
4-1. Mpu Board Connectors
4-1-1. Pin Arrangement Of Connector Housing
4-1-2. Name Of Parts
4-1-3. Installation Of Terminals Into Housing
4-1-4. How To Extract Terminals
4-1-5. Crimp Tools (Manufactured By Amp)
4-2. Water Resistant Connector
4-2-1. Water Resistant Connectors
4-2-2. Water Resistant Connectors
(Other Than Those Described Above)
Nichiyu Forklift 75 Series FBT13P FBT15P FBT18P FBT20PN Workshop Manual 07W-2203.pdf (188 pages)
1 General
2 Front Axle(Drive)
3 Rear Axle (Steering)
4 Tyre
5 Steering Linkage
6 Brake
7 Hydraulic System
7a Conrol Valve And Valve Linkage
7b Oil Tank And Oil Piping
7c Hydraulic Pump
7d Cylinder
8 Mast
9 Motor
10 Electric Parts
10a Control Unit
10b Accelerator
10c Display Panel And Directional Switch
10d Battery
10e Charger (Built - In)
11 Laser Pointer (Option)
12 Service Data
