New Holland Skid Steer Loader L225 Tier 4A Parts Catalog 47438540
Brand: New Holland
Type of Machine: Skid Steer Loader
Model: New Holland L225 Tier 4A Skid Steer Loader
Part Number: 47438540
Number of Pages: 1557 Pages
Pictorial Index - Main Sections
Pictorial Index - Machine Complation And Equipment,
Pictorial Index - Engine
Pictorial Index - Hydrostatic Transmission
Pictorial Index - Hydrostatic Transmission, Section Index - Hydrostatic Transmission
Pictorial Index - Hydraulic Systems
Pictorial Index - Axle And Wheels
Pictorial Index - Suspension And Tracks
Pictorial Index - Cab Climate Control
Pictorial Index - Electrical Systems
Pictorial Index - Front Loader
Pictorial Index - Platform, Cab, Bodywork And Decals
Section Index - Machine Complation And Equipment,
Initial Stocking List, List A - Parts Required For Planned Maintenance
Initial Stocking List, List B - Parts Recommended For Planned Maintenance And Basic
Repair
Filters
Filters, L225 T4
Capacities
Fire Extinguisher
Section Index - Engine
Cylinder Block & Related Parts
Engine Mount
Engine Mount, After August 15, 2014
Engine Mount, Before August 14, 2014
Hooks - Engine
Cylinder Head & Related Parts
Cylinder Head, Cover
Cylinder Head, Valve Cover
Engine, Block, Cover
Oil Sump & Related Parts
Injection Pump Drive, Cover
Crankshaft Pulley
Engine, Flywheel
Flywheel Case
Connecting Rod
Piston - Engine
Camshaft
Rocker Arms
Air Cleaner Assy
Air Cleaner & Exhaust (21-Sep-2014 & Prior)
Air Cleaner & Exhaust (22-Sep-2014 & Newer)
Air Filter, Electronic Controls
Air Cleaner - Air Intake Parts
Fuel Filter, Wif, Built Before Oct. 3, 2013
Fuel Filter/Water Separator, Built After Oct 4, 2013
Fuel Filter, Lines (25-Aug-2014 & Prior)
Fuel Filter, Lines (26-Aug-2014 & Newer)
Fuel Line & Tank (19-Jan-2015 & Prior)
Fuel Tank & Associated Parts (20-Jan-2015 & Newer)
Fuel Tank, Assy
Injection Equipment - Piping
Injection Equipment - Injector
Fuel Lines - Fuel Injection Pump
Foot Throttle, Hand And E-H Controls
Foot Throttle Control
Hand Throttle, Foot Controls
Turbocharger
Intake And Exhaust Lrg - V, Asn Nem479662
Exhaust Manifold
Intake Manifold
Pump, Engine Oil & Related Parts
Engine Oil Filter
Remote Engine Oil Filter Lines
Engine Oil Drain Line
Engine Oil Filler
Oil Pump & Lines
Filler Cap, Engine
Engine Breathers
Engine Oil Dipstick
Piping - Engine Cooling System
Water Pump & Related Parts
Temperature Control - Thermostat
Cooler Assembly, Before Aug 8, 2013, Sr220/Sv250/L225/C232
Cooler Assembly After Aug 8, 2013, Sr220/Sv250/L225/C232
Engine Cooling System Lines
Module, Radiator And Cooling Lg (L223-L230,C232,C238)
Fan Shroud
Deaeration System And Lines
Heat Exchanger
Engine, Fan
Fan & Pulley
Fan Drive
Var - 761068 Standard Fan Belt
Var - 761069 High Flow Fan Belt
Exhaust System, Egr, Heat Exchanger
Filter, Dpf
Hand Controls Linkage
Handle Mounting, Hand Controls
Foot Controls Mounting Assembly
Handle Mounting, Foot Controls
Handle Mounting, E-H Controls
Hand Control Interlink
Control Dampening And Centering, Hand Controls
Foot Control Interlink, Servo Pump Centering
Control Dampening, Foot Controls
Pedal Mounting, Foot Controls
Power Train
Axle, Gearbox
Hydrostatic Pump, Drive Lines, Mechanical Controls
Drive Lines, Hydrostatic Pump, Mechanical Control, C232 (19-Nov-2015 & Prior)
Hydrostatic Pump, Supply Lines, Mechanical Controls
Hydrostatic Pump, Drive Lines, E-H Controls
Hydrostatic Pump, Supply Lines, E-H Controls
Tandem Hydrostatic Pump, 46cc, Mechanical Control, Front
Tandem Hydrostatic Pump, 45cc, E-H Control
Tandem Hydrostatic Pump, 46cc, Mechanical Control, Rear
Tandem Hydrostatic Pump, 46cc, E-H Control
Hydrostatic Pump, 46cc Mdc Bushed
Tandem Hydrostatic Pump, Front, 46cc Mdc Bushed
Tandem Hydrostatic Pump, 46cc Mdc Bushed
Section Index - Hydraulic Systems
Standard Gear Pump
High Flow Gear Pump
Supply Hydraulic Plumbing
Hydraulic Return Plumbing
Hydraulic Fluid Reservoir
Hydraulic Oil Filter
Brake Valve, 1 Speed, L225
Brake Valve, Mechanical Controls
Brake Valve, 2 Speed, L225
Brake Valve, E-H Controls
Brake Valve, E-H, L225
Brake Lines, L225
Drive Motor Travel Hydraulic System, Mechanical Controls
Travel Speed, 1 Speed, L225
1 Speed Drive Motor, L225
Drive Motor Travel Hydraulic System, E-H Controls
Drive Motor Travel Hydraulic System, E-H Controls (03-Oct-2016 & Newer)
2 Speed Drive Motor
Travel Speed, 2 Speed, L225
2 Speed Drive Motor, L225
2 Speed Lines, L225
Travel Speed, E-H, L225
Loader Control Valve, Hand Controls
Loader Control Valve, Foot Controls
Loader Control Valve, E-H Controls, C232
Loader Control Valve, E-H Controls, L225
Auxiliary Chassis Plumbing, Standard Flow
Auxiliary Boom Arm Plumbing, Standard Flow
Auxiliary Chassis Plumbing, High Flow
Auxiliary Boom Arm Plumbing, High Flow
Auxiliary Case Drain Plumbing
High Flow Combiner Valve
Loader Valve Plumbing
Bucket Tip Lines
Bucket Tip Lines, After July, 31, 2013
Boom Hydr Lines
Lift Cylinder Lines After July, 31, 2013
No Ride Control
Ride Control Valve
Ride Control Lines
No Self Leveling
No Self Leveling, After May 1, 2012
Self Leveling
Self Leveling Valve
Boom Lift Cylinder, Lh
Boom Lift Cylinder, Rh
Bucket Cylinder
Hydraulic Coupler Chassis Plumbing
Hydraulic Coupler Boom Arm Plumbing
Hydraulic Coupler
Hydraulic Coupler Cylinder
Hydraulic Coupler Valve
Section Index - Frame
Counterweight
Section Index - Axle And Wheels
Non Pneumatic Wheels
Section Index - Suspension And Tracks
Rubber Track
Track Assy (19-Nov-2015 & Prior)
Track Assy (20-Nov-2015 & Newer)
Section Index - Cab Climate Control
Heater Plumbing
Heating System, Large Frame
Control Panel, Heater
Air Conditioner Assy
Heater Assy
Hvac Large Frame
Bracket, Hvac
A/C Compressor Mounting
Condenser Assy
Receiver-Dryer
Air Conditioner, Plumbing
Section Index - Electrical Systems
Diagnostic Sensors
Motor Electric Installation , Wire Harness
Park Brake Switch
Air Conditioner, Heating System, Large Frame
Standard 60 Amp Fuse
Fuse Box #1, Mechanical, Eh
Fuse Box #2, Eh
Wire Harness & Connector, Mechanical Controls
Wire Harness & Connector, Mechanical Controls, Open Cab
Wire Harness & Connector, Electronic Controls
Wire Harness & Connector, Electronic Controls, Open Cab
Chassis Option Harness, C232
Chassis Option Harness, L225
Rear Light Harness, Without Turn Signal Light
Rear Light Harness, With Turn Signal Light
Starter Motor
Glow Plugs
Block Heater
Alternator - Components
Engine, Alternator Mounting
Battery - Cables
No Battery Disconnect
Battery Disconnect
Front Light, Assy, Without Turn Signal
Front Light, Assy, With Turn Signal
Light W/O Turn Signal, Rh (All Nh)
Light W/Turn Signal, Rh (All Nh)
Light W/ Turn Signal, Lh (Al Lnh)
Light W/O Turn Signal, Lh (All Nh)
Rear Light
Turn Signal, Rear Cover
Light Console Switch
Horn
Fuel Transfer Pump, Switch (7-Jun-2013 & Prior)
Seat Belt Harness
Common Instruments And Elec (All Nh)
Accessories Socket
Electronic Control Unit, Glow Plug
Instrument Cluster And Keyed Ignition, Open Cab
Instrument Cluster And Keyless Ignition, Enclosed Cab
No Multifunction Electrical
Lh Sub Handle, Hand Controls
Rh Sub Handle, Hand Controls
Lh Sub Handle, Foot Controls
Rh Sub Handle, Foot Controls
Level 100 Handle Grips, 1-Speed Mechanical Controls
Level 100 Handle Grip, Lh
Level 100 Handle Grip, Rh
Level 200 Handle Grips, 2-Speed Mechanical Controls, W/O Multi-Function
Electrical Control
Level 200 Handle Grip, Lh
Level 200 Handle Grip, Rh
Level 300 Handle Grips, 2-Speed Mechanical Controls, W/ Multi-Function Electrical
Control
Level 300 Handle Grip, Lh
Level 300 Handle Grip, Rh
E-H Controls, Sub Handles
Level 250 Handle Grips, E-H Controls, W/O Multi-Function Electrical Control
Level 250 Handle Grip, Lh, 2-Speed
Level 250 Handle Grip, Rh
Level 350 Handle Grips, E-H Controls, W/ Multi-Function Electrical Control
Level 350 Handle Grip, Lh
Level 350 Handle Grip, Rh
Windshield Washer Reservoir Assy
Windshield Wash Reservoir
Electronic Injection , Module
Electronic Control Unit, Telematics
Telematics
Section Index - Front Loader
Coupler
Service Frame, Coupler
Coupler, 25-Nov-2013 And Newer
Boom Lock
Manual Coupler
Bucket, 72", Dirt And Foundry, Gray
Bucket, 72", Low Profile, Gray
Bucket, 72", Extended Low Profile, Gray
Bucket, 72", Light Material, Gray
Bucket, 78", Dirt And Foundry, Gray
Bucket, 72", Heavy Duty Dirt, Grey
Bucket Spill Guard, 78" Bucket
Bucket, 72", Slurry, Grey
Bucket, 78", Heavy Duty Dirt, Grey
Bucket, 78", Extended Low Profile, Gray
Bucket, 84", Heavy Duty Dirt, Grey
Bucket, 84", Extended Low Profile, Gray
Bucket, 84", Light Material, Gray
Bucket, 84", Slurry, Grey
Boom
Kit, Tier 4 Hand Controls
Dia Kit, Fire Extinguisher
Dia Kit, Interior Mirror
Dia Kit, Aspirator
Dia Kit, Radiator Debris
Dia Kit, E-H Hydrostatic Pump, Drive Lines Upgrade
Dia Kit, E-H Hydrostatic Pump Drive Lines Upgrade (12-Jan-2017 & Newer)
Dia Kit, E-H W/ Ehf Hydrostatic Pump, Drive Lines Upgrade
Dia Kit, Mechanical Hydrostatic Pump, Drive Lines Upgrade
Dia Kit, Mechanical Hydrostatic Pump Drive Lines Upgrade (12-Jan-2017 & Newer)
Dia Kit, Ride Control Med - Lrg
Dia Kit, Cylinder Guard
Dia Kit, Foot Controls, Servo
Dia Kit, Self Level
Dia Kit, Hydraulic Coupler - Vertical
Dia Kit, High Flow Aux 36.6/20.4cc
Dia Kit, 2nd Front Hydraulic Auxiliary, Vertical Booms
Dia Kit, Lrg Frm Hand Controls, Servo
Dia Kit, Hand Controls
Dia Kit, Large Frame Hand Controls
Dia Kit, Drawbar Attachment
Dia Kit, Counterweight Lfw Nh
Dia Kit, Counterweight Lft Nh
Dia Kit, Rops Service Frame
Dia Kit, 4 Point Lift Hook
Dia Kit, Front Counterweight
Dia Kit, Track Covers, Large Frame (C232,C238)
Dia Kit, Complete Heat
Dia Kit, Complete Hvac
Dia Kit, Heater Components
Dia Kit, F5c Hvac Hose T4
Dia Kit, F5c Heat Hoses
Dia Kit, Beacon
Dia Kit, Strobe Light
Dia Kit, Radio
Dia Kit, Side Lamp
Dia Kit, Turn Signal, Large Frame
Dia Kit, Road Lights
Dia Kit, Battery Disconnect
Dia Kit, Hand Controls, Servo
Dia Kit, Handle 200, Lh Grip, Mechanical Controls
Dia Kit, Handle 300, Lh Grip, No 2nd Auxiliary, Mechanical Controls
Dia Kit, Handle 300, Rh Grip, Mechanical Controls
Dia Kit, Handle 350, Lh Grip, No 2nd Auxiliary, E-H Controls
Dia Kit, Handle 350, Rh Grip, E-H Controls
Dia Kit, Handle 400, Lh Grip, 2nd Auxiliary, Mechanical Controls
Dia Kit, Handle 400, Rh Grip, Mechanical Controls
Dia Kit, Handle 450, Lh Grip, 2nd Auxiliary, E-H Controls
Dia Kit, Multifunction Electrical, Eh & Mech Controls
Dia Kit, Chassis Option Harness, Mechanical Controls
Dia Kit, Wide Bucket Eu Lights
Dia Kit, Block Heater 220v (Row)
Dia Kit, Italy Specific Parts
Dia Kit - Russia Specific Parts
Dia Kit, Block Heater 120v (Na)
Dia Kit, Telematics
Dia Kit, Lh Handle Grip Upgrade
Dia Kit, Rh Handle Grip Upgrade
Dia Kit, Lh Handle Grip Mounting
Dia Kit, Rh Handle Grip Mounting
Kit, Boom
Dia Kit, Coupler Cross Tube Reinforcement
Dia Kit, Rh Boom Link
Dia Kit, Lh Boom Link
Dia Kit, Bucket Bolt- On Tooth
Dia Kit, Bucket Spill Guard, 84"
Dia Kit, Bolt On Cutting Edge, 72" Bucket
Dia Kit, Bucket Spill Guard, 72"
Dia Kit, Bolt On Cutting Edge, 78" Bucket
Dia Kit, Single Point Lift Hook, Vertical Booms
Dia Kit, Bolt On Cutting Edge, 84" Bucket
Dia Kit, Pallet Fork 48 Tines
Dia Kit, 3 Point Seat Belt
Dia Kit, Cab Side Window
Dia Kit, Glass Front Door
Dia Kit, Demo Front Door
Dia Kit, Demo Rear Door
Dia Kit, Fops Level 2 Modifications
Dia Kit, Interior Trim Nh
Dia Kit, Debris Soft Parts
Dia Kit, Interior Trim Nh Euro
Dia Kit, Debris Hard Parts With Seals
Dia Kit, Armrests (All Nh)
Dia Kit, Mirror
Dia Kit, Fender Extensions, Lrg (Nh)
Dia Kit, Hoods And Covers
Dia Kit, Cab, Seal, Sides
Dia Kit, Cab Lock
Dia Kit, Lap Bar
Dia Kit Heavy Duty Rear Door
Dia Kit, Heavy Duty Rear Door
Kit, Cab Side Windows
Dia Kit, Hoods & Covers
Section Index - Platform, Cab, Bodywork And Decals
Rear Hood And Chassis Access Covers
Rear Hood And Chassis Access Covers, Bsn Ngm412736
Hood Spring
Rear Door
Rear Hood And Chassis Access Covers After Jan 28, 2014
Fan Guard
Engine Covers
Rear Covers - Na, No Ehf
Engine Soundproofing
Decals, Model
Decals, No Hvac
Decals, Foot, Controls
Decals, Hand, Controls
Canada Specific Decal
Lh, Side Screen, Service Kit
Rh, Side Screen, Service Kit
Loader Arm Stop, 40mm Stop
Loader Stop, 63mm, 12" Tires
Loader Arm Stop, 40mm Stop, 14" Tire
Seat, Non-Suspension, Mounting
Seat, Non-Suspension, Mounting (03-Oct-2016 & Newer)
Seat, Non-Suspension (03-Oct-2016 & Newer)
Seat, Mechanical Suspension, Mounting
Seat, Mechanical Suspension, Mounting (03-Oct-2016 & Newer)
Mechanical Suspension Seat
Seat, Mechanical Suspension (03-Oct-2016 & Newer)
Seat, Air Suspension, Mounting
Seat, Air Suspension, Mounting (03-Oct-2016 & Newer)
Seat, Air Suspension (03-Oct-2016 & Newer)
Cab Sealing Strip, Rear
Seat Belt, 2" Lap Belt
Seat Belt, 3 Pt, Lap And Shoulder Belt
Seat Belt, 3" Lap Belt, Service Kit
Glass Door Mounting Components (1-Feb-2013 & Prior)
Glass Door Assy Components (1-Feb-2013 & Prior)
Glass Door Mounting Components (2-Feb-2013 & Newer)
Glass Door Assy Components (2-Feb-2013 & Newer)
Demo Door Mounting Components (1-Feb-2013 & Prior)
Demo Door Assy Components (1-Feb-2013 & Prior)
Demo Door Mounting Components (2-Feb-2013 & Newer)
Demo Door Assy Components (2-Feb-2013 & Newer)
Lh Rh Window Kit
Rear Window, Na
Upper Window
Side Window Assy
Lh Cab Window
Side Window Assy, Asn Njm442820
Rh Cab Window
Cab Harness Seal
Fuse Cover Assy And Cup Holder
Floor Mat, Mechanical Hand Control
Floor Mat, Mechanical Foot Controls
Floor Mat, E-H Controls
Floor Plate, Hand Or E-H Controls
Floor Plate, Foot Controls
Cab Headliner, No Radio
Cab Headliner, With Radio
Trim, Open Cab
Trim Interior
Enclosed Cab Trim
Adapter, Ssl Attachment Blank, L225
Adapter, Ssl Attachment Blank, C232
Auger Drive, L225
Auger Drive, C232
Auto Rake, L225
Auto Rake, C232
Backhoes, L225
Backhoes, C232
Bale Handler, L225
Bale Handler, C232
Bale Spear, L225
Bale Spear, C232
Angle Broom, L225
Angle Broom, C232
Hopper Broom, L225
Hopper Broom, C232
Pick-Up Broom, L225
Pick-Up Broom, C232
4 X 1 Bucket (Construction), L225
4 X 1 Bucket (Construction), C232
Power Side Discharge Buckets, L225
Power Side Discharge Buckets, C232
Chipper, L225
Chipper, C232
Cold Planers, High Flow, L225
Cold Planers, High Flow, C232
Cold Planers, Standard Flow, L225
Cold Planers, Standard Flow, C232
Concrete Bucket, L225
Concrete Bucket, C232
Concrete Claw, L225
Concrete Claw, C232
Dozer Blades, L225
Dozer Blades, C232
Grader Rakes, L225
Grader Rakes, C232
Grapples, Brush, Construction, L225
Grapples, Brush, Construction, C232
Grapple, Log, L225
Grapple, Log, C232
Grapple, Scrap, Construction, L225
Grapple, Scrap, Construction, C232
Harley Power Box Rake, L225
Harley Power Box Rake, C232
Hydraulic Hammers, L225
Hydraulic Hammers, C232
Lift Boom, L225
Lift Boom, C232
Load Monitors, L225
Load Monitors, C232
Manure Fork & Manure Fork With Grapple, L225
Manure Fork & Manure Fork With Grapple, C232
Manure Scrapers, L225
Manure Scrapers, C232
Snow Pusher Attachment, 10.5ft
Snow Pusher Attachment, 8ft
Snow Pusher Attachment, Heavy Duty Moldboard Components
Snow Pusher Attachment, Side Panel & Moldboard Attaching Hardware
Attachment, Hyd Pos Fork-Nursery Sleeves
