New Holland Motor Grader RG140 RG170 RG200 Parts Catalog 75131010
Brand: New Holland
Type of Machine: Motor Grader
Model: New Holland RG140 ; RG170 ; RG200 Motor Grader
Part Number: 75131010
Publication Date: 2002
Number of Pages: 835 Pages
Special Equipment Opcional (Rg140)
Special Equipment Opcional (Rg170-Rg200)
Engine, Model: 140
Engine, Short Block, Model: 140
Engine Mounts, Model: 140
Engine Mounts, Model: 170
Engine Mounts, Model: 200
Crankcase And Cylinder, Model: 140
Crancase And Cylinder, Model: 140
Cylinder Head, Model: 140
Block Covers, Model: 140
Intake Manifold, Model: 140
Oil Sump, Model: 140
Crankcase, Model: 140
Crankshaft And Flywheel, Model: 140
Connecting Rods And Pistions, Model: 140
Camshaft Drive, Model: 140
Valve Gear, Model: 140
Intake And Exhaust Valve, Model: 140
Fuel Lines, Model: 140
Fuel Lines, Model: 170, 200
Throttle Control
Throttle Control Linkage, Model: 170, 200
Throttle Control, Model: 140
Air Cleaner And Mouting, Model: 140
Air Cleaner And Mounting, Model: 170, 200
Precleaner, Model: 140
Precleaner, Modle: 170, 200
Air Cleaner
Fuel Injection System, Model: 140
Fuel Injections System, Model: 140
Fuel Filter, Model: 140
Injection Pump, Model: 140
Fuel Sediment Bowl, Model: 200
Fuel Filter, Model: 170, 200
Nozzle Holder, Model: 140
Cold Weather Starting Aid
Cold Weather Starting Aid - Model 140
Turbo Charger, Model 140
Exhaust Manifold, Model: 140
Muffler & Exhaust Pipe, Model: 140
Muffler & Exhaust Pipe, Model: 170, 200
Oil Pump, Model: 140
Oil Filter & Heat Exchanger, Model: 140
Oil Filter & Heat Exchanger, Model: 170, 200
Water Tank
Radiator & Piping, Models: 170, 200
Piping Engine Radiator, Model: 140
Piping Engine Oil Cooler, Model: 200
Air-Tight Element - Model 140, 170, 200
Water-Pump & Piping, Model: 140
Water Pump And Lines, Model: 170, 200
Water Pump, Model: 140
Fan And Fan Drive (Suction Fan)
Fan And Dan Drive
Fan Drive Assembly
Idler Assembly
Fan And Fan Drive, Model: 140
Belt Stretcher And Belt, Model: 170, 200
Transmission, Model: 140, 170
Transmission-1st Speed Shaft, Model: 140, 170
Transmission-2nd Speed Shaft, Model: 140, 170
Transmission-3rd Speed Shaft, Model: 140, 170
Transmission-4th Speed Shaft, Model: 140, 170
Transmission-5th Speed Shaft, Model:140, 170
Transmission-6th Speed Shaft, Model: 140, 170
Transmission-Out Put Shaft, Model: 140, 170
Transmission-Valve, Model: 140, 170
Transmission-Valve
Transmission-Solenoid Valve
Transmission-Out Put Flange
Transmission-Pump, Model: 200
Transmission-Clutch Assy, Model: 200
Transmission - 1st Speed Shaft, Model: 200
Transmission - 2nd Speed Shaft, Model: 200
Transmission - 3rd Speed Shaft, Model: 200
Transmission - 4th Speed Shaft, Model: 200
Transmission - 5th Speed Shaft, Model: 200
Transmission - 6th Speed Shaft, Model: 200
Transmission-Out Put Shaft, Model: 200
Transmission, Model: 200
Transmission Valve, Model: 200
Transmission-Parking Brake Disc
Transmission-Parking Brake Caliper
Axle Oil Cooler With Water Piping, Model: 140
Axle Oil Cooler With Water Piping, Model: 170
Transmission Oil Cooler
Transmission Oil Dipstick, Model: 140, 170
Transmission Oil Dipstick, Model: 200
Axle Oil Cooler Oil Piping, Model: 170
Axle Oil Cooler With Oil Cooler Piping, Model: 140
Transmission Pump And Filter Lines
Transmission Oil Filter
Transmission Control
Front Axle
Rear Axle, Graziano
Rear Axle, Clark-Hurth
Rear Axle Final Drive & Brake Assembly, Clark-Hurth
Brake Control
Brake System With Graziano Axle, Models: 140, 170
Brake System, Model: 140,170,200 (Clark-Hurth Axle)
Parking Brake Control, Model: 140, 170
Parking Brake Control, Model: 200
Parking Break Control, Model: 140, 170
Hand Brake Control Lever
Hand Brake Control Lever (85805438)
Front Frame, Model: 170
Front Frame, Model: 140
Front Frame, Model: 200
Rear Main Frame
Articulation Joint, Lower
Articulation Joint, Upper
Articulation Cylinder
Tow Hook
Operator''S Console
Power Steering-Control Unit
Emergency Steering
Emergency Steering Pump
Steering Cylinder (73065116)
Rear Wheel, Model: 140, 170
Tires And Wheels, Model:140, 170
Tires And Wheels, Model: 200
Tandem R.H./L.H. - Std. On Model 140 & 170 (Graziano)
Tandem R.H./L.H. - Std. On Model 200 - Option On Model 140 & 170
(Clark-Hurth)
Tandem R.L./Lh - Std. On Model 200 - Option On Model 140 & 170
Moldboard Hydraulic System
Hydraulic System Moldboard
Circle Shift Hydraulic
Saddle Lock Pin Cylinder And Piping, Standard
Saddle Lock Pin Cylinder And Piping, Optional
Moldboard Lift Piping
Circle Turn Hydraulic
Scarifier Hydraulic System
Scarifier Piping
Dozer Blade Float Control (Special Equipment Optional)
Front Wheel Lean Piping
Hydraulic Articulation System
Rear Hydraulic System
Ripper Hydraulic System
Scafifier And Ripper Hydraulic System
Ripper Hydraulic System, Model: 170, 200
Ripper Hydraulic System, Model: 140
Steering/Brake Hydraulic System, Model: 170, 200
Steering/Brake Hydraulic System, Model: 140
Steering Hydraulic System
Rear Hydraulic System, Model: 170, 200
Read Hydraulic System, Model 170, 200
Hydraulic System- Differential Lock, Model: 140
Hydraulic System - Differential Lock
Solenoid Valve Assembly - Saddle Lock Pin, Model: 140, 170
Solenoid Valve Assembly, Model: 200
Diagnostic Test Panel
Hydraulic Accumulator-Moldboard Side Shift (Special Equipment
Optional)
Hydraulic Accumulator-Moldboard Lift (Special Equipment Optional)
Solenoid Valve
Solenoid Valve Assy-Dozer Blade Float Control (Special Equipment
Center Moldboard Float
Saddle And Cylinder, 3 Position (Optional Na)
Saddle And Cylinder, Fixed Position (Optional Na)
Saddle & Lifting Cylinder, 5 Position
Moldboard Drawbar And Circle
Reduction Gear, 75250861
Hydraulic Motor Assembly
Ripper Tool Bar And Linkage (73162631), Model: 170, 200
Ripper Tool Bar And Linkage (73162839), Model: 140
Scarifier
Moldboard 12 Ft. (75250348), Model: 140
Moldboard 13ft. (75250344), Model: 170
Moldboard 14ft. (75250199), Model: 200
Dozer Blade And Skid Plates
Moldboard Extensions
Hydraulic Oil Tank Assembly
Pump Assembly, Model: 140
Pump (75252143), Model: 140
Oil Pump (75251956), Model: 170, 200
Hydraulic Pump - 75252598
Valve Assembly (73160567)
Valve Assembly (73162923)
Inlet Valve (75289553)
Valve-Moldboard Lift Left/Right (75289554)
Valve-Scarifier/Ripper (75289555)
Valve-Moldboard Shift 75289556
Valve-Pitch/Wheel Lean 75289557
Valve-Circle Turn (75289558)
Valve-Articulation (75289560)
Valve-Circle Shift (75289559)
Outlet Valve (75289561)
Valve (75289586), Circuit Relief
Valve (75289611)
Valve (75289609), Main Relief
Tilt Cylinder (75220689)
Moldboard Lift Cylinder 75251459 (R) 75252455 (L)
Moldboard Pitch Cylinder (75250031)
5 Point Saddle Lock Pin Cylinder 73124588 (Rh) 73124575 (Lh), Optional
Circle Shift Cylinder (75220709)
Moldboard Side Shift Cylinder (75250020)
3 Point Saddle Lock Pin Cylinder (75250238), Optional
Articulation Cylinder 75213774(Rh) 75213779(Lh)
Ripper Lift Cylinder (75251723), Model: 170, 200
Scarifier Lift Cylinder (73067421)
Ripper Lift Cylinder (75251696), Model: 140
Starter Motor, Model: 140
Starter Motor, Model: 170, 200
Alternator And Support (45 Amp), Model: 170, 200
Alternator And Support (45 Amp), Model: 140
Alternator And Support (70 Amp), Model 140
Alternator And Support(70 Amp), Models 170,200
Electric System
Electric System-Instrument Panel
Cigarette Lighter
Electric System-Transmission
Rear Light Set
Lighting System, Front
Electric System, Model: 170, 200
Electric System, Transmission
Electric System, Model: 140
Emergency Steering Electric System
Back Up Alarm System
Electrica System-Hydraulic Accumulator (Special Equipment
Light Assembly
Directional Lights Assembly
Light Special Equipment
Horn
Alternator (75208381)
Alternator (Delcom Remy)- 75241505
Starter Engine (75204899), Model: 170, 200
Starter Motor (75252133), Model: 140
Tools
Shell
Console Covers
Guards, Model: 140
Guards, Model: 170, 200
Raido Sound Suppressors
Low Profile Cab
Air Conditioner Filter
Air Conditioner Filter-Low Profile Cab
Cab-Low Profile
Cab Door
Low Profile Cab Door
Door Hinge
Rear View Mirror
Rear View Mirror - Low Profile Cab
Lock System, Rh
Low Profile Cab Lock System R.H.
Lock System, Lh
Low Profile Cab Lock System L.H.
Lock System
Lock Key
Rear/Front Windshield Motor
Low Profile Cab Rear Windshield Motor
Rear Windshield Wiper
Low Profile Cab Rear Winshield
Front Upper Windshield Wiper
Low Profile Cab Front Winshield
Cab Shade Screen
Low Profile Cab Curtain
Covering R.H.
Low Profile Cab Covering R.H.
Covering L.H.
Low Profile Cab Covering L.H.
Covering Rear
Low Profile Cab Covering Rear
Low Profile Cab Overhead Liner
Low Profile Cab Overhead Arrangement
Cab Electrical System
Low Profile Cab Electric System
Open Cab
Open Cab Covering
Open Cab Electrical System
Air Conditioner System, Model: 140
Heater And Air Conditioner, Model: 170, 200
Heater And Air Conditioner, Model: 140
Air Conditioner System, Model: 170, 200 (Special Equipment Optional)
Special Equipment - Stradale
Special Equipment
Brand: New Holland
Engine, Model: 140
Throttle Control
Air Cleaner
Water Tank
Fan And Dan Drive
Fan Drive Assembly
Idler Assembly
Transmission-Valve
Front Axle
Rear Axle, Graziano
Brake Control
Rear Main Frame
Tow Hook
Operator''S Console
Emergency Steering
(Clark-Hurth)
Scarifier Piping
Optional)
Solenoid Valve
Scarifier
Valve (75289611)
Electric System
Cigarette Lighter
Rear Light Set
Light Assembly
Horn
Tools
Shell
Console Covers
Guards, Model: 140
Low Profile Cab
Cab-Low Profile
Cab Door
Door Hinge
Rear View Mirror
Lock System, Rh
Lock System, Lh
Lock System
Lock Key
Cab Shade Screen
Covering R.H.
Covering L.H.
Covering Rear
Open Cab
Open Cab Covering
Special Equipment
- New Holland Crawler Excavator E265, E305 Tier 3 Workshop Manual_60413674
- New Holland LB90.B-LB115.B Engines F4GE0454C-F4GE0484G 604.13.612 Repair Manual
- New Holland W130 Workshop Manual
- New Holland Excavator E9SR 604.13.391 Repair Manual
- New Holland W190 Workshop Manual
- New Holland TVT 135_145_155_170_190_195 Series Service Manual 6035448106
- New Holland Crawler Dozer D350 84568077A Service Manual
- New Holland W190 (UK) Workshop Manual
- New Holland Skid Steers L175 C175 Workshop Manual
- New Holland W170 Workshop Manual
- New Holland E385C Hino Diesel Engine J08E-UN 47374920A Service Manual
- New Holland Hydraulic Hammers CB18S - CB27S - CB37S 603.67.221.03 Service Manual
- New Holland W130B Service Manual
- New Holland Loader Backhoe B110 B115 87643846 Repair Manual
- New Holland W190B Workshop Manual
