New Holland Motor Grader RG140.B to RG200.B VHP Service Manual 71114389 2012
Brand: New Holland
Type of Machine: Motor Grader
Type of Manual: Service Manual, Electrical Schematic
Model: New Holland RG140.B ; RG170.B ; RG200.B ; RG140.B VHP ; RG170.B VHP ; RG200.B VHP ; RG170.B AWD ; RG200.B AWD Motor Grader
Part Number: 71114389
Publication Date: 2012
Number of Pages: 1128 Pages
General
Section Index - General
Standard Torque Especifications
Fluids and Lubricants
Metric Conversion Chart
Service Tools
Section Index – Engines
Charge Air Cooler System
Fuel System
Section Index - Fuel System
Fuel System
Electrical
Section Index - Electrical
Removal and Installation of Starter and Alternator
Electrical Diagram – Models Without All Wheel Drive System
Electrical Diagram – Models With All Wheel Drive System
Battery
Alternator – 80 Ampere
Steering
Section Index - Steering
Front Wheel, Axle and Wheel Lean
Steering Control Valve – RG140.B VHP / RG170.B VHP / RG200.B VHP / RG170.B AWD / RG200.B AWD
Models
Steering Priority Valve – RG140.B VHP / RG170.B VHP / RG200.B VHP / RG170.B AWD / RG200.B AWD
Models
Power Train
Section Index - Power Train
ZF Transmission – Ergopower 5/6 WG-160 – RG140.B / RG170.B / RG140.B VHP / RG170.B VHP Models
FUNK Transmission – Specifications, Pressure Checks, Troubleshooting – RG140.B VHP / RG170.B VHP
Models
FUNK Transmission – RG140.B VHP / RG170.B VHP / RG170.B AWD Models
FUNK Transmission – RG200.B / RG200.B VHP / RG200.B AWD Models
Front Axle – RG140.B / RG170.B / RG200.B / RG140.B VHP / RG170.B VHP / RG200.B VHP Models
Front Drive Axle – RG170.B AWD / RG200.B AWD Models
Transmission Gear Box (Wheel Reductor) For Front Drive Axle – RG170.B AWD / RG200.B AWD Models
Rear Axle Assembly (Graziano) – RG140.B / RG140.B VHP Models
Rear Axle Assembly (Graziano) – RG170.B / RG170.B VHP / RG170.B AWD / RG200.B / RG200.B VHP /
RG200.B AWD Models
Tandem for Rear Axle Assembly (Graziano)
Tandem Flange Adjustments (Graziano)
Brakes
Sect ion Index – Brakes
Hydraulic Brake Troubleshooting
Brake Pedal Valve and System
Hydraulics
Section Index - Hydraulics
Removal and Installation of Hydraulic Components
Front Wheel Drive Hydraulic Pump and Motor – RG170.B AWD / RG200.B AWD Models
Hydraulic Schematics – RG170.B AWD / RG200.B AWD Models
Mounted Equipment
Section Index - Mounted Equipment
Air Conditioning Troubleshooting and System Checks for Systems With HFC-134A Refrigerant
Air Conditioner System Service
Removal and Installation of Air Conditioning Components for Systems With HFC-134A Refrigerant
Rear Ripper
Frame, Articulation Joint Circle and Scarifier
Front Blade and Counterweight
ROPS Cab
Cab Glass Installation
