New Holland Motor Grader F140B F170B F200B Operators Manual 84322023 2011 BR
Language: Brazilian
Brand: New Holland
Type of Machine: Motor Grader
Type of Manual: Operators Manual, Electrical Schematic
Model: New Holland Motor Grader
F140B Tier 1 - Cummins 6BTAA 5.9 Engine and ZF Transmission -From serial number NAAF07000
F170B Tier 0 - Cummins 6CT 8.3 Engine and ZF Transmission -From serial number NAAF09000
F170B Tier 2 - Cummins 6CTAA 8.3 Engine and ZF Transmission -From serial number NAAF09000
F200B Tier 0 - Cummins 6CT 8.3 Engine and Funk Transmission -From serial number NAAF11000
F200B Tier 2 - Cummins 6CT AA 8.3 Engine and Funk Transmission -From serial number NAAF11000
Part Number: 84322023
Publication Date: 2011
Number of Pages: 254 Pages
AO PROPRIETÁRIO
COMPArTIMeNTO PArA AlOjAMeNTO DO MANuAl DO OPerADOr.
lADO DIreITO, lADO eSQuerDO, DIANTeIrA e TrASeIrA DA MÁQuINA.
NÚMerOS De IDeNTIFICAÇÃO.
COMPONeNTeS DA MÁQuINA.
SEgURANÇA/DECALQUES/SINAIS DE MÃO
reGrAS De SeGurANÇA
ANTeS DA OPerAÇÃO.
OPerAÇÃO DA MÁQuINA
reGrAS ADICIONAIS De SeGurANÇA
eSTACIONAMeNTO DA MÁQuINA e PArADA DO MOTOr
PreveNÇÃO CONTrA QueIMADurAS
exTINTOr De INCêNDIO
PreveNÇÃO De INCêNDIO Ou exPlOSÃO
MANuTeNÇÃO.
MANuTeNÇÃO DAS rODAS e PNeuS
eSTruTurA rOPS
NOrMAS BÁSICAS De SeGurANÇA
MANuTeNÇÃO.
leIA O MANuAl DO OPerADOr.
NOrMAS De SeGurANÇA.
SIMBOlOGIA
DeCAlQueS De SeGurANÇA
SINAIS De MÃO
CONTROLES E INSTRUMENTOS
POSTO DO OPerADOr
COMANDOS DA CABINe.
CONSOle DIANTeIrO (ACIMA DO vOlANTe De DIreÇÃO)
CONSOle DIANTeIrO (ABAIxO DO vOlANTe De DIreÇÃO).
INDICADOreS DO PAINel De INSTruMeNTOS
OPerAÇÃO DA MOTONIvelADOrA COM TrANSMISSÃO AuTOMÁTICA ZF
(MODelOS F140B e F170B COM TrANSMISSÃO ZF)
OPerAÇÃO DA MOTONIvelADOrA COM TrANSMISSÃO FuNK (MODelOS F200B COM TrANSMISSÃO FuNK)
INSTruÇõeS De OPerAÇÃO DA TrANSMISSÃO FuNK
FreIO De eSTACIONAMeNTO (MODelOS F140B e F170B COM TrANSMISSÃO ZF)
SISTeMA De Ar CONDICIONADO, CAleFAÇÃO e CIrCulAÇÃO De Ar
BANCO DO OPerADOr
FreIO De eSTACIONAMeNTO (MODelOS F200B COM TrANSMISSÃO FuNK)
CINTOS De SeGurANÇA.
INSTRUÇÕES DE OPERAÇÃO
ANTeS DA PArTIDA NO MOTOr
INTervAlOS PArA PrIMeIrOS ServIÇOS.
APóS AS PrIMeIrAS 100 HOrAS De OPerAÇÃO
PeríODO De AMACIAMeNTO
CONexõeS DA BATerIA AuxIlIAr.
PArTIDA AuxIlIAr
DeSlOCANDO uMA MÁQuINA INOPerANTe
RODAS E PNEUS
CAlIBrANDO OS PNeuS
MANuTeNÇÃO DOS PNeuS Ou ArOS.
DIreÇÃO DA BANDA De rODAGeM
POrCAS De rODA
PreSSÃO DOS PNeuS.
LUBRIFICAÇÃO/FILTROS/FLUIDOS
reCOMeNDAÇõeS GerAIS De SeGurANÇA ANTeS De INICIAr A MANuTeNÇÃO
HOríMeTrO DO MOTOr
PINO De TrAvAMeNTO PArA TrANSPOrTe e MANuTeNÇÃO
CAPuZ DO MOTOr
MANuTeNÇÃO.
FluIDOS e luBrIFICANTeS
TABelA De luBrIFICAÇÃO e MANuTeNÇÃO
POrTAS De ACeSSO
Nível DOS FluIDOS.
GrAxeIrAS
reCOMeNDAÇõeS De vISCOSIDADe DO óleO/FAIxA De TeMPerATurA De uTIlIZAÇÃO.
MOTOr.
SISTeMA DO FIlTrO De Ar.
SISTeMA De ArreFeCIMeNTO DO MOTOr
SISTeMA De COMBuSTível
SISTeMA HIDrÁulICO/SISTeMA De FreIOS
TrANSMISSÃO
eIxO TrASeIrO
TANDeM
reDuTOr DO GIrA CírCulO
reServATórIO DO líQuIDO DO lAvADOr DO PÁrA-BrISA (OPCIONAl)
MANUTENÇÃO E AjUSTES.
verIFICAÇÃO DO FreIO De eSTACIONAMeNTO
eSTruTurA De PrOTeÇÃO CONTrA CAPOTAMeNTO (rOPS)
TOrQue De APerTO DOS PArAFuSOS DO BANCO DO OPerADOr e CINTOS De SeGurANÇA
exTINTOr De INCêNDIO (Se eQuIPADO)
COrreIAS DO AlTerNADOr e DO COMPreSSOr DO Ar CONDICIONADO
INTervAlO De MANuTeNÇÃO
verIFICAÇÃO DA COrreIA DO AlTerNADOr
INSPeÇÃO DA COrreIA.
INSPeÇÃO DO TeNSOr
INSTAlAÇÃO DA COrreIA.
GuIAS DO CírCulO
verIFICAÇÃO e AjuSTe
reGulAGeM DAS PlACAS De DeSGASTe.
BArrA De TrAÇÃO
PAINel De DIAGNóSTICO HIDrÁulICO
SISTEMA ELÉTRICO
OPerAÇÃO DAS BATerIAS COM SeGurANÇA.
MANuTeNÇÃO DAS BATerIAS.
Nível DO eleTrólITO DAS BATerIAS
reSPIrOS DAS BATerIAS
lIMPeZA DAS BATerIAS.
PArTIDA De eMerGêNCIA COM BATerIAS AuxIlIAreS
lIGAÇÃO DAS BATerIAS AuxIlIAreS
DeSlIGAr AS BATerIAS AuxIlIAreS.
lIMP-HOMe (lF e lr)
SISTeMA AuxIlIAr DA TrANSMISSÃO
COMe-HOMe
CuIDADOS ANTeS De reAlIZAr QuAlQuer PrOCeDIMeNTO De SOlDA NA MÁQuINA.
CAIxA De FuSíveIS (MÁQuINAS COM TrANSMISSÃO ZF).
relAÇÃO DOS FuSíveIS e reléS PArA TrANSMISSÃO ZF
CAIxA De FuSíveIS (MÁQuINAS COM TrANSMISSÃO FuNK)
relAÇÃO DOS FuSíveIS e reléS PArA TrANSMISSÃO FuNK
SuBSTITuIÇÃO DOS FuSíveIS
rÁDIO
lISTA De COMPONeNTeS
ARMAzENAMENTO DA MÁQUINA.
PrePArAÇÃO PArA O ArMAZeNAMeNTO.
reuTIlIZAÇÃO DA MÁQuINA APóS O ArMAZeNAMeNTO
MOTOr
TrANSMISSÃO ZF (MODelOS F140B e F170B)
TrANSMISSÃO FuNK (MODelOS F200B)
PNeuS.
FreIOS
TANDeM
eIxO DIANTeIrO
eIxO TrASeIrO
DIreÇÃO.
SISTeMA eléTrICO.
PeSOS eM CONDIÇõeS De OPerAÇÃO (MODelOS F140B)
PeSOS eM CONDIÇõeS De OPerAÇÃO (MODelOS F170B)
PeSOS eM CONDIÇõeS De OPerAÇÃO (MODelOS F200B)
GIrA-CírCulO.
BArrA De TrAÇÃO.
CHASSI
lâMINA (MOlDBOArD)
SISTeMA HIDrÁulICO
ACeSSórIOS
ÍNDICE ALFABÉTICO
TERMO DE gARANTIA
REDE DISTRIBUIDORES NEW HOLLAND BRASIL
