652
1,893,758
New Holland Mini Excavator E37C Operators Manual 51566507 2018
Brand: New Holland
Model: New Holland E37C Mini Excavator
Engine: Yanmar 3TNV88F-ESHYB Engine
Part Number: 51566507
Publication Date: 2018
Number of Pages: 262 Pages
1 GENERAL INFORMATION
Note to the Owner
Intended use
Electro-Magnetic Compatibility (EMC)
Telematics (optional)
Manual scope and required training level
Product identification
Operator's manual storage on the machine
Machine orientation.
Machine components.
EC Declaration of Conformity
2 SAFETY INFORMATION
Signal word definitions
Safety rules.
Ecology and environment
Hand signals
Noise emission
Vibration levels
Safety signs
3 CONTROLS AND INSTRUMENTS
Access to operator's platform
Door and steps
Operator's seat
Operator's seat
Forward controls
Forward controls
Windshield
Left-hand side controls
Safety lock lever
Engine speed control
Emergency exit hammer
Windshield washer reservoir
Right-hand side controls
Dozer blade control lever.
Instrument cluster
Air conditioning control
Ventilation and heating
Rearward controls
Storage compartment
Overhead controls
Cab internal lighting
Radio
Exterior controls
Side doors
Rear view mirrors.
Battery disconnect switch
Fuel tank.
4 OPERATING INSTRUCTIONS
Starting the unit
Anti-theft protection.
Starting the engine
Bringing the machine up to operating temperature.
Operating the machine in hot or cold weather.
Lowering the attachment in the event of a failure
Bucket replacement
Caution while using rubber tracks
Stopping the unit
Stopping the engine
Moving the unit
Machine travel
Parking the unit
Parking the machine.
5 TRANSPORT OPERATIONS
Road transport
Loading the machine onto a transport trailer
Preparing for road transport
Tie downs for shipping.
Unloading the machine from a transport trailer.
Shipping transport
Handling the machine
Recovery transport
Towing the machine
6 MAINTENANCE
General information
Basic instructions
General specification - Biodiesel fuels
Fluids and lubricants
Releasing pressure in the hydraulic system.
Fuel system bleeding
Protecting the electronic and electrical systems during battery charging or welding.
Maintenance planning
Maintenance chart.
Break-in period
Grease points (Bucket)
Grease points (Boom and arm)
Grease points (Blade)
Tightening torques.
Engine oil and filter
Fuel filter.
Hydraulic oil return filter
Pilot line filter
Travel reduction gears.
Boom swing cylinder
Every 10 hours
Engine oil level
Engine coolant level
Hydraulic oil level
Fuel filter water separator
Fan and alternator drive belt
Air-conditioning compressor drive belt
Every 50 hours
Track tension
Swing ring gear
Fuel tank drain.
Every 100 hours
Every 250 hours
Battery
Swing bearing
Boom swing cylinder
Tightening torques.
Every 500 hours
Fuel filter.
Air cleaner
Radiator and coolers
Radiator fan
Every 1000 hours
Pilot line filter
Every 2000 hours
Air cleaner
Engine coolant
Hydraulic oil suction filter
Hydraulic hoses
Every 5000 hours
Hydraulic oil
When necessary
Bulb replacement
Cab air filter.
Fuel tank strainer
Control levers.
Plastic and resin parts
Air-conditioning system.
Fuse and relay locations
Fuses
Storage
Preparing for storage
Periodic checks.
Starting up the machine after storage
7 TROUBLESHOOTING
Fault code resolution
Engine - Troubleshooting.
Electrical systems - Troubleshooting
Other systems - Troubleshooting.
8 SPECIFICATIONS
Machine specifications
Dimensions
Weights
9 ACCESSORIES
Direct fit buckets.
Klac type buckets.
Auxiliary hydraulic circuits
Hydraulic oil - breaker
Quick coupling system - Klac type
Load handling
Thumb bracket
Rotating beacon
Fire extinguisher.
