New Holland Loader Backhoe B95 Parts Catalog 87359334NA 2006
Brand: New Holland
Type of Machine: Loader Backhoe
Model: New Holland B95 Loader Backhoe
Part Number: 87359334NA
Publication Date: 2006
Number of Pages: 1146 Pages
Sections
Maintenance Parts
Engine 1/2
Engine 2/2
Oil Pump, Pan
Cylinder Block - Covers
Breather - Engine
Cylinder Head - Covers
Cylinder Head - Valve Mechanism
Manifold - Intake
Manifold - Exhaust
Pistons - Connecting Rod
Flywheel - Engine
Pulley - Crankshaft
Dynamic Balancer, Gears & Shafts
Dynamic Balancer, Gears & Shafts (2831300)
Camshaft
Fuel Injection Pump
Fuel Injection System
Fuel Pump
Turbocharger
Engine, Oil
Oil Pump - Engine
Oil Filters - Engine
Piping - Engine Oil
Oil Filter And Cooler
Cooling System - Engine
Thermostat - Engine Cooling System
Water Pump - Control
Fan Drive
Power Take-Off
Starter Motor
Engine - Lift Hook
Accessory Engine
Accessory Engine - Ventilator
Accessory Engine- Alternator
Accessory Engine - Bracket Muffler
Accessory Engine - Starter
Fuel Tank - Muffler - Radiator - Air Cleaner - Chassis
Fuel Tank & Related Parts
Muffler & Extensions
Expansion Tank
Air Cleaner & Hoses
Frame (Center Pivot)
Air Intake Cap & Pre-Cleaner
Front Weights
Transmission 1/2
Transmission 2/2
Gearing Speed Gear
Transmissiongearing Speed Gear (2wd Power-Shuttle)
Transmissiongearing Speed Gear (4wd Power-Shuttle)
Gear Filter Pipes (Power-Shuttle)
Transmission Esternalshifting Controls (Power-Shuttle)
Front & Rear Driveshaft (Power-Shuttle)
Transmission Oil Cooling Pipes (Power-Shuttle)
Front Axle
Front Axle (2wd)
4wd Front Axle, Housing, Bushings & Supports
4wd Front Axle, Swivel Housing & Steering Cylinder
4wd Front Axle, Hubs
4wd Front Axle, Ring Gear & Pinion Assembly
4wd Front Axle, Differential
4wd Front Axle, Drive Shaft
Front Axle - (4wd) W/Gear,Bevel
Rear Axle
Rear Axle (Power-Shuttle) (Center Pivot)
Electrical
Chassis Harness & Ground Wire (Power Shuttle)
Battery Lock-Out Switch & Ground Wire (Power Shuttle)
Engine Harness (Power Shuttle)
Single Battery
Double Battery
Cold Start
Slides Valves
Hydraulic Oil Reservoir
Hydraulic Pump (35+35-154l/Mm)
Hydraulic Pump (40+35-165l/Mm)
Hydraulic System Piping (Center Pivot)
Front Hydraulic Pump Intake & Outlet Hoses (Center Pivot)
Hydraulic System Piping(Center Pivot)
Rear Hydraulic Pump Stabilizer, Loader & Backhoe Valve Hoses
(Center Pivot)
Quick Release Couplers & Hoses (Center Pivot)
Return Manifold Hoses (Center Pivot)
Oil Cooler & Filter Hoses (Center Pivot)
Filter Assembly & Hose To Return Manifold (Center Pivot)
Loader Lift Cylinder Hoses (Center Pivot)
Loader Bucket Cylinder Hoses (Center Pivot)
Hydraulic System Piping Na (Center Pivot)
Backhoe Control Valve Hoses (Center Pivot)
Rotation Plate Hose Clamps (Center Pivot)
Backhoe Control Valve(Center Pivot)
Dipper Valve Section (Center Pivot)
Bucket, Swing, & Boom Valve Section (Center Pivot)
Two-Section Control Valve For Loader
Backhoe Control Valve, 6 Sections (Center Pivot) North America
6 Section Pilot Control Valve Support, Complete
2 Section Pilot Control Valve Support, Complete
6 Section Pilot Control Valve Support, Complete (Center Pivot)
Valve, Joystick Pilot Controls - Extended Version - (Rigth Hand)
7 Section Pilot Control Valve Support, Complete
7 Section Pilot Control Valve Support, Complete (Center Pivot)
Europe
Valve, Joystick Pilot Controls (Right Hand)
Valve, Joystick Pilot Controls (Left Hand)
7-Sections Excavator Control Valve (Center Pivot) North America
Loader Control Valve (Center Pivot)
Loader Control Valve, Two Section, Cap & Unload Valve (Center Pivot)
Loader Control Valve, Two Section, Relief & Check Valves (Center
Pivot)
Loader Control Valve, Two Section, By-Pass Kit (Center Pivot)
Loader Control Valve, Two Section, Unload Kit Or Dump Valve
Loader Control Valve, Three Section (Center Pivot)
Loader Control Valve, Three Section, Cap & Unload Valve (Center
Loader Control Valve, Three Section, Relief & Check Valves (Center
Stabilizer Control Valve, Two Section (Center Pivot)
Stabilizer Control Valve, Lh & Rh Section (Center Pivot)
Stabilizer Control Valve, Tree Section (Center Pivot)
Stabilizer Control Valve, Third Section (Center Pivot)
Lock Valve For Bucket 4x1 / 6x1
Lock Valve On Loader Tilting Cylinders
Lock Valve On Loader Lift Cylinders
Locking Valve On Backhoe Lift And Dipp. Cylinder
Backhoe Lift & Dipperstick Cylinder Lock Valve
Glide Ride Valve,Hydraulic System For Machine Frame Levelling &
On/Off Switch
Three-Section Control Valve For Loader
Kit Of Conversion From 2 To 3 Spools
Telescopic Control Valve, 3 Sections(Center Pivot)
Hed Telescopic Contorl Valve, Section Hoses(Center Pivot)
Hed Cylinder Piston End Hydraulic Lines(Center Pivot)
Hed Cylinder Rod End Hydraulic Lines(Center Pivot)
Hed Foot Pedal, Cable & Decals(Center Pivot)
Body & Hood
Cab Screen
Cab Fasteners
Loader 1/1
Backhoe 1/2
Backhoe 2/2
Transport Lock" Rear Locking" (Center Pivot)
"Transport Lock" On/Off Switch, Valve & Hoses
Transport Lock Hook, Cylinder & Hose (Side Shift,Center Pivot)
Swing Post Assembly, Bushings & Pins
Swing Post Pins & Transport Lock Hook
Distributor Valve Support (Center Pivot)
Arms And Joints
Lift Cylinder
Loader Bucket Control Cylinder
Lift Cylinder And Bucket Pipes
Self-Leveling Linkage, Loader Controls (Center Pivot)
Self-Leveling Linkage, Loader Arm (Center Pivot)
Stabilizer Cylinders (Center Pivot)
Pipes For Stabilizer Cylinders (Center Pivot)
Return To Dig Sensor
Cylinders And Rotation Plate
Swing Cylinders Backhoe
Front Control Valve Support And Transmissions (Center Pivot)
Silent Hammer Cb65s
Hammer Cb65b
Shovel And Rear Lifting Hooks
4x1 & 6x1 Bucket Hydraulic Lines (P. Shuttle)
System Hammer Components (Cab)
Hydraulic Cylinder (Bucket 4x1-6x1)
Bucket 4x1 (1 M3) With Blade
Bucket 4x1 (1 M3) With Blade "Common Grey"
Bucket 6x1 (1,15 M3) With Blade "Common Grey"
Bucket 4x1 (1 M3) With Tine
Bucket 4x1 (1 M3) With Tine "Common Grey"
Bucket 6x1 (1,15 M3) With Tine
Bucket 6x1 (1 M3) With Blade
Bucket 6x1 (1 M3) With Blade "Common Grey"
Bucket 6x1 (1 M3) With Tine
Bucket 6x1 (1 M3) With Tine "Common Grey"
Bucket 6x1 (1,15 M3) With Tine "Common Grey"
Boom - Dipper Short
Short Dipper
Short Dipper - Bucket Motion
Short Dipper - Hydraulic System
Hydraulic Bucket Cylinder
Hydraulic Ditching Cylinder
Hydraulic Lifting Cylinder
12" (305mm) Backhoe Bucket With Pin Teeth
12" (305mm) Backhoe Bucket With Bolt-On Teeth
18" (457mm) Backhoe Bucket With Pin Teeth
18" (457mm) Backhoe Bucket With Bolt-On Teeth
24" (610mm) Backhoe Bucket With Pin Teeth
24" (610mm) Backhoe Bucket With Bolt-On Teeth
30" (762mm) Backhoe Bucket With Pin Teeth
30" (762mm) Backhoe Bucket With Bolt-On Teeth
36" (914mm) Backhoe Bucket With Pin Teeth
36" (914mm) Backhoe Bucket With Bolt-On Teeth
0.88 M3 Bucket Without Tines
1 M3 Bucket
Standard 1mc Bucket With Forks
Standard 1m3 Bucket With Forks And Extra Reversible Blade
Bolt-On Tooth Kit, 12" (305mm) Backhoe Bucket
Standard 1m3 Bucket With Forks And Tine
Bolt-On Tooth Kit, 18" (457mm) & 24" (610mm) Backhoe Buckets
0.88 M3 Bucket And Extra Reversible Blade
Bolt-On Tooth Kit, 30" (762mm) Backhoe Bucket
Bolt-On Tooth Kit, 36" (914mm) Backhoe Bucket
Pin Tooth Kit, 12" (305mm) Backhoe Bucket
Pin Tooth Kit, 30" (762mm) Backhoe Bucket
Pin Tooth Kit, 36" (914mm) Backhoe Bucket
Standard 1mc Bucket With Tine
Standard 1mc Bucket With Extra Reversible Blade
Ditch Cleaning Bucket
Front Bucket Teeth
Loader Bucket Reversible Blade
Scrab Grab
Fork Kit, Converts4x1 Bucket To 6x1
Hand Hammer Switch
Manual Hammer System
Manual Hammer Valve
Hydraulic System For Hammer (Center Pivot)
Rear Hammer Control Valve
Hydraulic System For Hammer (4ws)
Hydraulic System For Hammer (Side Shift Europa)
Hammer Kit From Lifting Arm To Demolition Arm
Rear Mechanical Quick-Coupling
Front Mechanical Quick-Coupling
Boom - Long Dipper
Long Dipper
Long Dipper - Bucket Motion
Long Dippêr - Hydraulic System
Long Dipper - Hydraulic System
Telescopic Dipper Long - Hydraulic System
Telescopic Dipper Long - Hydraulic Lifting Cylinder
Boom - Telescopic Dipper Short
Telescopic Dipper Short - Hydraulic System
Telescopic Dipper Short- Bucket Motion
Telescopic Dipper Short - Hydraulic Systemm
Body, Hood & Driver''S Post 1/3
Body, Hood & Driver''S Post 2/3
Body, Hood & Driver''S Post 3/3
Stabilizer Control Without Auto-Up (Center Pivot)
Stabilizer Control With Auto-Up (Center Pivot)
Cab / Ceiling Light
Safety Frame- Instruments And Gauges
Back-Up Alarm
Igniton Switch, Power Point, Fuse Panel & Side Console Harness
(Rops Cp Power Shuttle)
Rh Side Console Trim, Instrument Cluster & Switches (Rops Cp Power
Shuttle)
Igniton Switch, Power Point, Fuse Panel & Side Console Harness (Cab
Cp Power Shuttle)
Front And Rear Windscreen Wipers
Windscreen Wipers Reservoir & Nozzles
Radio Antenna & Speaker Cover
Lamps & Lights - Cab (Usa)
Lamps & Lights - Rops (Usa)
Cab-Safety Frame / Extinguisher
Cab - Frame-Door
Rops - Safety Frame
Windows
Fenders, Rear
Door Components
Firewall Seal, Rops
Rear Windows
Cab / Soft Trim
Cab / Soft Trim (Power Shuttle)
Rh & Backhoe Console Trim, Rops (Center Pivot)
Roof, Rops
Rear Mirror- Sun Screen
Front Console - Rops (Power Shuttle)
Rh Side Console Seal & Clips - Rops (Power Shuttle)
Cab / Panel Dash
Cab/ Canopy
Heater Water Hoses
Cab-Safety Frame / Brake Pedal
Cab-Safety Frame / Hand Brake
Transport Lock Control
Hand-Operated And Pedal-Operated Accelerator Control
Power Steering Motor, Wheel & Column Trim (Na)
Power Steering Motor Hoses
Power Steering Motor, Wheel & Column (Na)
Foward/Reverse & Multi-Purpose Lever (Power-Shuttle - Center
Stabilizer Control
Pilot Control Diagnostics
Cab Plugs, Floor Plates & Air Conveyer, Center Pivot
Rops Plugs & Floor Plate (Center Pivot)
Information Symbol Decals - Usa (Power Shuttle)
Cab Warning & Information Decals (Power Shuttle)
Backhoe, Loader & Engine Warning Decals (Power Shuttle)
Plates (Power Shuttle)
B95 B95lr Model Identification
B95 Model Identification
A/C Housing & Filters
A/C Blower & Coils
Heater Coil Hoses
A/C & Heater Control Panel
A/C & Heater Console Ducts
Transformation Set From Heating To Air Conditioning
Housing & Filters
Heater Blower & Coils
Cab Heating Coating Plug
Case 3 Lever Backhoe Controls, Console & Levers
Case 3 Lever Backhoe Controls, Bellcrank & Support
Case 3 Lever Backhoe Controls, Bucket Tie-Rod Assembly
Case 3 Lever Backhoe Controls, Upper Swing Tie-Rod Assembly
Case 3 Lever Backhoe Controls, Dipper, Swing & Boom Linkage
Case 3 Lever Backhoe Controls, Swing Control Pedal
Loader Control Valve, Two Section, Lever & Decal
2 Lever Backhoe Controls, Lever, Boot & Decals (Center Pivot)
Locking Valve On Backhoe Lift Cylinder
Iso 2 Lever Backhoe Controls, Levers, Boot & Decals (Center Pivot)
Iso 2 Lever Backhoe Controls, Tie-Rod Assembly (Center Pivot)
4 Lever Backhoe Controls, Console, Levers & Bellcrank (Center
4 Lever Backhoe Controls, Upper Tie-Rod Assembly, Center Pivot
4 Lever Backhoe Controls, Lower Tie-Rod Assembly (Center Pivot)
Internal Fan
Machine Part Air Conditioning Set
A/C Compressor Attaching Group
A/C Compressor
A/C Filter & Condenser Attaching Group
Steering Column, Fixed & Adjustable
Seat Belts, 2" & 3"
Rotating Beacon
Front Console With Speedometer, 4wd
Front Console Without Speedometer (Cab)
Speed Sensor(P.Shuttle)
Rh Console With Instruments
Rh Console With Instruments And Diagnostics
Antitheft
Cloth Seat & Attaching Hardware - Cabine
Air Ride Cloth Seat & Attaching Hardware - Cabine
Vinyl Seat Cushions, Armrests & Related Parts (Rops)
Vinyl Seat With Armrests & Mounting Hardware (Rops)
Vinyl Seat Mounting Plate, Adjusting Rails & Seat Belt (Rops)
Vinyl Seat Upper Suspension Parts (Rops)
Vinyl Seat Lower Suspension Parts (Rops)
Tool Kit
Safety Plates - Usa
Front Wheels, 2wd
Driving Wheels(4wd)
Drive Wheels
Variation
Stabilizer Foot Ground (Center Pivot)
Stabilizer Foot Street Pad (Center Pivot)
Reversible Stabilizer Foot (Center Pivot)
4wd Steering Lock
Fenders, Front
Battery Connection
Brand: New Holland
Sections
Maintenance Parts
Engine 1/2
Engine 2/2
Oil Pump, Pan
Breather - Engine
Manifold - Intake
Manifold - Exhaust
Flywheel - Engine
Pulley - Crankshaft
Camshaft
Fuel Injection Pump
Fuel Pump
Turbocharger
Engine, Oil
Oil Pump - Engine
Piping - Engine Oil
Fan Drive
Power Take-Off
Starter Motor
Engine - Lift Hook
Accessory Engine
Expansion Tank
Air Cleaner & Hoses
Front Weights
Transmission 1/2
Transmission 2/2
Gearing Speed Gear
Front Axle
Front Axle (2wd)
Rear Axle
Electrical
Single Battery
Double Battery
Cold Start
Slides Valves
(Center Pivot)
Europe
Pivot)
On/Off Switch
Body & Hood
Cab Screen
Cab Fasteners
Loader 1/1
Backhoe 1/2
Backhoe 2/2
Arms And Joints
Lift Cylinder
Silent Hammer Cb65s
Hammer Cb65b
Boom - Dipper Short
Short Dipper
1 M3 Bucket
Front Bucket Teeth
Scrab Grab
Hand Hammer Switch
Manual Hammer Valve
Boom - Long Dipper
Long Dipper
Cab / Ceiling Light
Back-Up Alarm
Shuttle)
Cp Power Shuttle)
Cab - Frame-Door
Rops - Safety Frame
Windows
Fenders, Rear
Door Components
Firewall Seal, Rops
Rear Windows
Cab / Soft Trim
Roof, Rops
Cab / Panel Dash
Cab/ Canopy
Heater Water Hoses
Stabilizer Control
A/C Blower & Coils
Heater Coil Hoses
Housing & Filters
Internal Fan
A/C Compressor
Seat Belts, 2" & 3"
Rotating Beacon
Antitheft
Tool Kit
Safety Plates - Usa
Front Wheels, 2wd
Driving Wheels(4wd)
Drive Wheels
Variation
4wd Steering Lock
Fenders, Front
Battery Connection
- New Holland Crawler Excavator E265, E305 Tier 3 Workshop Manual_60413674
- New Holland LB90.B-LB115.B Engines F4GE0454C-F4GE0484G 604.13.612 Repair Manual
- New Holland W130 Workshop Manual
- New Holland Excavator E9SR 604.13.391 Repair Manual
- New Holland W190 Workshop Manual
- New Holland TVT 135_145_155_170_190_195 Series Service Manual 6035448106
- New Holland Crawler Dozer D350 84568077A Service Manual
- New Holland W190 (UK) Workshop Manual
- New Holland Skid Steers L175 C175 Workshop Manual
- New Holland W170 Workshop Manual
- New Holland E385C Hino Diesel Engine J08E-UN 47374920A Service Manual
- New Holland Hydraulic Hammers CB18S - CB27S - CB37S 603.67.221.03 Service Manual
- New Holland W130B Service Manual
- New Holland Loader Backhoe B110 B115 87643846 Repair Manual
- New Holland W190B Workshop Manual
