118
6,911
New Holland Excavator MH2.6 MH3.6 Tier 3 Repair Manual 87730662A
Brand: New Holland
Type of Machine: Excavator
Type of Manual: Repair Manual
Model: New Holland MH2.6, MH3.6 Tier 3 Excavator
Part Number: 87730662A
Number of Pages: 915 Pages
Section 01 Main Operating Rules
1. Introduction
11. Foreword
12. Manual Handling
Section 02 Safety Precautions
1. Safety Precautions
2. Safety Decals
Section 03 Features And Data
1. Foreword
2. Identification Data
3. Noise Levels (2000/14/Ec)
4. Summary Plate For Maintenance Operations
5. Wheeled Excavator Main Components
51. Technical Specifications
52. Operating Weights
53. Digging Performance
54. Transport Dimensions
55. Bucket Usefulness Depending On Arm
6. Filling Chart
Section 04 Upper Structure
1. Upper Structure
2. Main Frame And Counterweight
3. Power Unit
31. Engine
4. Radiator
5. Hydraulic Pumps
51. Main Pump
52. Double Pump With Gears
6. Air Cleaner
7. Exhaust Silencer
8. Hydraulic Oil Tank
9. Fuel Tank
10 Fuel Transfer Pump
11 Guards And Covers
12 Cab
13 Swinging Assy
14 Main Control Valve
15 Slew Device
151. Slew Hydraulic Motor
152. Slew Reduction Unit
16 Control Lever
17 Control Pedal
18 Steering Unit
19 Swivel Joint
191. Features And Data
20 Brake Pedal Valve
21 Accumulators
22 Pressure Switches
23 Solenoid Valves
Section 05 Undercarriage
1. Slewing Bearing
2. Lower Frame
3. Travel Assy
31. Travel Hydraulic Motor
32. Speeds Gear Box
33. Steering Axles: Front And Rear
34. Rigid Rear Axle
35. Drive Shaft
4. Wheels And Tyres
41. Tyres
5. Blade
6. Lateral Stabilizers
Section 06 Front Attachment
1. Introduction
2. Cylinder Removal And Installation
21. Bucket Cylinder
22. Arm Cylinder
23. Positioning Cylinder
24. Boom Cylinder
3. Mh26 - Cylinders
31. Bucket Cylinder
32. Arm Cylinder
33. Positioning Cylinder
34. Boom Cylinder
4. Mh36 - Cylinders
41. Bucket Cylinder
42. Arm Cylinder
43. Positioning Cylinder
44. Boom Cylinder
5. Antidrop Valve
6. Pins And Bushings
7. Buckets
Section 07 Hydraulic System
1. Hoses And Fittings
2. Hydraulic System
21. Main Pipelines
22. Suction And Delivery Pipelines
23. Return Pipelines
24. Draining Pipelines
25. Front Attachment Pipelines
26. Nibbler/Breaker Control Pipelines
27. Slew Control Pipelines - Travel And Blade/Stabilizer
28. Steering Pipelines (Machine 4wd)
29. Steering Pipelines (Machine 2wd)
210 Brake Pipelines
211 Power Steering Pipelines
212 Lateral Stabilizers And Blade Control Pipeline
213 Lock Valves
214 Stabilizers/Blade Selection Valve
215 Front Axle Lock
216 Axle Lock Valve
217 Pressure Relief Valve
3. Operation Of Circuits
Section 08 Electrical System
2. Features And Data
3. Components Location And Operation
4. Undercarriage Electric Components
41. Machine With Four Steering Wheels
42. Machine With Two Steering Wheels
5. Control Units Electric System
6. Light And Beams Group
7. Gauges And Controls
71. Dashboards
72. Control Levers
73. Switches And Control Lights Panel
74. Switches And Warning Lamps
75. Monitor Panel
76. Key Start Switch
77. Left Control Lever
78. Right-Hand Control Lever
79. Control Panel And Switches
710 Machine Control Card
711 Pump Control Card
8. Electric Components
81. Throttle Lever Control
82. Swivel Joint
83. Batteries
84. Generator
85. Starter
9. Control Line And Wiring Harnesses
91. Controls On Consoles
92. Controls For Side Panel Switches
93. Anti-Tilting Check Control Line
94. Working Lights Control Line
95. Traffic Beams Control Line
96. Steering Column Controls
Section 09 Troubleshooting
1. Introduction
2. Hydraulic System Troubleshooting
3. Electrical System Troubleshooting
Section 10 Performance Test
1. Introduction
11. General Information For Machine Testing
2. Standard Performances - Mh26
21. Table Of Excavator Standard Performances
22. Hydraulic Components Standard Performance
23. Main Pump P-Q Curve
3. Standard Performances - Mh36
31. Table Of Excavator Standard Performances
32. Hydraulic Components Standard Performance
33. Main Pump P-Q Curve
4. Preparation For Performance Test
5. Excavator Performance Test
51. Engine Performance
52. Swing Performance
53. Front Attachment Performance
54. Control Levers
6. Boom/Slew Performance
61. Combined Slew/Boom Test
62. Steering
63. Brakes System
7. Gear Box
71. Gear Box Pressure Check
8. Components Performance
81. Overpressure Valve And Pilot Control Line
82. Overpressure Relief Valves
83. Drive Shaft
84. Hydraulic Pumps - Mh26
85. Hydraulic Pumps - Mh36
86. Travel Motor
