New Holland Excavator E215B E215BLC Operation Manual 87739539 2007
Brand: New Holland
Type of Machine: Excavator
Model: New Holland E215B, E215BLC Excavator
Part Number: 87739539
Publication Date: 2007
Number of Pages: 241 Pages
Foreword
General
Periodic Inspections
Notice
Keep Operation & Maintenance Manual Storage
For Ordering
1. Safety Precautions
1.1 General Safety Information
1.2 Safety Precautions
1.3 Warning Labels & Decals
1.3.1 Warning Labels & Decals Maintenance
1.3.2 Location Of Warning Labels & Decals
1.4 Pre-Start Safety
1.5 Safety During Operation
1.6 Inspection & Maintenance Safety
1.7 Battery Safety
1.8 Prohibited Machine Operation
1.9 End Of Work Shift Safety
1.10 Towing The Machine
2. Machine Familiarization
2.1 Basic Components Of The Machine
2.2 Operator Cab Nomenclature
2.3 Component & Controls Nomenclature
2.3.1 Gauge Cluster
2.3.2 Location Of Switches And Meters
2.3.3 Levers And Pedals
2.3.4 Fuses & Relay Box
2.3.5 Fusible Link (For Starter)
2.3.6 Mechatro-Controller (Cpu), Engine Controller (Ecu)
2.3.7 Handling Of Antenna
2.3.8 Air Conditioner
2.3.9 Handling Of Seat Belt
2.3.10 Operator Seat
2.3.11 Operator Cab
2.3.12 Fuel Pump
2.3.13 Emergency Escape From Cab
2.3.14 Other Equipment (Accessory)
3. Machine Operation
3.1 Machine Operation
3.1.1 Everyday Check-Up
3.1.2 Checking Before Starting Engine
3.1.3 Adjusting Operator Seat
3.1.4 Adjusting Mirror
3.1.5 Checking Function Of Gauge Cluster
3.1.6 Checking Work Light
3.1.7 Starting Engine
3.1.8 Stopping Machine Engine
3.1.9 Inspection After Starting Engine
3.1.10 Machine Warming-Up
3.1.11 Work Mode Select Switch
3.1.12 Controls Decal
3.1.13 Machine Operation
3.1.14 Practices To Improve Efficiency
3.1.15 Flagman Hand Signals
3.1.16 Parking The Machine
3.1.17 Precautions After Operation
3.1.18 Machine Operation In Adverse Weather Conditions
4. Maintenance
4.1 General Information
4.2 General Safety & Precautions
4.3 Lubricant, Fuel & Coolant Specifications
4.4 Use Of Bio-Degradable Oils
4.5 Maintenance Parts
4.6 Torque Values For Specified
4.7 Torque Specifications For Bolts & Nuts
4.8 Torque Specifications For Joints & Hydraulic Hoses
4.9 Inspection & Maintenance Chart
4.10 When Required
4.11 Pre-Start (Every 8 Hours) Inspection & Maintenance
4.12 50 Hour (Weekly) Inspection & Maintenance Procedures
4.13 120 Hour Inspection & Maintenance Procedure
4.14 250 Hour (3-Month) Inspection & Maintenance Procedure
4.15 500 Hour Inspection & Maintenance Procedures
4.16 1000 Hour (12-Month) Inspection & Maintenance Procedures
4.17 2000 Hour Inspection & Maintenance Procedures
5. Transportation
5.1 Ground Transportation
5.1.1 Machine Preparation
5.1.2 Loading/Unloading The Machine
5.1.3 Securing The Machine
5.2 Lifting Machine
5.3 Installing And Removing Mirror
6. Specifications
6.1 General Specifications
6.2 Shoe Types
6.3 Working Ranges
6.4 Bucket And Arm Combinations
7. Optional Equipment
7.1 Operation Of Hydraulic Breaker And Nibbler
7.1.1 Selection Of Hydraulic Breaker And Nibbler
7.1.2 Before Operating Breaker Or Nibbler
7.1.3 Precautions For Impurity And Hydraulic Oil
7.1.4 Work Mode Selection And Selector Valve
7.1.5 Setting Stop Valve
7.1.6 Flow Rate Control
7.1.7 Basic Operation
7.1.8 Prohibited Work In Use Of Breaker
7.1.9 Periodic Inspection And Maintenance Interval
7.1.10 Reinforcing Attachment
7.1.11 Prohibited Work In Use Of Nibbler
7.1.12 Precaution To Be Exercised
On Breakers Of Different Manufactures
7.2 Travel Alarm Switch (Option)
Brand: New Holland
Foreword
General
Notice
For Ordering
1.7 Battery Safety
2.3.1 Gauge Cluster
2.3.11 Operator Cab
2.3.12 Fuel Pump
4. Maintenance
4.10 When Required
5. Transportation
5.2 Lifting Machine
6. Specifications
6.2 Shoe Types
6.3 Working Ranges
- New Holland Crawler Excavator E265, E305 Tier 3 Workshop Manual_60413674
- New Holland LB90.B-LB115.B Engines F4GE0454C-F4GE0484G 604.13.612 Repair Manual
- New Holland W130 Workshop Manual
- New Holland Excavator E9SR 604.13.391 Repair Manual
- New Holland W190 Workshop Manual
- New Holland TVT 135_145_155_170_190_195 Series Service Manual 6035448106
- New Holland Crawler Dozer D350 84568077A Service Manual
- New Holland W190 (UK) Workshop Manual
- New Holland Skid Steers L175 C175 Workshop Manual
- New Holland W170 Workshop Manual
- New Holland E385C Hino Diesel Engine J08E-UN 47374920A Service Manual
- New Holland Hydraulic Hammers CB18S - CB27S - CB37S 603.67.221.03 Service Manual
- New Holland W130B Service Manual
- New Holland Loader Backhoe B110 B115 87643846 Repair Manual
- New Holland W190B Workshop Manual
