New Holland Excavator E18SR Parts Catalog 87519740NA 2007
Brand: New Holland
Type of Machine: Excavator
Model: New Holland E18SR Excavator
Applicable Number: PU08-05001~
Part Number: 87519740NA
Publication Date: 2007
Number of Pages: 374 Pages
Filter, Fuel - Filter, Oil
Frame Assembly, Upper (Pu52f00032f1) (Pu24c00012f1 Cover)
Bracket Group, Swing (Pu02b00066f1, 76f1, 69f1, 65f1)
Counterweight Instal (Pu60c00016f1, 15f1)
Engine Assy (Pu02p00013f1)
Engine Instal (Pu02p00016f1)
Radiator Instal (Pu05p00016f1, 17f1)
Radiator Assy (Pu05p00015f1)
Air Cleaner Assy (Pu11p00006f1)
Muffler (Pu12p00014f1)
Fuel Lines (Pu21p00002f1)
Fuel Lines
Tank Instal, Fuel (Pu20p00015f1, 14f1)
Tank Instal, Hydraulic (Pu33h00016f1, 19f1)
Control Assy, Engine (Pu11m00012f1)
Power Take-Off Assy (Pu30p00013f1)
Motor Instal, Swing (Pu32w00012f1)
Lubrication Lines (Pu71h00012f1)
Control Valve Instal (Pu64h00019f1)
Hydraulics - Pump To Control Valve (Pu30h00013f1)
Hydraulics - Upper / Swing Motor To Cylinder (Pu03h00016f1,
Pu19h00018f1, Pu42h00024f1)
Hydraulics - Upper / At Control Valve
Hydraulics - Upper / Nibbler & Breaker (Pu03h00017f1)
Hydraulics - Return / Nibbler & Breaker (Pu32h00018f1, 16f1)
Hydraulics - Return / Nibbler & Breaker / At Tank & Valve
Controls, Operator (Pu03m00033f1)
Cover Assy, Operator Controls (Pu03m01367f1)
Wrist Support, Operator Controls (Pu03m01368f1)
Control Box Assy (Lh) (Pu03m00036f1)
Lock Assy (Pu03m01122f1)
Lever Assy, Control (Crawler) (Pu50m00014f1)
Lever Assy, Control (Dozer) (Pu03m01308f1)
Lever Assy, Control (Pm50m00004f3) & Pedal Instal (Pu55m00003f1)
Hydraulics - Remote Control Lines (Pu64h00022f1, Pu68h00033f1, 28f1,
34f1)
Hydraulics - Remote Control Lines At Valve (Pu06h00020f1, 15f1, 21f1)
Hydraulics - Control Lines, Valve Instal (Pu64h00024f1, 25f1)
Hydraulics - Control Lines, Propel (Pu62h00003f1, 04f1, 05f1)
Hydraulics - Control Lines, Valve (At Tank, Pump, Solenoid Valve)
(Pu64h00023f1)
Floorplate & Floormat (Pu03m00035f1)
Canopy Assy (Pu06c00014f1)
Work Lamp Assy (Pa80s00003f1)
Seat Assy Instal (Pu25m00022f1)
Guards & Covers (Exterior, Upper) (Pu21c00017f1)
Key Assy (Pw03m01870f1)
Gauge Assy, Cluster (Pu59s00001f1)
Battery Instal (Pu72e00012f1)
Electrical Assy, Upper (Harness) (Pu03e00002f1)
Electrical Assy, Upper (Hardware)
Electrical Assy, Upper (Cable, Fuse, Relay)
Electrical Assy, Upper (Horn)
Harness Assy (At Air Cleaner) (Pu11e00001f1)
Relay Assy (Harness) (Pu24e00016f1)
Lower Frame Group (Pu02f00034f1, Pu53d00016f1, Pu19h00016f1)
Cylinder Instal (Crawler Frame Width) (Pu01v00034f1)
Slewing Ring Assembly (Pf40f00002f1)
Idler Assy (Pu52d00017f1)
Idler Assembly (Pu52d00019f1)
Idler Adjuster Assy (Pe54d00001f1)
Track Roller Assy (Pu64d00015f1)
Shoe Assy, Track / Belt (Pe61d00002f1, Pe60d00003f1)
Hydraulics - Lower / At Swivel (Pu02h00015f1, Pu19h00017f1,
Pu13h00012f1)
Hydraulics - Lower (Pu12h00012f1, Pu13h00013f1)
Dozer Assy, Frame (Pu51b00023f1, 25f1, 26f1, 24f1)
Boom Assy, Standard 1.8m (6 Ft) (Pu02b00061f1, 64f1, 67f1)
Hydraulic Lines - Boom 1.8m (6 Ft) & Cylinder (Pu42h00026f1, 21f1, 23f1,
22f1)
Hydraulic Lines - Boom 1.8m (6 Ft) & Arm (Nibbler & Breaker)
(Pu42h00020f1, Pu43h00017f1)
Cylinder Instal (Boom) (Pu02b00077f1)
Lamp Instal & Harness (Boom) (Pu80s00012f1)
Arm Assy, Standard 0.98m (3 Ft 2 In) (Pu12b00049f1)
Hydraulic Lines - Arm, Standard 0.98m (3 Ft 2 In)(Pu43h00018f1)
Bucket Instal (Pu61b00049f1)
Tools & Accessories (Pm01t00002fe)
Counterweight Instal (Pu60c00023f1)
Pedal Assy, Operator Control (Pu14m00001f1)
Arm Assy, Long 1.20m (4 Ft) (Pu12b00052f1)
Hydraulic Lines - Arm, Long 1.20m (4 Ft) (Pu43h00022f1)
Hydraulic Lines - Boom & Arm 1.20m (4 Ft) (Nibbler & Breaker)
(Pu42h00020f1)
Decals / Name Plate Instal / Label Location (Pu22t00054f1 - F4)
Decals / Name Plate (Pu22t00054f1 - F4)
Decals / Name Plate Instal (Pu22t00048f3, F4)
Valve Assy, Control (Pu30v00017f1)
Valve Assy O-Rings (Pu30v00017f1)
Valve Section, Control Valve - Slewing/Swing (Pu30v00019f1)
Valve Section, Control Valve - Dozer (Pu30v00020f1)
Valve Section, Control Valve - Supply, Travel Independence
(Pu30v00021f1)
Valve Section, Control Valve - Service (Pu30v00022f1)
Valve Section, Control Valve - Arm (Pu30v00023f1)
Valve Section, Control Valve - Boom Swing (Pu30v00024f1)
Valve Section, Control Valve - Travel Right (Pu30v00025f1)
Valve Section, Control Valve - Supply, Connecting (Pu30v00026f1)
Valve Section, Control Valve - Travel Left (Pu30v00027f1)
Valve Section, Control Valve - Boom (Pu30v00028f1)
Valve Section, Control Valve - Bucket (Pu30v00029f1)
Valve Assy, Overload Relief (Pm22v00005f1-Fg)
Valve Assy, Anti-Cavitation (Ph21v00001f1)
Plug Assy, Service Section (Ph50t00001f1)
Valve Assy, Relief (Pr22v00004f1-Fa)
Motor Assy, Swing (Pu15v00019f1)
Valve Assy, Relief (Swing Motor) (Pu22v00001f1)
Motor Assy, Propelling (Pu15v00021f1)
Pump Assy (Pu10v00014f1)
Cylinder Assy, Boom (Canopy) (Pu01v00024f1)
Cylinder Assy, Arm (Pu01v00036f1)
Cylinder Assy, Bucket (Pu01v00035f1)
Cylinder Assy, Dozer (Pu01v00029f1)
Cylinder Assy, Swing (Pu01v00028f1)
Cylinder Assy, Crawler (Pu01v00030f1)
Valve Assy, Pilot (Px30v00043f1)
Valve Assy, Pilot (Propelling) (Pm30v00019f1)
Valve Assy, Solenoid (Px35v00003f1)
Valve Assy, Relief (Yr22v00001f1)
Valve Assy, Selector (Px30v00060f1, F2)
Joint Assy, Swivel (Pa55v00001f1 - F4)
Valve Mechanism
Rocker Cover
Camshaft
Crankcase
Crankshaft Bearing
Gear Cover
Flywheel Plate
Oil Pan
Pistons & Connecting Rods
Crankshaft & Flywheel
Manifolds
Oil Screen & Oil Filter
Thermostat
Fan & Belt
Fuel Injection System
Fuel Injection Nozzle
Filter Assy, Water Sediment
Filter Assy, Fuel
Governor Parts
Fuel Injection Pump Mounting
Fuel Injection Pump
Fuel Injection Pump Drive
Starter Assy
Starter Mounting & Glow Plug
Glow Lamp
Alternator Mounting
Alternator Assy
Magnetic Switch
Speed Control
Kit, Engine Gasket
