New Holland Excavator E16 E18 Workshop Manual 60413396 2005
Brand: New Holland
Type of Machine: Excavator
Type of Manual: Workshop Manual, Hydraulic Schematic
Model: New Holland E16 ; E18 Excavator
Engine: Yanmar 3TNE74 Engine
Part Number: 60413396
Publication Date: 2005
Number of Pages: 667 Pages
Section 1 - How To Use
Sections Index
Introduction
Features Of The Manual
Section 2 - Safety Rules
Safety Rules
Safety Signs
Section 3 - Preliminary
General Precautions For Repairs
Escaping Procedure In Case Of Emergency
International Unit Conversion System
Section 4 - Specification
Foreword
Identification Data
Noise Levels (2000/14/Ec)
Summary Plate For Maintenance Operations
Basic Components Of The Mini Excavator
Technical Specifications
Digging Performances (Canopy)
Digging Performances (Cab)
Transport Dimensions (Canopy)
Transport Dimensions (Cab)
Lifting Capacities (Cab)
Lifting Capacities (Canopy)
Machine And Components Weight (Dry)
Buckets Application
Filling Chart
Section 5 - Tools
Tools Of Cylinders
Tool Of Hydraulic Pump
Tool Of Pilot Valve Track
Tool Of Roller Track
Tool Of Idler Adjuster
Tools Of Engine
Tools Of Travel Motor
Section 6 - Standard Maintenance Time Table
Preface
Standard Working Time Table For The Maintenance
Section 7 - Maintenance Standards And Test Procedures
How To Use Maintenance Standards And Precuations
Performance Inspection Standard Table
Measuring Engine Speed
Measuring Hydraulic Oil Pressure
Measuring Travel Performances
Measuring Slew Performances
Measuring Attachment Operating Performances
Measuring Slew Bearing Performances
Measuring Crawler Tension
Section 8 - Hydraulic System
Function And Features Of Hydraulic Circuit
Hydraulic Circuits And Components
Hydraulic Circuit Operation
Section 9 - Electrical System
How To Read Circuit Diagram
Section 10 - Attachment
Attachment Assy And Name
Bucket
Arm
Boom
Swing
Dozer
Hydraulic Cylinders
Section 11 - Upper Structure
Canopy
Guard
Floor Plate
Battery
Counterweight
Hydraulic Oil Tank
Air Cleaner
Muffler
Control Valve
Solenoid Valve
Pilot Valve
Pilot Valve Travel
Slew Motor
Joint Swivel
Selector Valve
Upper Frame
Section 12 - Travel System
Low Structure
Crawler
Slide Plate
Roller Tracks
Idler Adjuster
Sprocket
Travel Motor
Slew Bearing
Lower Frame
Section 13 - Troubleshooting Hydraulic System
General Precautions
Trouble Diagnosis: Hydraulic
Troubleshooting
Section 14 - Troubleshooting Electrical System
Trouble Diagnosis: Electrical
Troubleshooting
Section 15 - Troubleshooting Engine
Trouble Diagnosis: Engine
Troubleshooting
Section 16 - Engine
Specifications And Performance
Cross Sectional Views
Cooling Water, Lubricating Oil And Fuel Oil
Troubleshooting
Measuring Instruments
Measurement, Inspection And Adjustment
Adjustment The Valve Head Clearance
Checking The V-Belt Tension
Measuring And Checking The Injection Pressure And Spray Patterns Of The Fuel Injection Valve
Checking And Adjustament The Fuel Injection Timing
Adjustament The No-Load Maximum (Or Minimum) Revolutions
Checking The Cooling Water System And Radiator For Water Leakage
Checking The Battery
Checking The Sensors
Checking The Oil Cooler
Checking The Piston Cooling Nozzle
Measuring Procedure, Service Data And Corrective Action
Disassembly And Reassembly
Service Data
Tightening Torque
Fuel Injection Pump For Indirect Injection System
Fuel Injection Pump For Direct Injection System
Governor
Turbocharger
Brand: New Holland
Sections Index
Introduction
Safety Rules
Safety Signs
Foreword
Identification Data
Buckets Application
Filling Chart
Section 5 - Tools
Tools Of Cylinders
Tools Of Engine
Preface
Bucket
Arm
Boom
Swing
Dozer
Hydraulic Cylinders
Canopy
Guard
Floor Plate
Battery
Counterweight
Hydraulic Oil Tank
Air Cleaner
Muffler
Control Valve
Solenoid Valve
Pilot Valve
Pilot Valve Travel
Slew Motor
Joint Swivel
Selector Valve
Upper Frame
Low Structure
Crawler
Slide Plate
Roller Tracks
Idler Adjuster
Sprocket
Travel Motor
Slew Bearing
Lower Frame
General Precautions
Troubleshooting
Troubleshooting
Troubleshooting
Section 16 - Engine
Troubleshooting
Service Data
Tightening Torque
Governor
Turbocharger
- New Holland Crawler Excavator E265, E305 Tier 3 Workshop Manual_60413674
- New Holland LB90.B-LB115.B Engines F4GE0454C-F4GE0484G 604.13.612 Repair Manual
- New Holland W130 Workshop Manual
- New Holland Excavator E9SR 604.13.391 Repair Manual
- New Holland W190 Workshop Manual
- New Holland TVT 135_145_155_170_190_195 Series Service Manual 6035448106
- New Holland Crawler Dozer D350 84568077A Service Manual
- New Holland W190 (UK) Workshop Manual
- New Holland Skid Steers L175 C175 Workshop Manual
- New Holland W170 Workshop Manual
- New Holland E385C Hino Diesel Engine J08E-UN 47374920A Service Manual
- New Holland Hydraulic Hammers CB18S - CB27S - CB37S 603.67.221.03 Service Manual
- New Holland W130B Service Manual
- New Holland Loader Backhoe B110 B115 87643846 Repair Manual
- New Holland W190B Workshop Manual
