New Holland Crawler Excavator EH130 Parts Catalog 7-9241NA 2014
Brand: New Holland
Type of Machine: Crawler Excavator
Model: New Holland EH130 Crawler Excavator
Part Number: 7-9241NA
Publication Date: 2014
Number of Pages: 628 Pages
Filter & Capacities, Eh130
Filters & Capacities, Eh130
Engine Mounting
Engine Mounting Brackets
Engine Assy
Engine Control Assy
Accelerator Pedal Control Spacer
Air Cleaner Assy
Inner Element Air Filter
Muffler Assy
Radiator Mounting
Radiator Assy
Water Pump System
Thermostat And Housing
Water Bypass
Gear Housing
Manifold - Intake
Manifold - Exhaust
Oil Pump
Oil Filter
Oil Lines
Oil Pan And Gauge
Cylinder Head Cover
Crankshaft And Piston
Camshaft
Air Breather
Turbocharger
Turbocharger System
Gasket Kit
Element Kit
Engine Filters
Fuel Lines (Yy21p00002f1)
Fuel Lines (Yy21p00002f2)
Fuel Lines & Filter
Fuel Injection System
Water Separator
Injuction Pump & Miscellaneous Parts
Injection Pump Coupling
Feed Pump
Power Take Off Assy (Yx30p00002f1)
Travel Motor
Travel Motor Uper Section
Electrical Control Parts
Generator
Relay Assy
Harness Assy (Cab)
Harness Assy, Upperstructure
Harness Assy (Engine)
Horn Mounting
Battery Mounting
Lamp Assy (Yn80s00010f2)
Lamp Mounting
Light Assy (Yw80s00001f1)
Lamp Mounting - Boom
Flashers, Side
Switch (Instrument Panel)
Hydraulic Tank Assy (Yy33h00013f6)
Hydraulic Lines - Hydraulic Pump (Yy30h00002f1)
Hydraulic Lines - Main (Yy03h00023f2)
Hydraulic Lines - Return (Yy32h00003f1)
Hydraulic Lines - Lower (Yy02h00017f1)
Hydraulic Lines - Upper (Yy03h00030f1)
Hydraulic Lines - Remote Control, Pump (Yy06h00021f1)
Hydraulic Lines - Remote Control, Valve (Yy64h00046f1)
Hydraulic Lines - Remote Control, Valve (Yy68h00048f1)
Hydraulic Lines - Remote Control, Multi (Yy68h00029f1)
Hydraulic Lines - Boom 4.6m (15ft 1in)
Hydraulic Lines - Boom 4.6m (15ft 1 In) (Nibbler & Breaker)
Hydraulic Lines - Arm 2.45m (8ft)
Hydraulic Lines - Arm 2.45m (8ft) (Nibbler & Breaker)
Hydraulic Lines - Arm 2.95m (9ft 8in)
Hydraulic Lines - Arm 2.95m (9ft 8in) (Nibbler & Breaker)
Pump
Pump Assy
Pump - Gear
Pump - Gear - Dozer (Yv10v00006f1)
Case Assy, Gear
Pump - Regulator
Mounting - Swing Motor
Swing Motor Assy (Yy15v00004f1)
Swing Motor (Yx15v00004f1,F2,F3)
Swing Motor - Reduction
Hydraulics - Joint, Swivel Center (Yn55v00037f2)
Valve Mounting (Yx64h00002f1)
Valve Mounting (Yy64h0032f1)
Valve, Pressure Relief (Yn22v00002f1 - F7)
Valve, Selector (Yy30v00019f1)
Valve Assy - Pilot, Travel (Yx30v0004f1)
Valve Assy - Pilot (Yy30v00055f1,F2)
Valve Assy - Control (Yn30v00075f1,F2) (Option)
Valve Assy - Control (Yy30v00008f1,F2,F3)
Valve Assy - Control (Yy30v00044f1), Page 1 Of 3
Valve Assy - Control (Yy30v00044f1), Page 2 Of 3
Valve Assy - Control (Yy30v00044f1), Page 3 Of 3
Valve Assy, Swing (Yx30v00006f1,F2)
Valve, Bypass (Yy30v00045f1)
Valve Assy, Relief (2436r1119f1 - F6)
Valve Assy, Relief (Lp22v00001f1 - F2)
Valve Assy, Relief (Yt22v00006f1 - F6)
Valve Assy, Relief (Yx22v00002f1)
Valve Assy, Relief (Yy22v00007f1 - F2)
Valve Assy, Solenoid (Lc35v00004f1,F2)
Valve Assy, Solenoid (Yb35v00003f1)
Valve Assy, Solenoid (Yt35v00005f1)
Valve Assy, Solenoid (Yt35v00012f1)
Valve Assy, Solenoid (Yt35v00013f1)
Valve Assy, Solenoid (Yt35v00014f1)
Valve Assy, Solenoid (Yy35v00006f1)
Section Assy, Inlet (Yr20v00001f1)
Section Assy, Spool (Yt30v00027f1)
Valve Assy, Lock (Yx30v00009f1)
Cylinder Assy, Boom, Right Hand
Cylinder Assy, Boom, Left Hand
Cylinder Assy, Arm (Yy01v00003f1, F2)
Cylinder Assy, Bucket
Connectors
Turntable Bearing
Turntable (Yy52f00027f5)
Turntable - Access Covers
Counterweight
Counterweight (Guards)
Cover - Supports
Bracket Assy (Yy21c01149f1)
Mounting Bracket
Cover Assy
Cover Assy (Yy21c01114f3)
Cover Assy (Hood)
Plate, Floor (Yy03m00014f1)
Cab Mounting
Cab - Glass
Cab Assy
Cab - Window, Front
Cab Door
Controls - Operators Compartment
Control Box Assy (Right Hand)
Control Box Assy (Left Hand)
Controls - Operators Compartment (Lever Assy)
Lever Assy
Instrument Panel Assy
Instrument Cluster
Seat Assembly (Yt25m00026f1)
Seat Assembly (Yy25m00002f1)
Seat Belt
Fire Extinguisher
Air Conditioner
Air Conditioner Mounting
Air Conditioner Assy (Yv20m00003f3)
Air Conditioner Assy (Yt20m00009f1)
Air Dryer Assy
Air Conditioning Compressor
Air Conditioner (Filter Assy)
Air Conditioner Assy (Yt20m00004f1, F2)
Mirror Installation (Lc52c00002f2)
Mirror Installation (Yt52c00008f5)
Mirror Installation (Yy52c00003f1)
Sunvisor
Boom Assy 4.6m (15ft 1in)
Arm Assy, Long 2.95m (9ft 8 In)
Arm Assy 2.45m (8ft)
Bucket- Mounting
Decals - Frame (Position)
Decals - Frame
Decals - Cab
Decals - Cab (Lift Capacities)
Decals (Attachment)
Decals (Pattern Change Card), (Yn20t01476p1)
Tools
Undercarriage
Undercarriage - Block (Cover Assy)
Track - Idler
Track - Idler Assy
Track - Adjuster
Track - Roller Assy
Track - Roller, Upper
Track - Shoe (Yy60d00005f1)
Track - Shoe (Yy60d00007f1-F2)
Steps - Mounting
