New Holland Crawler Excavator E305C EVO Operators Manual 48016684 2016
Brand: New Holland
Type of Machine: Crawler Excavator
Model: New Holland E305C EVO Crawler Excavator
Engine: Isuzu GH-6HK1X Engine
Part Number: 48016684
Publication Date: 2016
Number of Pages: 256 Pages
1 General Information
Note To The Owner
Intended Use
Electro-Magnetic Compatibility (Emc)
Product Identification
Operator's Manual Storage On The Machine
Machine Orientation
Machine Components
2 Safety Information
Safety Rules And Signal Word Definitions
Safety Rules
Ecology And The Environment
Hand Signals
Safety Signs
3 Controls And Instruments
Access To Operator's Platform
Frame - Access/Exit
Position Of The Operator’s Compartment Controls And Accessories
Operator's Seat
Mechanical Suspension Seat
Air Suspension Seat (Option)
Forward Controls
Hand Control Levers And Pedals
Windshield
Front Lower Window
Front Right-Hand Console
System Display And Function Control Panel
Monitor Switches
Menu Screen Display
Clock Adjustment
Left-Hand Side Controls
Left-Hand Control Arm
Gate Lock Lever And Safety Bar
Heating, Ventilation Or Air-Conditioning Control
Cab Internal Lighting
Emergency Exit Hammer
Sliding Windows On Door
Right-Hand Side Controls
Right-Hand Control Arm
Cab Radio
Right-Hand Console
Cup Holder
Rearward Controls
Fuse Box
Magazine Rack
Refrigerated/Heated Compartment
Storage Compartment
Coat Hanger Hook
Overhead Controls
Roof Curtain
Roof Hatch
Sun Shield (Optional)
Exterior Controls
Rear View Mirrors
Rear View Camera (Option)
Front Storage Box
Side Doors
Battery Master Switch
Engine Hood
Lower Panels
Windshield Washer Reservoir
Safety Valves (Optional)
Optional Tool Supply Valves (Optional)
Fuel Tank Filler Pump (If Equipped)
4 Operating Instructions
Commissioning The Unit
Cab - Operating
Break-In Period
Starting The Unit
Anti-Theft Protection
Starting The Engine
Bringing The Machine Up To Operating Temperature
Engine Operation
Operating The Machine In Hot Or Cold Weather
Machine Operation
Stopping The Unit
Stopping The Engine
Moving The Unit
Machine Travel
Handling The Machine
Load Handling
Lowering The Attachment In The Event Of A Failure
Auxiliary Hydraulic Circuits
Parking The Unit
Parking The Machine
5 Transport Operations
Shipping Transport
Loading The Machine Onto A Transport Trailer
Tie Downs For Shipping
Unloading The Machine From A Transport Trailer
Recovery Transport
Towing
6 Maintenance
Basic Instructions
Fluids And Lubricants
Engine Oil Recommended Operating Temperature Range
Grease Points
Levels
Fuel System
Hydraulic Circuit
Air Filter
Swing Reduction Gear
Travel Reduction Gears
Tracks
Radiator And Coolers
Fan And Alternator Drive Belt
Adjustment Of Engine Valve Rocker Clearances
Fuel Tank Filter
Protecting The Electrical/Electronic Systems During Charging Or Welding
Machine Inspection And Cleaning
Checking The Machine Settings
Plastic And Resin Parts
Checking The Cylinders For Leaks
Tooth Tip Wear Limits On The Backhoe Bucket
Replacing A Tooth On A Backhoe Bucket (Side Pin Type)
Replacing A Backhoe Bucket
Air Conditioning
Gas Spring Inspection
Torque Specifications
Fuses
Batteries
Starter Motor
Bulb Replacement
Maintenance Planning
Maintenance Chart
Storage
Preparing For Storage
Periodic Checks
Starting Up After Storage
7 Troubleshooting
Fault Code Resolution
Engine Troubleshooting
8 Specifications
Machine Specifications
Dimensions
Weights
9 Accessories
Direct Fit Buckets
Brand: New Holland
Note To The Owner
Intended Use
Machine Orientation
Machine Components
Safety Rules
Hand Signals
Safety Signs
Frame - Access/Exit
Operator's Seat
Forward Controls
Windshield
Front Lower Window
Monitor Switches
Menu Screen Display
Clock Adjustment
Cab Radio
Right-Hand Console
Cup Holder
Rearward Controls
Fuse Box
Magazine Rack
Storage Compartment
Coat Hanger Hook
Overhead Controls
Roof Curtain
Roof Hatch
Exterior Controls
Rear View Mirrors
Front Storage Box
Side Doors
Engine Hood
Lower Panels
Cab - Operating
Break-In Period
Starting The Unit
Starting The Engine
Engine Operation
Machine Operation
Stopping The Unit
Stopping The Engine
Moving The Unit
Machine Travel
Load Handling
Parking The Unit
Parking The Machine
Shipping Transport
Recovery Transport
Towing
6 Maintenance
Basic Instructions
Grease Points
Levels
Fuel System
Hydraulic Circuit
Air Filter
Tracks
Fuel Tank Filter
Air Conditioning
Fuses
Batteries
Starter Motor
Bulb Replacement
Maintenance Chart
Storage
Periodic Checks
7 Troubleshooting
8 Specifications
Dimensions
Weights
9 Accessories
Direct Fit Buckets
- New Holland Crawler Excavator E265, E305 Tier 3 Workshop Manual_60413674
- New Holland LB90.B-LB115.B Engines F4GE0454C-F4GE0484G 604.13.612 Repair Manual
- New Holland W130 Workshop Manual
- New Holland Excavator E9SR 604.13.391 Repair Manual
- New Holland W190 Workshop Manual
- New Holland TVT 135_145_155_170_190_195 Series Service Manual 6035448106
- New Holland Crawler Dozer D350 84568077A Service Manual
- New Holland W190 (UK) Workshop Manual
- New Holland Skid Steers L175 C175 Workshop Manual
- New Holland W170 Workshop Manual
- New Holland E385C Hino Diesel Engine J08E-UN 47374920A Service Manual
- New Holland Hydraulic Hammers CB18S - CB27S - CB37S 603.67.221.03 Service Manual
- New Holland W130B Service Manual
- New Holland Loader Backhoe B110 B115 87643846 Repair Manual
- New Holland W190B Workshop Manual
