New Holland Crawler Excavator E175C EVO Operators Manual 90420888 2020
Brand: New Holland
Type of Machine: Crawler Excavator
Model: New Holland E175C EVO Crawler Excavator
Part Number: 90420888
Publication Date: 2020
Number of Pages: 370 Pages
1 General Information
Note To The Owner
Read The Operator's Manual
Electromagnetic Interferance
Operator's Manual Storage On The Machine
Identification Identification Of The Sides Of The Machine
Machine Components
Identification Plates
Vibration Levels
Noise Level
Ecology And Environment
2 Safety Information
Safety Rules
Safety Rules (Signal Word Definitions)
Safety Rules (Personnel)
Operating Precautions (Starting The Machine)
Operating Precautions (Machine Operation)
Safty Precautions (Weld Works)
Protecting The Electronic And Electrical Systems During Welding Or Battery Charging
Safty Precautions – Fuel Handling
Fire And Explosion Prevention
Safty Precautions (Utility Lines)
Safty Precautions (Movement Of Loads)
Safty Precautions (Machine Transport)
Operating Precautions (Stopping The Machine)
Safty Precautions – (Machine Service)
Roll Over Protection Structure (Rops)
Hand Signals
Safety Decals
3 Controls And Instruments
Access To Operator's Platform
Access To Operator’s Platform
Controls And Accessories
Operator's Seat
Mechanical Suspension Seat
Air Suspension Seat (Option)
Forward Controls
Hand Control Levers And Pedals
Windshield
Front Lower Window
Front Right-Hand Console
System Monitor / Function Control Panel
Monitor Switches
Menu Screen Display
Clock Adjustment
Left-Hand Side Controls
Left-Hand Side Controls – (Machines Equipped With Auxiliary Low-Flow Hydraulic Circuit) 3-41
Control Panel (Heating, Ventilation And Air Conditioning)
Heating, Ventilation Or Air-Conditioning Control
Function Cancellation Lever And Safety Bar
Cab Internal Lighting
Emergency Exit Hammer
Sliding Windows On Door
Right-Hand Side Controls
Right Hand Side Controls
Right Hand Side Controls – (Machines Equipped With Auxiliary High-Flow Hydraulic Circuit)
Radio
Right-Hand Console
Coat Hanger Hook
Cup Holder
Rearward Controls
Fuse Box
Magazine Rack
Refrigerated/Heated Compartment
Storage Compartment
Overhead Controls
Roof Curtain
Sunroof
Sunshield (Optional)
Exterior Controls
Fuel Reservoir
Rearview Mirrors
Rear View Camera (Optional)
Storage Compartment
Side Doors
Electrical (Master Switch)
Engine Hood
Lower Panels
Windshield Washer Resevoir
Safety Valves (Optional)
Optional Tool Supply Valves (Optional)
Fuel Reservoir Filling Pump (If Equipped)
4 Operating Instructions
Commissioning The Unit
Before Starting The Engine
Break-In Period
Starting The Unit
Anti-Theft Protection
Starting The Engine
Bringing The Machine Up To Operating Temperature
Engine Operation
Machine Operation – (Operating Instructions)
Machine Operation – (Hot Or Cold Weather)
Stopping The Unit
Stopping The Engine
Moving The Unit
Machine Travel
Handling The Machine
Load Handling
Machine Operation
Lowering The Attachment In The Event Of A Failure
Auxiliary Hydraulic Circuits
Parking The Unit
Parking The Machine
5 Transport Operations
Shipping Transport
Transporting The Machine
Tie Downs For Shipping
Unloading The Machine From A Transport Trailer
Recovery Transport
Towing
6 Maintenance
Maintenance And Adjustments
Engine Lubrication System
Engine Coolant System
Organic Acid Technology (Oat) Coolant
Fuel System
Engine Air Filter System
Air-Conditioning System
Plastic And Resin Parts
Maintenance Planning
Maintenance Chart
As Required
Pre-Fuel Filter (Draining)
Fuel System (Bleed Air)
Fuel Reservoir Filter (Cleaning)
Engine Air Pre Filter – (If Equipped) (Checking And Cleaning)
Fan And Alternator Drive Belt (Replacement)
Air-Conditioning Compressor Drive Belt (How To Check The Tension)
Tracks (Cleaning)
Tracks (Tension Check And Adjustment)
Cylinders (Checking)
Bucket Teeth (Checking)
Bucket Teeth – Models With Side Pin (Replacement)
Bucket (Replacement)
Gas Spring (Checking)
Every 10 Hours Or Daily
Engine Oil (Checking The Level)
Engine Coolant (Checking The Level)
Hydraulic Fluid (Checking The Level)
Fuel Reservoir (Water And Sediment Drainage)
Fan And Alternator Drive Belt (Checking)
Radiator And Coolers (Checking)
Initial 50 Hours
Tracks – Shoes (Checks And Adjustment Of Torque In Initial Period)
Special Torques (Check In Initial Period)
Every 50 Hours Or Weekly
Cab Air Filter (Cleaning)
Lubrication Points
First 250 Hours
Pilot Filter – Hydraulic Fluid (Replacement In Initial Period)
Hydraulic Fluid Return Filter (Replacement In Initial Period)
Swing Reduction Oil (Change In Initial Period)
Travel Reduction Oil (Change In Initial Period)
Every 250 Hours
Pre-Fuel Filter (Replacement)
Fuel Transfer Pump (Checking)
Engine Air Filter (Verification And Cleaning)
Hydraulics Reservoir (Water And Sediment Drainage)
Swing Reduction Oil (Checking The Level)
Travel Reduction Oil (Checking The Level)
Tracks – Shoes (Check And Adjust The Torque)
Tracks – Rollers And Tensioner Wheels (Check)
Fan And Alternator Drive Belt (How To Check The Tension)
Battery (Charge Checks)
Battery Electrolyte (Checking The Level)
Special Torques (Checking)
Every 500 Hours
Fuel Feed Pump Filter (Cleaning)
Engine Oil And Filter (Replacement)
Air-Conditioning Refrigerant (Checking)
Radiator And Coolers (Cleaning)
Lubrication Points
Every 1000 Hours
Engine Air Filter (Replacement)
Hydraulic Breather Filter (Replacement Of The Element)
Swing Reduction Oil (Changing)
Travel Reduction Oil (Changing)
Engine Valves (Checking Clearance And Adjustment)
Alternator (Checking)
Starter Motor (Checking)
Lubrication Points
Every 2000 Hours
Pilot Filter – Hydraulic Fluid (Check)
Hydraulic Fluid Return Filter (Replacement)
Cab Air Filters (Replacement)
Lubrication Points
Every 4000 Hours
Engine Coolant (Changing)
Every 5000 Hours
Hydraulic Suction Filter (Replacement Or Cleaning)
Hydraulic Fluid (Changing)
Hydraulic Components (Bleed)
Electrical
Fuses (Replacement)
Starting With Auxiliary Batteries
Battery (Replacement)
Bulbs (Replacement)
Storage
Preparation For Storage
Periodic Checks
Removal From Storage
7 Specifications
Lubrication, Filters And Fluids
Specifications (Motor)
Specifications (Hydraulic System)
Specifications (Bucket)
General Specification
Weights
Dimensions
Digging Data
Torque Specifications
8 Accessories
Direct Fit Buckets
Direct Fit Buckets
Brand: New Holland
Note To The Owner
Machine Components
Vibration Levels
Noise Level
Safety Rules
Hand Signals
Safety Decals
Operator's Seat
Forward Controls
Windshield
Front Lower Window
Monitor Switches
Menu Screen Display
Clock Adjustment
Radio
Right-Hand Console
Coat Hanger Hook
Cup Holder
Rearward Controls
Fuse Box
Magazine Rack
Storage Compartment
Overhead Controls
Roof Curtain
Sunroof
Exterior Controls
Fuel Reservoir
Rearview Mirrors
Storage Compartment
Side Doors
Engine Hood
Lower Panels
Break-In Period
Starting The Unit
Starting The Engine
Engine Operation
Stopping The Unit
Stopping The Engine
Moving The Unit
Machine Travel
Load Handling
Machine Operation
Parking The Unit
Parking The Machine
Shipping Transport
Recovery Transport
Towing
6 Maintenance
Fuel System
Maintenance Chart
As Required
Tracks (Cleaning)
Initial 50 Hours
Lubrication Points
First 250 Hours
Every 250 Hours
Every 500 Hours
Lubrication Points
Every 1000 Hours
Lubrication Points
Every 2000 Hours
Lubrication Points
Every 4000 Hours
Every 5000 Hours
Electrical
Fuses (Replacement)
Bulbs (Replacement)
Storage
Periodic Checks
7 Specifications
Weights
Dimensions
Digging Data
8 Accessories
Direct Fit Buckets
Direct Fit Buckets
- New Holland Crawler Excavator E265, E305 Tier 3 Workshop Manual_60413674
- New Holland LB90.B-LB115.B Engines F4GE0454C-F4GE0484G 604.13.612 Repair Manual
- New Holland W130 Workshop Manual
- New Holland Excavator E9SR 604.13.391 Repair Manual
- New Holland W190 Workshop Manual
- New Holland TVT 135_145_155_170_190_195 Series Service Manual 6035448106
- New Holland Crawler Dozer D350 84568077A Service Manual
- New Holland W190 (UK) Workshop Manual
- New Holland Skid Steers L175 C175 Workshop Manual
- New Holland W170 Workshop Manual
- New Holland E385C Hino Diesel Engine J08E-UN 47374920A Service Manual
- New Holland Hydraulic Hammers CB18S - CB27S - CB37S 603.67.221.03 Service Manual
- New Holland W130B Service Manual
- New Holland Loader Backhoe B110 B115 87643846 Repair Manual
- New Holland W190B Workshop Manual
