653
1,893,908
New Holland Crawler Excavator E140CSR Operators Manual 47425573 2012
Brand: New Holland
Type of Machine: Crawler Excavator
Model: New Holland E140CSR Crawler Excavator
Part Number: 47425573
Publication Date: 2012
Number of Pages: 352 Pages
1 General Information
Note To The Owner
Product Identification
Vibration To The Operator
Noise Level
Cab Protection (Rops And Fops)
2 Safety Information
General Safety Information
Warning Labels And Decals
Pre-Start Safety
3 Controls/Instruments
Access To Operator's Platform
Emergency Escape From Cab
Operator's Seat
Operator Seat
Seat Belt
Forward Controls
Console Front Console - Localisation Overview
Instrument Cluster
Offset Boom Controls
Right-Hand Side Controls
Radio
Air Conditioner
Rearward Controls
Console - Operating
4 Operating Instructions
Commissioning The Unit
Machine Operation
Checking Before Starting Engine
Fuel Pump
Adjusting Operator Seat
Adjusting Mirror
Checking Function Of Gauge Cluster
Checking Work Light
Starting The Unit
Starting Engine
Inspection After Starting Engine
Machine Warming-Up
Selection Of Work Mode And Switching Of The Attachment Mode
Stopping The Unit
Stopping Machine Engine
Parking The Unit
Parking The Machine
5 Transport Operations
Road Transport
Machine Preparation
Loading/Unloading The Machine
Preparing For Road Transport
Securing The Machine
Shipping Transport
Lifting Machine
Recovery Transport
Installation And Removal Of Mirror For Safety
6 Working Operations
Controls Decal
Practices To Improve Efficiency
Hand Signals
Lowering Attachment When Sudden Engine Failure Occurs
Machine Operation In Adverse Weather Conditions
Towing The Machine
7 Maintenance
General Safety And Precautions
Exhaust Gas Post-Cleaning Device
Maintenance Parts
Torque Values For Specified
Torque Specifications For Bolts And Nuts
Torque Specifications For Joints And Hydraulic Hoses
Maintenance Chart
Pre-Start (Every 8 Hours)
General Check
Attachment Lubrication
Every 50 Hours (Weekly)
Batteries
Fuel Tank Drain
Track Tension
Every 120 Hours
Swing Motor Reduction Oil
Travel Reduction Unit Oil
Every 250 Hours
Air Cleaner Maintenance
Checking The Radiator Hoses
Radiator And Oil Cooler Debris Screen
Fan, Alternator, A/C Belt Wear And Tension
Checking For Intake Rubber Hose
Air-Conditioner Filters Service
Cleaning Or Replacement Of Radiator Cap
Every 500 Hours
Replacing Engine Oil
Refilling Engine Oil
Replacing The Oil Filter
Replacing The Pre-Filter
Replacing The Fuel Filter
Bleeding The Fuel System
Cleaning Fuel Tank Cap And Strainer
Greasing The Slewing Ring
Checking Slewing Ring Fitting Bolts For Loosening
Lubricating Push Rod Of Control Lever With Grease
Checking The Air-Conditioner Refrigerant
Every 1000 Hours (12 Months)
Checking Engine Mounting Bracket For Tightening
Replacing Return Filters
Replacement Of Air Breather Element
Checking Voltage
Every 1500 Hours
Ccv Filter (Fuel Filter) Element
Every 2000 Hours
Changing Engine Coolant
Cleaning Suction Strainer
Cleaning Of Pilot Line Filter
Changing Oil In Swing Reduction Unit
Checking Grease In Slewing Ring Grease Bath
Swing Reduction Lubrication
Change Oil In Travel Motor Reduction Units
Every 5000 Hours
Change Hydraulic Oil
When Required
Checking And Replacing Wiper Blade
Wind Washer Fluid Reservoir
Replacement Of Bucket
Check For Abrasion/Damages On Tooth Point And Side Cutter
Reversing Backhoe Bucket
Adjusting Bucket Mount Gap
Fuses And Relay Box
Fusible Link (For Starter)
Fluids And Lubricants Fluid And Lubricants
Storage
Machine Storage
Care During Storage
Storage Up After
8 Specifications
General Specifications
Shoe Types
Working Ranges
Bucket And Arm Combinations
9 Accessories
Operation Of Hydraulic Breaker And Nibbler (For 1 Pedal Type)
Proportional Hand Control (Extra, Nibbler And Breaker)
Objects Handling
Operation Of Dozer Blade
Use Of Bio-Degradable Oils
10 Forms And Declarations
Ec Declaration Of Conformity
