New Holland Backhoe Loader LB90.B to LB115.B Workshop Manual 60413547
Brand: New Holland
Type of Manual: Workshop Manual, Hydraulic And Electrical Schematic
Model: New Holland LB90.B ; LB95.B ; LB110.B ; LB115.B Backhoe Loader
Serial Number:
Engine:
F4GE0454C*D660 Engine - LB90.B ; LB95.B
F4GE0484C*D660 Engine - LB110.B
F4GE0484C*D655 Engine - LB115.B
Part Number: 60413547
Number of Pages: 1083 Pages
Section 00 - Safety Precautions
Section 01 - Maintenance
Section 02 - Technical Specifications
1. Models.
2. Identification Of Main Components.
3. Technical Specifications.
4. Loader Attachment Dimensions And Performance
5. Backhoe Attachment Dimensions And Performance
6. Lifting Capacities
7. Loader Bucket With Forks Dimensions And Performance.
8. Fluid And Lubricant Capacities And Specifications
Section 17 - Torque Converters
1. Powershuttle Torque Converter
1.1 Description And Operation
1.2 Technical Specifications
1.3 Overhaul
1.4 Inspection.
1.5 Disassembly And Assembly.
1.6 Stall Test
1.7 Fault Finding
2. Powershift Torque Converter
2.1 Description And Operation
2.2 Technical Specifications
2.3 Overhaul
2.4 Inspection.
2.5 Disassembly And Assembly.
2.6 Stall Test
2.7 Fault Finding
Section 21 - Transmission
1. Powershuttle Transmission “Turner Model Com-T4-2025”
1.1 Technical Specifications
1.2 Tightening Torques
1.3 Transmission Controls.
1.4 Lubrication.
1.5 Transmission Oil Flow And Supply
1.6 Transmission Hydraulic Valves And Pressure Test Points.
1.7 Transmission Power Flow
1.8 Transmission 2wd Components
1.9 Transmission 4wd Components
1.10 Transmission Removal.
1.11 Disassembly And Assembly.
1.12 Fault Finding.
1.13 Special Tools
2. Powershift Transmission “Dana T16000”
2.1 Technical Specifications.
2.2 Transmission Controls
2.3 Lubrication
2.4 Pressure Specifications And Check Points.
2.5 Transmission Cooler.
2.6 Transmission Hydraulic Diagram
2.7 Operation.
2.8 Power Flows.
2.9 Gear And Clutch Lay Out
2.10 Transmission Removal And Installation.
2.11 Transmission Components
2.12 Disassembly And Assembly
2.13 Special Tools
2.14 Fault Finding.
2.15 Fault Finding.
Section 25 - Front Axles
1. Front Axle 2wd “Carraro”
1.1 Technical Specifications.
1.2 Disassembly And Assembly
1.3 Fault Finding.
2. Front Axle 4wd “Carraro”
2.2 Disassembly And Assembly
2.3 Fault Finding.
3. Front Axle 4ws “Carraro”
3.1 Technical Specifications.
3.2 Disassembly And Assembly
3.3 Fault Finding.
4. Special Tools.
Section 27 - Rear Axle
1. Rear Axle 2ws
1.2 Technical Specifications.
1.3 Disassembly And Assembly
1.4 Fault Finding.
2. Rear Axle 4ws “Carraro”.
2.3 Fault Finding.
3. Special Tools.
Section 33 - Brakes System
1. Technical Specifications
2. Hand Brake
2.1 Hand Brake Adjustment
3. Brake Cylinders
4. Oil Brake Tank.
5. Bleeding Procedure
Section 35 - Hydraulic System
1. Hydraulic Diagrams
1.1 Hydraulic Diagram - 2ws Centre Pivot Mechanical Models.
1.2 Hydraulic Diagram - 2ws Sideshift Mechanical Models.
1.3 Hydraulic Diagram - 2ws Centre Pivot Pilot Models
1.4 Hydraulic Diagram - 2ws Sideshift Pilot Models
1.5 Hydraulic Diagram - 4ws Centre Pivot Mechanical Models.
1.6 Hydraulic Diagram - 4ws Sideshift Mechanical Models.
1.7 Hydraulic Diagram - 4ws Centre Pivot Pilot Models
1.8 Hydraulic Diagram - 4ws Sideshift Pilot Model
2. Hydraulic Pump
2.3 Load Sensing Valve
2.4 Removal
2.5 Components
2.6 Disassembly And Assembly.
3. Control Valves
3.1 Control Valves “Husco” (Lb110.B Centre Pivot Mechanical Models)
3.2 Control Valves “Rexroth” (Mechanical Models)
3.3 Control Valves “Rexroth” (Pilot Models)
4. Hydraulic Swing System
4.1 Description And Operation
4.2 Hydraulic Oil Flow
4.3 Precision Swing Control
5. Hydraulic Cylinders
5.1 Loader Cylinder.
5.2 Loader Bucket Cylinder
5.3 4x1 Bucket Cylinder
5.4 Backhoe Boom Cylinder
5.5 Backhoe Dipper Cylinder
5.6 Backhoe Bucket Cylinder.
5.7 Short And Long Telescopic Cylinder
5.8 Stabilizer Cylinder (Centre Pivot Models).
5.9 Stabilizer Cylinder (Sideshift Models).
5.10 Swing Cylinder
5.11 Backhoe Sideshift Locking Cylinder (Sideshift).
5.12 Special Tools.
6. Control Levers
6.1 Technical Specifications
6.2 Description And Operation
6.3 Disassembly And Assembly.
6.4 Control Lever Valve
7. Fault Finding And Flow Testing
7.1 Preliminary Checks.
7.2 Fault Finding (With “Husco” Control Valves) - Lb110.B Centre Pivot
7.3 Pressure Testing (With “Husco” Control Valves) - Lb110.B Centre Pivot.
7.4 Fault Finding (With “Rexroth” Control Valves)
7.5 Pressure Testing (With “Rexroth” Control Valves).
Section 39 - Chassis
1. Description And Operation
2. Removal And Installation Components
2.1 Components Within The Chassis
2.2 Components Below The Chassis
2.3 Components Attached Outside The Chassis
2.4 Components Attached Above The Chassis
2.5 Tightening Torques
Section 41 - Steering System
1. Steering System 2ws
2. Steering System 4ws
3. Power Steering
3.2 Components
3.3 Disassembly And Assembly
3.4 Special Tools
3.5 Fault Finding.
Section 50 - Cab Heating And Air Conditioning
2. Cab Heating.
2.1 Description And Operation.
3. Air Conditioning
3.1 Principals Of Air Conditioning
3.2 Safety Precautions
3.3 Description And Operation.
3.4 Fault Finding And Testing
3.5 Flushing The System
3.6 Evacuating The System.
3.7 Charging The System.
3.8 Components Overhaul
3.9 Compressor
3.10 Special Tools
Section 55 - Electrical System
1. Generalities
1.1 Temporary Wiring Harness Repair
1.2 Fault Finding.
2. Electrical Diagrams.
2.1 Electrical Diagrams - Powershuttle Cab
2.2 Electrical Diagrams - Powershift Cab
2.3 Electrical Diagrams - 4ws.
2.4 Electrical Diagrams - Rops
3. Controls And Instruments
3.1 Front Instrument Panel
3.2 Side Instrument Panel
3.3 Diagnostic Signaling
3.4 Calibration Of Speedometer
3.5 Immobiliser Circuit
4. Starting System
4.2 Fault Finding
4.3 Starter Motor
5. Alternator
5.1 Technical Specifications
5.2 Description And Operation
5.3 Components
5.4 Removal
5.5 Preliminary Check And Tests
5.6 Fault Finding
6. Battery
6.3 Battery Replacement
6.4 Maintenance.
6.5 Tests
6.6 Connecting A Booster Battery
6.7 Battery Master Switch (Optional Lb90.B - Lb95.B)
7. Component Testing
7.1 General Introduction
7.2 Component Testing.
7.3 Ground Points.
Section 82 - Loader
1. Loader Attachment Controls.
2. Loader Bucket Self Leveling
3. Loader Attachment Safety Strut
4. Loader Bucket Removal
5. Loader Removal (2ws)
6. Loader Removal (4ws)
Section 84 - Backhoe
1. Description And Operation.
2. Backhoe Attachment Mechanical Control Version
3. Backhoe Attachment Pilot Control Version
4. Removal And Installation
5. Telescopic Dipper Revision.
Brand: New Holland
Serial Number:
Engine:
1. Models.
1.3 Overhaul
1.4 Inspection.
1.6 Stall Test
1.7 Fault Finding
2.3 Overhaul
2.4 Inspection.
2.6 Stall Test
2.7 Fault Finding
1.4 Lubrication.
1.12 Fault Finding.
1.13 Special Tools
2.3 Lubrication
2.7 Operation.
2.8 Power Flows.
2.13 Special Tools
2.14 Fault Finding.
2.15 Fault Finding.
1.3 Fault Finding.
2.3 Fault Finding.
3.3 Fault Finding.
4. Special Tools.
1. Rear Axle 2ws
1.4 Fault Finding.
2.3 Fault Finding.
3. Special Tools.
2. Hand Brake
3. Brake Cylinders
4. Oil Brake Tank.
2. Hydraulic Pump
2.4 Removal
2.5 Components
3. Control Valves
5.10 Swing Cylinder
5.12 Special Tools.
6. Control Levers
3. Power Steering
3.2 Components
3.4 Special Tools
3.5 Fault Finding.
2. Cab Heating.
3. Air Conditioning
3.9 Compressor
3.10 Special Tools
1. Generalities
1.2 Fault Finding.
4. Starting System
4.2 Fault Finding
4.3 Starter Motor
5. Alternator
5.3 Components
5.4 Removal
5.6 Fault Finding
6. Battery
6.4 Maintenance.
6.5 Tests
7.3 Ground Points.
Section 82 - Loader
- New Holland Crawler Excavator E265, E305 Tier 3 Workshop Manual_60413674
- New Holland LB90.B-LB115.B Engines F4GE0454C-F4GE0484G 604.13.612 Repair Manual
- New Holland W130 Workshop Manual
- New Holland Excavator E9SR 604.13.391 Repair Manual
- New Holland W190 Workshop Manual
- New Holland TVT 135_145_155_170_190_195 Series Service Manual 6035448106
- New Holland Crawler Dozer D350 84568077A Service Manual
- New Holland W190 (UK) Workshop Manual
- New Holland Skid Steers L175 C175 Workshop Manual
- New Holland W170 Workshop Manual
- New Holland E385C Hino Diesel Engine J08E-UN 47374920A Service Manual
- New Holland Hydraulic Hammers CB18S - CB27S - CB37S 603.67.221.03 Service Manual
- New Holland W130B Service Manual
- New Holland Loader Backhoe B110 B115 87643846 Repair Manual
- New Holland W190B Workshop Manual
