New Holland Backhoe Loader B95C B95CLR Tier 4A Parts Manual 675445702 2014
Brand: New Holland
Model: New Holland B95C Tier 4A ; B95CLR Tier 4A Backhoe Loader
Part Number: 675445702
Publication Date: 2014
Number of Pages: 2249 Pages
Pictorial Index - Main Sections
Pictorial Index - Engine
Pictorial Index - Torque Converter
Pictorial Index - Transmission, Powershuttle
Pictorial Index - Transmission, Powershift
Pictorial Index - 4wd Lines
Pictorial Index - 2wd Lines
Pictorial Index - Front Axle - 4wd
Pictorial Index - Rear Axle - 2ws
Pictorial Index - Brakes & Controls
Pictorial Index - Hydraulic Systems
Pictorial Index - Hydraulic Systems - Center Pivot
Pictorial Index - Hydraulic Systems, Hydraulic Cylinder
Pictorial Index - Towing Hook And Ballasting
Pictorial Index - Frames, Center Pivot
Pictorial Index - Steering - 2ws
Pictorial Index - Axle And Wheels - 2ws
Pictorial Index - Axle - 2wd
Pictorial Index - Cab Climate Control
Pictorial Index - Electrical Systems
Pictorial Index - Front Loader
Pictorial Index - Backhoe, Center Pivot
Pictorial Index - Accessories
Pictorial Index - Cab, Guards, Coverings And Decals
Pictorial Index - Platform, Cab, Bodywork And Decals
Dia Kit List (Onhold)
Dia Kit
Initial Stocking List (List A)
Initial Stocking List (List B)
(On Hold) Filters & Capacities
Maintenance Parts - Filters
Engine Assy
Engine, Support
Air Cleaner And Lines - C7259
Air Cleaner And Lines - D7259 - End S/N Nfhh02382
Air Cleaner And Lines - Begin S/N Nfhh02383
Fuel Pipes
Electronic Throttle Pedal And Knob
Exhaust Muffler
Muffler
Exhaust Tube
Var - 742014 - Coolant Radiator, Hydraulic Fluid - Cab - C7325
Var - 742014 - Radiator Coolant Tubes - Cab - 2ws - D7325
Var - 742014 - Radiator - Cab - 2ws - D7325
Var - 742014 - Expansion Tank, Hose - Cab - 2ws - D7325
Var - 742014 - Radiator Frame And Support - Cab - 2ws - D7325
Var - 742014 - Engine Oil, Cooler - Cab - 2ws - D7325
Var - 742014 - Expansion Tank - Cab - 2ws - D7325
Var - 742014 - Air Conditioning, Cooler - Cab - 2ws - D7325
Var - 742014 - Air Conditioning, Condenser - Cab - 2ws - D7325
Var - 742014 - Fuel Cooler - Cab - 2ws - D7325
Var - 742013 - Coolant Radiator, Hydraulic Fluid - Cab - C7325
Var - 742013 - Radiator Coolant Tubes - Cab - 2ws - D7325
Var - 742013 - Radiator - Cab - 2ws - D7325
Var - 742013 - Expansion Tank, Hose - Cab - 2ws - D7325
Var - 742013 - Radiator Frame And Support - Cab - 2ws - D7325
Var - 742013 - Engine Oil, Cooler - Cab - 2ws - D7325
Var - 742013 - Expansion Tank - Cab - 2ws - D7325
Var - 742013 - Aftercooler - Cab - 2ws - D7325
Var - 742013 - Fuel Cooler - Cab - 2ws - D7325
Cooler, Hose
Fan With Viscous Joint - Cab
Torque Converter - Powershuttle - C7284
Torque Converter - Powershift - C7284
Torque Converter - Powershift - D7284
Torque Converter - Powershuttle - D7284
Pictorial Index - Transmission - Powershuttle
Pictorial Index - Transmission - Powershift
Transmission Oil Cooling Pipes - Powershuttle
Transmission Oil Dipstick - Powershuttle
Transmission Oil Filter - Powershuttle
Transmission Oil Cooling Pipes - Powershift
Transmission Oil Dipstick - Powershift
Transmission Oil Filter - Powershift
Transmission - Powershuttle - 4wd - Na - C7321
Transmission - Powershuttle - 4wd - Na - D7321
Transmission - 2wd Powershuttle - C7321
Transmission - 2wd Powershuttle - D7321
Transmission Housing - 2wd Powershuttle
Transmission Housing - 4wd Powershuttle
Transmission - 2ws Powershift - Na - C7321
Transmission - 2ws Powershift - Na - D7321
Transmission Housing - Powershift
Transmission Housing - 2ws Powershift
Transmission Control Hand Lever - Powershuttle
Transmission Control Valve - Powershuttle
Transmission Control Valve Solenoids - Powershuttle
Transmission Control Valve Solenoids - 4wd Powershuttle
Transmission Control Valve Remote Control - Powershift
Transmission Control Valve, Remote Control, Powershift
Transmission Gears, Driven Shaft And Bearings - 2wd Powershuttle
Transmission Gears, Driven Shaft And Bearings - 4wd Powershuttle Na
Transmission Gears, Driven Shaft And Bearings - Powershuttle Na
Gears, Transmission Drive Shaft And Bearings - Powershuttle
Gearbox Coupling - Powershuttle - Na
Primary Shaft - Powershuttle
Transmission Pump - Powershuttle
Transmission Input Shaft - 2ws Powershift
Pto Transmission Shaft - 2ws Powershift
Reverse Shaft Primary Shaft - Powershift
Transmission Shaft - Powershift-2ws
Transmission - Output Shaft, Dual Speed - Powershift 2ws
Transmission Pump - Powershift
Transmission Shaft - 4wd
Transmission Shaft - 2wd
Axles - Front Axle Installation - 4wd
Var - 742030 - Axles - Front Axle Housing - 4wd - C7349
Var - 742030 - Axles - Front Axle Housing - 4wd - D7349
Var - 742031 - Axles - Front Axle Housing - 4wd
Var - 742402 - Axles - Front Axle Housing - 4wd - C7349
Var - 742402 - Axles - Front Axle Housing - 4wd - D7349
Var - 742403 - Axles - Front Axle Housing - 4wd - C7349
Var - 742403 - Axles - Front Axle Housing - 4wd - D7349
Var - 742030, 742031, 742402, 742403 - Axles - Group Differential - 4wd
Var - 742030 - Axles - Bevel Gear - 4wd
Var - 742403 - Axles - Bevel Gear - 4wd
Var - 742402 - Axles - Bevel Gear - 4wd
Var - 742031 - Axles - Bevel Gear - 4wd
Var - 742031 - Axles - Front Axle Shaft - 4wd
Var - 742030, 742402, 742403 - Axles - Front Axle Shaft - 4wd - C7349
Var - 742030, 742402, 742403 - Axles - Front Axle Shaft - 4wd - D7349
Var - 742031 - Axles - Wheel Hub And Steering Knuckle - 4wd
Var - 742030, 742402, 742403 - Axles - Wheel Hub And Steering Knuckle - 4wd
Var - 742030, 742031, 742402, 742403 - Axles - Epyciclic Final Drive - 4wd
Rear Axle Installation - 2ws
Rear Axle - 2ws
Bevel Gear And Bearings
Differential Lock
Differential Lock Control
Epicyclical Reduction Unit
Parking Brake - Powershuttle - Na
Parking Brake - 2ws Powershift - Na
Parking Brake- 2ws Powershift - Na
Brake Pump Control Pedals
Brake, Master Cylinder
Brake Hydraulic System
Brake Pump Lines
Pictorial Index - Hydraulic Systems - Pilot Control
Pictorial Index - Hydraulic System - Hydraulic Cylinder
Pump (95/100 Hp), Fixed Displacement
Pump (95/100 Hp), Fixed Displacement, Components
Variable Delivery Hydraulic Pump (96 Hp)
Variable Delivery Hydraulic Pump (96 Hp), Components
Hydraulic Oil Reservoir
Var - 742331, 742332, 742333 - Pilot 6,7 Spool - Control Valve Pipes
Var - 742333, 742334, 742335, 742336 - Pilot 7 Spool - Control Valve Pipes
Var - 742019 - Glide Ride - Ride Control Hydraulic System - Na - Mech.Ctrl Version -
C7348
Var - 742019 - Glide Ride - Ride Control Hydraulic System - Accumulator, Hose - D7348
Var - 742019 - Glide Ride - Ride Control Hydraulic System - Valve - D7348
Var - 742019 - Glide Ride - Ride Control Hydraulic System - Accumulator - D7348
Var - 742019 - Ride Control, Pressure Switch - D7348
Var - 742019 - Glide Ride - Ride Control Hydraulic System - Pilot Ctrl Version - Eu
Mech.Ctrl Version - C7348
Var - 742331, 742332, 742333, 742334, 742335, 742336, 742341 - Pilot 6,7,8 Spool - Joystick To
Attachment Control Valve Pipes
Var - 742331, 742332, 742333, 742334, 742335, 742336 - Pilot 6,7 Spool - Backhoe Control
Valve Control Knob - Lh
Var - 742331, 742332 - Pilot 6 Spool - Backhoe Control Valve Control Knob - Rh
Var - 742333, 742334, 742335, 742336, 742341 - Pilot 7,8 Spool - Backhoe Control Valve
Control Knob - Rh
Var - 742017 - Rear Hammer Circuit - Hammer System Piping - Center Pivot - Mech.Ctrl
Var - 742017 - Rear Hammer Circuit - Hammer System Piping - Center Pivot (Vvp) - Pilot
Ctrl - C7443
Ctrl - D7443
Var - 742017 - Rear Hammer Circuit - Hammer Control Valve - Mech.Ctrl - C7425
Var - 742017 - Rear Hammer Circuit - Hammer Control Valve - Mech.Ctrl - D7425
Var - 742017 - Rear Hammer Circuit - Hammer System Piping - Center Pivot Mech. Ctrl
Var - 742017 - Rear Hammer Circuit - Hammer System Piping - Pilot Ctrl
Var - 742017 - Rear Hammer Circuit - Hammer System Piping - C7443
Var - 742017 - Rear Hammer Circuit - Hammer System Piping - D7443
Var - 742018 - Hand Hammer System - Hammer System Piping - Center Pivot (Front Hand
Tool Circuit) Mech Ctrl
Var - 742018 - Hand Hammer System - Hammer System Piping (Front Hand Tool Circuit)
Pilot Ctrl
Var - 742018 - Hand Hammer System - Hammer Control Valve (Front Hand Tool Circuit)
Mech Ctrl - C7425
Mech Ctrl - D7425
Hydraulic Oil Tank Return Pipe - Center Pivot - Na
Var - 742331, 742332, 742333, 742324, 742335, 742336, 742341 - Pilot 6,7,8, Spool - Hydraulic
Pump Delivery To Control Valve Hose - Center Pivot - Na
Pressure Detection Pipes Loader System - Center Pivot - Na
Oil Return Pipes
Loader Cylinder Pipes - 2ws - C7348
Line, Cylinder, Bucket, Front - D7348
Line, Cylinder, Loader Arm - D7348
Pump To And Loader Control Valve Hose - Center Pivot - Na
Loader Cylinders Pipes - C7348
Loader Cylinders Pipes - D7348
Loader Cylinders Pipes - Center Pivot - Na
Loader Cylinders Pipes - Center Pivot - Pilot Control - Na - C7348
Loader Cylinders Pipes - Center Pivot - Pilot Control - Na - D7348
Loader Cylinders Pipes - Side Shift - Eu - Mech. Ctrl - D7348
Var - 742010 - Lock Valve - Lock Valve On Loader Lift Cylinders - C7348
Var - 742010 - Lock Valve, Lift Cylinder - D7348
Var - 742010 - Lock Valve - Lock Valve On Loader Tilt Cylinders - C7348
Var - 742010 - Line, Cylinder, Loader, Lock Valve - D7348
Var - 742010 - Lock Valve, Front, Bucket - D7348
Var - 742010 - Front, Bucket, Line, Lock Valve - D7348
Var - 742010 - Bucket, Control Valve, Solenoid, Lock Valve - D7348
Lift Cylinder
Swing Cylinders Pipes - Pilot Ctrl
Swing Cylinders Pipes - Center Pivot - Na
Backhoe Dipper And Bucket Cylinders Pipes - Pilot Ctrl
Backhoe Dipper And Bucket Cylinders Pipes - Center Pivot - Na
Backhoe Boom Cylinder Pipes - Pilot Ctrl
Swing Plate Clamps - Center Pivot - Mech. Ctrl Version
Swing Plate Clamps - Center Pivot - Pilot Ctrl Version
Var - 742333 - Pilot 7 Spool - Backhoe Control Valve To Backhoe Pipes - Center Pivot
Var - 742333, 742334, 742341 - Pilot 7,8 Spool - Telescopic Dipper Cylinder Pipes
Var - 742333, 742334, 742341 - Pilot 7,8 Spool - Backhoe Bucket Cylinder Pipes
Valve - Swing Dampening
Stabilizer Cylinders Pipes - Center Pivot Pilot Crtl - Na
Stabilizer Cylinders Pipes - Center Pivot Mech.Ctrl - Na
Stabilizer Cylinder - Center Pivot
Hydraulic System Oil Filter - C7348
Hydraulic System Oil Filter - Center Pivot - Na
Hydraulic System Oil Filter - D7348
Loader Bucket Cylinder
Var - 742469, 742470, 742471, 742472, 742473, 742474, 742475, 742476 - Loader Bucket 4x1 - 6x1 -
Clam Cylinder - D7338
Var - 742433, 742434, 742469, 742470, 742471, 742472, 742473, 742474, 742475, 742476 - Loader
Bucket 4x1-6x1 - Clam Cylinder - C7338
Loader Bucket Self-Leveling - Eu - Pilot Ctrl Na
Loader Bucket Self-Leveling - Mech.Ctrl - Na
Loader Bucket Self-Leveling External Control - Eu - Pilot Ctrl Na
Loader Bucket Self-Leveling External Control - Mech.Ctrl - Na
Loader Control Valve Support
Loader Control Valve Support - Center Pivot - Na
Var - 720390 - Loader Control Lever - Na - Loader Control Valve Lever Support, Two
Sections - Na
Var - 742302, 742700 - 2 Spool Loader Valve - Loader Control Valve, Boom Section
Var - 742302, 742700 - 2 Spool Loader Valve - Loader Control Valve, Bucket Section
Var - 742302 - 2 Spool Loader Valve - Loader Control Lever Support
Var - 742302 - 2 Spool Loader Valve - Loader Control Valve, 2 Sections
Var - 742302, 742700 - 2 Spool Loader Valve - Loader Control Valve, Inlet Section
Var - 742700 - 4x1, 6x1 Bucket Hydraulic System - Loader Control Valve, Options
Section Wp
Var - 742700 - 4x1, 6x1 Bucket Hydraulic System - Loader Control Valve, 3 Sections
Wp
Var - 742700 - 4x1, 6x1 Bucket Hydraulic System - Hydraulic System - Side Shift - Eu
Var - 720725, 742700 - 4x1, 6x1 Bucket Hydraulic System - Valve Proportional Control
4x1 - 6x1
Var - 728336 - Control Valve, Front Loader Hydraulic System, Mechanical,
Components - Na
Var - 720725 - Control Valve, Front Loader Hydraulic System, Mechanical,
Var - 720725 - 4x1 Hydraulic Circuit - Hydraulic System - Na
Var - 728336 - Control Valve, Mechanical, Check Valve - Na
Var - 720725, 728336 - Control Valve, Mechanical, Check Valve - Na
Var - 720725 - Control Valve, Mechanical, Detent
Var - 720725 - Control Valve, Mechanical, Seal Sheet
Var - 728336 - Control Valve, Mechanical, Seal Sheet
Var - 720725 - Control Valve, Mechanical, Check Valve
Var - 728336 - Control Valve, Mechanical, Detent
Var - 742331 - Pilot 6 Spool - Na - Tower Assy 6 Sections - Na
Var - 742331, 742332, 742333, 742334, 742335, 742336, 742341 - Pilot 6 Spool - Backhoe Levers
And Control Valve Support
Var - 742331, 742332, 742333, 742334, 742335, 742336, 742341 - Pilot 6 Spool - Pilot
Accumulator
Handle And Boot
Var - 742331, 742332 - Pilot Valve, Pressure Control Valve, Components
Var - 742331 - Backhoe Control Valve, 6 Sections, Pilot Controls, Components - Na
Var - 728727, 742301, 742331, 742332, 742333, 742334, 742335, 742336, 742341, 742702 - Backhoe
Control Valve, 6, 7, 8 Sections, Inlet Section, Pilot Controls
Var - 742331, 742332, 742333, 742334, 742335, 742336, 742341 - Backhoe Control Valve, 6, 7, 8
Sections, Boom Section, Pilot Controls
Var - 742331, 742333, 742335 - Backhoe Control Valve, 6, 7 Sections, Swing Section,
Pilot Controls
Var - 728727, 742331, 742332, 742333, 742334, 742335, 742336, 742341, 742702 - Backhoe
Control Valve, 6, 7, 8 Sections, Bucket Section, Pilot Controls
Sections, Dipper Section, Pilot Controls
Var - 742331, 742333, 742335 - Backhoe Control Valve, 6, 7 Sections, Stabilizer Section
Var - 742333, 742335 - Pilot 7 Spool - Tower Assy 7 Sections - Center Pivot
Var - 742333, 742334, 742335, 742336 - Pilot Controls, Pressure Control Valve - C7592
Var - 742333, 742334, 742335, 742336 - Pilot Controls, Pressure Control Valve - D7592
Var - 742333, 742335 - Backhoe Control Valve, 7 Sections, Pilot Controls, Na - Center
Pivot
Var - 742333, 742334, 742335, 742336, 742341 - Backhoe Control Valve, 7, 8 Sections,
Telescopic, Pilot Controls
Var - 742024 - Backhoe Control Valve, 6 Spool, Mounting, Mechanical - Na - C7373
Var - 742024 - Backhoe Control Valve, 6 Spool, Mounting, Mechanical - Na - D7373
Var - 742024 - Backhoe Control Valve, 6-Spool, Mechanical, Components - Na - C7373
Var - 742024 - Backhoe Control Valve, 6 Spool, Mechanical, Components - Na - D7373
Var - 742024 - Backhoe Control Valve, 6 Spool, Plugs, Mechanical - Na
Var - 742024 - Backhoe Control Valve, 6 Spool, Check Valve, Mechanical - Na
Var - 720721, 728727 - Backhoe Control Valve, 7 Spool, Mounting, Mechanical - Na -
C7373
D7373
Var - 720721, 728727 - Backhoe Control Valves, 7 Sections - Na - C7373
Var - 720721, 728727 - Backhoe Control Valve, 7 Spool, Mechanical, Components - Na -
Var - 720721, 728727 - Backhoe Control Valve, 7 Spool, Check Valve, Mechanical - Na
Var - 720934, 728393, 742012 - Control Valve Support - Na
Var - 720394 - Backhoe Controls - 2 Control Valves Lever - Iso-Na
Backhoe Controls - 2 Control Valves Lever - Iso - Na
Var - 728393 - Backhoe Controls - 2 Control Valves Lever - Nh-Na
Var - 742012 - Backhoe Controls - 4 Control Valves Lever - Nh-Na, W/ Cab
Var - 742012 - Backhoe Controls - Tie Rods - Nh-Na, W/ Cab
Var - 742012 - Backhoe Controls - 4 Control Valves Lever - Nh-Na, W/O Cab
Var - 742012 - Backhoe Controls - Tie Rods - Nh-Na, W/O Cab
Var - 720721, 728727 - Hed Hydraulic System - Na - Telescopic Dipper Control Valve
Control Pedal - Na
Stabilizer Control Lever
Var - 728514, 728902 - Hed/Std Dipperstick (4.42m) - Boom Cylinder - C9009
Var - 728514, 728902 - Hed/Std Dipperstick (4.42m) - Boom Cylinder - D9009
Var - 742900, 742901 - Hed/Std Dipperstick (4.72m) - Boom Cylinder - C9009
Var - 742900, 742901 - Hed/Std Dipperstick (4.72m) - Boom Cylinder - D9009
Var - 728514, 728902, 742900, 742901 - Hed/Std Dipperstick - Boom Cylinder Pipes
Var - 728514, 728902 - Hed/Std Dipperstick (4.42m) - Dipper Cylinder
Var - 742900, 742901 - Hed/Std Dipperstick (4.72m) - Dipper Cylinder
Var - 728514, 728902, 742900, 742901 - Hed/Std Dipperstick - Dipper Cylinder Pipes
Var - 728514, 728902 - Hed/Std Dipperstick (4.42m) - Bucket Cylinder
Var - 742900, 742901 - Hed/Std Dipperstick (4.72m) - Bucket Cylinder
Var - 728514 - Std Dipperstick - Bucket Cylinder Pipes
Var - 728902 - Hed Dipperstick - Bucket Cylinder Pipes
Var - 728514, 728902, 742900, 742901 - Std/Hed Dipperstick - Bucket Cylinder Fittings
Var - 742900 - Std Dipperstick - Bucket Cylinder Pipes
Var - 742901 - Hed Dipperstick - Bucket Cylinder Pipes
Var - 720721 - Hed Hydraulic System - Na - Backhoe Bucket Cylinder Pipes - Center
Swing Cylinder
Var - 728902 - Hed Dipperstick (4.42m) - Telescopic Arm Cylinder
Var - 742901 - Hed Dipperstick (4.72m) - Telescopic Arm Cylinder
Var - 720721 - Hed Hydraulic System - Na - Telescopic Dipper Cylinder Pipes - Center
Var - 742290 - Front Counterweight Light - Front Counterweight
Var - 742291 - Front Counterweight Medium - Front Counterweight
Var - 742292 - Front Counterweight Heavy - Front Counterweight
Pictorial Index - Frames - Center Pivot
Frame - Center Pivot
Mechanical Transport Lock - Center Pivot - Na - C7331
Var - 742015 - Mechanical Transport Lock - Transport Lock Control Lever -
Powershuttle - Eu - Cab - C7324
Var - 742015 - Mechanical Transport Lock Control Lever - Cab - D7324
Mechanical Transport Lock - Transport Lock Control Lever - Powershuttle - Rops
- C7324
- D7324
Var - 742015 - Transport Lock Control Lever - Breakdown
Var - 720535 - Stabilizer Pads - Ground Stabilizer Pads - Center Pivot
Var - 720536 - Stabilizer Pads - Reversible Stabilizer Pads - Center Pivot
Steering Column And Covering - Powershuttle - Na - Cab
Steering Column And Covering - Powershuttle - Na - Rops
Var - 742650 - Steering Wheel - Fixed Steering Column
Steering Column And Covering - Powershift - Na
Adjustable Steering Column - Powershift
Var - 742651 - Steering Wheel - Adjustable Steering Column
Front Axle Steering Linkage - 2wd
Var - 742031 - Axles - Front Axle Steering Linkage - 4wd
Var - 742030, 742402, 742403 - Axles - Front Axle Steering Linkage - 4wd - C7349
Var - 742030, 742402, 742403 - Axles - Front Axle Steering Linkage - 4wd - D7349
Power Steering Pipes - Na
Power Steering - Breakdown - Mech Control (Na)
Power Steering - Breakdown - Pilot Control (Na)
Steering Cylinder - 2wd
Var - 742031 - Axles - Front Axle Steering Cylinder - 4wd
Var - 742030, 742402, 742403 - Axles - Front Axle Steering Cylinder - 4wd - C7349
Var - 742030, 742402, 742403 - Axles - Front Axle Steering Cylinder - 4wd - D7349
Front Axle Installation - 2wd
Front Axle Housing - 2wd
Front Axle Wheel Hub - 2wd
Var - 813866 - Front Wheels - 2wd
Var - 827874 - Front Wheels - 4wd - Na
Var - 827964, 827974 - Front Wheels - 4wd - Na
Front Wheels - 4wd - Na (Var. 828864)
Var - 863269 - Rear Wheels - Na
Var - 836279, 839366 - Rear Wheels - Na
Var - 836696 - Rear Wheels - Na
Heater Delivery Or Return Hoses
Var - 742013 - Cab Heating - Housing & Filters - Cab - C7428
Var - 742013 - Cab, Heater, Components - D7428
Var - 742013 - Cab Heating - Cab Heater/Fan Unit - Cab - C7428
Var - 742013 - Cab Heating - Cab Heater Valve And Lines - Cab - C7428
Var - 742013 - Cab Heating - Temperature Control Panel - Cab - C7428
Var - 742013 - Heater, Control Panel, Components - D7428
Var - 742013 - Cab Heating - Cab Air Outlets System - Cab - C7428
Var - 742013 - Cab Heater, Air Outlets System - D7428
Var - 742013 - Cab Heating - Coating Plugs
Var - 742013 - Cab, Heater - Harness - D7428
Var - 742014 - Cab Air Conditioning (Hot/Cold) - Compressor To Radiator Pipes
Var - 742014 - Cab Air Conditioning (Hot/Cold) - Compressor Support
Var - 742014 - Cab Air Conditioning (Hot/Cold) - A/C Unit Condenser
Var - 742014 - Cab Air Conditioning (Hot/Cold) - A/C Housing And Cab Filters - C7428
Var - 742014 - Cab Air Conditioning, Components - D7428
Var - 742014 - Cab Air Conditioning (Hot/Cold) - A/C Evaporator And Fan - C7428
Var - 742014 - Cab Air Conditioning (Hot/Cold) - Water Delivery Pipes/System - C7428
Var - 742014 - Cab Air Conditioning (Hot/Cold) - A/C Control Panel - C7428
Var - 742014 - Cab Air Conditioning, A/C Control Panel, Components - D7428
Var - 742014 - Cab Air Conditioning (Hot/Cold) - Cab Air Outlets System - C7428
Var - 742014 - Cab Air Conditioning, Air Duct System - D7428
Var - 742014 - Cab, Air Conditioning - Harness - D7428
Sensor - Transmission Powershift
Sender - Fuel Tank
Sensor Muffler
Switch Air Restriction
Engine Cable Harness
Engine Cable Harness - Powershuttle - Na
Engine Cable Harness - Powershift - Na
Var - 742019, 742011 - Front Instrument With Speedometer - Speed Sensor -
Powershuttle - Na
Thermostat - Transmission Powershift
Harness - Transmission Powershift
Suppressor Diode Harness
Var - 742331, 742333, 742335, 742341 - Backhoe Control Valve - Control Lever Harness
Rear Cable Harness - Powershuttle - Na
Rear Cable Harness - Powershift - Na
Starter Motor - C9058
Starter Motor - D9058
Starter Motor, Jumper, Support - D9058
Starter Motor
Glow Plug Control Module
Battery Disconnecting Switch - Powershuttle - Na
Battery Disconnecting Switch - Powershift - Na
Var - 861131 - Battery 12v 95ah 900a - Battery Cable And Battery
Var - 861321 - Double Battery 12v 60ah 600a - Double Battery Cables And Double
Battery
Headlamp, Components
Working Light - Cab - Na - Powershuttle
Working Light - Cab - Na - Powershift
Working Light - Rops - Na
Var - 742793 - Front Working Lights - Front Light
Var - 741794, 742794 - Rear Working Lights - Rear Lights
Var - 728758 - Rotating Beacon - Rops
Var - 728758 - Rotating Beacon - Cab
Reverse Alarm
Parking Brake Switch
Var - 742095 - Stabilizer Control Without Auto-Up - Switch Stabilizer Control -
Center Pivot
Var - 742096 - Stabilizer Control With Auto-Up - Switch Stabilizer Control - Center
Loader Bucket Return To Dig Sensor
Var - 742010 - Lock Valve - Lock Valve Switch
Pilot Control Unit
Var - 742331, 742333, 742335 - Pilot Control Unit
Front Cable Harness - Rops
Front Cable Harness - Cab - Powershuttle
Front Cable Harness - Powershift
Roof Cable Harness - Rops
Cab Roof Cable Harness - Cab - 2ws
Main Cable Harness And Engine Starting Switch - Rops -Na-
Cab Main Cable Harness And Engine Starting Switch - Cab - Powershuttle
Cab Main Cable Harness And Engine Starting Switch - Cab - Powershift
Electric System Components - Rops -Na-
Cab Electric System Components - Cab -Na-
Front Instrument Panel - Powershift
Front Instrument Panel - Powershuttle
Var - 423095, 742011 - Front Panel With/Without Speedometer - Dashboard - Cab
Var - 742787 - Front Panel With/Without Speedometer - Dashboard - Cab
Var - 423095, 742011 - Front Panel With/Without Speedometer - Dashboard - Rops
Var - 742787 - Front Panel With/Without Speedometer - Dashboard - Rops
Rh Side Instrument Panel - Na - Cab
Rh Side Instrument Panel - Na - Rops
Antenna - C7448
Antenna - D7448
Var - 742017 - Rear Hammer System - Control Pedal - Cab
Var - 742017 - Rear Hammer System - Control Pedal - Rops
Gearshift Lever And Light Lever - Powershuttle - Na - Cab
Gearshift Lever And Light Lever - Powershuttle - Na - Rops
Gearshift Lever And Light Lever - Powershift - 2ws - Na
Var - 742035 - Gearshift Lever - Ground Travel Lever - Powershift
Cab Inner Ceiling Light
Windscreen Wiper Motor
Winscreen Washer Water Reservoir
Var - 742019 - Glide Ride - Ride Control Switch
Fuse Holder Box - Rops - Na
Fuse Holder Box - Powershuttle
Fuse Holder Box - Powershift
Electronic Control Unit
Trax Controller
Controller
Var - 745122 - Fleetforce™
Loader Arm
Var - 728527 - Loader Bucket 0.88m3 With Cutting - Loading Bucket 0.88m3 Reversible
Blade
Var - 728536 - Loader Bucket 1m3 With Teeth - Loading Bucket 1m3 With Teeth
Var - 728537 - Loader Bucket 1m3 With Blade - Loading Bucket 1m3 With Reversible
Var - 728525 - Loader Bucket 1m3 W/Forks And Rever. Cutt. - Loading Bucket 1m3
W/Forks And Rever. Blade
Var - 742471 - 4x1 Bucket With Blade - Loading Bucket 4x1 (1m3) With Blade "Common
Grey"
Grey" - C7338
Grey" - D7338
Var - 742472 - 4x1 Bucket With Teeth - Loading Bucket 4x1 (1m3) With Teeth "Common
Var - 742473 - 6x1 Bucket With Blade - Loading Bucket 6x1 (1m3) With Blade "Common
Var - 742474 - 6x1 Bucket With Teeth - Loading Bucket 6x1 (1m3) With Teeth "Common
Var - 720734 - Loader Quick Coupler Mechanical - Quick Coupling
Pictorial Index - Backhoe - Center Pivot
Var - 728514, 728902, 742900, 742901 - Hed/Std Dipper - Boom
Var - 728514 - Std Dipper (4.42m) - Short Dipper
Var - 742900 - Std Dipper (4.72m) - Long Dipper
Var - 728902 - Hed Dipper (4.42m) - Telescopic Dipper Short
Var - 742901 - Hed Dipper (4.72m) - Telescopic Dipper Long
Var - 728514, 728902, 742900, 742901 - Hed/Std Dipper - Linkage
Var - 741548 - Backhoe Bucket - Ditch Cleaning Bucket
Var - 718557, 728515 - Backhoe Bucket - Backhoe Bucket With Pin Teeth, 12" - Na
Var - 718558, 728516 - Backhoe Bucket - Backhoe Bucket With Pin Teeth, 18" - Na
Var - 718559, 728517 - Backhoe Bucket - Backhoe Bucket With Pin Teeth, 24" - Na
Var - 718560, 728518 - Backhoe Bucket - Backhoe Bucket With Pin Teeth, 30" - Na
Var - 718561, 728519 - Backhoe Bucket - Backhoe Bucket With Pin Teeth, 36" - Na
Var - 718562, 728520 - Backhoe Bucket - Backhoe Bucket With Pin Teeth (Extra Hd), 18" -
Na
Var - 718563 - Backhoe Bucket - Backhoe Bucket With Pin Teeth (Extra Hd), 24" - Na
Var - 741386 - Backhoe Bucket - Backhoe Bucket With Pin Teeth, Hd 12" - Na
Var - 741387 - Backhoe Bucket - Backhoe Bucket With Pin Teeth, Hd 18" - Na
Var - 741388, 742388 - Backhoe Bucket - Backhoe Bucket With Pin Teeth, Hd 24" - Na
Var - 741389 - Backhoe Bucket - Backhoe Bucket With Pin Teeth, Hd 30" - Na
Var - 741390 - Backhoe Bucket - Backhoe Bucket With Pin Teeth, Hd 36" - Na
Var - 728733 - Backhoe Quick Attachment Mechanical
Var - 742201 - Backhoe Lifting Hook
Swing Cylinder Support
Transport Lock Hook
Mechanical Transport Lock Hook
Swing Cylinder Support - Center Pivot
Dia Kit, Opt 3 Section Hydraulic System Bucket 4x1
Dia Kit, Opt. Ride Control - C7348
Dia Kit, Opt. Hydraulic System For Ride Control - D7348
Dia Kit, Opt. Hydraulic System 4x1 Bucket With Joystick
Dia Kit, Opt. Hydraulic System 4x1 Bucket With Converter Kit From 2 To 3 Spools And
Joystick Ps
Dia Kit, Opt. Conversion Kit Loader Control Valve 2 To 3 Spools
Dia Kit, Opt. Backhoe Controls 2 Levers Nh Cab Na
Dia Kit, Opt. Loader Valve 3 Spools With Lever
Dia Kit, Opt. Conversion Kit 2 To 3 Spools Stabilizer Control Valve
Dia Kit, Locking Valve Option
Dia Kit, Opt. Hydraulic System 4x1 Bucket With Converter Kit 2 To 3 Spools And
Joystick
Joystick Pt
Dia Kit, Opt. Hand Hammer System
Dia Kit, Opt. Hand Hammer System - C7425
Dia Kit, Opt. Hand Hammer System - D7425
Dia Kit, Opt. Kit Hammer System (From Boom To Dipper) - Sideshift - C7443
Dia Kit, Opt. Hed Hydraulic System - Center Pivot - 2ws
Dia Kit, Opt. Hammer System
Dia Kit, Opt. Hammer System Cp 2ws Mech. Ctrl
Dia Kit, Opt. Hammer System Cp 2ws Mech. Ctrl - C7425
Dia Kit, Opt. Hammer System Cp 2ws Mech. Ctrl - D7425
Dia Kit, Opt. Kit Hammer System (From Boom To Dipper) - Center Pivot - C7443
Dia Kit, Opt. Joystick For 4x1 Loader Bucket
Dia Kit, Opt. Kit Bi-Directional Auxiliary Hydraulic
Dia Kit, Opt. Hydraulic Transport Lock 2ws Pt Na
Dia Kit, Opt. Hydraulic Transport Lock 2ws Ps Na
Dia Kit, Opt. Check Valves For 4x1 - 6x1
Dia Kit, Opt. Lock-Out Valves On Boom And Dipper Cylinder
Dia Kit, Opt. Lock-Out Valve On Boom Cylinder
Dia Kit, Opt Hydraulic System For 4x1 Bucket With Conversion Kit 2 To 3 Spool And
Dia Kit, Opt. Kit Conversion 2 To 3 Spool Blade
Dia Kit, Opt. Swing Dampening Control
Dia Kit, Opt. Kit 3/8 Flat Face Hydraulic Couplers
Dia Kit, Opt. Kit 3/4 Flat Face Hydraulic Couplers
Dia Kit, Opt. Hydraulic Cushion Kit
Dia Kit, Opt. Bi-Directional Auxiliary Hydraulic Kit - Pilot Control
Dia Kit, Opt. Front Counterweight - Small - Standard
Dia Kit, Opt. Front Counterweight - Medium
Dia Kit, Opt. Front Counterweight - Large
Dia Kit, Opt. Front Additional Counterweight For 2ws Cwt Standard
Dia Kit, Opt. Front Additional Counterweight For 2ws Medium Cwt
Dia Kit, Opt. Stabilizers Pads-Ground Grey
Dia Kit, Opt. Stabilizers Pads Reversible - Grey
Dia Kit, Opt. Cardan Shaft Guard Common Grey
Dia Kit, Opt. Fixed Steering Column - Cab
Dia Kit, Opt. Adjustable Steering Column - Cab
Dia Kit, Opt. Fixed Steering Column - Rops
Dia Kit, Opt. Adjustable Steering Column - Rops
Dia Kit, Conversion Kit From Heater To Air Conditioner - C7438
Dia Kit, Antitheft
Dia Kit, Opt. Kit For Double Battery Equipment
Dia Kit, Front Working Lights
Dia Kit, Front Dashboard With Speedometer
Dia Kit, Block Heater (220v) - Eu
Dia Kit, Fleetforce™ - C9046
Dia Kit, Fleetforce™ - D9046
Dia Kit, Block Heater (120v) - Na
Dia Kit, Opt Fork Kit - Standard Bucket
Dia Kit, Opt. Loader Bucket 0.88 Cu.M.L./Teeth
Dia Kit, Opt. Loader Bucket - 1 Cu.M.
Dia Kit, Opt. 1 Cu.M. Loader Bucket With Forkes
Dia Kit, Opt. Tooth Loader Bucket
Dia Kit, Opt. Supplementary Reversible Cutting Edge
Dia Kit, Opt. Bucket Lifting Hook
Dia Kit, Opt. Loader Bucket - 1 Cu.M. With Reversible Cutting Edge
Dia Kit, Opt. 4x1 Loader Bucket 1m3 With Teeth "Common Grey"
Dia Kit, Opt. 4x1 Loader Bucket 1m3 With Teeth "Common Grey" - C7338
Dia Kit, Opt. 4x1 Loader Bucket 1m3 With Teeth "Common Grey" - D7338
Dia Kit, Opt. 6x1 Loader Bucket 1m3 With Teeth "Common Grey"
Dia Kit, Opt. 6x1 Loader Bucket 1m3 With Teeth "Common Grey" - C7338
Dia Kit, Opt. 6x1 Loader Bucket 1m3 With Teeth "Common Grey" - D7338
Dia Kit, Opt. Bucket 1.3 Cubic Yd
Dia Kit, Opt. 116 Grader Rake
Dia Kit, Opt. 108 Grader Rake
Dia Kit, Opt. 97 Grader Rake
Dia Kit, Opt. Lift Boom
Dia Kit, Opt. 90 4x1 Bucket
Dia Kit, Opt. 120 Snow Blade
Dia Kit, Opt. 108 Snow Blade
Dia Kit, Opt. Scrap Grapple Bucket
Dia Kit, Opt. Fork Conversion Kit 4x1 To 6x1 1.00 M3 "Common Grey"
Dia Kit, Opt. Bucket 88 In Pin-On
Dia Kit, Opt. Pallet Forks
Dia Kit, Quick Coupler, Mechanical
Dia Kit, Opt. Electric Coupler
Dia Kit, Opt. Quick Manual Coupler Backhoe
Dia Kit, Opt. Teeth Kit Backhoe Bucket Na 12in/305mm
Dia Kit, Opt. Teeth Kit Backhoe Bucket Na 18-24in/457-610mm
Dia Kit, Opt. Teeth Kit Backhoe Bucket Na 30in/762mm
Dia Kit, Opt. Teeth Kit Backhoe Bucket Na 36in/910mm
Dia Kit, Opt. Lift Hook Backhoe Bucket
Dia Kit, Opt. Silenced Hammer Cb65s Lb
Dia Kit, Opt. Silenced Hammer Cb65b Lb
Dia Kit, Opt. Tooth Backhoe Bucket Na
Dia Kit, Opt. Thumb With Stiff Arm For Fixed Dipper
Dia Kit, Opt. Thumb With Stiff Arm For Extendable Dipper
Dia Kit, Opt. Thumb With Hydraulic For Fixed Dipper
Dia Kit, Opt. Thumb With Hydraulic For Extendable Dipper
Dia Kit, Opt. Thumb With Mechanical
Dia Kit, Slow Motion Vehicle Sign
Dia Kit, Opt. Angle Broom 96in - Mechanical Control
Dia Kit, Opt. Angle Broom 96in - Pilot Control
Dia Kit, Opt. Manual Angle Kit - Angle Broom
Dia Kit, Opt. Hydraulic Angle Kit - Angle Broom
Dia Kit, Opt. 2in Seat Belt
Dia Kit, Opt. 3in Seat Belt
Engine Hood Panels - C7310
Engine Hood Grid - C7310
Engine Hood Accessories - C7310
Heat Shield - Rops
Engine Hood, Accessories - C7330
Control Logogram Decals - Powershuttle (Na) - Mech Control
Control Logogram Decals - Na - Mech Control - Gear Pump
Control Logogram Decals - Powershuttle (Na) - Pilot Control
Control Logogram Decals - Na - Pilot Controlo - Wp
Control Logogram Decals - Powershift (Na) - Mech Control
Control Logogram Decals - Powershift (Na) - Pilot Control
Decals B95c / B95clr - Powershuttle (Na)
Decals B95c / B95clr - Powershift (Na)
Var - 742048 - Russia Homologation Decal
Var - 728514, 728902 - Decals B95c - Decals
Var - 742900, 742901 - Decals B95clr - Decals
Decals - Cab
Decals - Rops
Safety Or Functional Decals - Na
Var - 728982, 728986, 728993 - Safety Decals - Warning Decals - Na
Safety Frame - Rops
Frame - Rops - Na
Anti-Skid Strip - Rops
Rear Fenders - 2ws
Var - 742284 - Outside Rear View Mirror Left - Na
Var - 728879 - Outers Rear View Mirror Rh
Var - 720851 - Deluxe Seat - Mechanically Adjusted Operator's Seat - Cab Mech
Control
Var - 720851 - De Luxe Seat - Mechanically Adjusted Operator's Seat - Cab Mech
Control, Cushion
Control, Support
Control, Safety Belt
Control, Suspension
Control, Adjuster
Var - 728851 - Deluxe Seat - Mechanically Adjusted Operator's Seat - Cab Mech
Control (Na)
Var - 728851 - De Luxe Seat - Mechanically Adjusted Operator's Seat - Cab Mech
Control (Na), Cushion
Control (Na), Support
Control (Na), Safety Belt
Control (Na), Suspension
Control (Na), Adjuster
Var - 720851 - Deluxe Seat - Mechanically Adjusted Operator's Seat - Cab Pilot
Var - 720851 - De Luxe Seat - Mechanically Adjusted Operator's Seat - Cab Pilot
Var - 728851 - Deluxe Seat - Mechanically Adjusted Operator's Seat - Cab Pilot
Var - 728851 - De Luxe Seat - Mechanically Adjusted Operator's Seat - Cab Pilot
Var - 720856 - Vinyl Seat - Mechanically Adjusted Operator's Seat - Rops Mech
Var - 728856 - Vinyl Seat - Mechanically Adjusted Operator's Seat - Rops Mech
Control , Cushion
Var - 720856 - Vinyl Seat - Mechanically Adjusted Operator's Seat - Rops Pilot
Var - 728856 - Vinyl Seat - Mechanically Adjusted Operator's Seat - Rops Pilot
Var - 720855 - Super Deluxe Seat - Pneumatically-Adjusted Operator's Seat - Cab -
Mech Control
Var - 720855 - Super De Luxe Seat W/2 In Seat Belt, Cushion
Var - 720855 - Super De Luxe Seat W/2 In Seat Belt, Support
Var - 720855 - Super De Luxe Seat W/2 In Seat Belt, Adjuster
Var - 720855 - Super Deluxe Seat W/2 In Seat Belt, Suspension Seat
Var - 728855 - Super Deluxe Seat - Pneumatically-Adjusted Operator's Seat - Cab -
Mech Control (Na)
Var - 728855 - Super De Luxe Seat W/2 In Seat Belt, Cushion
Var - 728855 - Super De Luxe Seat W/2 In Seat Belt, Support
Var - 728855 - Super De Luxe Seat W/2 In Seat Belt, Adjuster
Var - 728855 - Super Deluxe Seat W/2 In Seat Belt, Suspension Seat
Pilot Control
Cab Frame - Na Mech Control
Cab Frame Pilot Control
Protections - Cab
Cab Fasteners - Powershift (Na) - Mech Control
Cab Fasteners - Powershuttle (Na) - Mech Control
Cab Fasteners - Powershuttle (Na) - Pilot Control
Cab Fasteners - Powershift (Na) - Pilot Control
Rops Fasteners - Na
Cab Fasteners
Cab Roof - Cab (Na)
Cab Roof - Rops
Front Sun Curtain - Cab
Outside Rear View Mirror Left - Eu
Rear View Mirror - Rops
Cab Doors
Cab Door Retainer
Cab Door Handle With Lock
Cab Door Gasket
Windshield Glass And Front Side Windows
Window Latch
Three-Quarter Window Hinge
Three-Quarter Window Glasses And Gaskets
Backlight Frame
Backlight Catch
Backlight Hinge
Front Dashboard - Cab
Front Dashboard - Rops
Fasteners Of Side Instrument Panel - Cab
Fasteners Of Side Instrument Panel - Rops
Ceiling Console - Cab
Rh Side Dashboard Powershuttle - Na - Mech. Controls - Cab.
Rh Side Dashboard - Powershuttle - Na - Mech. Controls - Cab.
Rh Side Dashboard - Powershuttle - Na - Pilot Controls - Cab.
Rh Side Dashboard - Powershuttle - Na - Mech.Controls - Rops
Rh Side Dashboard - Powershift - Na - Mech.Controls
Rh Side Dashboard - Powershuttle - Na - Pilot Controls - Rops
Rh Side Dashboard - Powershift - Na - Pilot Controls
Lh Side Dashboard And Front Floor Carpet - Powershuttle - Na - Cab.
Lh Side Dashboard And Front Floor Carpet - Powershift - Na
Var - 742015 - Lh Side Dashboard - Cab
Rear Consolle - Na- Mech. Control - Cab
Rear Consolle Na - Pilot Control - Cab
Rear Consolle - Na - Mech. Control Rops
Rear Consolle - Na - Pilot Control Rops
Bulkhead, Front
Rear Floor Carpet - Mech. Controls - Cab
Rear Floor Carpet - Pilot Controls - Cab
Floor Carpet - Mech. Controls - Rops
Floor Carpet - Pilot Controls - Rops
Brand: New Holland
Dia Kit
Engine Assy
Engine, Support
Fuel Pipes
Exhaust Muffler
Muffler
Exhaust Tube
Cooler, Hose
Rear Axle - 2ws
Differential Lock
Brake Pump Lines
C7348
Control Knob - Rh
Ctrl - C7443
Ctrl - D7443
Pilot Ctrl
Mech Ctrl - C7425
Mech Ctrl - D7425
Oil Return Pipes
Lift Cylinder
Sections - Na
Section Wp
Wp
4x1 - 6x1
Components - Na
Accumulator
Handle And Boot
Pilot Controls
Pivot
C7373
D7373
Control Pedal - Na
Swing Cylinder
- C7324
- D7324
Sender - Fuel Tank
Sensor Muffler
Powershuttle - Na
Starter Motor
Battery
Reverse Alarm
Center Pivot
Pilot Control Unit
Antenna - C7448
Antenna - D7448
Trax Controller
Controller
Loader Arm
Blade
Grey"
Grey" - C7338
Grey" - D7338
Na
Transport Lock Hook
Joystick Ps
Joystick
Joystick Pt
Dia Kit, Antitheft
Heat Shield - Rops
Decals - Cab
Decals - Rops
Safety Frame - Rops
Frame - Rops - Na
Rear Fenders - 2ws
Control
Control, Cushion
Control, Support
Control, Suspension
Control, Adjuster
Control (Na)
Control , Cushion
Mech Control
Mech Control (Na)
Pilot Control
Protections - Cab
Rops Fasteners - Na
Cab Fasteners
Cab Roof - Cab (Na)
Cab Roof - Rops
Cab Doors
Cab Door Retainer
Cab Door Gasket
Window Latch
Backlight Frame
Backlight Catch
Backlight Hinge
Bulkhead, Front
- New Holland Crawler Excavator E265, E305 Tier 3 Workshop Manual_60413674
- New Holland LB90.B-LB115.B Engines F4GE0454C-F4GE0484G 604.13.612 Repair Manual
- New Holland W130 Workshop Manual
- New Holland Excavator E9SR 604.13.391 Repair Manual
- New Holland W190 Workshop Manual
- New Holland TVT 135_145_155_170_190_195 Series Service Manual 6035448106
- New Holland Crawler Dozer D350 84568077A Service Manual
- New Holland W190 (UK) Workshop Manual
- New Holland Skid Steers L175 C175 Workshop Manual
- New Holland W170 Workshop Manual
- New Holland E385C Hino Diesel Engine J08E-UN 47374920A Service Manual
- New Holland Hydraulic Hammers CB18S - CB27S - CB37S 603.67.221.03 Service Manual
- New Holland W130B Service Manual
- New Holland Loader Backhoe B110 B115 87643846 Repair Manual
- New Holland W190B Workshop Manual
