New Holland Backhoe Loader B90B to B115B Tier 3 Service Manual 84428663B
Brand: New Holland
Type of Manual: Service Manual, Hydraulic And Electrical Schematic
Model: New Holland Backhoe Loader Tier 3
B90B ; B90BLR ; B100B ; B100BLR ; B100BTC ; B110B ; B110BTC ; B115B
Part Number: 84428663B
Number of Pages: 1279 Pages
Section 00 - Safety Rules
Foreword
Safety Instructions
Prevention Of Fire Or Explosions
Prevention Of Burns
Precautions For Waste Disposal
Section 01 - Maintenance
Section 02 - Technical Specifications
Models
Identification Of Main Components
Diesel Engine
Brakes
Steering
Front Counterweight
Noise And Vibration Levels
Buckets
Tyres
Dimensions And Performance
Dimensions - 2ws Sideshift
Dimensions - 2ws Center Pivot
Dimensions - 2ws Tc - Sideshift
Dimensions - 4ws Sideshift
Dimensions - 4ws Center Pivot
Loader Attachment Performance
Performance Of Loader Attachment With Forks
Backhoe Attachment Performance
Backhoe Attachment Lifting Capacity
Maximum Lifting Loads
Loader Attachment Maximum Lifting Load Table
Backhoe Attachment Maximum Lifting Load Table
Supply Summary Table
Section 21 - Transmission
Powershuttle Transmission
Hydraulic Diagram
Controls
Lubrication
Greasing
Removal From Machine
Disassembly And Assembly
Troubleshooting
Repair Times
Special Tools
Powershift Transmission
Controls
Lubrication
Greasing
Troubleshooting
Repair Times
Special Tools
Section 25 - Front Axles
2wd - 2ws Front Axle
Lubrication And Greasing
Troubleshooting
4wd - 2ws Front Axle
Troubleshooting
Special Tools
4ws Front Axle
Troubleshooting
Repair Times
Special Tools
Section 27 - Rear Axle
2ws Rear Axle
(B90b - B100b - B100btc)
Troubleshooting
Repair Times
Special Tools
2ws Rear Axle
(B110b - B110btc)
Troubleshooting
Repair Times
Special Tools
4ws Rear Axle
(B115b)
Troubleshooting
Repair Times
Special Tools
Section 33 - Brake System
Operation
Adjustment
Service Brake
Operation
Section 35 - Hydraulic System
Hydraulic Diagrams
Hydraulic Diagram - 2ws Sideshift Mechanical Models
Hydraulic Diagram - 2ws Sideshift Pilot Models
Hydraulic Diagram - 2ws Center Pivot Pilot Models
Hydraulic Diagram - 4ws Sideshift Mechanical Models
Hydraulic Diagram - 4ws Sideshift Pilot Models
Hydraulic Diagram - 4ws Center Pivot Pilot Models
Hydraulic Fixed-Flow-Rate Gear Pump
Hydraulic Variable-Flow-Rate Piston Pump
Control Valves
Loader Control Valve
Backhoe Attachment Control Valve
Relief Valves
Backhoe Attachment Control Valve Pilot Solenoid Valve
Accumulator “Glide Ride” Parker
Maintenance
Safety
Checking And Adjusting The Precharge Pressure
Hydraulic Swing System
Operation
Hydraulic Cylinders
Loader Attachment Boom Cylinder
Loader Bucket Cylinder
4x1 Loader Bucket Cylinder
Backhoe Boom Cylinder
Backhoe Attachment Dipper Cylinder
Backhoe Bucket Cylinder
Telescopic Cylinder
Stabilizer Cylinder - Center Pivot
Stabilizer Cylinder - Sideshift
Swing Cylinder
Backhoe Attachment Lock Cylinder - Sideshift
Special Tools
Hydraulic Control Levers
Controls And Operation
Components
Control Lever Valve
Troubleshooting
Preliminary Checks
Troubleshooting (With “Rexroth” Control Valves)
Swing
Section 39 - Chassis
Description
Removal And Installation Of Components
Components Within The Chassis
Components Of The Lower Part Of The Chassis
Components Attached Outside The Chassis
Components Of The Upper Part
Section 41 - Steering System
Description
2ws Steering System
4ws Steering System
Power Steering
Components
Disassembly
Assembly
Section 50 - Cab Heating And Air Conditioning
General
Cab Heating
Controls
Operation
Overhaul
Troubleshooting
Air Conditioning
Principles Of Air Conditioning
Controls
Operation
Troubleshooting And Testing
Flushing The System
Draining The System
Charging The System
Overhaul
Compressor
Troubleshooting
Section 55 - Electric System
Electric Diagrams
Electric Diagrams - Powershuttle Rops (B90b)
Electric Diagrams - Powershuttle Cab (B90b)
(B100b - B100btc - B110b - B110btc)
Electric Diagrams - Powershift Cab (B110b - B110btc)
Electric Diagrams - 4ws Powershift Cab (B115b)
Controls And Instruments
Front Instrument Panel
Side Instrument Cluster Panel (B90b)
Side Instrument Cluster Panel (B100b - B100btc - B110b - B110btc - B115b)
Side Instrument Cluster (B90b)
Side Instrument Cluster (B100b - B100btc - B110b - B110btc - B115b)
Anti-Start System
Diagnostic Display (B100b - B100btc - B110b - B110btc - B115b)
Symbols
Setup Menu
Procedure About Self Test
On Board Error Code Retrieval
Backlighting And Dimming
Work Hours
Operation
Warning System
Maintenance
Warning Messages
Starting System
Operation
Starter Motor
Troubleshooting
Operation
Components
Removal
Preliminary Checks And Tests
Troubleshooting
Battery
Operation
Replacement
Charge And Electrolyte Level Check
Connecting A Booster Battery
Battery Master Switch
Troubleshooting
Section 82 - Loader
Loader Attachment Controls
Loader Attachment Operation
4x1 Loader Bucket Control (Optional)
Loader Attachment Control Lock
(Specific To Certain Countries)
Loader Bucket Self-Levelling
Loader Attachment Safety Strut
(B90b - B100b - B110b)
(B100btc - B110btc - B115b)
Removal And Installation Of Loader Bucket
Loader Bucket (B90b - B100b - B110b)
Loader Bucket (B100btc - B110btc - B115b)
Loader Bucket With Forks (Optional)
Bucket Teeth Replacement
Loader Removal
Loader Attachment (B90b - B100b - B110b)
Loader Attachment
Section 84 - Backhoe
Description And Operation
Backhoe Attachment Controls
Backhoe Attachment Mechanical Controls
Backhoe Attachment Hydraulic Controls
Backhoe Attachment Sideshift (Sideshift Version)
Backhoe Attachment Disassembly
Center Pivot Backhoe Attachment Disassembly
Sideshift Backhoe Attachment Disassembly
Backhoe Bucket Replacement
Dipper Remove
Telescopic Dipper Revision
Overhaul
Backhoe Attachment Hydraulic Handling
Controls
Hydraulic Diagram
Handling Cylinder
