New Holland Backhoe Loader B115 Parts Catalog 87364132NA 2006
Brand: New Holland
Model: New Holland B115 Backhoe Loader
Part Number: 87364132NA
Publication Date: 2006
Number of Pages: 982 Pages
Sections
Maintenance Parts
Engine 1/2
Engine 2/2
Oil Pump, Pan
Cylinder Block - Covers
Breather - Engine
Cylinder Head - Covers
Cylinder Head - Valve Mechanism
Manifold - Intake
Manifold - Exhaust
Pistons - Connecting Rod
Flywheel - Engine
Pulley - Crankshaft
Dynamic Balancer, Gears & Shafts
Dynamic Balancer, Gears & Shafts (2831300)
Camshaft
Fuel Injection Pump
Fuel Injection System
Fuel Pump
Turbocharger
Engine, Oil
Oil Pump - Engine
Oil Filters - Engine
Piping - Engine Oil
Oil Filter And Cooler
Cooling System - Engine
Thermostat - Engine Cooling System
Water Pump - Control
Fan Drive
Power Take-Off
Starter Motor
Engine - Lift Hook
Accessory Engine
Accessory Engine- Alternator
Accessory Engine - Bracket Muffler
Accessory Engine - Starter
Accessory Engine - Ventilator
Fuel Tank - Muffler - Radiator - Air Cleaner - Chassis
Fuel Tank & Related Parts
Muffler & Extensions
Expansion Tank
Air Cleaner & Hoses
Frame (Center Pivot)
Air Intake Cap & Pre-Cleaner
Front Weights
Transmission 1/2
Transmission 2/2
Gearing Speed Gear
Transmissiongearing Speed Gear (2wd Power-Shuttle)
Transmissiongearing Speed Gear (4wd Power-Shift)
Transmission (4wd, 4ws, Power-Shift)
Transmission (4wd, 4ws Power-Shift)
Gear Filter Pipes (Power-Shift)
Front & Rear Driveshaft (Power-Shift)
Transmission Oil Cooling Pipes (Power-Shuttle)
Transmission Oil Cooling Pipes (Power-Shift)
Front Axle
Front Axle (4ws) - Box
Front Axle (4ws) - Steering Axles
Front Axle (4ws) - Bevel Gear Pair
Front Axle (4ws) - Differential Locking
Self-Locking Front Axle: Differential Automatic Locking 4ws
Front Axle (4ws) - Axle-Shaft Articulated
Front Axle (4ws) - Hubs
Rear Axle
Rear Axle, Rh & Center Housing
Rear Axle, Lh Housing & Bushings
Rear Axle, Rh Swivel Housing, Steering Cylinder & Sensor
Rear Axle, Lh Swivel Housing
Rear Axle, Ring Gear & Pinion Assembly
Rear Axle, Pinion Shims
Rear Axle, Differential (Standard)
Self-Locking Rear Axle, Differential (Self Locking)
Rear Axle, Brakes
Rear Axle, Wheel Carrier & Hub
Rear Axle, Planetary Gears & Cover
Electrical
Chassis Harness & Ground Wire (Power Shift)
Battery Lock-Out Switch & Ground Wire (Power Shift)
Engine Harness (Power Shift)
Single Battery
Double Battery
Cold Start
Slides Valves
Hydraulic Oil Reservoir
Hydraulic Pump (35+35-154l/Mm)
Hydraulic Pump (40+35-165l/Mm)
Hydraulic System Piping
Hydraulic System Piping(Center Pivot)
Filter Assembly & Hose To Return Manifold (Center Pivot)
Hydraulic System Piping Na 4ws (Center Pivot)
Backhoe Control Valve, 6 Sections (Center Pivot)
Backhoe Control Valve, Inlet Section
Backhoe Control Valve, Boom Section
Backhoe Control Valve, Swing Section
Backhoe Control Valve, Bucket Section
Backhoe Control Valve, Dipperstick Section
Backhoe Control Valve, Stabilizer Section (Center Pivot)
Two-Section Control Valve For Loader
Lock Valve On Tilting Cylinder
Lock Valve On Lifting Cylinder
Lock Valve
Backhoe Control Valve, 6 Sections (Center Pivot) North America
6 Section Pilot Control Valve Support, Complete
2 Section Pilot Control Valve Support, Complete
6 Section Pilot Control Valve Support, Complete (Center Pivot)
Valve, Joystick Pilot Controls - Extended Version - (Rigth Hand)
7 Section Pilot Control Valve Support, Complete
7 Section Pilot Control Valve Support, Complete (Center Pivot)
Europe
6 Section Pilot Control Valve Support,Complete
Valve, Joystick Pilot Controls (Right Hand)
Valve, Joystick Pilot Controls (Left Hand)
7-Sections Excavator Control Valve (Center Pivot) North America
Locking Valve On Backhoe Lift And Dipp. Cylinder
Backhoe Lift & Dipperstick Cylinder Lock Valve
Glide Ride Valve,Hydraulic System For Machine Frame Levelling &
On/Off Switch
Pedal-Operated Telescopic Dipper Hydraulic System (Center Pivot)
Three-Section Control Valve For Loader
Kit Of Conversion From 2 To 3 Spools
Hydraulic System Presetting For Telescopic Links Pedal
Operated(Center Pivot)
Body & Hood
Cab Screen
Cab Fasteners
Loader 1/1
Backhoe 1/2
Backhoe 2/2
Transport Lock Hook, Cylinder & Hose (Side Shift,Center Pivot)
Hydraulic System For "Transport Lock" Rear Locking
Swing Post Assembly, Bushings & Pins
Swing Post Pins & Transport Lock Hook
Distributor Valve Support (Side Shift)
Arms And Joints
Lift Cylinder
Loader Bucket Control Cylinder
Lift Cylinder And Bucket Pipes
Stabilizer Cylinders (Center Pivot)
Pipes For Stabilizer Cylinders (Center Pivot)
Return To Dig Sensor
Cylinders And Rotation Plate
Swing Cylinders Backhoe
Front Control Valve Support And Transmissions (Center Pivot)
Silent Hammer Cb65s
Hammer Cb65b
Shovel And Rear Lifting Hooks
System Hammer Components (Cab)
Bucket 6x1 (1,15 M3) With Blade
Hydraulic Cylinder (Bucket 4x1-6x1)
Bucket 6x1 (1,15 M3) With Blade "Common Grey"
Bucket 6x1 (1,15 M3) With Tine
Bucket 6x1 (1,15 M3) With Tine "Common Grey"
Bucket 4x1 (1,15 M3) With Blade
Bucket 4x1 (1,15 M3) With Blade "Common Grey"
Bucket 4x1 (1,15 M3) With Tine
Bucket 4x1 (1,15 M3) With Tine "Common Grey"
1,13 M3 Bucket
1,13 M3 Bucket W/Tines
1,13 M3 Bucket With Extra Reversible Blade
Hydraulic Bucket Cylinder
Hydraulic Ditching Cylinder
12" (305mm) Backhoe Bucket With Pin Teeth
12" (305mm) Backhoe Bucket With Bolt-On Teeth
18" (457mm) Backhoe Bucket With Pin Teeth
18" (457mm) Backhoe Bucket With Bolt-On Teeth
24" (610mm) Backhoe Bucket With Pin Teeth
24" (610mm) Backhoe Bucket With Bolt-On Teeth
30" (762mm) Backhoe Bucket With Pin Teeth
30" (762mm) Backhoe Bucket With Bolt-On Teeth
36" (914mm) Backhoe Bucket With Pin Teeth
36" (914mm) Backhoe Bucket With Bolt-On Teeth
Bolt-On Tooth Kit, 12" (305mm) Backhoe Bucket
Bolt-On Tooth Kit, 18" (457mm) & 24" (610mm) Backhoe Buckets
Bolt-On Tooth Kit, 30" (762mm) Backhoe Bucket
Bolt-On Tooth Kit, 36" (914mm) Backhoe Bucket
Pin Tooth Kit, 12" (305mm) Backhoe Bucket
Pin Tooth Kit, 30" (762mm) Backhoe Bucket
Pin Tooth Kit, 36" (914mm) Backhoe Bucket
1.15 M3 Bucket With Forks And Cutter Blade
1,15 M3 Bucket With Forks And Extra Reversible Blade
1,15mc Bucket With Forks And Tine
Ditch Cleaning Bucket
Front Bucket Teeth
1.15 Bucket Fork Kit For Conversion From 4x1 To 6x1
Hand Hammer Switch
4x1 & 6x1 Bucket Hydraulic Lines (4ws)
Manual Hammer System
Manual Hammer Valve
Kit-Hydraulic System With 3 Section For Bucket 4x1 / 6x1
Hydraulic System For Hammer (Center Pivot)
Rear Hammer Control Valve
Hydraulic System For Hammer (4ws)
Hydraulic System For Hammer (Side Shift Europa)
Rear Mechanical Quick-Coupling
Boom - Long Dipper
Long Dipper
Long Dipper - Bucket Motion
Long Dippêr - Hydraulic System
Long Dipper - Hydraulic System
Telescopic Dipper Long - Hydraulic System
Telescopic Dipper Long - Hydraulic Lifting Cylinder
Body, Hood & Driver''S Post 1/3
Body, Hood & Driver''S Post 2/3
Body, Hood & Driver''S Post 3/3
Stabilizer Control Without Auto-Up (Center Pivot)
Stabilizer Control With Auto-Up (Center Pivot)
Power Steering Hydraulic System
Power Steering Hydraulic System (4ws)
Cab / Ceiling Light
Back-Up Alarm
Igniton Switch, Power Point, Fuse Panel & Side Console Harness (Cab
Cp Power Shift)
Front Dash (Cab Cp Power Shift)
Front And Rear Windscreen Wipers
Windscreen Wipers Reservoir & Nozzles
Radio Antenna & Speaker Cover
Lamps & Lights - Cab (Usa)
Cab-Safety Frame / Extinguisher
Cab - Frame-Door
Rops - Safety Frame
Windows
Fenders, Rear
Door Components
Rear Windows
Cab / Soft Trim
Cab / Soft Trim (Power Shuttle)
Cab / Soft Trim (Power Shift)
Rear Mirror- Sun Screen
Front Console - Rops (Power Shuttle)
Cab / Panel Dash
Cab/ Canopy
Heater Water Hoses
Cab-Safety Frame / Brake Pedal
Cab- Brake Pedal
Cab-Safety Frame / Hand Brake (Eur)
Power Steering Motor
Power Steering Motor, Wheel & Column (4ws)
Foward/Reverse & Multi-Purpose Lever, Cab (Power-Shift)
Stabilizer Control
Pilot Control Diagnostics
Cab / Miscellaneous Caps (Center Pivot) Usa
Information Symbol Decals (Power Shuttle)
Warning Symbol Decals
Cab Warning & Information Decals
Backhoe, Loader & Engine Warning Decals
Information Symbol Decals (Power Shift)
Foward/Reverse & Steering Decals
B115 Model Identificatio
A/C Housing & Filters
A/C Blower & Coils
Heater Coil Hoses
A/C & Heater Control Panel
A/C & Heater Console Ducts
Transformation Set From Heating To Air Conditioning
Housing & Filters
Heater Blower & Coils
Cab Heating Coating Plug
2 Lever Backhoe Controls, Lever, Boot & Decals
2 Lever Backhoe Controls, Lever Tie-Rod Assembly
Jcb 2 Lever Backhoe Controls, Lower Tie-Rod Assembly
4 Lever Backhoe Controls, Console, Levers & Bellcrank
4 Lever Backhoe Controls, Upper Tie-Rod Assembly
4 Lever Backhoe Controls, Lower Tie-Rod Assembly
Iso 2 Lever Backhoe Controls, Levers, Boot & Decals
Iso 2 Lever Backhoe Controls, Tie-Rod Assembly
Locking Valve On Backhoe Lift Cylinder
Internal Fan
Egs Control, 20 & 40km/H (Power Shift)
Machine Part Air Conditioning Set
A/C Compressor Attaching Group
A/C Compressor
A/C Filter & Condenser Attaching Group
Seat Belts, 2" & 3"
Rotating Beacon
Rh Console With Instruments And Diagnostics
Antitheft
Cloth Seat & Attaching Hardware - Cabine
Air Ride Cloth Seat & Attaching Hardware - Cabine
Tool Kit
Safety Plates - Usa
Variation
Stabilizer Foot Ground (Center Pivot)
Stabilizer Foot Street Pad (Center Pivot)
Reversible Stabilizer Foot (Center Pivot)
4wd Steering Lock
Battery Connection
Fenders, Front
