MT-Pro 4.1 - Automotive Motortester Oscilloscope (program in Russian only)
MT-Pro 4.1 - Automotive Motortester Oscilloscope (in EN RU ES PT)
The price does not include delivery, as Depends on the region and the weight of the kit.
The program has next language: English, Russian, Spanish, Portuguese.
MT-Pro 4.1 Maximum kit - $595
MT-Pro 4.1 Start kit - $325
If you need it and write to me for details.
- Measuring unit, patch cord, power cable, hook, CD. For the diagnosis of electronic and electrical systems of a car
- BB capacitive sensor. For the diagnosis of classic ignition systems with a mechanical distributor or a common central explosive wire
- The sensor of the first cylinder. To synchronize the first cylinder and mark the parade of cylinders
- Vacuum sensor. To control the timing of the timing, diagnose the piston group, check the uniformity of the cylinders, search for misfire 2 pcs
- The probe is measuring. Universal measuring probe ending with a flexible needle 3 pcs
- Set of explosive capacitive sensors DIS-6. For the diagnosis of bipolar ignition systems (DIS) of 2, 4 and 6 cylinder engines
- Temporarily does not come with the kit! Pressure sensor (DD) PS100 at 100 bar + pressure sensor extension
- Test lead ending in two crocodile clips
- Measuring probe ending with two needle-needle outputs
- Inductive sensor Lx1. For first cylinder synchronization in individual ignition systems
- Inductive sensor Lx6. For the diagnosis of an individual ignition system of 6 cylinder engines
- Temporarily does not come with the kit! Vibration Sensor (DV). For monitoring the condition of nozzles in gasoline and diesel engines, high-pressure fuel equipment, determining the moment and duration of injection, it can also be used as a sensor for the strobe of a diesel engine
- Spark Polarity Detector (DP). To quickly determine the spark polarity of bipolar ignition systems (DIS) and to verify the correct connection of coils in distributor systems
- Temporarily does not come with the kit! Photosensor (PD). For the test, the efficiency of the cylinders in cases where the engine does not have a standard crankshaft position sensor or access to it is very difficult
- Six-needle measuring probe
- Hantek CC-650. For the diagnosis of battery, starter, alternator.
- Measuring unit, patch cord, power cable, hook. For the diagnosis of electronic and electrical systems of a car
- Vacuum sensor. To control the timing of the timing, diagnose the piston group, check the uniformity of the cylinders, search for misfires
- The probe is measuring. Universal measuring probe ending with a flexible needle.
- Activation Launch x431 EasyDiag Golo + ThinkDiag + Autel AP200 + 1 time/1 year
- CNH EST 8.7 ( Engineering Level) Diagnostic Procedures
- Piwis 3 ver 37.2 - 40.0 for Vas6154 clone and PT3G, Piwis 2, Porsche PET
- MTU DiaSys 2.70 (Windows 7 supported) dont need usb dongle
- Activation keys ODIS Service, Engineering
- Remote Install - Porsche Piwis II Piwis III, PET2, POSES, WDS
- Video step-by-step tutorials for delete EGR/DPF/DEF/UREA/SCR Cummins volvo cat detroit
- iDecoder 4.5 - for VIN/PIN, DPF/DTC/IMMO Off
- Remote install - Mercedes-Benz - Xentry DAS XUS SCN Vediamo Monaco WIS EPC
- Remote Install - Volvo Premium Tech Tool (PTT) + DevTool, EWD, Impact, Prosis, VIDA
- Cummins Insite 8 Activation - KG
- Remote Install VAG - ODIS-E, ODIS-S, VAS PC, ETKA, ELSA
- Remote install - GM Opel LAAM, GMIO, GMNA, GDS2, GlobalTis32, Tech2win, TIS 2000
- Cummins Insite 8 + Activation
- Remote install - PSA Peugeot Citroen - DiagBox, Service Box, LASER, Sedre
