Martin Welker
104
230,310
Mitsubishi Reach Truck ESR20N2 ESR23N2 EDR18N2 82824109 Spare Parts Catalog
Brand: Mitsubishi
Type of Machine: Reach Truck
Model: Mitsubishi ESR20N2 ESR23N2 EDR18N2 Forklift
Series Number: 82824109
Publication Date: 2018
Number of Pages: 170 Pages
001 01-11-0103 Labels - K
002 01-11-0118 Labels - MIT
003 01-11-0126 Labels - MIT ES
004 01-11-0197 Labels - UL USA
005 01-11-0282 Lateral part - 21.25 MITGN
006 01-11-0631 Bonnet - 21.25
007 01-11-0901 Bracket - C (1.5 ball)
008 01-11-0942 Bracket - Monitor R7016
009 01-11-2934 Overhead guard - 21.25 R7016
010 01-11-3072 Connect. Group, Bonnet - 16.25 21.25
011 01-11-3119 Connecting element - C (1.5 ball) 90mm
012 01-11-3145 Overhead guard - A ca. 1035mm R7016
013 01-11-3193 Connection group
014 01-11-3264 Connection group - hoods
015 01-11-4179 Cover
016 01-11-4179 Cover 2
017 01-11-4694 Cover - RAL7016 439x740
018 01-11-5357 Door - MITGN
019 01-11-7690 Instrument hood - RAL7016
020 01-11-8013 Knob
021 01-11-8182 Label, Batterie Size - 18 ES
022 01-11-8198 Label, Batterie Size - ES
023 01-11-8286 Label, Caution - ES
024 01-11-8295 Label, Cold Storage
025 01-11-8304 Label, Danger - ES
026 01-11-8315 Label, danger of crushing - ES
027 01-11-8448 Label, Jacking point - ES
028 01-11-8618 Label, Multipilot
029 01-11-9231 Label, Warning - ES
030 01-11-9232 Label, Warning - ES
031 01-11-9233 Label, Warning - ES
032 01-11-9234 Label, Warning - ES
033 01-11-9236 Label, Warning - ES
034 01-11-9237 Label, Warning - ES
035 01-11-9238 Label, Warning - ES
036 01-11-9240 Label, Warning - ES
037 01-11-9307 Label, Warning Label - ES
038 01-11-9875 Labels - ES
039 01-20-0228 Connect. Group, Drive
040 01-20-0618 Drive Traction - 36V 6,9kW
041 01-20-1472 Motor, Traction - 36V 6,9kW + brake
042 01-20-1530 Motor, Traction - AC 36V 6,9kW
043 01-20-1644 Pedal group
044 01-20-1672 Pedal group - twin
045 01-20-1803 Transmission
046 01-20-1809 Transmission
047 01-46-0208 Brake-Spring pressure - 24VDC 60Nm
048 01-46-0247 Pedal group
049 01-39-0050 Connection group - drive wheel
050 01-39-0179 Load wheel
051 01-39-0542 Wheel - castor wheel+bearing
052 01-39-0695 Wheel Tandem, Load - (5in x 3.62in)R7016
053 01-39-0967 Wheel, Supporting
054 01-54-0237 Drive, Steering - 0.7kW 36V 12V-Dual-S
055 01-54-1194 Wheel, Steering - blanko
056 01-72-0034 Connection group
057 01-72-0039 Connection group - Hydraulic unit
058 01-72-0123 Filter, Return line
059 01-72-0379 Hydr. Connection group - 21.25
060 01-72-0405 Hydr. Connection group - Oil reservior
061 01-72-1111 Pump motor - AC 36V 20kW
062 01-72-1170 Pump unit - AC 36V 20kW 22³ HP
063 01-72-1207 Pump, Hydraulic - 22cm³
064 01-72-1258 Reservoir, Oil - 30 L
065 01-72-1259 Reservoir, Oil - 30 L
066 01-72-1851 Valve- Control
067 01-72-1852 Valve- Control
068 01-04-0139 Bracket
069 01-04-0675 Cable, Power - E
070 01-04-0755 Cable, Truck - 21.25
071 01-04-0812 Cable, Truck - 565mm 1750mm
072 01-04-0900 Camera
073 01-04-0913 Camera - 51°CMOS
074 01-04-1095 Connection group
075 01-04-1096 Connection group
076 01-04-1318 Contactor rack - HP
077 01-04-1953 Drive control group, Steering
078 01-04-2505 El. system, Aux. - Opt. h3=242-450
079 01-04-3882 Fan
080 01-04-4122 Flashing beacon - yellow R7016
081 01-04-4634 Holder, Fuse
082 01-04-4643 Horn
083 01-04-5175 Key switch - 702
084 01-04-5181 Key switch - 702 rot
085 01-04-5374 Kit Cable - Pantograph DD Opt
086 01-04-5470 Kit Cable, Truck
087 01-04-5471 Kit Cable, Truck
088 01-04-5930 Monitor - 7,0 TFT 48V
089 01-04-6789 Multipilot - HF5
090 01-04-7250 Plate, Mounting Electrics - HP
091 01-04-7366 Pushbutton, Instrument Hood - C
092 01-04-7534 Sensor - battery gate
093 01-04-7535 Sensor - battery gate
094 01-04-7887 Switch, in Instrument Hood - D
095 01-04-8466 Working light - LED R7016
096 02-10-0033 Block, Roller
097 02-10-0034 Block, Roller
098 02-10-0080 Bracket
099 02-10-0132 Cable guide
100 02-10-0147 Cable guide - h3=272-450
101 02-10-0148 Cable guide - h3=272-450
102 02-10-0149 Cable guide - Pantograph
103 02-10-1131 Connect. elem., Mast - h3=320
104 02-10-1222 Mast, DZ - h3=320 RAL7016
105 02-10-1376 Connection group - h3 272
106 02-10-1463 Cover
107 02-10-1464 Cover
108 02-10-3192 Cylinder, Lift - A 1425 C1625 R7016
109 02-10-3251 Cylinder, Lift - A 2601 C 2892 R7016
110 02-10-3377 Mounting parts - Chain freelift cyl.
111 02-10-3429 Mounting parts - h3=242-347
112 02-10-3914 Cylinder, Lift - for h3 320 R7016
113 02-10-3915 Cylinder, Lift - for h3 320 R7016
114 02-10-3916 Cylinder, Lift - for h3 320 R7016
115 02-10-3917 Cylinder, Lift - for h3 320 R7016
116 02-10-3918 Cylinder, Lift - for h3 320 R7016
117 02-10-3919 Cylinder, Lift - for h3 320 R7016
118 02-10-4528 Roller, Supporting
119 02-10-4607 Sensor - h3=2420-4500
120 02-10-4663 Stop
121 02-10-4664 Stop
122 02-10-4670 Stop - h3=2420-4500
123 02-10-6788 Guard - for h3=272-..R7016
124 02-10-6845 Guide - h3=198-347
125 02-10-6849 Guide pulley
126 02-10-7240 Hydr. Connections, Mast - h3=242-450
127 02-10-7251 Hydr. Connections, Mast - h3=320
128 02-10-7252 Hydr. Connections, Mast - h3=320
129 02-10-8017 Kit Cable, Mast - Opt for h3 320-347
130 02-10-8035 Kit, Service Aux. - CABLE TENSIONER
131 02-10-8320 Load chain
132 02-10-8334 Load chain
133 02-10-8363 Load chain - 106Gl 2019mm
134 02-10-8408 Load chain - for h3=320
135 02-10-8939 Mast Triplex FFL - h3=320 RAL7016
136 02-04-0361 Eccentric bush - D75 d50x63
137 03-85-0294 Monitor
138 03-85-0296 Monitor
139 03-04-0340 Bracket - Batterierolle
140 03-04-0707 Lock, Battery - 21.25 R7016
141 03-04-0905 Roller, Battery
142 03-04-0963 Spacer - battery box spacer
143 03-04-1001 Support, Battery - 21.25 R9005
144 03-85-0294 Monitor 2
145 03-85-0296 Monitor 3
146 03-85-0294 Monitor 4
147 03-85-0296 Monitor 4
148 05-25-0031 Block, Cylinder
149 05-25-0056 Bush - cast iron
150 05-25-0604 Cylinder Hydr. - left
151 05-25-0612 Cylinder Hydr. - right
152 05-25-0653 Cylinder, Tilt
153 05-25-0810 Fixed Parts, Sideshift Carriage
154 05-25-1120 Fork - 2A 35x100x1070
155 05-25-1121 Fork - 2A 35x100x1070 cam.
156 05-25-2411 Forks, Pair - 2A 35x100x1070 w.ca.
157 05-25-2506 Frame - Pantograph DD
158 05-25-3235 Pantograph - DD
159 05-25-3250 Pantograph - DD ISS+-50 2A 825
160 05-25-3258 Pantograph - DD ISS 2A 825 R7016
161 05-25-3412 Roller, Supporting
162 05-25-3515 Sideshift Carriage - 2A 825+-50
163 05-25-3858 Valve - (DD)
