Mitsubishi Fuso Truck Canter Owners Manual MH996508 2011
Brand: Mitsubishi Fuso
Type of Manual: Owners Manual
Model: Mitsubishi Fuso Canter Truck
Part Number: MH996508
Publication Date: 2011
Number of Pages: 467 Pages
cover
1. Recommendation to drivers
Chassis number and engine number
Nameplate
Maintenance
MITSUBISHI genuine parts and recommended lubricants/hydraulic fluids
Fuels
AdBlue
Handling of the new vehicle
Preventing problems and accidents
When servicing the vehicles with 12-volt and 24-volt power circuits
Driving in foreign countries
2. Warning labels
Labels inside the cab
Exterior labels
3. Opening and closing
Starter key
Engine immobilizer (theft prevention device)
Doors
Keyless entry system
Entering and leaving the vehicle
Door window glass
Cargo deck gates
4. Seat and steering wheel adjustments
Seats
Seat belts
Supplemental restraint system (SRS) - air bag and seat belt pre-tensioner system
Steering wheel
5. Switches and controls
Arrangement of switches and controls
Starter switch
Starting the engine
Warming up the engine
Stopping the engine
Idling stop and start (ISS) system
Pedals
Gearshift lever
DUONIC
Parking brake lever
Combination switch
Hazard warning lamp switch
Fog lamps
Rearview mirrors
Mirror heater switch
Horn switch
Regeneration controlling DPF system
BlueTec® system
6. Instruments and warning lamps
Arrangement of instruments and warning lamps
Speedometer
Tachometer
Water temperature gauge
Fuel gauge
Urea level indicator
Multi-information system
Warning/indicator telltale
Warning/indicator lamps
7. Starting and driving
Precautions when setting the vehicle in motion
Precautions for driving
Tips for improving fuel economy
Braking
Antilock braking system (ABS)
On uphill and downhill roads
On rough roads and in bad weather
Parking
Loading cargo
8. Handling special equipment
Power take-off switch
Dump truck
4WD system - FG models
Limited slip differential
Hill start assist system
9. Heating and air conditioning
Front air outlets
Rear air outlets
Manual air conditioner
Fully automatic air conditioner
Heater
Rear air conditioner
10. Interior equipment and accessories
AM/FM radio
AM/FM radio and CD player
Using the radio
Cigarette lighter
Ashtrays
Coat hooks
Sun visors
Interior lamp
Step lamp
Fluorescent lamp
Inside rearview mirror
Small article compartments
11. In cold weather
Coolant
Engine oil
Fuels
When parking the vehicle after replenishing the AdBlue®
Other recommendations for cold weather operation
Installing tire chains
12. Simple inspection and service
General precautions for servicing the vehicle
Onboard tools
To reach the access opening
Tilting the cab
Pre-operational checks
Greasing
Oils and fluids
Filter elements
Draining water from fuel filter
Engine coolant - check and replacement
V-belts - check and adjustment
Steering wheel - check
Service brakes - check and adjustment
Parking brake - check and adjustment
Tires - check
Tire replacement
Wheel nuts - check and retightening
Tire rotation
Spare tire
Wiper blade - replacement
Windshield washer - fluid level check and refilling
Battery - check
Air filters - cleaning
Cleaning your vehicle
Intercooler - cleaning
Lamps - inspection for dirt and damage
13. Useful advices for emergencies
Possible failures, causes and remedies
Stopping your vehicle in an emergency
If the engine overheats
When a fuse has blown
When a lamp has burn out
When braking is sluggish
If the engine stalls while the vehicle is in motion
If a tire goes flat while the vehicle is in motion
When the battery has run down
If fuel tank becomes empty (Bleeding the fuel system)
If the urea tank becomes empty
Towing
14. Service data
Recommended lubricants/hydraulic fluids and quantities
Service data
15. Alphabetical index
cover
Nameplate
Maintenance
Fuels
AdBlue
2. Warning labels
Exterior labels
Starter key
Doors
Door window glass
Cargo deck gates
Seats
Seat belts
Steering wheel
Starter switch
Starting the engine
Stopping the engine
Pedals
Gearshift lever
DUONIC
Parking brake lever
Combination switch
Fog lamps
Rearview mirrors
Horn switch
BlueTec® system
Speedometer
Tachometer
Fuel gauge
Braking
Parking
Loading cargo
Dump truck
Front air outlets
Rear air outlets
Heater
AM/FM radio
Using the radio
Cigarette lighter
Ashtrays
Coat hooks
Sun visors
Interior lamp
Step lamp
Fluorescent lamp
11. In cold weather
Coolant
Engine oil
Fuels
Onboard tools
Tilting the cab
Greasing
Oils and fluids
Filter elements
Tires - check
Tire replacement
Tire rotation
Spare tire
Battery - check
Towing
14. Service data
Service data
- Mitsubishi Forklift Trucks FB20CA,FB25CA,FB28CA,FB30CA Parts Manual
- Mitsubishi Lift Trucks Diesel Engines S4E S4E2 S6E S6E2 42080-Up Parts Catalog
- MITSUBISHI S4K, S6K Engine Service Manual
- Mitsubishi Diesel Engines 4DQ3 4DQ3-T 4DQ5 03044-up 09658-up Parts Catalog
- Mitsubishi Forklift Trucks FB10TCA,FB14TCA,FB15TCA,FB18TCA Parts Manual
- MITSUBISHI S4S, S6S Engine Service Manual
- Mitsubishi Forklift Trucks FBP16 FBP18 FBP20 FBP25 FBP30 WEBN2685 Parts Catalog
- Mitsubishi Engine К21 К25 Repair Manual (used with Nissan forklift Mitusbishi Forklift)
- Misubishi Forklift GM 4.3L (G6) Engine Service Manual
- Mitsubishi Forklift FD25 Service Manual
- Mitsubishi Diesel Engines FD20 FD25 FD30 FD35A 11405-Up Parts Catalog
- Mitsubishi FG20K FD20K FG25K FD25K EF17B-15001-up EF18B-65001-up Parts Catalog
- Mitsubishi Forklift FG15 Service Manual
- Mitsubishi Forklift FGC25 Service Manual
- Mitsubishi Lift Trucks FG 20_23_25 FD 20_23_25 10001-Up_60001-Up Parts Catalog
