Momed80
150
35,046
Mitsubishi Fuso Truck Canter FEA5 FEB7 FEC7 Instructions Manual 2011
Brand: Mitsubishi Fuso
Type of Manual: Instructions Manual
Model: Mitsubishi Fuso Canter Europe Body Equipment Mounting Directives Truck
FEA01BL4SEA6, FEA01BL4SEA7, FEA01CL4SEA6, FEA01CL4SEA7, FEA01EL4SEA6, FEA01EL4SEA7, FEA51CL4SEA7
FEA51EL4SEA7, FEA5A1BL4SEA7, FEB01BL4SEA6, FEB01BL4SEA7, FEB01BL4SEA8, FEB01CL4SEA6, FEB01CL4SEA7
FEB01CL4SEA8, FEB01EL4WEA6, FEB01EL4WEA7, FEB01GL4SEA6, FEB01GL4SEA7, FEB01GL4SEA8, FEB71CL4SEA7
FEB71GL4SEA8, FEB71GL4WEA7, FEB71GL4WEA8, FEC71HL4SEA7, FEC71HL4SEA8, FEC71KL4SEA7, FEC71KL4SEA8
Publication Date: 2011
Number of Pages: 313 Pages
1 Introduction
1.1 Concept of these body/equipment mounting directives
1.2 Conventions
1.3 Vehicle safety
1.4 Operational safety
1.5 Note on copyright
2 General
2.1 Vehicle and model designations
2.2 Technical advice and contact persons
2.3 Letter of no objection
2.4 Product and vehicle information for body manufacturers
2.5 Product safety
2.6 Trademarks
2.7 Accident prevention
2.8 Recycling of components
2.9 Quality system
3 Planning the entire vehicle
3.1 Selecting the chassis
3.2 Vehicle modifications
3.3 Dimensions, weights, overall vehicle height
3.4 Tyres
3.5 Bolted and welded connections
3.6 Soundproofing
3.7 Exhaust system
3.8 Maintenance and repairs
3.9 Optional equipment
4 Technical threshold values for planning
4.1 Vehicle overhang and technical wheelbases
4.2 Weight distribution, CoG height, anti-roll bars
4.3 Steerability
4.4 Clearance for the basic vehicle and bodies
4.5 Permissible load on cab roof
4.6 Vehicle body incline
5 Damage prevention
5.1 Brake hoses/cables and lines
5.2 Welding work
5.3 Corrosion protection measures
5.4 Corrosion prevention in welding work
5.5 Bolted connections
5.6 Painting work
5.7 Chassis springs
5.8 Tilting the cab
5.9 Towing and tow-starting
5.10 Risk of fire
5.11 Electromagnetic compatibility (EMC)
5.12 Storing and handing over the vehicle
6 Modifications to the basic vehicle
6.1 General
6.2 Chassis frame material
6.3 Drilling work on the vehicle frame
6.4 Welding work on the vehicle frame
6.5 Reinforcement
6.6 Brake systems
6.7 Modifications to the wheelbase
6.8 Frame modifications
6.9 Mounting of implements and auxiliary components
6.10 Cab
6.11 Seats and bench seat
6.12 Power take-offs
6.13 Installation of propeller shafts
6.14 Exhaust system
6.15 Fuel system
6.16 Others
7 Construction of bodies
7.1 General
7.2 Mounting frame
7.3 Mounting frame attachment
7.4 Tank and dry-bulk bodies
7.5 Loading crane
7.6 Others
8 Electrics / Electronics
8.1 Electrical system
8.2 Electric wiring
8.3 Handling of electric/electronic equipment
8.4 Power supply
8.5 Charging/discharging balance
8.6 Electric circuit continuity check
8.7 Precautions for electric welding
8.8 Lighting
8.9 Mobile communications systems
9 Calculations
9.1 Axle load calculation
10 Technical Data
10.1 Model line-up
10.2 Specifications
10.3 Spring characteristic
10.4 Engine transmission assembly
10.5 Power take-offs
10.6 Other equipment
10.7 Other technical data
Index
