Momed80
150
35,046
Mitsubishi Fuso Truck 2017 CANTER FEC5 FEC7 FEC9 FECX FG Owners Manual MH994193 2016
Brand: Mitsubishi Fuso
Type of Manual: Owners Manual
Model: Mitsubishi Fuso 2017 CANTER FEC5 FEC7 FEC9 FECX FG Truck
Part Number: MH994193
Publication Date: 2017
Number of Pages: 528 Pages
1. Vehicle Information And Reference
Chassis And Engine Numbers
Vehicle Identification Number (Vin)
Maintenance
Fuels
Diesel Exhaust Fluid (Def)
Recording, Storing, And Handling Of The Vehicle Data
Reporting Safety Defects
Obtaining Service
2. Warning Labels
Interior Labels
Exterior Labels
3. Opening And Closing
Starter Key *
Engine Immobilizer Starter Key *
Doors
Central Door Locks
Keyless Entry System
Entering And Exiting The Vehicle
Door Window Glass
4. Seat And Steering Wheel Adjustments
Seats
Seat Belts
Steering Wheel
5. Switches And Controls
Location Of Switches And Controls
Starter Switch
Starting The Engine
Warming Up The Engine
Stopping The Engine
Pedals
Parking Brake Lever
Combination Switch
Duonic®
Cruise Control
Hazard Warning Lamp Switch
Front Fog Lamp Switch *
Van Body Dome Light Switch
Rearview Mirrors
Heated Mirror Switch *
Horn Switch
Transmission Pto *
Bluetec® System
Idle Limiting System *
6. Instrument And Warning Lamps
Instrument And Warning Lamp Locations
Speedometer
Tachometer
Coolant Temperature Gauge
Fuel Gauge
Def Level Indicator
Multi-Information System
Warning/Indicator Telltale
Warning/Indicator Lamps
7. Starting And Operating Your Vehicle
Precautions While Shifting The Vehicle Into Gear
Driving Precautions
Tips For Improving Fuel Economy
Braking
Antilock Braking System (Abs)
On Uphill And Downhill Roads
On Rough Roads And In Bad Weather
Parking
Vehicles With Limited Slip Differential *
Loading Cargo
8. 4wd Operation
Control And Indicator Lamps For 4wd Operation
Advice On Use Of The 4wd Mode
Precautions To Be Taken When Selecting The 4wd Mode
9. Climate Control Systems
Front Air Outlets
Rear Air Outlets *
Manual Air Conditioner *
Fully Automatic Air Conditioner *
Rear Heater *
Outside Air Inlets
10. Interior Equipment And Accessories
Cigarette Lighter
Ashtrays
Coat Hooks
Sun Visors
Interior Lamp
Step Lamp
Small Article Compartments
Using The Radio
Am/Fm Radio And Cd Player *
11. Cold Weather Care And Information
Coolant
Engine Oil
Fuels
When Parking The Vehicle After Replenishing The Def (Diesel Exhaust Fluid)
Other Recommendations For Cold Weather Operation
Installing Tire Chains
12. Simple Inspection And Service
General Precautions When Servicing The Vehicle
To Reach The Access Opening
Tilting The Cab
Pre-Operational Checks
Lubrication
Greasing
Oils And Fluids
Filter Elements
Draining Water From Fuel Filter
Engine Coolant – Inspection And Replacement
V-Belts – Inspection And Adjustment
Steering Wheel – Inspection
Service Brakes – Inspection
Parking Brake – Inspection And Adjustment
Tires – Inspection
Tire Replacement
Wheels And Wheel Nuts – Inspection And Retightening
Tire Rotation
Wiper Blade – Replacement
Windshield Washer – Fluid Level Inspection And Refilling
Battery – Inspection
Air Filters – Cleaning
Cleaning Your Vehicle
Intercooler – Cleaning
13. Roadside Emergency Information
Possible Causes And Solutions
Stopping Your Vehicle In An Emergency
If The Engine Overheats
When A Fuse Has Blown
When A Lamp Has Burned Out
When Braking Is Sluggish
If The Engine Stalls While The Vehicle Is In Motion
If A Tire Goes Flat While The Vehicle Is In Motion
When The Battery Has Discharged
If Fuel Tank Becomes Empty (Bleeding The Fuel System)
If The Def Tank Becomes Empty
Towing
When The Vehicle Becomes Stuck In Soft Ground
14. Vehicle Service Specifications
Recommended Lubricants/Hydraulic Fluids And Quantities
15. Maintenance Schedule
16. Alphabetical Index
Maintenance Record
