Momed80
150
35,046
Mitsubishi Fuso Truck 2014 CANTER FE FG Owners Manual MH996888 2012
Brand: Mitsubishi Fuso
Type of Manual: Owners Manual
Model: Mitsubishi Fuso 2014 CANTER FE FG Truck
Part Number: H996888
Publication Date: 2014
Number of Pages: 468 Pages
1. Recommendation To Drivers
Chassis And Engine Numbers
Vehicle Identification Number (Vin)
Maintenance
Fuels
Def (Diesel Exhaust Fluid)
Handling Of The New Vehicle
Reporting Safety Defects
Obtaining Service
2. Warning Labels
Labels Inside The Cab
Exterior Labels
3. Opening And Closing
Starter Key
Engine Immobilizer (Theft Prevention Device)
Doors
Central Door Locks
Keyless Entry System
Entering And Leaving The Vehicle
Door Window Glass
4. Seat And Steering Wheel Adjustments
Seats
Seat Belts
Steering Wheel
5. Switches And Controls
Arrangement Of Switches And Controls
Starter Switch
Starting The Engine
Warming Up The Engine
Stopping The Engine
Pedals
Parking Brake Lever
Combination Switch
Duonic®
Cruise Control
Hazard Warning Lamp Switch
Front Fog Lamp Switch
Van Body Dome Light Switch
Rearview Mirrors
Mirror Heater Switch
Horn Switch
Transmission Pto
Bluetec® System
6. Instruments And Warning Lamps
Arrangement Of Instruments And Warning Lamps
Speedometer
Tachometer
Water Temperature Gauge
Fuel Gauge
Def Level Indicator
Multi-Information System
Warning/Indicator Telltale
Warning/Indicator Lamps
7. Starting And Driving
Precautions When Setting The Vehicle In Motion
Precautions For Driving
Tips For Improving Fuel Economy
Braking
Antilock Braking System (Abs)
On Uphill And Downhill Roads
On Rough Roads And In Bad Weather
Parking
Vehicles With Limited Slip Differential
Loading Cargo
8. 4wd Operation
Control And Indicator Lamps For 4wd Operation
Advice On Use Of The 4wd Mode
Precautions To Be Taken When Selecting The 4wd Mode
9. Heating And Air Conditioning
Front Air Outlets
Rear Air Outlets
Manual Air Conditioner
Fully Automatic Air Conditioner
Rear Heater
Outside Air Inlets
10. Interior Equipment And Accessories
Cigarette Lighter
Ashtrays
Coat Hooks
Sun Visors
Interior Lamp
Step Lamp
Small Article Compartments
Using The Radio
Am/Fm Radio And Cd Player
11. In Cold Weather
Coolant
Engine Oil
Fuels
When Parking The Vehicle After Replenishing The Def (Diesel Exhaust Fluid)
Other Recommendations For Cold Weather Operation
Installing Tire Chains
12. Simple Inspection And Service
General Precautions For Servicing The Vehicle
To Reach The Access Opening
Tilting The Cab
Pre-Operational Checks
Lubrication
Greasing
Oils And Fluids
Filter Elements
Draining Water From Fuel Filter
Engine Coolant - Check And Replacement
V-Belts - Check And Adjustment
Steering Wheel - Check
Service Brakes - Check
Parking Brake - Check And Adjustment
Tires - Check
Tire Replacement
Wheel Nuts - Check And Retightening
Tire Rotation
Wiper Blade - Replacement
Windshield Washer - Fluid Level Check And Refilling
Battery - Check
Air Filters - Cleaning
Cleaning Your Vehicle
Intercooler - Cleaning
13. Useful Advice For Emergencies
Possible Failures, Causes And Remedies
Stopping Your Vehicle In An Emergency
If The Engine Overheats
When A Fuse Has Blown
When A Lamp Has Burned Out
When Braking Is Sluggish
If The Engine Stalls While The Vehicle Is In Motion
If A Tire Goes Flat While The Vehicle Is In Motion
When The Battery Has Run Down
If Fuel Tank Becomes Empty (Bleeding The Fuel System)
If The Def Tank Becomes Empty
Towing
When The Vehicle Becomes Stuck In Soft Ground
14. Service Data
Recommended Lubricants/Hydraulic Fluids And Quantities
Service Data
15. Maintenance Schedule
16. Alphabetical Index
