Hyundai
86
176,834
Mitsubishi Fuso Canter For Egypt Shop Manual 00ELT0061
Brand: Mitsubishi Fuso
Type of Manual: Shop Manual
Model: Mitsubishi Fuso Canter For Egypt
Part Number: 00ELT0061
Number of Pages: 447 Pages
GROUP 00 GENERAL
VEHICLE MODEL CODING SYSTEM
EQUIPMENT MODEL CODING SYSTEM
POWER TRAIN TABLE
HOW TO READ THIS MANUAL
CHASSIS NUMBER, ENGINE NUMBER AND NAME PLATE
PRECAUTIONS FOR MAINTENANCE OPERATION
JACKING UP
TABLE OF STANDARD TIGHTENING TORQUES
GROUP 21 CLUTCH
SPECIFICATIONS
STRUCTURE AND OPERATION
TROUBLESHOOTING
ON-VEHICLE INSPECTION AND ADJUSTMENT
CLUTCH PEDAL
CLUTCH MASTER CYLINDER
CLUTCH HOSE
CLUTCH PROPER
CLUTCH CONTROL
GROUP 22 MANUAL TRANSMISSION
SPECIFICATIONS
TROUBLESHOOTING
REMOVAL AND INSTALLATION OF TRANSMISSION
GEAR SHIFTER UPPER
REAR COVER AND PARKING BRAKE
REVERSE IDLER GEAR
TRANSMISSION BODY
DRIVE PINION
MAINSHAFT
COUNTERSHAFT
TRANSMISSION CONTROL
BEARING PULLER AND INSTALLER
GROUP 25 PROPELLER SHAFT
SPECIFICATIONS
TROUBLESHOOTING
REMOVAL AND INSTALLATION OF PROPELLER SHAFT
PROPELLER SHAFT
GROUP 26 FRONT AXLE
SPECIFICATIONS
TROUBLESHOOTING
WHEEL HUB AND BRAKE DRUM
KNUCKLE AND KINGPIN, FRONT AXLE
TIE ROD
GROUP 27 REAR AXLE
SPECIFICATIONS
TROUBLESHOOTING
AXLE HOUSING
REDUCTION AND DIFFERENTIAL
GROUP 31 WHEEL, TIRE
SPECIFICATIONS
TROUBLESHOOTING
WHEEL, TIRE
GROUP 33 FRONT SUSPENSION
TROUBLESHOOTING
STABILIZER <FE85>
SHOCK ABSORBER
LEAF SPRING
GROUP 34 REAR SUSPENSION
TROUBLESHOOTING
STABILIZER <FE85>
SHOCK ABSORBER
LEAF SPRING
GROUP 35 BRAKE
SPECIFICATIONS
TROUBLESHOOTING
VACUUM PUMP
BRAKE MASTER CYLINDER
BRAKE PEDAL AND VACUUM BOOSTER
FRONT DRUM BRAKE
REAR DRUM BRAKE
GROUP 36 PARKING BRAKE
SPECIFICATIONS
TROUBLESHOOTING
PARKING BRAKE CONTROL
PARKING BRAKE
GROUP 37 STEERING
SPECIFICATIONS
TROUBLESHOOTING
STEERING COLUMN
POWER STEERING GEAR ASSEMBLY AND DRAG LINK
POWER STEERING OIL PUMP
POWER STEERING OIL TANK
GROUP 41 BUMPER, FRAME
SPECIFICATIONS
FRONT BUMPER
FRAME
GROUP 42 CAB MOUNTING, TILT
SPECIFICATIONS
TROUBLESHOOTING
REMOVAL AND INSTALLATION OF CAB
FRONT CAB MOUNTING
REAR CAB MOUNTING
CAB TILT LINK <FE84>
CAB STAY <FE84>
GROUP 43 DOOR
SPECIFICATIONS
TROUBLESHOOTING
FRONT DOOR
GROUP 51 EXTERIOR
TROUBLESHOOTING
MIRROR
WIPER AND WASHER
FRONT COVER
FRONT GRILLE, FRONT CORNER PANEL AND HEADLAMP
STEP
WHEEL HOUSE
WINDOW GLASS
GROUP 52 INTERIOR
SEAT
SEAT BELT
INSTRUMENT PANEL
TRIM AND SCUFF PLATE
HEAD LINING
GROUP 55 HEATER, VENTILATION
SPECIFICATIONS
TROUBLESHOOTING
HEATER CONTROL
AIR DUCT
HEATER UNIT, BLOWER
