Mitsubishi Forklift SBP16N3 Chassis Mast Options Internal Hosing Europe Parts Catalog DOC00048959
Brand: Mitsubishi
Type of Machine: Forklift
Region: Europe
Model: Mitsubishi SBP16N3 Chassis Mast Options Internal Hosing Europe
Part Number: DOC00048959
Number of Pages: 516 Pages
ACCESSORIES
ACCUMULATOR PLUG
COMPUTER RACK
LIST BRACKET
ACCESSORY RACK
BUZZER
BATTERY CHANGING DEVICE
LI-ION KIT
MAST, LOOSE PARTS, STANDARD
MAST, LOOSE PARTS, INITIAL LIFT
MAST, LOOSE PARTS, STRADDLE
BATTERY SHIMMING
ELECTRIC PANEL
ELECTRIC PANEL, SWE
ELECTRIC PANEL, PLATFORM
ELECTRIC PANEL, PLATFORM, SWE
FAN
FAN (RL638286)
CHARGING CONNECTOR, 150Ah BATTERY
CHARGING CONNECTOR, 500Ah BATTERY
INTERNAL CHARGER POWER CABLE, LEAD ACID, EURO
INTERNAL CHARGER POWER CABLE, LEAD ACID, UK
INTERNAL CHARGER POWER CABLE, LEAD ACID, DK
INTERNAL CHARGER POWER CABLE, LEAD ACID, SUI
ON-BOARD CHARGER POWER CABLE, LI-ION, EURO
ON-BOARD CHARGER POWER CABLE, LI-ION, UK
ON-BOARD CHARGER POWER CABLE, LI-ION, DK
ON-BOARD CHARGER POWER CABLE, LI-ION, SUI
INTERNAL CHARGER, 30A
POWER SUPPLY, 12V 150W
FORK CARRIAGE
FORK CARRIAGE, W_ LOAD BACKREST
FORK CARRIAGE, INITIAL LIFT
FORK CARRIAGE, W_ LOAD BACKREST, INITIAL LIFT
LIFTING CARRIAGE, SIMPLEX, DUPLEX, DUPLEX W_ FREE LIFT, STRADDLE
LIFTING CARRIAGE, TRIPLEX, STRADDLE
LIFTING CARRIAGE, TRIPLEX W_ FREE LIFT
LEVERAGE, SIMPLEX & DUPLEX
LEVERAGE, TRIPLEX
LOAD SUPPORT, WO_ STRADDLE
LOAD SUPPORT, STRADDLE
MAIN ASSEMBLY
MAIN ASSEMBLY, INITIAL LIFT
MAIN ASSEMBLY, STRADDLE
TRACTOR UNIT
TRACTOR UNIT, SWE
TRACTOR UNIT, SIDE SUPPORT
TRACTOR UNIT, INITIAL LIFT
TRACTOR UNIT, INITIAL LIFT, SWE
TRACTOR UNIT, INITIAL LIFT + PLATFORM
TRACTOR UNIT, INITIAL LIFT + PLATFORM, SWE
TRACTOR UNIT, PLATFORM
TRACTOR UNIT, PLATFORM, SWE
TRACTOR UNIT, PLATFORM, SIDE SUPPORT
PLATFORM
PLATFORM SENSOR
SIDE SUPPORT SENSOR
BATTERY COVER ASSEMBLY
DECALS
HINGE, RIGHT
HINGE, LEFT
TILLER ARM
TILLER HEAD
TILLER, TILLER HEAD
TILLER ASSEMBLY
TILLER ASSEMBLY, PLATFORM
TILLER ASSEMBLY, Z-SHAPE
TILLER FOOT
TILLER FOOT, PLATFORM
JOINT, TILLER FASTENER
SWITCH, KEY, W_ PIN-CODE
KEYBOARD
KEYBOARD, PLATFORM
HYDRAULIC AGGREGATE, 1.0T
HYDRAULIC AGGREGATE, 1.2-1.4T
HYDRAULIC AGGREGATE, 1.6T
HYDRAULIC SIDE SUPPORT, RIGHT
HYDRAULIC SIDE SUPPORT, LEFT
CENTER CYLINDER, SIMPLEX & DUPLEX, 1.0T
FREE LIFT CYLLINDER, SIMPLEX & DUPLEX, 1.0T
CENTER CYLINDERS HYDRAULIC PIPE, DUPLEX W_ FREE LIFT
SIDE CYLINDERS, SIMPLEX
SIDE CYLINDERS, DUPLEX
SIDE CYLINDERS, DUPLEX W_ FREE LIFT
SIDE CYLINDERS, TRIPLEX
SIDE CYLINDERS, TRIPLEX W_ FREE LIFT
SIDE CYLINDERS HOSE, TRIPLEX W_ FREE LIFT
STANDARD LIFT CYLINDER (RL467826)
HYDRAULIC SYSTEM, VALVE ELEMENT + HOSES
VALVE BLOCK
MAST UNIT, SIMPLEX, 1.0T
MAST UNIT, SIMPLEX, 1.2-1.6T
MAST UNIT, DUPLEX, 1.0T
MAST UNIT, DUPLEX, 1.2T
MAST UNIT, DUPLEX, 1.4-1.6T
MAST UNIT, DUPLEX W_ FREE LIFT, 1.2T
MAST UNIT, TRIPLEX W_ FREE LIFT, 1.2-1.6T
MAST UNIT, SIMPLEX, 1.2-1.6T INITIAL LIFT
MAST UNIT, DUPLEX W_ FREE LIFT, 1.4-1.6T
MAST UNIT, TRIPLEX, 1.2-1.6T INITIAL LIFT
MAST UNIT, TRIPLEX W_ FREE LIFT, 1.2-1.6T SIDE SUPPORT
MAST UNIT, DUPLEX, 1.6T STRADDLE
MAST UNIT, TRIPLEX, 1.6T STRADDLE
MAST GUARD ASSEMBLY
SIDE CYLINDER CHAIN
LIFT CARRIAGE CHAIN, TRIPLEX
CENTER CYLINDER CHAIN, DUPLEX, 1.0T
FREE LIFT CYLINDER CHAIN
INTERMEDIATE MAST CHAIN, TRIPLEX, 1.2-1.6T
SPEED REDUCTION SENSOR, DUPLEX & TRIPLEX
SPEED REDUCTION SENSOR, DUPLEX W_ FREE LIFT
SPEED REDUCTION SENSOR, TRIPLEX W_ FREE LIFT
CHAIN YOKE, SIMPLEX
CHAIN YOKE, DUPLEX
CHAIN WHEEL, SIMPLEX
CHAIN WHEEL, TRIPLEX
CHAIN WHEEL, TRIPLEX & TRIPLEX W_ FREE LIFT
BRACKET, CHAIN WHEEL
SIDE GUIDE ROLLER
PLUG, LEFT, DUPLEX W_ FREE LIFT SIDE CYLINDER
PLUG, RIGHT, DUPLEX W_ FREE LIFT SIDE CYLINDER
DRIVING UNIT
DRIVING UNIT, COLD STORAGE
DRIVING UNIT (RL657226)
GEAR
DRIVE WHEEL
LOAD WHEEL, SINGLE
LOAD WHEEL, TANDEM
CASTER WHEEL, STANDARD
CASTER WHEEL, STRADDLE
