Mitsubishi Forklift RB16N2 Chassis Mast Options Internal Hosing Europe Parts Catalog DOC00032598
Brand: Mitsubishi
Type of Machine: Forklift
Region: Europe
Model: Mitsubishi RB16N2 Chassis Mast Options Internal Hosing Europe
Part Number: DOC00032598
Number of Pages: 594 Pages
MAIN ASSEMBLY
OPERATOR COMPARTMENT, STANDARD CABIN
OPERATOR COMPARTMENT, COLD CABIN
OPERATOR COMPARTMENT, COLD CABIN (RL624641)
OPERATOR COMPARTMENT, COLD CABIN (RL624640)
OPERATOR COMPARTMENT, COLD CABIN - FRAME PARTS
OPERATOR COMPARTMENT, COLD CABIN - DOOR
CONTROL PANEL (STANDARD)
CONTROL PANEL (DUAL PEDAL)
DUAL PEDAL - 1
DUAL PEDAL - 2
DUAL PEDAL - 3
HEATER I (COLD CABIN)
HEATER II (COLD CABIN)
STEERING UNIT
STEERING WHEEL, ROCKING PART
STEERING WHEEL, ROCKING PART, COLD STORAGE
STEERING WHEEL, PRE-ASSEMBLY
STEERING WHEEL, PRE-ASSEMBLY, COLD STORAGE
STEERING WHEEL AND BRODIE KNOB
SWITCH
SWITCH, KEY, W_ PIN-CODE
DUAL JOYSTICK ASSEMBLY, WO_ FR
DUAL JOYSTICK, WO_ FR
DUAL JOYSTICK ASSEMBLY, W_ FR
DUAL JOYSTICK, W_ FR
DECALS
DECALS, COLD CABIN
CHASSIS ASSEMBLY - 1
CHASSIS ASSEMBLY - 2
ACTIVE SWAY CONTROL
BATTERY COVER, 465Ah
BATTERY COVER, 620Ah
BATTERY COVER, 775Ah
BATTERY LATCH, STANDARD
BATTERY LATCH, OPTION
BATTERY ROLLER MAIN ASSEMBLY
BATTERY ROLLER
BATTERY ROLLER (RL465065)
EL-PANEL COVER, STANDARD
EL-PANEL COVER, LI-ION STANDARD
EL-PANEL COVER, COLD STORAGE
FASTENER, WIRE SET BRAKE
FASTENER, WIRE SET CONNECTOR
LATCH
LOWERING STOP 500mm
MACHINERY SHIELD
PROTECTIVE COVER
SEAT PLATE
CUSHION
SENSOR PLATE ASSEMBLY
STEP (RL618936)
STEP (RL618931)
EL-PANEL, W_ 400A CONTROLLER (STANDARD)
EL-PANEL, W_ 400A CONTROLLER (STANDARD) - EN1175
EL-PANEL, W_ 400A CONTROLLER (COLD CABIN)
EL-PANEL, W_ 400A CONTROLLER (COLD CABIN) - EN1175
EL-PANEL, W_ 500A CONTROLLER (STANDARD)
EL-PANEL, W_ 500A CONTROLLER (STANDARD) - EN1175
EL-PANEL, W_ 500A CONTROLLER (COLD CABIN)
EL-PANEL, W_ 500A CONTROLLER (COLD CABIN) - EN1175
CONVERTER EL-PANEL
VOLTAGE CONVERTER
AUDIO SYSTEM
BATTERY CABLE
BLUE SPOT LIGHT
DRIVING LIGHT
FUSE HOLDER
POWER OUTLET DC_DC 24V, 200W
READING LIGHT
VCM WITH SOFTWARE
HYDRAULIC SYSTEM, 4-VALVE
HYDRAULIC SYSTEM, 5-VALVE
PRESSURE SENSOR
4-VALVE BLOCK
5-VALVE BLOCK
PUMP MOTOR ASSEMBLY
PUMP MOTOR 30V 10KW
PUMP MOTOR 30V 14KW
PUMP, 16cc & 19cc
GASKET KIT
OIL TANK
OIL TANK FILTER
FREE LIFT CYLINDER, i20TF
GASKET HOLDER, i20TF
GASKET HOLDER, Ø40
GASKET HOLDER, Ø45
REACH CYLINDER
FRAME PRESSURE HOSE
DRIVE UNIT WITH MOTOR
TRACTION MOTOR 30V 7kW
TRACTION MOTOR 30V 7,5kW
GEAR (RL636920)
GEAR (RL618590)
GEAR (RL618235)
BRAKE
AUX HOSE FASTENERS, i20TF (STANDARD)
AUX HOSE FASTENERS, i20TF (COLD STORAGE)
HOSES AND CHAINS i16TF (STANDARD)
HOSES AND CHAINS i16TF (COLD STORAGE)
CHAINS 16TF, INTERMEDIATE MAST
CHAINS 16TF, LIFTING CARRIAGE
HOSES AND CHAINS i20TF, 4800-7000 (STANDARD)
HOSES AND CHAINS i20TF, 7500-13000 (STANDARD)
HOSES AND CHAINS i20TF, 4800-7000 (COLD STORAGE)
HOSES AND CHAINS i20TF, 7500-13000 (COLD STORAGE)
PISTON & FREELIFT CYLINDER, i16TF
PISTON & FREELIFT CYLINDER, i20TF
HEIGHT SENSOR, i16TF_i20TF
SIDE SHIFT AND TILT SENSOR
SIDESHIFT AND TILT SENSOR CENTERING ASSEMBLY
SIDESHIFT AND TILT SENSOR WIRE SET
PALLET SENSOR
BEARING CLEARANCE ROLLER
HOSE ROLLER, WO_ MAST CABLE
HOSE ROLLER, WO_ MAST CABLE (COLD STORAGE)
HOSE ROLLER, W_ MAST CABLE
HOSE ROLLER, W_ MAST CABLE (COLD STORAGE)
LIFING CARRIAGE (STANDARD)
LIFTING CARRIAGE (RL484007-P)
LIFTING CARRIAGE (REINFORCED)
LIFING CARRIAGE (RL605831)
GASKET HOLDER
LIFTING CARRIAGE (SIDE SHIFTER)
LIFTING CARRIAGE (RL620814)
SIDE SHIFT FORK POSITIONER
TELESCOPIC FORK
FORK (RL624579)
LOAD SUPPORT
FORK ASSY
REACH CARRIAGE (WIDE FORK)
REACH CARRIAGE (NARROW FORK)
DRIVE WHEEL
LOAD WHEEL
LOAD WHEEL BRAKE
BRAKE ASSEMBLY
ABBOT
ABBOT, GPRS
ABBOT, GPRS+iBUTTON
ABBOT, WLAN
ABBOT, WLAN+iBUTTON
ACCESSORY RACK, STANDARD
ACCESSORY RACK, DRIVE IN
ACCESSORY RACK, COLD CABIN
ARM REST
BATTERY CHANGING DEVICE, 465Ah
BATTERY CHANGING DEVICE, 620Ah
BATTERY CHANGING DEVICE, 775Ah
SIDE GUIDE ROLLER
BRACKET, MOUNTING
BRACKET, ONLY PROTECTIVE COVER
ACCESSORIES
BRACKET, WITH ACCESSORIES
BUZZER
CABLE HOLDER CASE (FORK CAMERA)
CAMERA ASSY
COMPUTER RACK
DRIVING SEAT, MSG20
DRIVING SEAT, MSG20, ARM REST
DRIVING SEAT, MSG20, SAFETY BELT
DRIVING SEAT, MSG65
DRIVING SEAT, MSG65, W_ LEFT ARM REST
DRIVING SEAT, MSG65, W_ VINYL BACK REST
DRIVING SEAT, MSG75
FAN
FIRE EXTINGUISHER
FIRE EXTINGUISHER ASSEMBLY
CABIN FAN
FAN, 48V
HYDRAULIC SYSTEM, ADDITIONAL, 5-VALVE
INSULATOR
INTERCOM SYSTEM
MIRROR, WIDE ANGLE
OHG PROTECTIVE COVER
DRIVER SHOULDER SHIELD
WARNING LIGHT, RUBBER BASE
WARNING LIGHT, STROBE
WINDSHIELD WIPER
WORKING LIGHT (RLMX100144)
WORKING LIGHT (RLMX100130)
WRITING PAD
