Mitsubishi Forklift OPB20N2 Chassis Mast Options Internal Hosing Europe Parts Catalog DOC00035790
Brand: Mitsubishi
Type of Machine: Forklift
Region: Europe
Model: Mitsubishi OPB20N2 Chassis Mast Options Internal Hosing Europe
Part Number: DOC00035790
Number of Pages: 548 Pages
ACCESSORIES
BATTERY LOCKING, FIXED
BATTERY LOCKING, OPEN TO LEFT - OPTION
BATTERY LOCKING, OPEN TO RIGHT - OPTION
BATTERY LOCKING, LI-ION - OPTION
BATTERY LOCK LEVERAGE
BATTERY CHANGING DEVICE, 465Ah - ACCESSORY
BATTERY CHANGING DEVICE, 620Ah - ACCESSORY
BATTERY CONNECTOR
BATTERY ROLLER
DRIVING SEAT (NEW)
DRIVING SEAT (OLD)
STEERING, 465Ah (FIXED PLATFORM)
STEERING, 620Ah (FIXED PLATFORM) - OPTION
STEERING (LIFT PLATFORM)
GAS SPRING
POWER SUPPLY 12V - ACCESSORY
POWER SUPPLY 24V - ACCESSORY
POWER SUPPLY 5V USB - ACCESSORY
ACCESSORY RAIL - ACCESSORY
STEPS
STORAGE UNIT (FIXED PLATFORM) - ACCESSORY
BUZZER - ACCESSORY
FIRE EXTINGUISHER ASSEMBLY
PICKING TRAY (LIFT PLATFORM) - ACCESSORY
ACCESSORY RACK, 1 PC, C-SIZE, RAM MOUNT - ACCESSORY
ACCESSORY RACK, 2 PCS, C-SIZE, RAM MOUNT - ACCESSORY
ACCESSORY RACK, 1 PC, D-SIZE, RAM MOUNT - ACCESSORY
ACCESSORY RACK, 2 PCS, D-SIZE, RAM MOUNT - ACCESSORY
ACCESSORY RACK, 1 PC, D-SIZE, RAM MOUNT ON TRAY - ACCESSORY
ACCESSORY RACK, 2 PCS, D-SIZE, RAM MOUNT ON TRAY - ACCESSORY
BUMPER (FRONT GUARD) - ACCESSORY
BUMPER (HEAVY BUMPER) - ACCESSORY
WRAPPING FOIL HOLDER (LOAD BACKREST) - ACCESSORY
WRAPPING FOIL HOLDER (RAIL) - ACCESSORY
WRAPPING FOIL HOLDER (RISING PLATFORM) - ACCESSORY
LI-ION BATTERY KIT (LIFT PLATFORM, INTEGRATED) - OPTION
LI-ION BATTERY KIT (FIXED PLATFORM, INTEGRATED) - OPTION
DRIVING LIGHT (LIFT PLATFORM)
DRIVING LIGHT (FIXED PLATFORM)
BLUE SPOT LIGHT (LIFT PLATFORM)
BLUE SPOT LIGHT (FIXED PLATFORM)
RED SPOT LIGHT (LIFT PLATFORM)
RED SPOT LIGHT (FIXED PLATFORM)
EL-PANEL (LOW LIFT)
EL-PANEL (LOW LIFT) - OLD
EL-PANEL (MAST LIFT)
EL-PANEL (MAST LIFT) - OLD
EL-PANEL (RL629754)
FAN
FORK CARRIAGE, STANDARD
FORK CARRIAGE, COLD STORAGE - OPTION
FORK CARRIAGE (540x1150mm, X=960) EUR PALLET - STANDARD
FORK CARRIAGE (540x2375mm, X=1465) 2 EUR PALLETS - OPTION
FORK CARRIAGE (540x3600mm, X=2500) 3 EUR PALLETS - OPTION
FORK CARRIAGE (540x1000mm, X=785) UK PALLET - OPTION
FORK CARRIAGE (540x2375mm, X=1670) 2 UK PALLETS - OPTION
FORK CARRIAGE (660x2375mm, X=1670) 2 UK PALLETS - OPTION
FORK CARRIAGE (520x1465mm, X=960) 2 TROLLEYS - OPTION
FORK CARRIAGE (520x2165mm, X=1050) 3 TROLLEYS - OPTION
FORK CARRIAGE (520x2165mm, X=1465) 3 TROLLEYS - OPTION
FORK CARRIAGE (520x2900mm, X=1800) 4 TROLLEYS - OPTION
FORK CARRIAGE (VARIABLE) SPECIAL PALLET - OPTION
FORK CARRIAGE (520x1800mm, X=1260) - OPTION
FORK CARRIAGE (520x2375mm, X=1465) - OPTION
FORK SPRING ASSEMBLY
FORK CROSSWIDE HANDLING - ACCESSORY
LEVERAGE ASSEMBLY
LEVER ASSEMBLY
SHAFT FOR LEVER (BASIC)
SHAFT FOR LEVER (COLD STORAGE) - OPTION
PUSH ROD (L=877, X=960mm, NORMAL) - STANDARD
PUSH ROD (L=702, X=960mm, NORMAL) - OPTION
PUSH ROD (L=1717, X=1800mm, HEAVY) - OPTION
PUSH ROD (L=2417, X=2500, HEAVY) - OPTION
PUSH ROD (L=967, X=1050, HEAVY) - OPTION
PUSH ROD (L=1382, X=1465, HEAVY) - OPTION
PUSH ROD (L=1587, X=1670, HEAVY) - OPTION
PUSH ROD (X=785-2500, HEAVY) - OPTION
PUSH ROD (L=1177, X=1260, HEAVY) - OPTION
CHASSIS, 465Ah (LOW LIFT) - STANDARD
CHASSIS, 620Ah (LOW LIFT) - OPTION
CHASSIS, 465Ah (MAST LIFT) - STANDARD
CHASSIS, 620Ah (MAST LIFT) - OPTION
CHASSIS (LOW LIFT)
CHASSIS (MAST LIFT)
CHASSIS, TRACTOR UNIT 465Ah
CHASSIS, TRACTOR UNIT 600Ah
HYDRAULIC SYSTEM, LOW LIFT WITHOUT PRESSURE SENSOR (FIXED PLATFORM)
HYDRAULIC SYSTEM, LOW LIFT WITH PRESSURE SENSOR (FIXED PLATFORM) - OPTION
HYDRAULIC SYSTEM, LOW LIFT WITHOUT PRESSURE SENSOR (LIFT PLATFORM)
HYDRAULIC SYSTEM, LOW LIFT WITH PRESSURE SENSOR (LIFT PLATFORM) - OPTION
HYDRAULIC SYSTEM, MAST LIFT WITHOUT PRESSURE SENSOR (FIXED PLATFORM)
HYDRAULIC SYSTEM, MAST LIFT WITH PRESSURE SENSOR (FIXED PLATFORM) - OPTION
HYDRAULIC SYSTEM, MAST LIFT WITHOUT PRESSURE SENSOR (LIFT PLATFORM)
HYDRAULIC SYSTEM, MAST LIFT WITH PRESSURE SENSOR (LIFT PLATFORM) - OPTION
HYDRAULIC AGGREGATE, MINI 3G 2,2kW
HYDRAULIC AGGREGATE, MINI 3G 2,2kW WITH VALVE BLOCK
HYDRAULIC AGGREGATE, MICRO POWER PACK 2G WITH 1,2kW (FOR LOW LIFT WITHOUT PRESSURE SENSOR)
HYDRAULIC AGGREGATE, MICRO POWER PACK 2G WITH 1,2kW (FOR LOW LIFT WITH PRESSURE SENSOR)
HYDRAULIC AGGREGATE, LOW LIFT WITH PRESSURE SENSOR - FIXED PLATFORM
HYDRAULIC AGGREGATE, LOW LIFT WITHOUT PRESSURE SENSOR
LIFT CYLINDER, 850mm
LIFT CYLINDER, 1200mm - OPTION
CYLINDER (LIFT PLATFORM)
CYLINDER (LOW LIFT)
MAIN ASSEMBLY (LOW LIFT)
MAIN ASSEMBLY (MAST LIFT)
TRACTOR UNIT (FIXED PLATFORM)
TRACTOR UNIT (LIFT PLATFORM)
PLATFORM
INSTRUMENT PANEL, KEY+DISPLAY (FIXED PLATFORM)
INSTRUMENT PANEL, KEY+DISPLAY (LIFT PLATFORM)
INSTRUMENT PANEL, PIN KEY+PIN PAD+DISPLAY (FIXED PLATFORM)
INSTRUMENT PANEL, PIN KEY+PIN PAD+DISPLAY (LIFT PLATFORM)
INSTRUMENT PANEL, KEY+AURORA (FIXED PLATFORM)
INSTRUMENT PANEL, KEY+AURORA (LIFT PLATFORM)
INSTRUMENT PANEL, PIN KEY+AURORA (FIXED PLATFORM)
INSTRUMENT PANEL, PIN KEY+AURORA (LIFT PLATFORM)
INSTRUMENT PANEL, KEY+DISPLAY, LI-ION (FIXED PLATFORM)
INSTRUMENT PANEL, KEY+DISPLAY, LI-ION (LIFT PLATFORM)
INSTRUMENT PANEL, PIN KEY+PIN PAD+DISPLAY, LI-ION (FIXED PLATFORM)
INSTRUMENT PANEL, PIN KEY+PIN PAD+DISPLAY, LI-ION (LIFT PLATFORM)
INSTRUMENT PANEL, KEY+AURORA, LI-ION (FIXED PLATFORM)
INSTRUMENT PANEL, KEY+AURORA, LI-ION (LIFT PLATFORM)
INSTRUMENT PANEL, PIN KEY+AURORA, LI-ION (FIXED PLATFORM)
INSTRUMENT PANEL, PIN KEY+AURORA, LI-ION (LIFT PLATFORM)
KEYBOARD, PIN CODE UNIT
BATTERY COVER, 465Ah (FIXED PLATFORM)
BATTERY COVER, 620Ah (FIXED PLATFORM)
BATTERY COVER, 465Ah (LIFT PLATFORM)
BATTERY COVER, 620Ah (LIFT PLATFORM)
MACHINERY SHIELD ASSEMBLY
COVER PLATE
PLATE WITH FAN
PAPER HOLDER
PICKING TRAY
BACK PLATE
COVER PLATE
SWITCH
BACK REST
LIMIT SWITCH
OPERATOR COMPARTMENT, WITHOUT FLOOR SWITCH
OPERATING COMPARTMENT, WITH FLOOR SWITCH - OPTION
PEDAL, FLOOR SWITCH ASSEMBLY
STEERING WHEEL
EMERGENCY STOP - OPTION
EMERGENCY STOP, LI-ION - OPTION
WARNING LIGHT, WITHOUT 2ND LEVEL OR LOAD BACKREST - ACCESSORY
WARNING LIGHT, WITH 2ND LEVEL OR LOAD BACKREST - ACCESSORY
DECAL
MAST ASSEMBLY (LIFT PLATFORM)
MAST ASSEMBLY (FIXED PLATFORM)
LIFT CHAIN, 850mm
LIFT CHAIN, 1200mm - OPTION
LIFTING CARRIAGE (570x1150, X=785) - STANDARD
LIFTING CARRIAGE (540x1150, X=785) - OPTION
LIFTING CARRIAGE (570x1450, X=785) - OPTION
LIFTING CARRIAGE (540x1450, X=785) - OPTION
LIFTING CARRIAGE (540x950, X=635) - OPTION
LIFTING CARRIAGE (570x950, X=635) - OPTION
LIFTING CARRIAGE (540x2165, X=1050) - CSM
MAST (LIFT HEIGHT 850mm, FW570, X=785) - STANDARD
MAST (LIFT HEIGHT 1200mm, FW540, X=635) - OPTION
MAST (LIFT HEIGHT 850mm, FW540, X=635) - OPTION
MAST (LIFT HEIGHT 1200mm, FW540, X=785) - OPTION
MAST (LIFT HEIGHT 850mm, FW540, X=785) - OPTION
MAST (LIFT HEIGHT 1200mm, FW570, X=635) - OPTION
MAST (LIFT HEIGHT 850mm, FW570, X=635) - OPTION
MAST (LIFT HEIGHT 1200mm, FW570, X=785) - OPTION
MAST (LIFT HEIGHT 850mm, FW540, X=1050) - CSM
LOAD SUPPORT, 850mm - ACCESSORY
LOAD SUPPORT, 1200mm - ACCESSORY
DRIVE UNIT
GEAR
STEERING MOTOR
DRIVING WHEEL, VULKOLLAN
DRIVING WHEEL, FRICTION - OPTION
LOAD WHEEL, TANDEM (LOW LIFT)
LOAD WHEEL, TANDEM (MAST LIFT)
