Mitsubishi Forklift FBS20 48V Chassis Mast Controls Europe Parts Catalog WEBN2729-01
Brand: Mitsubishi
Type of Machine: Forklift
Region: Europe
Model: Mitsubishi FBS20 48V Chassis Mast Controls Europe
Part Number: WEBN2729-01
Number of Pages: 383 Pages
HARNESS GP (WIRING)
01-04-02A PANEL GP CONTROL PART 1 OF 2
01-04-02B PANEL GP CONTROL PART 2 OF 2
01-04-02C PANEL GP CONTROL PART 1 AND 2 OF 3
01-04-02D PANEL GP CONTROL PART 3 OF 3
01-04-02E PANEL GP CONTROL (BOARD GP DRIVER)
01-04-02F PANEL GP CONTROL (CONTACTOR ASSY.-DIRECTIONAL)
01-04-02G PANEL GP CONTROL (CONTACTOR ASSY.-LINE)
01-04-02H PANEL GP CONTROL (CONTACTOR ASSY.-BYPASS)
01-04-02I PANEL GP CONTROL (CONTACTOR ASSY.-PUMP)
01-04-03A CONNECTOR GP BATTERY (SBE - 36 VOLT)
01-04-03B CONNECTOR ASSY. BATTERY (36 VOLT)
01-04-04A CONNECTOR GP BATTERY (48 VOLT)
01-04-04B CONNECTOR ASSY. BATTERY (48 VOLT)
SWITCH GP ELECTRICAL
HORN GP ELECTRICAL
01-04-07A INSTRUMENT GP
01-04-07B INSTRUMENT GP
01-20-01A MOTOR GP DRIVE (36 VOLT)
01-20-01B MOTOR GP MAIN DRIVE (36 VOLT)
01-20-02A MOTOR GP DRIVE (48 VOLT)
01-20-02B MOTOR GP DRIVE (48 VOLT)
01-20-03A MOTOR GP ELECTRIC POWER STEER PUMP (36 VOLT)
01-20-03B MOTOR GP ELECTRIC POWER STEER PUMP (36 VOLT)
01-20-04A MOTOR GP ELECTRIC POWER STEER PUMP (48 VOLT)
01-20-04B MOTOR GP ELECTRIC POWER STEER PUMP (48 VOLT)
01-20-05A MOTOR GP HYDRAULIC PUMP (36 VOLT)
01-20-05B MOTOR GP HYDRAULIC PUMP (36 VOLT)
01-20-06A MOTOR GP HYDRAULIC PUMP (48 VOLT)
01-20-06B MOTOR GP HYDRAULIC PUMP (48 VOLT)
AXLE GP DRIVE R.H.
AXLE GP DRIVE L.H.
MOUNTING GP DRIVE AXLE
TIRE GP SOLID PNEUMATIC
MOUNTING GP DRIVE WHEEL
AXLE GP STEER
MOUNTING GP STEER
01-11-01A PANEL GP TOP
01-11-01B PANEL GP TOP
PANEL GP SIDE
01-11-03A RESTRAINT GP BATTERY
01-11-03B RESTRAINT GP BATTERY
FLOOR PLATE GP
01-11-05A COUNTERWEIGHT GP
01-11-05B COUNTERWEIGHT GP
01-11-05C COUNTERWEIGHT GP
CONSOLE GP
01-11-07A GUARD GP OVERHEAD
01-11-07B GUARD GP OVERHEAD
PAINT & LUBE GP
SEAT GP - SUSPENSION
01-51-01A CONTROL GP ACCELERATION
01-51-01B CONTROL GP ACCELERATION
CONTROL GP BRAKE
CONTROL GP SERVICE BRAKE
BRAKE GP SERVICE
BRAKE GP PARKING
LINES GP BRAKE
STEERING WHEEL & GEAR GROUP
CONTROL GP FORWARD & REVERSE
01-75-01A PUMP GP POWER STEERING PART 1 OF 2
01-75-01B PUMP GP POWER STEERING PART 2 OF 2
PUMP GROUP HYDRAULIC
LINES GROUP POWER STEER
FILTER GP HYDRAULIC OIL
01-75-05A TANK GP HYDRAULIC
01-75-05B TANK GP HYDRAULIC (LARGE)
LINES GP MAST OPERATING
CONTROL GP MAST OPERATING VALVE (3 - WAY)
01-75-08A VALVE GP CONTROL (3-WAY)
01-75-08B VALVE GP CONTROL (3-WAY)
01-75-08C VALVE GP CONTROL (3-WAY)
01-75-08D VALVE GP CONTROL (3-WAY)
MOUNTING GP MAST OPERATING VALVE
CONTROL VALVE FLOW
1200791 CYLINDER GP - TILT - SIMPLEX - DUPLEX - TRIPLEX 1 REQUIRED
1200792 CYLINDER GP - TILT - SIMPLEX - DUPLEX - TRIPLEX 1 REQUIRED
1200793 CYLINDER GP - TILT - SIMPLEX - DUPLEX - TRIPLEX 1 REQUIRED
1200796 CYLINDER GP - TILT - SIMPLEX - DUPLEX - TRIPLEX 1 REQUIRED
1200794 CYLINDER GP - TILT - SIMPLEX - DUPLEX - TRIPLEX 1 REQUIRED
1200795 CYLINDER GP - TILT - SIMPLEX - DUPLEX - TRIPLEX 1 REQUIRED
CYLINDER GP - TILT
MOUNTING GP - CYLINDER - TILT REAR
FORKS
LIFT BRACKET
02-45-01A MAST COMMON PARTS (SIMPLEX) G15A20-60
02-45-01B MAST COMMON PARTS (SIMPLEX) G15A20-60
SIMPLEX MAST G15A20-60
LIFT CYLINDER (SIMPLEX) G15A20-60
02-52-01A MAST COMMON PARTS (DUPLEX) H15A27-40
02-52-01B MAST COMMON PARTS (DUPLEX) H15A27-40 PART 1 OF 2
02-52-01C MAST COMMON PARTS (DUPLEX) H15A27-40 PART 2 OF 2
DUPLEX MAST H15A27-40
LIFT CYLINDER (DUPLEX) H15A27-40 (1ST)
LIFT CYLINDER (DUPLEX) H15A27-40 (2ND)
02-50-01A MAST COMMON PARTS (TRIPLEX) J15B37-70
02-50-01B MAST COMMON PARTS (TRIPLEX) J15B37-70
02-50-01C MAST COMMON PARTS (TRIPLEX) J15B37-70 PART 1 OF 3
02-50-01D MAST COMMON PARTS (TRIPLEX) J15B37-70 PART 2 OF 3
02-50-01E MAST COMMON PARTS (TRIPLEX) J15B37-70 PART 3 OF 3
TRIPLEX MAST J15B37-70
LIFT CYLINDER (TRIPLEX) J15B37-70 (1ST)
LIFT CYLINDER (TRIPLEX) J15B37-70 (2ND)
215 LIFT TRUCK OPTIONS CHASSIS OPTION AR.
217 LIFT TRUCK OPTIONS CHASSIS OPTION AR. 4WAY
219 LIFT TRUCK OPTIONS CHASSIS OPTION AR. VALVE GP
221 LIFT TRUCK OPTIONS MIRROR KIT
223 LIFT TRUCK OPTIONS DRAW BAR PIN KIT
225 LIFT TRUCK OPTIONS LIGHT GROUP ROAD
229 LIFT TRUCK OPTIONS BACKUP WARNING KIT
231 LIFT TRUCK OPTIONS WARNING LAMP KIT (AMBER)
233 LIFT TRUCK OPTIONS LIGHT GROUP 2F_1B (36V)
235 LIFT TRUCK OPTIONS LIGHT GROUP 2F_1B (48V)
237 LABEL KIT (FRENCH)
239 LABEL KIT (SPANISH)
241 LABEL KIT (ITALIAN)
243 LABEL KIT (GERMAN)
245 LABEL KIT (DUTCH)
247 LABEL KIT (PORTUGUESE)
249 LABEL KIT (DANISH)
251 LABEL KIT (GREEK)
253 LIFT TRUCK OPTIONS CONNECTOR AS - SBE (36 VOLT)
255 LIFT TRUCK OPTIONS CONNECTOR AS - SBE (48 VOLT)
257 LIFT TRUCK OPTIONS CONNECTOR AS - SBE (36 VOLT)
259 LIFT TRUCK OPTIONS CONNECTOR AS - SBE (48 VOLT)
261 LIFT TRUCK OPTIONS BATTERY CONTAINER
263 LIFT TRUCK OPTIONS TIRE GROUP CUSHION
265 LIFT TRUCK OPTIONS SPARE WHEEL CUSHION
267 LIFT TRUCK OPTIONS SPARE WHEEL (SOLID PNEUMATIC)
269 LIFT TRUCK OPTIONS 3 - WAY SIMPLEX G15A20-60
275 LIFT TRUCK OPTIONS 4 - WAY SIMPLEX G15A20-60
277 LIFT TRUCK OPTIONS 3 - WAY DUPLEX H15A27-40
283 LIFT TRUCK OPTIONS 4 - WAY DUPLEX H15A27-40
287 LIFT TRUCK OPTIONS 3 - WAY TRIPLEX J15B37-70
293 LIFT TRUCK OPTIONS 4 - WAY TRIPLEX J15B37-70
Brand: Mitsubishi
Region: Europe
HARNESS GP (WIRING)
HORN GP ELECTRICAL
AXLE GP DRIVE R.H.
AXLE GP DRIVE L.H.
AXLE GP STEER
MOUNTING GP STEER
PANEL GP SIDE
FLOOR PLATE GP
CONSOLE GP
PAINT & LUBE GP
CONTROL GP BRAKE
BRAKE GP SERVICE
BRAKE GP PARKING
LINES GP BRAKE
CONTROL VALVE FLOW
CYLINDER GP - TILT
FORKS
LIFT BRACKET
- Mitsubishi Forklift Trucks FB20CA,FB25CA,FB28CA,FB30CA Parts Manual
- Mitsubishi Lift Trucks Diesel Engines S4E S4E2 S6E S6E2 42080-Up Parts Catalog
- MITSUBISHI S4K, S6K Engine Service Manual
- Mitsubishi Diesel Engines 4DQ3 4DQ3-T 4DQ5 03044-up 09658-up Parts Catalog
- Mitsubishi Forklift Trucks FB10TCA,FB14TCA,FB15TCA,FB18TCA Parts Manual
- MITSUBISHI S4S, S6S Engine Service Manual
- Mitsubishi Forklift Trucks FBP16 FBP18 FBP20 FBP25 FBP30 WEBN2685 Parts Catalog
- Mitsubishi Engine К21 К25 Repair Manual (used with Nissan forklift Mitusbishi Forklift)
- Misubishi Forklift GM 4.3L (G6) Engine Service Manual
- Mitsubishi Forklift FD25 Service Manual
- Mitsubishi Diesel Engines FD20 FD25 FD30 FD35A 11405-Up Parts Catalog
- Mitsubishi FG20K FD20K FG25K FD25K EF17B-15001-up EF18B-65001-up Parts Catalog
- Mitsubishi Forklift FG15 Service Manual
- Mitsubishi Forklift FGC25 Service Manual
- Mitsubishi Lift Trucks FG 20_23_25 FD 20_23_25 10001-Up_60001-Up Parts Catalog
